[OpenLayers-Commits] r11836 - in trunk/openlayers: lib/OpenLayers/Handler tests/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Mar 31 07:35:27 EDT 2011
Author: erilem
Date: 2011-03-31 04:35:24 -0700 (Thu, 31 Mar 2011)
New Revision: 11836
   trunk/openlayers/lib/OpenLayers/Handler/Path.js
   trunk/openlayers/tests/Handler/Path.html
when drawing make sure the point follow the cursor, even after zooming in or out, p=jorix, r=me (closes #3195)
Modified: trunk/openlayers/lib/OpenLayers/Handler/Path.js
--- trunk/openlayers/lib/OpenLayers/Handler/Path.js	2011-03-31 11:35:15 UTC (rev 11835)
+++ trunk/openlayers/lib/OpenLayers/Handler/Path.js	2011-03-31 11:35:24 UTC (rev 11836)
@@ -157,6 +157,7 @@
         this.line.geometry.addComponent(
             this.point.geometry, this.line.geometry.components.length
+        this.layer.addFeatures([this.point]);
         this.callback("point", [this.point.geometry, this.getGeometry()]);
         this.callback("modify", [this.point.geometry, this.getSketch()]);
         this.drawFeature();
Modified: trunk/openlayers/tests/Handler/Path.html
--- trunk/openlayers/tests/Handler/Path.html	2011-03-31 11:35:15 UTC (rev 11835)
+++ trunk/openlayers/tests/Handler/Path.html	2011-03-31 11:35:24 UTC (rev 11836)
@@ -105,7 +105,7 @@
     function test_bounds(t) {
-        t.plan(2);
+        t.plan(5);
         var geometry;
         var map = new OpenLayers.Map('map');
         map.addLayer(new OpenLayers.Layer.WMS("", "", {}));
@@ -115,16 +115,22 @@
         var handler = new OpenLayers.Handler.Path(control, {},
             {stopDown: true, stopUp: true});
         var activated = handler.activate();
+        t.eq(handler.layer.features.length, 2,
+            "There are two features in the layer after activation.");
         // click on (150, 75)
         var evt = {xy: new OpenLayers.Pixel(150, 75), which: 1};
         handler.mousemove(evt);
         handler.mousedown(evt);
         handler.mouseup(evt);
+            "There are two features in the layer after first click.");
         // click on (175, 100)
         evt = {xy: new OpenLayers.Pixel(175, 100), which: 1};
+            "There are two features in the layer after second click.");
         t.ok(handler.line.geometry.getBounds().equals(
                     new OpenLayers.Bounds(0,-35.15625,35.15625,0)),
              "Correct bounds");
More information about the Commits mailing list
