[OpenLayers-Commits] r11602 - in sandbox/ahocevar/renderer-ng: . examples lib/OpenLayers/Control lib/OpenLayers/Strategy tests/Strategy
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue Mar 1 10:43:17 EST 2011
Author: ahocevar
Date: 2011-03-01 07:43:16 -0800 (Tue, 01 Mar 2011)
New Revision: 11602
   sandbox/ahocevar/renderer-ng/
   sandbox/ahocevar/renderer-ng/examples/spherical-mercator.html
   sandbox/ahocevar/renderer-ng/lib/OpenLayers/Control/Navigation.js
   sandbox/ahocevar/renderer-ng/lib/OpenLayers/Control/TouchNavigation.js
   sandbox/ahocevar/renderer-ng/lib/OpenLayers/Strategy/BBOX.js
   sandbox/ahocevar/renderer-ng/tests/Strategy/BBOX.html
merging r11589:HEAD from trunk
Property changes on: sandbox/ahocevar/renderer-ng
___________________________________________________________________
Modified: svn:mergeinfo
   - /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:10635-10646,10648-10676,10678-10685,10687-10692,10694-10991,10995-11588
   + /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:10635-10646,10648-10676,10678-10685,10687-10692,10694-10991,10995-11588,11590-11601
Modified: sandbox/ahocevar/renderer-ng/examples/spherical-mercator.html
--- sandbox/ahocevar/renderer-ng/examples/spherical-mercator.html	2011-03-01 15:39:57 UTC (rev 11601)
+++ sandbox/ahocevar/renderer-ng/examples/spherical-mercator.html	2011-03-01 15:43:16 UTC (rev 11602)
@@ -32,7 +32,7 @@
 function init(){
     var maxExtent = new OpenLayers.Bounds(-20037508, -20037508, 20037508, 20037508),
-        restrictedExtent = maxExtent.clone(-20037508, -20037508, 20037508, 20037508),
+        restrictedExtent = maxExtent.clone(),
         maxResolution = 156543.0339;
     var options = {
Modified: sandbox/ahocevar/renderer-ng/lib/OpenLayers/Control/Navigation.js
--- sandbox/ahocevar/renderer-ng/lib/OpenLayers/Control/Navigation.js	2011-03-01 15:39:57 UTC (rev 11601)
+++ sandbox/ahocevar/renderer-ng/lib/OpenLayers/Control/Navigation.js	2011-03-01 15:43:16 UTC (rev 11602)
@@ -32,7 +32,7 @@
     dragPan: null,
-     * APIProprety: dragPanOptions
+     * APIProperty: dragPanOptions
      * {Object} Options passed to the DragPan control.
     dragPanOptions: null,
Modified: sandbox/ahocevar/renderer-ng/lib/OpenLayers/Control/TouchNavigation.js
--- sandbox/ahocevar/renderer-ng/lib/OpenLayers/Control/TouchNavigation.js	2011-03-01 15:39:57 UTC (rev 11601)
+++ sandbox/ahocevar/renderer-ng/lib/OpenLayers/Control/TouchNavigation.js	2011-03-01 15:43:16 UTC (rev 11602)
@@ -27,7 +27,7 @@
     dragPan: null,
Modified: sandbox/ahocevar/renderer-ng/lib/OpenLayers/Strategy/BBOX.js
--- sandbox/ahocevar/renderer-ng/lib/OpenLayers/Strategy/BBOX.js	2011-03-01 15:39:57 UTC (rev 11601)
+++ sandbox/ahocevar/renderer-ng/lib/OpenLayers/Strategy/BBOX.js	2011-03-01 15:43:16 UTC (rev 11602)
@@ -90,6 +90,14 @@
                 "refresh": this.update,
                 scope: this
+            if(this.layer.visibility == true) {
+                this.update();
+            } else {
+                this.layer.events.on({
+                    "visibilitychanged": this.update,
+                    scope: this
         return activated;
@@ -106,10 +114,8 @@
         if(deactivated) {
             this.layer.events.un({
                 "moveend": this.update,
-                scope: this
-            this.layer.events.un({
                 scope: this
@@ -127,7 +133,8 @@
     update: function(options) {
         var mapBounds = this.getMapBounds();
-        if ((options && options.force) || this.invalidBounds(mapBounds)) {
+        if (mapBounds !== null && ((options && options.force) ||
+                                   this.invalidBounds(mapBounds))) {
             this.calculateBounds(mapBounds);
             this.resolution = this.layer.map.getResolution();
             this.triggerRead();
@@ -142,6 +149,9 @@
      * {<OpenLayers.Bounds>} Map bounds in the projection of the layer.
     getMapBounds: function() {
+        if (this.layer.map === null) {
+            return null;
         var bounds = this.layer.map.getExtent();
         if(!this.layer.projection.equals(this.layer.map.getProjectionObject())) {
             bounds = bounds.clone().transform(
Modified: sandbox/ahocevar/renderer-ng/tests/Strategy/BBOX.html
--- sandbox/ahocevar/renderer-ng/tests/Strategy/BBOX.html	2011-03-01 15:39:57 UTC (rev 11601)
+++ sandbox/ahocevar/renderer-ng/tests/Strategy/BBOX.html	2011-03-01 15:43:16 UTC (rev 11602)
@@ -270,6 +270,29 @@
+    // Test fix for Ticket #3142
+    function test_layerLoadedAfterBeingAdded(t) {
+        t.plan(1);
+        var dummy = new OpenLayers.Layer(null, {isBaseLayer: true});
+        var strategy = new OpenLayers.Strategy.BBOX({
+            ratio: 1 // makes for easier comparison to map bounds
+        var layer = new OpenLayers.Layer.Vector(null, {
+            protocol: new OpenLayers.Protocol(),
+            strategies: [strategy]
+        var map = new OpenLayers.Map("map");
+        map.addLayer(dummy);
+        map.setCenter(new OpenLayers.LonLat(0, 0));
+        map.addLayer(layer);
+        // test that the strategy bounds were set
+        t.ok(map.getExtent().equals(strategy.bounds), "[set center] bounds set to map extent");
   </script>
 </head>
 <body>
More information about the Commits mailing list
