[OpenLayers-Commits] r11656 - trunk/openlayers/lib/OpenLayers/Strategy
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Mar 7 09:48:29 EST 2011
Author: fredj
Date: 2011-03-07 06:48:26 -0800 (Mon, 07 Mar 2011)
New Revision: 11656
   trunk/openlayers/lib/OpenLayers/Strategy/BBOX.js
   trunk/openlayers/lib/OpenLayers/Strategy/Cluster.js
   trunk/openlayers/lib/OpenLayers/Strategy/Filter.js
   trunk/openlayers/lib/OpenLayers/Strategy/Fixed.js
   trunk/openlayers/lib/OpenLayers/Strategy/Paging.js
   trunk/openlayers/lib/OpenLayers/Strategy/Refresh.js
re-add the Constructor API doc removed in r11641 (see #3149)
Modified: trunk/openlayers/lib/OpenLayers/Strategy/BBOX.js
--- trunk/openlayers/lib/OpenLayers/Strategy/BBOX.js	2011-03-07 14:42:08 UTC (rev 11655)
+++ trunk/openlayers/lib/OpenLayers/Strategy/BBOX.js	2011-03-07 14:48:26 UTC (rev 11656)
@@ -61,6 +61,15 @@
     response: null,
+     * Constructor: OpenLayers.Strategy.BBOX
+     * Create a new BBOX strategy.
+     * Parameters:
+     * options - {Object} Optional object whose properties will be set on the
+     *     instance.
      * Method: activate
      * Set up strategy with regard to reading new batches of remote data.
Modified: trunk/openlayers/lib/OpenLayers/Strategy/Cluster.js
--- trunk/openlayers/lib/OpenLayers/Strategy/Cluster.js	2011-03-07 14:42:08 UTC (rev 11655)
+++ trunk/openlayers/lib/OpenLayers/Strategy/Cluster.js	2011-03-07 14:48:26 UTC (rev 11656)
@@ -59,6 +59,15 @@
     resolution: null,
+     * Constructor: OpenLayers.Strategy.Cluster
+     * Create a new clustering strategy.
+     * Parameters:
+     *     instance.
      * APIMethod: activate
      * Activate the strategy.  Register any listeners, do appropriate setup.
Modified: trunk/openlayers/lib/OpenLayers/Strategy/Filter.js
--- trunk/openlayers/lib/OpenLayers/Strategy/Filter.js	2011-03-07 14:42:08 UTC (rev 11655)
+++ trunk/openlayers/lib/OpenLayers/Strategy/Filter.js	2011-03-07 14:48:26 UTC (rev 11656)
@@ -40,6 +40,15 @@
     caching: false,
+     * Constructor: OpenLayers.Strategy.Filter
+     * Create a new filter strategy.
+     * Parameters:
+     *     instance.
      *     By default, this strategy automatically activates itself when a layer
Modified: trunk/openlayers/lib/OpenLayers/Strategy/Fixed.js
--- trunk/openlayers/lib/OpenLayers/Strategy/Fixed.js	2011-03-07 14:42:08 UTC (rev 11655)
+++ trunk/openlayers/lib/OpenLayers/Strategy/Fixed.js	2011-03-07 14:48:26 UTC (rev 11656)
@@ -25,6 +25,15 @@
     preload: false,
+     * Constructor: OpenLayers.Strategy.Fixed
+     * Create a new Fixed strategy.
+     * Parameters:
+     *     instance.
      * Method: activate
      * Activate the strategy: load data or add listener to load when visible
Modified: trunk/openlayers/lib/OpenLayers/Strategy/Paging.js
--- trunk/openlayers/lib/OpenLayers/Strategy/Paging.js	2011-03-07 14:42:08 UTC (rev 11655)
+++ trunk/openlayers/lib/OpenLayers/Strategy/Paging.js	2011-03-07 14:48:26 UTC (rev 11656)
@@ -41,6 +41,15 @@
     paging: false,
+     * Constructor: OpenLayers.Strategy.Paging
+     * Create a new paging strategy.
+     * Parameters:
+     *     instance.
Modified: trunk/openlayers/lib/OpenLayers/Strategy/Refresh.js
--- trunk/openlayers/lib/OpenLayers/Strategy/Refresh.js	2011-03-07 14:42:08 UTC (rev 11655)
+++ trunk/openlayers/lib/OpenLayers/Strategy/Refresh.js	2011-03-07 14:48:26 UTC (rev 11656)
@@ -38,6 +38,15 @@
     timer: null,
+     * Constructor: OpenLayers.Strategy.Refresh
+     * Create a new Refresh strategy.
+     * Parameters:
+     *     instance.
More information about the Commits mailing list
