[OpenLayers-Commits] r11773 -
trunk/openlayers/lib/OpenLayers/Handler
commits-20090109 at openlayers.org
Wed Mar 30 07:30:10 EDT 2011
Author: erilem
Date: 2011-03-30 04:30:07 -0700 (Wed, 30 Mar 2011)
New Revision: 11773
trunk/openlayers/lib/OpenLayers/Handler/Path.js
trunk/openlayers/lib/OpenLayers/Handler/Point.js
some refactoring in the touch-specific code of draw handlers, r=sbrunner (closes #3208)
Modified: trunk/openlayers/lib/OpenLayers/Handler/Path.js
--- trunk/openlayers/lib/OpenLayers/Handler/Path.js 2011-03-30 09:57:41 UTC (rev 11772)
+++ trunk/openlayers/lib/OpenLayers/Handler/Path.js 2011-03-30 11:30:07 UTC (rev 11773)
@@ -45,6 +45,12 @@
freehandToggle: 'shiftKey',
+ * Property: timerId
+ * {Integer} The timer used to test the double touch.
+ timerId: null,
* Constructor: OpenLayers.Handler.Path
* Create a new path hander
@@ -214,6 +220,38 @@
+ * method: touchstart
+ * handle touchstart.
+ * parameters:
+ * evt - {event} the browser event
+ * returns:
+ * {boolean} allow event propagation
+ touchstart: function(evt) {
+ if (this.timerId &&
+ this.passesTolerance(this.lastTouchPx, evt.xy, this.dblclickTolerance)) {
+ // double-tap, finalize the geometry
+ this.lastTouchPx = evt.xy; // for up() to detect dblclick and do nothing
+ this.finishTouchGeometry();
+ window.clearTimeout(this.timerId);
+ this.timerId = null;
+ return false;
+ } else {
+ if (this.timerId) {
+ this.timerId = window.setTimeout(
+ OpenLayers.Function.bind(function() {
+ }, this), 300);
+ return OpenLayers.Handler.Point.prototype.touchstart.call(this, evt);
* Method: mousedown
* Handle mouse down. Add a new point to the geometry and
* render it. Return determines whether to propagate the event on the map.
@@ -295,7 +333,7 @@
this.stoppedDown = this.stopDown;
this.mouseDown = false;
- return !this.stopUp && !this.isDblclick;
+ return !this.stopUp;
Modified: trunk/openlayers/lib/OpenLayers/Handler/Point.js
--- trunk/openlayers/lib/OpenLayers/Handler/Point.js 2011-03-30 09:57:41 UTC (rev 11772)
+++ trunk/openlayers/lib/OpenLayers/Handler/Point.js 2011-03-30 11:30:07 UTC (rev 11773)
@@ -120,26 +120,13 @@
touch: false,
- * Property: timerId
- * {Integer} The timer used to test the double touch.
- timerId: null,
- * Property: last
+ * Property: lastTouchPx
* {<OpenLayers.Pixel>} The last pixel used to know the distance between
* two touches (for double touch).
- last: null,
+ lastTouchPx: null,
- * Property: dblclick
- * {Boolean} The current event is a dblclick.
- isDblclick: false,
* Constructor: OpenLayers.Handler.Point
* Create a new point handler.
@@ -281,6 +268,7 @@
this.lastDown = null;
this.lastUp = null;
+ this.lastTouchPx = null;
this.callback(key, [this.geometryClone()]);
if(cancel || !this.persist) {
this.destroyFeature();
@@ -415,32 +403,8 @@
this.touch = true;
- var last = this.last;
- this.last = evt.xy;
- if (this.timerId &&
- this.passesTolerance(last, evt.xy, this.dblclickTolerance)) {
- this.isDblclick = true;
- // a valid touch immediately adds a component and leaves us with a
- // complete geometry
- this.finishTouchGeometry();
- window.clearTimeout(this.timerId);
- this.timerId = null;
- return false;
- else {
- if (this.timerId) {
- this.isDblclick = false;
- this.timerId = window.setTimeout(
- OpenLayers.Function.bind(function() {
- }, this), 300);
- return this.down(evt);
+ return this.down(evt);
@@ -471,7 +435,7 @@
* {Boolean} Allow event propagation
touchmove: function(evt) {
return this.move(evt);
@@ -503,7 +467,7 @@
touchend: function(evt) {
- evt.xy = this.last;
+ evt.xy = this.lastTouchPx;
return this.up(evt);
More information about the Commits
