[OpenLayers-Commits] r11819 - in trunk/openlayers: lib/OpenLayers/Geometry tests/Geometry
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Mar 30 19:54:59 EDT 2011
Author: tschaub
Date: 2011-03-30 16:54:54 -0700 (Wed, 30 Mar 2011)
New Revision: 11819
   trunk/openlayers/lib/OpenLayers/Geometry/LinearRing.js
   trunk/openlayers/tests/Geometry/LinearRing.html
Making it so you can remove more points from a linear ring. p=gregers, r=me (closes #2172)
Modified: trunk/openlayers/lib/OpenLayers/Geometry/LinearRing.js
--- trunk/openlayers/lib/OpenLayers/Geometry/LinearRing.js	2011-03-30 23:38:31 UTC (rev 11818)
+++ trunk/openlayers/lib/OpenLayers/Geometry/LinearRing.js	2011-03-30 23:54:54 UTC (rev 11819)
@@ -93,7 +93,7 @@
      * point - {<OpenLayers.Geometry.Point>}
     removeComponent: function(point) {
-        if (this.components.length > 4) {
+        if (this.components.length > 3) {
             //remove last point
             this.components.pop();
Modified: trunk/openlayers/tests/Geometry/LinearRing.html
--- trunk/openlayers/tests/Geometry/LinearRing.html	2011-03-30 23:38:31 UTC (rev 11818)
+++ trunk/openlayers/tests/Geometry/LinearRing.html	2011-03-30 23:54:54 UTC (rev 11819)
@@ -58,7 +58,7 @@
     function test_LinearRing_removeComponent(t) {
-        t.plan(11);
+        t.plan(10);
         var components = [new OpenLayers.Geometry.Point(0,0),
                     new OpenLayers.Geometry.Point(0,10),
@@ -71,7 +71,7 @@
         t.eq(ring.components.length, 4, "removing from linear ring with 5 points: length ok");
         t.ok(ring.components[0].equals(components[0]), "point one correct");
         t.ok(ring.components[1].equals(components[1]), "point two correct");
-        t.ok(ring.components[2].equals(components[3]), "point one correct");
+        t.ok(ring.components[2].equals(components[3]), "point three correct");
         t.ok(ring.components[0] === ring.components[ring.components.length - 1],
              "first and last point are the same");
@@ -80,10 +80,10 @@
         t.ok(ringBounds.equals(testBounds), "bounds correctly recalculated");
         ring.removeComponent( ring.components[2] );
-        t.eq(ring.components.length, 4, "cant remove from linear ring with only 4 points. new length ok (unchanged)");
+        ring.removeComponent( ring.components[1] );
+        t.eq(ring.components.length, 3, "cant remove from linear ring with only 3 points. new length ok");
More information about the Commits mailing list
