[OpenLayers-Commits] r11633 - in trunk/openlayers:
	lib/OpenLayers/Control tests/Control
    commits-20090109 at openlayers.org
    Mon Mar  7 02:57:21 EST 2011
Author: erilem
Date: 2011-03-06 23:57:14 -0800 (Sun, 06 Mar 2011)
New Revision: 11633
   trunk/openlayers/lib/OpenLayers/Control/SelectFeature.js
   trunk/openlayers/tests/Control/SelectFeature.html
SelectFeature control - highlightOnly and toggle don't play well together, p=me, r=bartvde (closes #2812)
Modified: trunk/openlayers/lib/OpenLayers/Control/SelectFeature.js
--- trunk/openlayers/lib/OpenLayers/Control/SelectFeature.js	2011-03-07 05:38:51 UTC (rev 11632)
+++ trunk/openlayers/lib/OpenLayers/Control/SelectFeature.js	2011-03-07 07:57:14 UTC (rev 11633)
@@ -463,8 +463,23 @@
     unhighlight: function(feature) {
         var layer = feature.layer;
-        feature._lastHighlighter = feature._prevHighlighter;
-        delete feature._prevHighlighter;
+        // three cases:
+        // 1. there's no other highlighter, in that case _prev is undefined,
+        //    and we just need to undef _last
+        // 2. another control highlighted the feature after we did it, in
+        //    that case _last references this other control, and we just
+        //    need to undef _prev
+        // 3. another control highlighted the feature before we did it, in
+        //    that case _prev references this other control, and we need to
+        //    set _last to _prev and undef _prev
+        if(feature._prevHighlighter == undefined) {
+            delete feature._lastHighlighter;
+        } else if(feature._prevHighlighter == this.id) {
+            delete feature._prevHighlighter;
+        } else {
+            feature._lastHighlighter = feature._prevHighlighter;
         layer.drawFeature(feature, feature.style || feature.layer.style ||
             "default");
         this.events.triggerEvent("featureunhighlighted", {feature : feature});
Modified: trunk/openlayers/tests/Control/SelectFeature.html
--- trunk/openlayers/tests/Control/SelectFeature.html	2011-03-07 05:38:51 UTC (rev 11632)
+++ trunk/openlayers/tests/Control/SelectFeature.html	2011-03-07 07:57:14 UTC (rev 11633)
@@ -373,6 +373,114 @@
         map.events.triggerEvent("click", evt);
+    // test for http://trac.openlayers.org/ticket/2812
+    function test_highlightOnly_toggle(t) {
+        t.plan(8);
+         * setup
+        var map, layer, ctrl1, ctrl2, _feature, feature, evt, _style;
+        map = new OpenLayers.Map("map");
+        layer = new OpenLayers.Layer.Vector("name", {isBaseLayer: true});
+        map.addLayer(layer);
+        ctrl1 = new OpenLayers.Control.SelectFeature(layer, {
+            highlightOnly: false,
+            hover: false,
+            clickout: false,
+            toggle: true
+        map.addControl(ctrl1);
+        ctrl2 = new OpenLayers.Control.SelectFeature(layer, {
+            highlightOnly: true,
+            hover: true
+        map.addControl(ctrl2);
+        ctrl2.activate();
+        ctrl1.activate();
+        feature = new OpenLayers.Feature.Vector();
+        feature.layer = layer;
+        // override the layer's getFeatureFromEvent func so that it always
+        // returns the feature referenced to by _feature
+        layer.getFeatureFromEvent = function(evt) { return _feature; };
+        evt = {xy: new OpenLayers.Pixel(Math.random(), Math.random())};
+        map.zoomToMaxExtent();
+         * tests
+        // with renderIntent
+        ctrl1.renderIntent = "select";
+        ctrl2.renderIntent = "temporary";
+        // mouse over feature, feature is drawn with "temporary"
+        _feature = feature;
+        evt.type = "mousemove";
+        map.events.triggerEvent("mousemove", evt);
+        t.eq(feature.renderIntent, "temporary",
+             "feature drawn with expected render intent after \"mouseover\"");
+        // click in feature, feature is drawn with "select"
+        evt.type = "click";
+        map.events.triggerEvent("click", evt);
+        t.eq(feature.renderIntent, "select",
+             "feature drawn with expected render intent after \"clickin\"");
+        // mouse out of feature, feature is still drawn with "select"
+        _feature = null;
+             "feature drawn with expected render intent after \"mouseout\"");
+        // mouse over feature again, feature is drawn with "temporary"
+        // click in feature again, feature is drawn with "default"
+        t.eq(feature.renderIntent, "default",
+        // mouse out of feature again, feature is still drawn with "default"
+        _feature = null;
+        _feature = null;
     function test_setLayer(t) {
         t.plan(5);
         var map = new OpenLayers.Map("map");
More information about the Commits
