[OpenLayers-Commits] r11771 - in trunk/openlayers:
lib/OpenLayers/Handler tests/Handler
commits-20090109 at openlayers.org
Wed Mar 30 04:25:44 EDT 2011
Author: erilem
Date: 2011-03-30 01:25:40 -0700 (Wed, 30 Mar 2011)
New Revision: 11771
trunk/openlayers/lib/OpenLayers/Handler/Click.js
trunk/openlayers/tests/Handler/Click.html
click handler fires a "click" event when it should not, r=sbrunner (closes #3202)
Modified: trunk/openlayers/lib/OpenLayers/Handler/Click.js
--- trunk/openlayers/lib/OpenLayers/Handler/Click.js 2011-03-30 08:16:47 UTC (rev 11770)
+++ trunk/openlayers/lib/OpenLayers/Handler/Click.js 2011-03-30 08:25:40 UTC (rev 11771)
@@ -191,6 +191,7 @@
evt.xy = this.last.xy;
evt.lastTouches = this.last.touches;
this.handleSingle(evt);
+ this.down = null;
return true;
Modified: trunk/openlayers/tests/Handler/Click.html
--- trunk/openlayers/tests/Handler/Click.html 2011-03-30 08:16:47 UTC (rev 11770)
+++ trunk/openlayers/tests/Handler/Click.html 2011-03-30 08:25:40 UTC (rev 11771)
@@ -489,7 +489,7 @@
function test_touch_click(t) {
- t.plan(4);
+ t.plan(5);
// set up
@@ -511,6 +511,7 @@
// test
+ // the common case: a touchstart followed by a touchend
log = null;
handler.touchstart({xy: px(1, 1), touches: ["foo"]});
handler.touchend({touches: ["foo"]});
@@ -522,8 +523,19 @@
t.eq(log.y, 1, "evt.xy.y as expected");
t.ok(log.lastTouches, "evt.lastTouches as expected");
- // tear down
- map.destroy();
+ // now emulate a touch where touchstart doesn't propagate
+ // to the click handler, i.e. the click handler gets a
+ // touchend only
+ log = null;
+ handler.touchend({touches: ["foo"]});
+ t.delay_call(1, function() {
+ t.ok(log == null, "click callback not called");
+ // tear down
+ map.destroy();
More information about the Commits
