[OpenLayers-Commits] r11631 - in trunk/openlayers: lib/OpenLayers
lib/OpenLayers/Control tests tests/Control
commits-20090109 at openlayers.org
Mon Mar 7 00:02:55 EST 2011
Author: bartvde
Date: 2011-03-06 21:02:51 -0800 (Sun, 06 Mar 2011)
New Revision: 11631
trunk/openlayers/lib/OpenLayers/Control.js
trunk/openlayers/lib/OpenLayers/Control/PanZoom.js
trunk/openlayers/tests/Control.html
trunk/openlayers/tests/Control/PanZoomBar.html
Control should set this.div to null in destroy, thanks jorix for the updated patch, p=jorix,me r=me,fredj (closes #2850)
Modified: trunk/openlayers/lib/OpenLayers/Control/PanZoom.js
--- trunk/openlayers/lib/OpenLayers/Control/PanZoom.js 2011-03-07 01:26:56 UTC (rev 11630)
+++ trunk/openlayers/lib/OpenLayers/Control/PanZoom.js 2011-03-07 05:02:51 UTC (rev 11631)
@@ -64,10 +64,10 @@
* APIMethod: destroy
destroy: function() {
- OpenLayers.Control.prototype.destroy.apply(this, arguments);
this.removeButtons();
this.buttons = null;
this.position = null;
+ OpenLayers.Control.prototype.destroy.apply(this, arguments);
Modified: trunk/openlayers/lib/OpenLayers/Control.js
--- trunk/openlayers/lib/OpenLayers/Control.js 2011-03-07 01:26:56 UTC (rev 11630)
+++ trunk/openlayers/lib/OpenLayers/Control.js 2011-03-07 05:02:51 UTC (rev 11631)
@@ -229,6 +229,7 @@
this.map.removeControl(this);
this.map = null;
+ this.div = null;
Modified: trunk/openlayers/tests/Control/PanZoomBar.html
--- trunk/openlayers/tests/Control/PanZoomBar.html 2011-03-07 01:26:56 UTC (rev 11630)
+++ trunk/openlayers/tests/Control/PanZoomBar.html 2011-03-07 05:02:51 UTC (rev 11631)
@@ -44,8 +44,9 @@
control = new OpenLayers.Control.PanZoomBar();
map.addControl(control);
control.removeButtons();
+ var div = control.div;
map.destroy();
- t.eq(control.div.childNodes.length, 0, "control's div cleared.");
+ t.eq(div.childNodes.length, 0, "control's div cleared.");
t.eq(control.zoombarDiv, null, "zoombar div nullified.")
Modified: trunk/openlayers/tests/Control.html
--- trunk/openlayers/tests/Control.html 2011-03-07 01:26:56 UTC (rev 11630)
+++ trunk/openlayers/tests/Control.html 2011-03-07 05:02:51 UTC (rev 11631)
@@ -60,7 +60,7 @@
function test_Control_destroy(t) {
- t.plan(3);
+ t.plan(4);
var map = new OpenLayers.Map('map');
var control = new OpenLayers.Control();
@@ -70,6 +70,7 @@
t.ok(map.controls[map.controls.length - 1] != control, "map.controls doesn't contains control");
t.ok(control.map == null, "Control.map is null");
+ t.ok(control.div == null, "Control.div is null");
t.ok(control.handler == null, "Control.handler is null");
More information about the Commits
