[OpenLayers-Commits] r11759 - trunk/openlayers/tests/Handler
commits-20090109 at openlayers.org
Tue Mar 29 17:59:09 EDT 2011
Author: erilem
Date: 2011-03-29 14:59:08 -0700 (Tue, 29 Mar 2011)
New Revision: 11759
trunk/openlayers/tests/Handler/Point.html
better tests for the point handler, tests only patch
Modified: trunk/openlayers/tests/Handler/Point.html
--- trunk/openlayers/tests/Handler/Point.html 2011-03-29 19:22:13 UTC (rev 11758)
+++ trunk/openlayers/tests/Handler/Point.html 2011-03-29 21:59:08 UTC (rev 11759)
@@ -416,50 +416,121 @@
t.eq(handler.point, null,
"handler.point is null after destroy");
- function test_sequence_touch_1(t) {
- t.plan(7);
- log = [];
- var map = new OpenLayers.Map("map", { // 300 x 150
+ // Sequence tests
+ // Sequence tests basically involve executing a sequence of events
+ // and testing the resulting geometry.
+ // Below are tests for various drawing sequences. Tests can be
+ // added here each a non-working sequence is found.
+ // tap
+ function test_touch_sequence1(t) {
+ t.plan(8);
+ // set up
+ var log;
+ var map = new OpenLayers.Map("map", {
resolutions: [1]
var layer = new OpenLayers.Layer.Vector("foo", {
- maxExtent: new OpenLayers.Bounds(-100, -100, 100, 100),
+ maxExtent: new OpenLayers.Bounds(-10, -10, 10, 10),
isBaseLayer: true
map.addLayer(layer);
- var control = new OpenLayers.Control();
+ var control = new OpenLayers.Control({});
var handler = new OpenLayers.Handler.Point(control, {
- "done": function(g, f) {
- log.push({geometry: g, feature: f});
+ done: function(g, f) {
+ log = {geometry: g, feature: f};
control.handler = handler;
map.addControl(control);
- map.setCenter(new OpenLayers.LonLat(0, 0), 5);
+ map.setCenter(new OpenLayers.LonLat(0, 0), 0);
handler.activate();
- handler.touchstart({type: "touchstart", xy: new OpenLayers.Pixel(50, 75)});
- t.eq(log.length, 0, "touch start 1");
- handler.touchmove({type: "touchmove", xy: new OpenLayers.Pixel(250, 75)});
- t.eq(log.length, 0, "touch move");
- handler.touchend({type: "touchend"});
- t.eq(log.length, 0, "touch end");
- handler.touchstart({type: "touchstart", xy: new OpenLayers.Pixel(99, 75)});
- t.eq(log.length, 0, "touch start 2");
+ // test
- handler.touchmove({type: "touchmove", xy: new OpenLayers.Pixel(100, 75)});
+ var ret;
- t.eq(log.length, 1, "touch end");
- t.geom_eq(log[0].geometry, new OpenLayers.Geometry.Point(-50, 0), "geometry is correct");
+ // tap on (1, 0)
+ log = null;
+ ret = handler.touchstart({xy: new OpenLayers.Pixel(0, 0)});
+ t.ok(ret, '[touchstart] event propagates');
+ t.eq(log, null, '[touchstart] no finalization');
+ t.ok(isNaN(handler.point.geometry.x) && isNaN(handler.point.geometry.y),
+ '[touchstart] feature not modified');
+ ret = handler.touchmove({xy: new OpenLayers.Pixel(1, 0)});
+ t.ok(ret, '[touchmove] event propagates');
+ t.eq(log, null, '[touchmove] no finalization');
+ '[touchmove] feature not modified');
+ ret = handler.touchend({});
+ t.ok(ret, '[touchend] event propagates');
+ t.geom_eq(log.geometry, new OpenLayers.Geometry.Point(-149, 75),
+ "[touchend] correct point");
+ // tear down
+ map.destroy();
+ // tap-move
+ function test_touch_sequence2(t) {
+ t.plan(9);
+ // set up
+ var log;
+ resolutions: [1]
+ var layer = new OpenLayers.Layer.Vector("foo", {
+ isBaseLayer: true
+ map.addLayer(layer);
+ var handler = new OpenLayers.Handler.Point(control, {
+ control.handler = handler;
+ map.addControl(control);
+ handler.activate();
+ // test
+ var ret;
+ // tap-move (0, 0) -> (9, 0)
+ log = null;
+ ret = handler.touchmove({xy: new OpenLayers.Pixel(9, 0)});
+ t.eq(log, null, '[touchend] no finalization');
+ '[touchend] feature not modified');
+ // tear down
+ map.destroy();
</script>
</head>
<body>
More information about the Commits
