[OpenLayers-Commits] r11946 - in
sandbox/tschaub/editing/lib/OpenLayers: Control Handler
commits-20090109 at openlayers.org
Tue May 3 19:44:15 EDT 2011
Author: tschaub
Date: 2011-05-03 16:44:14 -0700 (Tue, 03 May 2011)
New Revision: 11946
sandbox/tschaub/editing/lib/OpenLayers/Control/DrawFeature.js
sandbox/tschaub/editing/lib/OpenLayers/Handler/Path.js
sandbox/tschaub/editing/lib/OpenLayers/Handler/Polygon.js
Methods for programmatically inserting vertices while digitizing.
Modified: sandbox/tschaub/editing/lib/OpenLayers/Control/DrawFeature.js
--- sandbox/tschaub/editing/lib/OpenLayers/Control/DrawFeature.js 2011-05-03 16:59:58 UTC (rev 11945)
+++ sandbox/tschaub/editing/lib/OpenLayers/Control/DrawFeature.js 2011-05-03 23:44:14 UTC (rev 11946)
@@ -121,6 +121,44 @@
this.events.triggerEvent("featureadded",{feature : feature});
+ * APIMethod: insertXY
+ * Insert a point in the current sketch given x & y coordinates.
+ * Parameters:
+ * x - {Number} The x-coordinate of the point.
+ * y - {Number} The y-coordinate of the point.
+ insertXY: function(x, y) {
+ if (this.handler && this.handler.line) {
+ this.handler.insertXY(x, y);
+ * APIMethod: insertDirectionLength
+ * Insert a point in the current sketch given a direction and a length.
+ * Parameters:
+ * direction - {Number} Degrees clockwise from the positive x-axis.
+ * length - {Number} Distance from the previously drawn point.
+ insertDirectionLength: function(direction, length) {
+ this.handler.insertDirectionLength(direction, length);
+ * APIMethod: finishSketch
+ * Finishes the sketch without including the currently drawn point.
+ * This method can be called to terminate drawing programmatically
+ * instead of waiting for the user to end the sketch.
+ finishSketch: function() {
+ this.handler.finishGeometry();
CLASS_NAME: "OpenLayers.Control.DrawFeature"
Modified: sandbox/tschaub/editing/lib/OpenLayers/Handler/Path.js
--- sandbox/tschaub/editing/lib/OpenLayers/Handler/Path.js 2011-05-03 16:59:58 UTC (rev 11945)
+++ sandbox/tschaub/editing/lib/OpenLayers/Handler/Path.js 2011-05-03 23:44:14 UTC (rev 11946)
@@ -164,6 +164,50 @@
+ * Method: insertXY
+ * Insert a point in the current sketch given x & y coordinates. The new
+ * point is inserted immediately before the most recently drawn point.
+ * Parameters:
+ this.line.geometry.addComponent(
+ new OpenLayers.Geometry.Point(x, y),
+ this.getCurrentPointIndex()
+ this.drawFeature();
+ * Method: insertDirectionLength
+ * Parameters:
+ direction *= Math.PI / 180;
+ var dx = length * Math.cos(direction);
+ var dy = length * Math.sin(direction);
+ var previousIndex = this.getCurrentPointIndex() - 1;
+ var p0 = this.line.geometry.components[previousIndex];
+ this.insertXY(p0.x + dx, p0.y + dy);
+ * Method: getCurrentPointIndex
+ * Returns:
+ * {Number} The index of the most recently drawn point.
+ getCurrentPointIndex: function() {
+ return this.line.geometry.components.length - 1;
* Method: freehandMode
* Determine whether to behave in freehand mode or not.
Modified: sandbox/tschaub/editing/lib/OpenLayers/Handler/Polygon.js
--- sandbox/tschaub/editing/lib/OpenLayers/Handler/Polygon.js 2011-05-03 16:59:58 UTC (rev 11945)
+++ sandbox/tschaub/editing/lib/OpenLayers/Handler/Polygon.js 2011-05-03 23:44:14 UTC (rev 11946)
@@ -130,8 +130,18 @@
OpenLayers.Handler.Path.prototype.addPoint.apply(this, arguments);
+ * Returns:
+ return this.line.geometry.components.length - 2;
* Method: enforceTopology
* Simple topology enforcement for drawing interior rings. Ensures vertices
* of interior rings are contained by exterior ring. Other topology
More information about the Commits
