[OpenLayers-Commits] r11776 - in sandbox/cmoullet/openlayers: . lib/OpenLayers/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Mar 30 08:00:56 EDT 2011
Author: cmoullet
Date: 2011-03-30 05:00:55 -0700 (Wed, 30 Mar 2011)
New Revision: 11776
   sandbox/cmoullet/openlayers/
   sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Path.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Point.js
Merge with trunk
Property changes on: sandbox/cmoullet/openlayers
___________________________________________________________________
Modified: svn:mergeinfo
   - /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:11161-11771
   + /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:11161-11775
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Path.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Path.js	2011-03-30 11:57:15 UTC (rev 11775)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Path.js	2011-03-30 12:00:55 UTC (rev 11776)
@@ -45,6 +45,12 @@
     freehandToggle: 'shiftKey',
+     * Property: timerId
+     * {Integer} The timer used to test the double touch.
+    timerId: null,
      * Constructor: OpenLayers.Handler.Path
      * Create a new path hander
@@ -214,6 +220,38 @@
+     * method: touchstart
+     * handle touchstart.
+     * parameters:
+     * evt - {event} the browser event
+     * returns:
+     * {boolean} allow event propagation
+    touchstart: function(evt) {
+        if (this.timerId &&
+            this.passesTolerance(this.lastTouchPx, evt.xy, this.dblclickTolerance)) {
+            // double-tap, finalize the geometry
+            this.lastTouchPx = evt.xy; // for up() to detect dblclick and do nothing
+            this.finishTouchGeometry();
+            window.clearTimeout(this.timerId);
+            this.timerId = null;
+            return false;
+        } else {
+            if (this.timerId) {
+            this.timerId = window.setTimeout(
+                OpenLayers.Function.bind(function() {
+                }, this), 300);
+            return OpenLayers.Handler.Point.prototype.touchstart.call(this, evt);
      * Method: mousedown
      * Handle mouse down.  Add a new point to the geometry and
      * render it. Return determines whether to propagate the event on the map.
@@ -295,7 +333,7 @@
         this.stoppedDown = this.stopDown;
         this.mouseDown = false;
-        return !this.stopUp && !this.isDblclick;
+        return !this.stopUp;
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Point.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Point.js	2011-03-30 11:57:15 UTC (rev 11775)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Point.js	2011-03-30 12:00:55 UTC (rev 11776)
@@ -120,26 +120,13 @@
     touch: false,
-     * Property: timerId
-     * {Integer} The timer used to test the double touch.
-    timerId: null,
-     * Property: last
+     * Property: lastTouchPx
      * {<OpenLayers.Pixel>} The last pixel used to know the distance between
      * two touches (for double touch).
-    last: null,
+    lastTouchPx: null,
-     * Property: dblclick
-     * {Boolean} The current event is a dblclick.
-    isDblclick: false,
      * Constructor: OpenLayers.Handler.Point
      * Create a new point handler.
@@ -281,6 +268,7 @@
         this.lastDown = null;
         this.lastUp = null;
+        this.lastTouchPx = null;
         this.callback(key, [this.geometryClone()]);
         if(cancel || !this.persist) {
             this.destroyFeature();
@@ -415,32 +403,8 @@
         this.touch = true;
-        var last = this.last;
-        this.last = evt.xy;
-        if (this.timerId &&
-            this.passesTolerance(last, evt.xy, this.dblclickTolerance)) {
-            this.isDblclick = true;
-            // a valid touch immediately adds a component and leaves us with a
-            // complete geometry
-            this.finishTouchGeometry();
-            window.clearTimeout(this.timerId);
-            this.timerId = null;
-            return false;
-        else {
-            if (this.timerId) {
-            this.isDblclick = false;
-            this.timerId = window.setTimeout(
-                OpenLayers.Function.bind(function() {
-                }, this), 300);
-            return this.down(evt);
+        return this.down(evt);
@@ -471,7 +435,7 @@
      * {Boolean} Allow event propagation
     touchmove: function(evt) {
         return this.move(evt);
@@ -503,7 +467,7 @@
     touchend: function(evt) {
-        evt.xy = this.last;
+        evt.xy = this.lastTouchPx;
         return this.up(evt);
More information about the Commits mailing list
