[OpenLayers-Commits] r11796 - in sandbox/cmoullet/openlayers: . lib
lib/OpenLayers/Handler
commits-20090109 at openlayers.org
Wed Mar 30 10:38:00 EDT 2011
Author: cmoullet
Date: 2011-03-30 07:37:59 -0700 (Wed, 30 Mar 2011)
New Revision: 11796
sandbox/cmoullet/openlayers/
sandbox/cmoullet/openlayers/lib/OpenLayers.js
sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Click.js
sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Path.js
sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Polygon.js
Merge with trunk
Property changes on: sandbox/cmoullet/openlayers
___________________________________________________________________
Modified: svn:mergeinfo
- /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:11161-11775,11777-11790
+ /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:11161-11775,11777-11795
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Click.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Click.js 2011-03-30 14:29:28 UTC (rev 11795)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Click.js 2011-03-30 14:37:59 UTC (rev 11796)
@@ -346,6 +346,10 @@
// already received a click
if (this.last.touches && this.last.touches.length === 1) {
// touch device, no dblclick event - this may be a double
+ if (this["double"]) {
+ // on Android don't let the browser zoom on the page
+ OpenLayers.Event.stop(evt);
this.handleDouble(evt);
// if we're not in a touch environment we clear the click timer
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Path.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Path.js 2011-03-30 14:29:28 UTC (rev 11795)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Path.js 2011-03-30 14:37:59 UTC (rev 11796)
@@ -25,7 +25,7 @@
* {<OpenLayers.Feature.Vector>}
line: null,
* Property: freehand
* {Boolean} In freehand mode, the handler starts the path on mouse down,
@@ -234,7 +234,7 @@
this.passesTolerance(this.lastTouchPx, evt.xy, this.dblclickTolerance)) {
// double-tap, finalize the geometry
this.lastTouchPx = evt.xy; // for up() to detect dblclick and do nothing
- this.finishTouchGeometry();
+ this.finishGeometry();
window.clearTimeout(this.timerId);
this.timerId = null;
return false;
@@ -337,14 +337,6 @@
- * Method: finishTouchGeometry
- * Finish the geometry and send it back to the control.
- finishTouchGeometry: function() {
- this.finishGeometry();
* APIMethod: finishGeometry
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Polygon.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Polygon.js 2011-03-30 14:29:28 UTC (rev 11795)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Polygon.js 2011-03-30 14:37:59 UTC (rev 11796)
@@ -151,10 +151,10 @@
+ * Method: finishGeometry
+ finishGeometry: function() {
var index = this.line.geometry.components.length - 2;
this.line.geometry.removeComponent(this.line.geometry.components[index]);
this.removePoint();
@@ -293,24 +293,5 @@
return geometry;
- * Method: dblclick
- * Handle double-clicks. Finish the geometry and send it back
- * to the control.
- * Parameters:
- * evt - {Event}
- dblclick: function(evt) {
- if(!this.freehandMode(evt)) {
- // remove the penultimate point
- var index = this.line.geometry.components.length - 2;
- this.line.geometry.removeComponent(this.line.geometry.components[index]);
- this.removePoint();
- this.finalize();
- return false;
CLASS_NAME: "OpenLayers.Handler.Polygon"
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers.js 2011-03-30 14:29:28 UTC (rev 11795)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers.js 2011-03-30 14:37:59 UTC (rev 11796)
@@ -330,8 +330,8 @@
"OpenLayers/Format/WMTSCapabilities.js",
"OpenLayers/Format/WMTSCapabilities/v1_0_0.js",
"OpenLayers/Format/XLS.js",
- "OpenLayers/Format/XLS/v1.js",
- "OpenLayers/Format/XLS/v1_1_0.js",
+ "OpenLayers/Format/XLS/v1.js",
+ "OpenLayers/Format/XLS/v1_1_0.js",
"OpenLayers/Layer/WFS.js",
"OpenLayers/Control/GetFeature.js",
"OpenLayers/Control/MouseToolbar.js",
More information about the Commits
