[OpenLayers-Commits] r11956 - in sandbox/august/trunk: lib/OpenLayers/Format/WPSCommon lib/OpenLayers/Layer playground playground/wmts playground/wps
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Fri May 6 20:45:03 EDT 2011
Author: augusttown
Date: 2011-05-06 17:45:02 -0700 (Fri, 06 May 2011)
New Revision: 11956
   sandbox/august/trunk/lib/OpenLayers/Format/WPSCommon/v1_0_0.js
   sandbox/august/trunk/lib/OpenLayers/Layer/Process.js
   sandbox/august/trunk/playground/index.html
   sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema.js
   sandbox/august/trunk/playground/wmts/wmts-ags-epsg3857.js
   sandbox/august/trunk/playground/wmts/wmts-ags-wgs84.js
   sandbox/august/trunk/playground/wps/wps-process-ags.js
update wmts samples;
update WPSCommon format and Process layer.
Modified: sandbox/august/trunk/lib/OpenLayers/Format/WPSCommon/v1_0_0.js
--- sandbox/august/trunk/lib/OpenLayers/Format/WPSCommon/v1_0_0.js	2011-05-05 16:55:27 UTC (rev 11955)
+++ sandbox/august/trunk/lib/OpenLayers/Format/WPSCommon/v1_0_0.js	2011-05-07 00:45:02 UTC (rev 11956)
@@ -1031,6 +1031,7 @@
     	// inject inputObj.identifier into inputObj.options.identifier
     	inputObj.options.identifier = inputObj.identifier;
+    	// TODO: if already exists, must replace existing one
     	this.inputs.push(inputObj);
Modified: sandbox/august/trunk/lib/OpenLayers/Layer/Process.js
--- sandbox/august/trunk/lib/OpenLayers/Layer/Process.js	2011-05-05 16:55:27 UTC (rev 11955)
+++ sandbox/august/trunk/lib/OpenLayers/Layer/Process.js	2011-05-07 00:45:02 UTC (rev 11956)
@@ -47,6 +47,16 @@
     processIdentifier: null,
+    process: null,
+     * APIProperty: autoLoad
+    autoLoad: false,
      * Constructor: OpenLayers.Layer.Process
Modified: sandbox/august/trunk/playground/index.html
--- sandbox/august/trunk/playground/index.html	2011-05-05 16:55:27 UTC (rev 11955)
+++ sandbox/august/trunk/playground/index.html	2011-05-07 00:45:02 UTC (rev 11956)
@@ -32,9 +32,12 @@
 			<tr><td><a href="wmts/wmts-geowebcache-wgs84.html"><b>wmts/wmts-geowebcache-wgs84.html</b></a></td></tr>
 			<tr><td><a href="wmts/wmts-geowebcache-customized-tilingschema.html"><b>wmts/wmts-geowebcache-customized-tilingschema.html</b></a></td></tr>
 			<tr><td><a href="wmts/jsapi-wmts-wgs84.html"><b>wmts/jsapi-wmts-wgs84.html</b></a></td></tr>
+			<tr><td><a href="wmts/jsapi-wmts-ags-wgs84.html"><b>wmts/jsapi-wmts-ags-wgs84.html</b></a></td></tr>
 			<tr><td><a href="wmts/jsapi-wmts-epsg3857.html"><b>wmts/jsapi-wmts-epsg3857.html</b></a></td></tr>
+			<tr><td><a href="wmts/jsapi-wmts-ags-epsg3857.html"><b>wmts/jsapi-wmts-ags-epsg3857.html</b></a></td></tr>
 			<tr><td><a href="wmts/jsapi-wmts-epsg3857-opengeo.html"><b>wmts/jsapi-wmts-epsg3857-opengeo.html</b></a></td></tr>
 			<tr><td><a href="wmts/jsapi-wmts-customized-tilingschema.html"><b>wmts/jsapi-wmts-customized-tilingschema.html</b></a></td></tr>
+			<tr><td><a href="wmts/jsapi-wmts-ags-customized-tilingschema.html"><b>wmts/jsapi-wmts-ags-customized-tilingschema.html</b></a></td></tr>
 			<tr><td><a href="wmts/jsapi-wmts-customized-tilingschema-swiss.html"><b>wmts/jsapi-wmts-customized-tilingschema-swiss.html</b></a></td></tr>
 			<tr><td><a href="wmts/wmts2tileinfo.html"><b>wmts/wmts2tileinfo.html</b></a></td></tr>
 			<tr><td><a href="../examples/wmts.html"><b>examples/wmts.html</b></a></td></tr>
Modified: sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema.js
--- sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema.js	2011-05-05 16:55:27 UTC (rev 11955)
+++ sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema.js	2011-05-07 00:45:02 UTC (rev 11956)
@@ -33,7 +33,7 @@
 	map = new OpenLayers.Map('map', options);
-	var url = "http://alexandertown0:6080/wmts/services/portland/MapServer/WMTS/tile";
+	var url = "http://sazabiii:6080/arcgis/rest/services/portland_wmts/MapServer/WMTS/tile";
 	// add a WMTS by manually configure the tileMatrixSet and matrixIds
 	// in this case you don't need to load and parse capabilities file
Modified: sandbox/august/trunk/playground/wmts/wmts-ags-epsg3857.js
--- sandbox/august/trunk/playground/wmts/wmts-ags-epsg3857.js	2011-05-05 16:55:27 UTC (rev 11955)
+++ sandbox/august/trunk/playground/wmts/wmts-ags-epsg3857.js	2011-05-07 00:45:02 UTC (rev 11956)
@@ -99,7 +99,8 @@
 	var agsWorldWmtsLayer = new OpenLayers.Layer.WMTS({
 		// general Grid layer options
-		url:			"http://alexandertown0:6080/wmts/services/world/MapServer/WMTS/tile",
+		//url:			"http://sazabiii:6080/arcgis/rest/services/world_wmts/MapServer/WMTS/tile",
+		url:			"http://ki:6080/arcgis/rest/services/world/MapServer/WMTS/tile",
 		isBaseLayer: 	false,
 		singleTile: 	false,
 		layer: 			"Layers",
@@ -120,7 +121,7 @@
 	var agsSfWmtsLayer = new OpenLayers.Layer.WMTS({
-		url:			"http://alexandertown0:6080/wmts/services/sanfrancisco/MapServer/WMTS/tile",
+		url:			"http://sazabiii:6080/arcgis/rest/services/sanfrancisco_wmts/MapServer/WMTS/tile",
 		isBaseLayer: 	false,
 		singleTile: 	false,
 		layer: 			"Layers",
Modified: sandbox/august/trunk/playground/wmts/wmts-ags-wgs84.js
--- sandbox/august/trunk/playground/wmts/wmts-ags-wgs84.js	2011-05-05 16:55:27 UTC (rev 11955)
+++ sandbox/august/trunk/playground/wmts/wmts-ags-wgs84.js	2011-05-07 00:45:02 UTC (rev 11956)
@@ -50,7 +50,7 @@
     map.addLayer(base_layer);
-	var url = "http://alexandertown0:6080/wmts/services/bluemarble/MapServer/WMTS/tile";
+	var url = "http://sazabiii:6080/arcgis/rest/services/bluemarble_wmts/MapServer/WMTS/tile";
Modified: sandbox/august/trunk/playground/wps/wps-process-ags.js
--- sandbox/august/trunk/playground/wps/wps-process-ags.js	2011-05-05 16:55:27 UTC (rev 11955)
+++ sandbox/august/trunk/playground/wps/wps-process-ags.js	2011-05-07 00:45:02 UTC (rev 11956)
@@ -256,8 +256,8 @@
     	this
-    //map.addControl(draw_control);
-    //draw_control.activate();
+    map.addControl(draw_control);
+    draw_control.activate();
     select_control = new OpenLayers.Control.SelectFeature(
     	wfs_layer_point,
@@ -277,8 +277,8 @@
-    map.addControl(select_control);
-    select_control.activate();
+    //map.addControl(select_control);
+    //select_control.activate();
     result_layer = new OpenLayers.Layer.Vector(
     	"__wps_results__",
@@ -316,7 +316,8 @@
 	if(!process) {
 		process = new OpenLayers.Process.WPS({
 			map: map,
-			url: "http://sazabiii:6080/arcgis/services/regression.advanced.services/GPServer/WPSServer?",
+			//url: "http://sazabiii:6080/arcgis/services/regression.advanced.services/GPServer/WPSServer?",
+			url: "http://ki:6080/arcgis/services/clip/GPServer/WPSServer?",
 			identifier: "buffer"
 			// TODO: more settings
@@ -498,7 +499,8 @@
 	if(!clip_process) {
 		clip_process = new OpenLayers.Process.WPS({
 			map: map,
+			url: "http://bi:6080/arcgis/services/clip/GPServer/WPSServer?",
 			identifier: "clip"
More information about the Commits mailing list
