[OpenLayers-Commits] r11950 - in
sandbox/tschaub/editing/lib/OpenLayers: Control Handler
commits-20090109 at openlayers.org
Wed May 4 14:57:35 EDT 2011
Author: tschaub
Date: 2011-05-04 11:57:34 -0700 (Wed, 04 May 2011)
New Revision: 11950
sandbox/tschaub/editing/lib/OpenLayers/Control/DrawFeature.js
sandbox/tschaub/editing/lib/OpenLayers/Handler/Path.js
Adding method to insert by x,y offsets.
Modified: sandbox/tschaub/editing/lib/OpenLayers/Control/DrawFeature.js
--- sandbox/tschaub/editing/lib/OpenLayers/Control/DrawFeature.js 2011-05-04 12:08:25 UTC (rev 11949)
+++ sandbox/tschaub/editing/lib/OpenLayers/Control/DrawFeature.js 2011-05-04 18:57:34 UTC (rev 11950)
@@ -137,6 +137,20 @@
+ * APIMethod: insertDeltaXY
+ * Insert a point given offsets from the previously inserted point.
+ * Parameters:
+ * dx - {Number} The x-coordinate offset of the point.
+ * dy - {Number} The y-coordinate offset of the point.
+ insertDeltaXY: function(dx, dy) {
+ if (this.handler && this.handler.line) {
+ this.handler.insertDeltaXY(dx, dy);
* APIMethod: insertDirectionLength
* Insert a point in the current sketch given a direction and a length.
@@ -151,6 +165,20 @@
+ * APIMethod: insertDirectionLength
+ * Insert a point in the current sketch given a direction and a length.
+ * Parameters:
+ * direction - {Number} Degrees clockwise from the positive x-axis.
+ * length - {Number} Distance from the previously drawn point.
+ insertDirectionLength: function(direction, length) {
+ this.handler.insertDirectionLength(direction, length);
* APIMethod: finishSketch
* Finishes the sketch without including the currently drawn point.
* This method can be called to terminate drawing programmatically
Modified: sandbox/tschaub/editing/lib/OpenLayers/Handler/Path.js
--- sandbox/tschaub/editing/lib/OpenLayers/Handler/Path.js 2011-05-04 12:08:25 UTC (rev 11949)
+++ sandbox/tschaub/editing/lib/OpenLayers/Handler/Path.js 2011-05-04 18:57:34 UTC (rev 11950)
@@ -181,6 +181,20 @@
+ * Method: insertDeltaXY
+ * Parameters:
+ var previousIndex = this.getCurrentPointIndex() - 1;
+ var p0 = this.line.geometry.components[previousIndex];
+ this.insertXY(p0.x + dx, p0.y + dy);
* Method: insertDirectionLength
@@ -192,9 +206,7 @@
direction *= Math.PI / 180;
var dx = length * Math.cos(direction);
var dy = length * Math.sin(direction);
- var previousIndex = this.getCurrentPointIndex() - 1;
- var p0 = this.line.geometry.components[previousIndex];
- this.insertXY(p0.x + dx, p0.y + dy);
+ this.insertDeltaXY(dx, dy);
More information about the Commits
