[OpenLayers-Commits] r11941 - in sandbox/tschaub/editing: examples
lib/OpenLayers/Geometry lib/OpenLayers/Layer
commits-20090109 at openlayers.org
Mon May 2 19:49:48 EDT 2011
Author: tschaub
Date: 2011-05-02 16:49:47 -0700 (Mon, 02 May 2011)
New Revision: 11941
sandbox/tschaub/editing/examples/point-grid.html
sandbox/tschaub/editing/examples/snap-grid.html
sandbox/tschaub/editing/lib/OpenLayers/Geometry/Polygon.js
sandbox/tschaub/editing/lib/OpenLayers/Layer/PointGrid.js
Docs for point grid.
Modified: sandbox/tschaub/editing/examples/point-grid.html
--- sandbox/tschaub/editing/examples/point-grid.html 2011-05-02 23:12:17 UTC (rev 11940)
+++ sandbox/tschaub/editing/examples/point-grid.html 2011-05-02 23:49:47 UTC (rev 11941)
@@ -53,6 +53,15 @@
<option value="350">350</option>
</select>
+ <div class="docs">
+ <p>
+ This example demonstrates a <code>OpenLayers.Layer.PointGrid</code>
+ layer to render a regularly spaced grid of point features.
+ </p><p>
+ See the <a href="point-grid.js" target="_blank">
+ point-grid.js source</a> to see how this is done.
+ </p>
+ </div>
<script src="../lib/OpenLayers.js"></script>
<script src="point-grid.js"></script>
</body>
Modified: sandbox/tschaub/editing/examples/snap-grid.html
--- sandbox/tschaub/editing/examples/snap-grid.html 2011-05-02 23:12:17 UTC (rev 11940)
+++ sandbox/tschaub/editing/examples/snap-grid.html 2011-05-02 23:49:47 UTC (rev 11941)
@@ -59,6 +59,17 @@
</select>
+ <p>
+ This example demonstrates feature editing with snapping to a regular
+ grid. The map is configured with a <code>OpenLayers.Layer.PointGrid</code>
+ layer and a <code>OpenLayers.Control.Snapping</code> agent.
+ </p><p>
+ See the <a href="snap-grid.js" target="_blank">
+ snap-grid.js source</a> to see how this is done.
+ </p>
+ </div>
<script src="snap-grid.js"></script>
</body>
Modified: sandbox/tschaub/editing/lib/OpenLayers/Geometry/Polygon.js
--- sandbox/tschaub/editing/lib/OpenLayers/Geometry/Polygon.js 2011-05-02 23:12:17 UTC (rev 11940)
+++ sandbox/tschaub/editing/lib/OpenLayers/Geometry/Polygon.js 2011-05-02 23:49:47 UTC (rev 11941)
@@ -258,6 +258,16 @@
return new OpenLayers.Geometry.Polygon([ring]);
+ * APIMethod: fromBounds
+ * Generate a polygon for the given bounds.
+ * Parameters:
+ * bounds - {<OpenLayers.Bounds>} A bounds object.
+ * Returns:
+ * {<OpenLayers.Geometry.Polygon>} A polygon representing the given bounds.
OpenLayers.Geometry.Polygon.fromBounds = function(bounds) {
var Point = OpenLayers.Geometry.Point;
Modified: sandbox/tschaub/editing/lib/OpenLayers/Layer/PointGrid.js
--- sandbox/tschaub/editing/lib/OpenLayers/Layer/PointGrid.js 2011-05-02 23:12:17 UTC (rev 11940)
+++ sandbox/tschaub/editing/lib/OpenLayers/Layer/PointGrid.js 2011-05-02 23:49:47 UTC (rev 11941)
@@ -17,19 +17,70 @@
OpenLayers.Layer.PointGrid = OpenLayers.Class(OpenLayers.Layer.Vector, {
- * Property: gridBounds
+ * APIProperty: dx
+ * {Number} Point grid spacing in the x-axis direction. Read-only. Use the
+ * <setSpacing> method to modify this value.
- gridBounds: null,
+ dx: null,
- dx: null,
+ * APIProperty: dy
+ * {Number} Point grid spacing in the y-axis direction. Read-only. Use the
dy: null,
+ * APIProperty: ratio
+ * {Number} Ratio of the desired grid size to the map viewport size.
+ * Default is 1.5. Larger ratios mean the grid is recalculated less often
+ * while panning. The <maxFeatures> setting has precedence when determining
+ * grid size. Read-only. Use the <setRatio> method to modify this value.
ratio: 1.5,
+ * APIProperty: maxFeatures
+ * {Number} The maximum number of points to generate in the grid. Default
+ * is 250. Read-only. Use the <maxFeatures> method to modify this value.
maxFeatures: 250,
+ * APIProperty: rotation
+ * {Number} Grid rotation (in degrees clockwise from the positive x-axis).
+ * Default is 0. Read-only. Use the <setRotation> method to modify this
+ * value.
rotation: 0,
- initialize: function(options) {
- options = options || {};
- OpenLayers.Layer.Vector.prototype.initialize.apply(this, [options.name, options]);
+ * APIProperty: origin
+ * {OpenLayers.LonLat} Grid origin. If not set at construction, the center
+ * of the map's maximum extent is used. Read-only. Use the <setOrigin>
+ * method to modify this value.
+ origin: 0,
+ * Property: gridBounds
+ * {<OpenLayers.Bounds>} Internally cached grid bounds (with optional
+ * rotation applied).
+ gridBounds: null,
+ * Constructor: OpenLayers.Layer.PointGrid
+ * Creates a new point grid layer.
+ * Parameters:
+ * config - {Object} An object containing all configuration properties for
+ * the layer. The <dx> and <dy> properties are required to be set at
+ * construction. Any other layer properties may be set in this object.
+ initialize: function(config) {
+ config = config || {};
+ OpenLayers.Layer.Vector.prototype.initialize.apply(this, [config.name, config]);
@@ -56,27 +107,64 @@
OpenLayers.Layer.Vector.prototype.removeMap.apply(this, arguments);
+ * APIMethod: setRatio
+ * Set the grid <ratio> property and update the grid.
+ * Parameters:
+ * ratio - {Number}
setRatio: function(ratio) {
this.ratio = ratio;
this.updateGrid(true);
+ * APIMethod: setMaxFeatures
+ * Set the grid <maxFeatures> property and update the grid.
+ * Parameters:
+ * maxFeatures - {Number}
setMaxFeatures: function(maxFeatures) {
this.maxFeatures = maxFeatures;
+ * APIMethod: setSpacing
+ * Set the grid <dx> and <dy> properties and update the grid. If only one
+ * argument is provided, it will be set as <dx> and <dy>.
+ * Parameters:
+ * dx - {Number}
+ * dy - {Number}
setSpacing: function(dx, dy) {
this.dx = dx;
this.dy = dy || dx;
+ * APIMethod: setOrigin
+ * Set the grid <origin> property and update the grid.
+ * Parameters:
+ * origin - {<OpenLayers.LonLat>}
setOrigin: function(origin) {
this.origin = origin;
+ * APIMethod: getOrigin
+ * Get the grid <origin> property.
+ * Returns:
+ * {<OpenLayers.LonLat>} The grid origin.
getOrigin: function() {
if (!this.origin) {
this.origin = this.map.getExtent().getCenterLonLat();
@@ -84,15 +172,33 @@
return this.origin;
+ * APIMethod: setRotation
+ * Set the grid <rotation> property and update the grid.
+ * Parameters:
+ * rotation - {Number} Degrees clockwise from the positive x-axis.
setRotation: function(rotation) {
this.rotation = rotation;
+ * Method: onMoveEnd
+ * Listener for map "moveend" events.
onMoveEnd: function() {
this.updateGrid();
+ * Method: getViewBounds
+ * Gets the (potentially rotated) view bounds for grid calculations.
+ * Returns:
getViewBounds: function() {
var bounds = this.map.getExtent();
if (this.rotation) {
@@ -105,6 +211,10 @@
return bounds;
+ * Method: updateGrid
+ * Update the grid.
updateGrid: function(force) {
if (force || this.invalidBounds()) {
var viewBounds = this.getViewBounds();
More information about the Commits
