[OpenLayers-Commits] r12144 - trunk/openlayers/lib/OpenLayers/Layer
commits-20090109 at openlayers.org
Thu Jun 30 10:51:26 EDT 2011
Author: ahocevar
Date: 2011-06-30 07:51:25 -0700 (Thu, 30 Jun 2011)
New Revision: 12144
trunk/openlayers/lib/OpenLayers/Layer/WMS.js
better documentation for Layer.WMS
Modified: trunk/openlayers/lib/OpenLayers/Layer/WMS.js
--- trunk/openlayers/lib/OpenLayers/Layer/WMS.js 2011-06-30 07:45:55 UTC (rev 12143)
+++ trunk/openlayers/lib/OpenLayers/Layer/WMS.js 2011-06-30 14:51:25 UTC (rev 12144)
@@ -76,20 +76,47 @@
* Constructor: OpenLayers.Layer.WMS
* Create a new WMS layer object
- * Example:
+ * Examples:
+ * This code creates a simple WMS layer using the image/jpeg format:
* (code)
* var wms = new OpenLayers.Layer.WMS("NASA Global Mosaic",
* "http://wms.jpl.nasa.gov/wms.cgi",
* {layers: "modis,global_mosaic"});
* (end)
+ * Note the 3rd argument (params). Properties added to this object will be
+ * added to the WMS GetMap requests used for this layer's tiles. The only
+ * mandatory parameter is "layers". Other common WMS params include
+ * "transparent", "styles" and "format". Note that the "srs" param will
+ * always be ignored. Instead, it will be derived from the baseLayer's or
+ * map's projection.
+ * This code creates a transparent WMS layer with additional options:
+ * (code)
+ * var wms = new OpenLayers.Layer.WMS("NASA Global Mosaic",
+ * "http://wms.jpl.nasa.gov/wms.cgi",
+ * layers: "modis,global_mosaic",
+ * transparent: true
+ * opacity: 0.5,
+ * singleTile: true
+ * (end)
+ * Note that by default, a WMS layer is configured as baseLayer. Setting
+ * the "transparent" param to true will apply some magic (see <noMagic>).
+ * The default image format changes from image/jpeg to image/png, and the
+ * layer is not configured as baseLayer.
* Parameters:
* name - {String} A name for the layer
* url - {String} Base url for the WMS
* (e.g. http://wms.jpl.nasa.gov/wms.cgi)
* params - {Object} An object with key/value pairs representing the
* GetMap query string parameters and parameter values.
- * options - {Ojbect} Hashtable of extra options to tag onto the layer
+ * options - {Ojbect} Hashtable of extra options to tag onto the layer.
+ * These options include all properties listed above, plus the ones
+ * inherited from superclasses.
initialize: function(name, url, params, options) {
var newArguments = [];
More information about the Commits
