[OpenLayers-Commits] r11678 - in trunk/openlayers:
lib/OpenLayers/Control tests/Control
commits-20090109 at openlayers.org
Tue Mar 8 11:31:38 EST 2011
Author: fredj
Date: 2011-03-08 08:31:36 -0800 (Tue, 08 Mar 2011)
New Revision: 11678
trunk/openlayers/lib/OpenLayers/Control/KeyboardDefaults.js
trunk/openlayers/tests/Control/KeyboardDefaults.html
remove Control.KeyboardDefaults::destroy method: handler destroy already done in the parent class. r=bartvde (closes #3155)
Modified: trunk/openlayers/lib/OpenLayers/Control/KeyboardDefaults.js
--- trunk/openlayers/lib/OpenLayers/Control/KeyboardDefaults.js 2011-03-08 16:19:36 UTC (rev 11677)
+++ trunk/openlayers/lib/OpenLayers/Control/KeyboardDefaults.js 2011-03-08 16:31:36 UTC (rev 11678)
@@ -37,19 +37,7 @@
* Constructor: OpenLayers.Control.KeyboardDefaults
- * APIMethod: destroy
- destroy: function() {
- if (this.handler) {
- this.handler.destroy();
- this.handler = null;
- OpenLayers.Control.prototype.destroy.apply(this, arguments);
* Method: draw
* Create handler.
Modified: trunk/openlayers/tests/Control/KeyboardDefaults.html
--- trunk/openlayers/tests/Control/KeyboardDefaults.html 2011-03-08 16:19:36 UTC (rev 11677)
+++ trunk/openlayers/tests/Control/KeyboardDefaults.html 2011-03-08 16:31:36 UTC (rev 11678)
@@ -12,6 +12,18 @@
t.eq( control.displayClass, "olControlKeyboardDefaults", "displayClass is correct" );
+ function test_Control_KeyboardDefaults_destroy (t) {
+ t.plan(2);
+ map = new OpenLayers.Map('map');
+ var control = new OpenLayers.Control.KeyboardDefaults();
+ map.addControl(control);
+ t.ok(control.handler != null, "control.handler is created");
+ control.destroy();
+ t.ok(control.handler == null, "control.handler is null after destroy");
+ map.destroy();
function test_Control_KeyboardDefaults_addControl (t) {
t.plan( 4 );
More information about the Commits
