[OpenLayers-Commits] r11722 - trunk/openlayers/examples
commits-20090109 at openlayers.org
Tue Mar 22 09:46:37 EDT 2011
Author: ahocevar
Date: 2011-03-22 06:46:33 -0700 (Tue, 22 Mar 2011)
New Revision: 11722
Added:
trunk/openlayers/examples/kml-pointtrack.html
trunk/openlayers/examples/kml-pointtrack.js
Making Layer.PointTrack play nicely with gx:Track from Format.KML. Thanks bartvde for the updated patch. r=fredj,bartvde (closes #2792)
Added: trunk/openlayers/examples/kml-pointtrack.html
--- trunk/openlayers/examples/kml-pointtrack.html (rev 0)
+++ trunk/openlayers/examples/kml-pointtrack.html 2011-03-22 13:46:33 UTC (rev 11722)
@@ -0,0 +1,38 @@
+<!DOCTYPE html>
+<html>
+ <head>
+ <meta name="viewport" content="width=device-width; initial-scale=1.0; maximum-scale=1.0; user-scalable=0;" />
+ <meta name="apple-mobile-web-app-capable" content="yes" />
+ <title>OpenLayers KML Track in a PointTrack Layer Example</title>
+ <link rel="stylesheet" href="../theme/default/style.css" type="text/css">
+ <link rel="stylesheet" href="../theme/default/google.css" type="text/css">
+ <link rel="stylesheet" href="style.css" type="text/css">
+ <style>
+ .olControlAttribution {
+ bottom: 2px;
+ </style>
+ <script src="../lib/OpenLayers.js"></script>
+ <script src="kml-pointtrack.js"></script>
+ </head>
+ <body onload="init()">
+ <h1 id="title">Parsing gx:Track in KML</h1>
+ <p id="shortdesc">
+ Demonstrates populating a PointTrack layer with gx:Track elements from KML.
+ </p>
+ <div id="map" class="smallmap"></div>
+ <div id="docs">
+ <p>
+ If a KML document contains <code><gx:Track></code>
+ elements and the extractTracks property is set true on the
+ parser, features will be created that represent track points.
+ These track points can easily be visualized as track lines with
+ a <code>PointTrack</code> layer, preserving the KML's original
+ styles.
+ </p>
+ <p>
+ View the <a href="kml-pointtrack.js" target="_blank">kml-pointtrack.js</a>
+ source to see how this is done.
+ </div>
+ </body>
+</html>
Added: trunk/openlayers/examples/kml-pointtrack.js
--- trunk/openlayers/examples/kml-pointtrack.js (rev 0)
+++ trunk/openlayers/examples/kml-pointtrack.js 2011-03-22 13:46:33 UTC (rev 11722)
@@ -0,0 +1,51 @@
+var map;
+function init() {
+ var mercator = new OpenLayers.Projection("EPSG:900913");
+ var geographic = new OpenLayers.Projection("EPSG:4326");
+ map = new OpenLayers.Map({
+ div: "map",
+ projection: mercator,
+ layers: [
+ new OpenLayers.Layer.OSM(),
+ new OpenLayers.Layer.PointTrack("Aircraft Tracks", {
+ projection: geographic,
+ strategies: [new OpenLayers.Strategy.Fixed()],
+ protocol: new OpenLayers.Protocol.HTTP({
+ url: "kml-track.kml",
+ format: new OpenLayers.Format.KML({
+ extractTracks: true,
+ extractStyles: true
+ dataFrom: OpenLayers.Layer.PointTrack.TARGET_NODE,
+ styleFrom: OpenLayers.Layer.PointTrack.TARGET_NODE,
+ eventListeners: {
+ "beforefeaturesadded": function(e) {
+ // group the tracks by fid and create one track for
+ // every fid
+ var fid, points = [], feature;
+ for (var i=0, len=e.features.length; i<len; i++) {
+ feature = e.features[i];
+ if (feature.fid !== fid || i === len-1) {
+ fid = feature.fid;
+ this.addNodes(points, {silent: true});
+ points = [];
+ points.push(feature);
+ return false;
+ center: new OpenLayers.LonLat(-93.2735, 44.8349).transform(geographic, mercator),
+ zoom: 8
+ map.addControl(new OpenLayers.Control.LayerSwitcher());
More information about the Commits
