[OpenLayers-Commits] r11731 - in sandbox/cmoullet/openlayers: .
examples lib/OpenLayers lib/OpenLayers/Handler tests tests/manual
commits-20090109 at openlayers.org
Tue Mar 29 04:14:48 EDT 2011
Author: cmoullet
Date: 2011-03-29 01:14:47 -0700 (Tue, 29 Mar 2011)
New Revision: 11731
sandbox/cmoullet/openlayers/
sandbox/cmoullet/openlayers/examples/arcgiscache_ags.html
sandbox/cmoullet/openlayers/lib/OpenLayers/Events.js
sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Box.js
sandbox/cmoullet/openlayers/tests/Map.html
sandbox/cmoullet/openlayers/tests/manual/vector-features-performance.html
merge with trunk
Property changes on: sandbox/cmoullet/openlayers
___________________________________________________________________
Modified: svn:mergeinfo
- /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:11161-11688,11690-11722
+ /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:11161-11688,11690-11730
Modified: sandbox/cmoullet/openlayers/examples/arcgiscache_ags.html
--- sandbox/cmoullet/openlayers/examples/arcgiscache_ags.html 2011-03-28 13:52:59 UTC (rev 11730)
+++ sandbox/cmoullet/openlayers/examples/arcgiscache_ags.html 2011-03-29 08:14:47 UTC (rev 11731)
@@ -141,7 +141,7 @@
tileSize: new OpenLayers.Size(layerInfo.tileInfo.cols, layerInfo.tileInfo.rows),
tileOrigin: new OpenLayers.LonLat(layerInfo.tileInfo.origin.x , layerInfo.tileInfo.origin.y),
maxExtent: layerMaxExtent,
- projection: 'EPSG:' + layerInfo.spatialReference.wkid,
+ projection: 'EPSG:' + layerInfo.spatialReference.wkid
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Events.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Events.js 2011-03-28 13:52:59 UTC (rev 11730)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Events.js 2011-03-29 08:14:47 UTC (rev 11731)
@@ -860,10 +860,9 @@
// returns incorrect offsets. So our best bet is to not invalidate the
// offsets once we have them, and hope that the page was not scrolled
// when we did the initial calculation.
- if (!((document.body.scrollTop != 0 ||
- document.body.scrollLeft != 0) &&
- navigator.userAgent.match(/iPhone/i))) {
- OpenLayers.Console.log("clear");
+ var body = document.body;
+ if (body && !((body.scrollTop != 0 || body.scrollLeft != 0) &&
+ navigator.userAgent.match(/iPhone/i))) {
this.element.offsets = null;
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Box.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Box.js 2011-03-28 13:52:59 UTC (rev 11730)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Box.js 2011-03-29 08:14:47 UTC (rev 11731)
@@ -183,7 +183,11 @@
deactivate: function () {
if (OpenLayers.Handler.prototype.deactivate.apply(this, arguments)) {
- this.dragHandler.deactivate();
+ if (this.dragHandler.deactivate()) {
+ if (this.zoomBox) {
+ this.removeBox();
return true;
} else {
return false;
Modified: sandbox/cmoullet/openlayers/tests/Map.html
--- sandbox/cmoullet/openlayers/tests/Map.html 2011-03-28 13:52:59 UTC (rev 11730)
+++ sandbox/cmoullet/openlayers/tests/Map.html 2011-03-29 08:14:47 UTC (rev 11731)
@@ -1593,9 +1593,21 @@
+ // test if we can call updateSize before document.body is ready. updateOk
+ // is tested in the test_updateSize function below
+ var earlyMap = new OpenLayers.Map();
+ var updateOk;
+ try {
+ earlyMap.updateSize();
+ updateOk = true;
+ } catch(e) {}
+ earlyMap.destroy();
function test_updateSize(t) {
- t.plan(2);
+ t.plan(3);
+ // checking updateSize from outside this test function (see above)
+ t.ok(updateOk, "updateSize works before document.body is ready");
var map, moveToCnt, size;
map = new OpenLayers.Map({div: "map"});
@@ -1625,7 +1637,7 @@
map.updateSize();
t.eq(moveToCnt, 1, "updateSize move the map if it has a center");
- map.destroy();
+ map.destroy();
function test_invisible_map(t) {
Modified: sandbox/cmoullet/openlayers/tests/manual/vector-features-performance.html
--- sandbox/cmoullet/openlayers/tests/manual/vector-features-performance.html 2011-03-28 13:52:59 UTC (rev 11730)
+++ sandbox/cmoullet/openlayers/tests/manual/vector-features-performance.html 2011-03-29 08:14:47 UTC (rev 11731)
@@ -81,9 +81,16 @@
function init(){
+ // allow testing of specific renderers via "?renderer=Canvas", etc
+ var renderer = OpenLayers.Util.getParameters(window.location.href).renderer;
+ renderer = (renderer) ? [renderer] : OpenLayers.Layer.Vector.prototype.renderers;
map = new OpenLayers.Map('map');
- vectorLayer = new OpenLayers.Layer.Vector("Vector Layer", {isBaseLayer: true});
+ vectorLayer = new OpenLayers.Layer.Vector("Vector Layer", {
+ isBaseLayer: true,
+ renderers: renderer
map.addLayers([vectorLayer]);
map.addControl(new OpenLayers.Control.MousePosition());
More information about the Commits
