[OpenLayers-Commits] r11700 -
trunk/openlayers/lib/OpenLayers/Renderer
commits-20090109 at openlayers.org
Fri Mar 11 21:31:40 EST 2011
Author: ahocevar
Date: 2011-03-11 18:31:39 -0800 (Fri, 11 Mar 2011)
New Revision: 11700
trunk/openlayers/lib/OpenLayers/Renderer/SVG2.js
duplicating constants from Renderer.SVG and fixing API docs. Thanks jorix for the pointer. Non-functional change.
Modified: trunk/openlayers/lib/OpenLayers/Renderer/SVG2.js
--- trunk/openlayers/lib/OpenLayers/Renderer/SVG2.js 2011-03-11 22:08:31 UTC (rev 11699)
+++ trunk/openlayers/lib/OpenLayers/Renderer/SVG2.js 2011-03-12 02:31:39 UTC (rev 11700)
@@ -42,7 +42,7 @@
labelNodeType: "g",
- * Constructor: OpenLayers.Renderer.SVG
+ * Constructor: OpenLayers.Renderer.SVG2
* Parameters:
* containerID - {String}
@@ -615,14 +615,14 @@
var align = style.labelAlign || "cm";
text.setAttributeNS(null, "text-anchor",
- OpenLayers.Renderer.SVG.LABEL_ALIGN[align[0]] || "middle");
+ OpenLayers.Renderer.SVG2.LABEL_ALIGN[align[0]] || "middle");
if (OpenLayers.IS_GECKO === true) {
text.setAttributeNS(null, "dominant-baseline",
- OpenLayers.Renderer.SVG.LABEL_ALIGN[align[1]] || "central");
+ OpenLayers.Renderer.SVG2.LABEL_ALIGN[align[1]] || "central");
} else {
tspan.setAttributeNS(null, "baseline-shift",
- OpenLayers.Renderer.SVG.LABEL_VSHIFT[align[1]] || "-35%");
+ OpenLayers.Renderer.SVG2.LABEL_VSHIFT[align[1]] || "-35%");
tspan.textContent = style.label;
@@ -758,6 +758,31 @@
CLASS_NAME: "OpenLayers.Renderer.SVG2"
+ * Constant: OpenLayers.Renderer.SVG2.LABEL_ALIGN
+ * {Object}
+OpenLayers.Renderer.SVG2.LABEL_ALIGN = {
+ "l": "start",
+ "r": "end",
+ "b": "bottom",
+ "t": "hanging"
+ * Constant: OpenLayers.Renderer.SVG2.LABEL_VSHIFT
+ * {Object}
+OpenLayers.Renderer.SVG2.LABEL_VSHIFT = {
+ // according to
+ // http://www.w3.org/Graphics/SVG/Test/20061213/htmlObjectHarness/full-text-align-02-b.html
+ // a baseline-shift of -70% shifts the text exactly from the
+ // bottom to the top of the baseline, so -35% moves the text to
+ // the center of the baseline.
+ "t": "-70%",
+ "b": "0"
* Function: OpenLayers.Renderer.SVG2.preventDefault
* Used to prevent default events (especially opening images in a new tab on
More information about the Commits
