[OpenLayers-Commits] r11827 - in trunk/openlayers: lib/OpenLayers/Handler tests/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Mar 31 05:01:07 EDT 2011
Author: sbrunner
Date: 2011-03-31 02:01:05 -0700 (Thu, 31 Mar 2011)
New Revision: 11827
   trunk/openlayers/lib/OpenLayers/Handler/Point.js
   trunk/openlayers/tests/Handler/Point.html
Cleanup mouse event on touch devices, r=erilem (closes #3215)
Modified: trunk/openlayers/lib/OpenLayers/Handler/Point.js
--- trunk/openlayers/lib/OpenLayers/Handler/Point.js	2011-03-31 08:28:28 UTC (rev 11826)
+++ trunk/openlayers/lib/OpenLayers/Handler/Point.js	2011-03-31 09:01:05 UTC (rev 11827)
@@ -219,6 +219,7 @@
             this.layer.destroy(false);
         this.layer = null;
+        this.touch = false;
         return true;
@@ -385,9 +386,6 @@
      * {Boolean} Allow event propagation
     mousedown: function(evt) {
-        if (this.touch) {
-            return;
         return this.down(evt);
@@ -402,7 +400,18 @@
     touchstart: function(evt) {
-        this.touch = true;
+        if (!this.touch) {
+            this.touch = true;
+            // unregister mouse listeners
+            this.map.events.un({
+                mousedown: this.mousedown,
+                mouseup: this.mouseup,
+                mousemove: this.mousemove,
+                click: this.click,
+                dblclick: this.dblclick,
+                scope: this
         this.lastTouchPx = evt.xy;
@@ -418,9 +427,6 @@
     mousemove: function(evt) {
-        if (this.touch) {
-            return;
         return this.move(evt);
@@ -450,9 +456,6 @@
     mouseup: function(evt) {
-        if (this.touch) {
-            return;
         return this.up(evt);
Modified: trunk/openlayers/tests/Handler/Point.html
--- trunk/openlayers/tests/Handler/Point.html	2011-03-31 08:28:28 UTC (rev 11826)
+++ trunk/openlayers/tests/Handler/Point.html	2011-03-31 09:01:05 UTC (rev 11827)
@@ -417,6 +417,88 @@
              "handler.point is null after destroy");
+    function test_touchstart(t) {
+        // a test to verify that the touchstart function does
+        // unregister the mouse listeners when it's called the
+        // first time
+        t.plan(4);
+        // set up
+        var map = new OpenLayers.Map("map", {
+            resolutions: [1]
+        var layer = new OpenLayers.Layer.Vector("foo", {
+            maxExtent: new OpenLayers.Bounds(-10, -10, 10, 10),
+            isBaseLayer: true
+        map.addLayer(layer);
+        var control = new OpenLayers.Control({});
+        var handler = new OpenLayers.Handler.Point(control, {});
+        control.handler = handler;
+        map.addControl(control);
+        map.setCenter(new OpenLayers.LonLat(0, 0), 0);
+        handler.activate();
+        function allRegistered() {
+            var eventTypes = ['mousedown', 'mouseup', 'mousemove', 'click', 'dblclick'],
+                eventType,
+                listeners,
+                listener,
+                flag;
+            for(var i=0, ilen=eventTypes.length; i<ilen; i++) {
+                flag =  false;
+                eventType = eventTypes[i];
+                listeners = map.events.listeners[eventType];
+                for(var j=0, jlen=listeners.length; j<jlen; j++) {
+                    listener = listeners[j];
+                    if(listener.func === handler[eventType] && listener.obj === handler) {
+                        flag = true;
+                        break;
+                if(!flag) {
+                    return false;
+            return true;
+        function noneRegistered() {
+                eventType,
+                listeners,
+                listener;
+                        return false;
+            return true;
+        // test
+        t.ok(allRegistered(), 'mouse listeners are registered');
+        handler.touchstart({xy: new OpenLayers.Pixel(0, 0)});
+        t.ok(noneRegistered(), 'mouse listeners are unregistered');
+        t.ok(handler.touch, 'handler.touch is set');
+        handler.deactivate();
+        t.ok(!handler.touch, 'handler.touch is not set');
+        // tear down
+        map.destroy();
     // Sequence tests
More information about the Commits mailing list
