[OpenLayers-Commits] r11697 - in trunk/openlayers/lib/OpenLayers: .
Renderer
commits-20090109 at openlayers.org
Fri Mar 11 14:29:00 EST 2011
Author: ahocevar
Date: 2011-03-11 11:28:55 -0800 (Fri, 11 Mar 2011)
New Revision: 11697
trunk/openlayers/lib/OpenLayers/Map.js
trunk/openlayers/lib/OpenLayers/Renderer/SVG.js
trunk/openlayers/lib/OpenLayers/Renderer/SVG2.js
reverting r11645, and fixing the root of the reported problem. r=bartvde (closes #2392)
Modified: trunk/openlayers/lib/OpenLayers/Map.js
--- trunk/openlayers/lib/OpenLayers/Map.js 2011-03-11 18:34:53 UTC (rev 11696)
+++ trunk/openlayers/lib/OpenLayers/Map.js 2011-03-11 19:28:55 UTC (rev 11697)
@@ -510,12 +510,6 @@
this.div = document.createElement("div");
this.div.style.height = "1px";
this.div.style.width = "1px";
- // Adding this to the DOM is a fix for Safari SVG rendering bugs;
- // See #2392. On initial render(), it is removed from the dom,
- // and a new div is added.
- this.div.style.display = "none";
- document.body.appendChild(this.div);
OpenLayers.Element.addClass(this.div, 'olMap');
@@ -650,11 +644,6 @@
* will be moved from the current to the new container.
render: function(div) {
- // Fix for Safari SVG rendering bugs; See #2392
- if(this.div && this.div.parentNode) {
- this.div.parentNode.removeChild(this.div);
this.div = OpenLayers.Util.getElement(div);
this.viewPortDiv.parentNode.removeChild(this.viewPortDiv);
Modified: trunk/openlayers/lib/OpenLayers/Renderer/SVG.js
--- trunk/openlayers/lib/OpenLayers/Renderer/SVG.js 2011-03-11 18:34:53 UTC (rev 11696)
+++ trunk/openlayers/lib/OpenLayers/Renderer/SVG.js 2011-03-11 19:28:55 UTC (rev 11697)
@@ -290,9 +290,9 @@
// the symbol viewBox is three times as large as the symbol
var offset = style.pointRadius * 3;
var size = offset * 2;
- var id = this.importSymbol(style.graphicName);
+ var src = this.importSymbol(style.graphicName);
pos = this.getPosition(node);
- widthFactor = this.symbolMetrics[id][0] * 3 / size;
+ widthFactor = this.symbolMetrics[src.id][0] * 3 / size;
// remove the node from the dom before we modify it. This
// prevents various rendering issues in Safari and FF
@@ -308,7 +308,6 @@
// See e.g. ticket http://trac.osgeo.org/openlayers/ticket/2985
// and this email thread
// http://osgeo-org.1803224.n2.nabble.com/Select-Control-Ctrl-click-on-Feature-with-a-graphicName-opens-new-browser-window-tc5846039.html
- var src = document.getElementById(id);
node.firstChild && node.removeChild(node.firstChild);
node.appendChild(src.firstChild.cloneNode(true));
node.setAttributeNS(null, "viewBox", src.getAttributeNS(null, "viewBox"));
@@ -339,7 +338,7 @@
"rotate(" + rotation + " " + pos.x + " " +
pos.y + ")");
} else {
- var metrics = this.symbolMetrics[id];
+ var metrics = this.symbolMetrics[src.id];
node.firstChild.setAttributeNS(null, "transform", "rotate("
+ rotation + " "
+ metrics[1] + " "
@@ -881,7 +880,7 @@
* graphicName - {String} name of the symbol to import
* Returns:
- * {String} - id of the imported symbol
+ * {DOMElement} - the imported symbol
importSymbol: function (graphicName) {
if (!this.defs) {
@@ -891,8 +890,9 @@
var id = this.container.id + "-" + graphicName;
// check if symbol already exists in the defs
- if (document.getElementById(id) != null) {
- return id;
+ var existing = document.getElementById(id)
+ if (existing != null) {
+ return existing;
var symbol = OpenLayers.Renderer.symbol[graphicName];
@@ -934,7 +934,7 @@
this.defs.appendChild(symbolNode);
- return symbolNode.id;
+ return symbolNode;
Modified: trunk/openlayers/lib/OpenLayers/Renderer/SVG2.js
--- trunk/openlayers/lib/OpenLayers/Renderer/SVG2.js 2011-03-11 18:34:53 UTC (rev 11696)
+++ trunk/openlayers/lib/OpenLayers/Renderer/SVG2.js 2011-03-11 19:28:55 UTC (rev 11697)
@@ -217,8 +217,8 @@
var offset = style.pointRadius * 3 * resolution;
- widthFactor = this.symbolMetrics[id].size * 3 / size * resolution;
+ widthFactor = this.symbolMetrics[src.id].size * 3 / size * resolution;
@@ -234,7 +234,6 @@
@@ -264,7 +263,7 @@
["rotate(", rotation, node._x, node._y, ")"].join(" ")
} else {
["rotate(", rotation, metrics.x, metrics.y, ")"].join(" ")
@@ -679,7 +678,7 @@
* Returns:
if (!this.defs) {
@@ -689,8 +688,9 @@
- return id;
+ var existing = document.getElementById(id);
+ return existing;
@@ -732,7 +732,7 @@
More information about the Commits
