[OpenLayers-Commits] r11959 - in trunk/openlayers:
lib/OpenLayers/Format/CSWGetRecords tests/Format/CSWGetRecords
commits-20090109 at openlayers.org
Mon May 9 03:52:44 EDT 2011
Author: erilem
Date: 2011-05-09 00:52:39 -0700 (Mon, 09 May 2011)
New Revision: 11959
trunk/openlayers/lib/OpenLayers/Format/CSWGetRecords/v2_0_2.js
trunk/openlayers/tests/Format/CSWGetRecords/v2_0_2.html
trunk/openlayers/tests/Format/CSWGetRecords/v2_0_2.js
CSWGetRecords format additions for parsing GeoNetwork specific fields, p=fvanderbiest, r=bartvde,me (closes #2961)
Modified: trunk/openlayers/lib/OpenLayers/Format/CSWGetRecords/v2_0_2.js
--- trunk/openlayers/lib/OpenLayers/Format/CSWGetRecords/v2_0_2.js 2011-05-09 07:36:57 UTC (rev 11958)
+++ trunk/openlayers/lib/OpenLayers/Format/CSWGetRecords/v2_0_2.js 2011-05-09 07:52:39 UTC (rev 11959)
@@ -27,13 +27,14 @@
* {Object} Mapping of namespace aliases to namespace URIs.
namespaces: {
- xlink: "http://www.w3.org/1999/xlink",
- xsi: "http://www.w3.org/2001/XMLSchema-instance",
csw: "http://www.opengis.net/cat/csw/2.0.2",
dc: "http://purl.org/dc/elements/1.1/",
dct: "http://purl.org/dc/terms/",
+ geonet: "http://www.fao.org/geonetwork",
+ ogc: "http://www.opengis.net/ogc",
ows: "http://www.opengis.net/ows",
- ogc: "http://www.opengis.net/ogc"
+ xlink: "http://www.w3.org/1999/xlink",
+ xsi: "http://www.w3.org/2001/XMLSchema-instance"
@@ -233,8 +234,19 @@
var record = {type: "Record"};
this.readChildNodes(node, record);
obj.records.push(record);
+ "*": function(node, obj) {
+ var name = node.localName || node.nodeName.split(":").pop();
+ obj[name] = this.getChildValue(node);
+ "geonet": {
+ "info": function(node, obj) {
+ var gninfo = {};
+ this.readChildNodes(node, gninfo);
+ obj.gninfo = gninfo;
"dc": {
// audience, contributor, coverage, creator, date, description, format,
// identifier, language, provenance, publisher, relation, rights,
Modified: trunk/openlayers/tests/Format/CSWGetRecords/v2_0_2.html
--- trunk/openlayers/tests/Format/CSWGetRecords/v2_0_2.html 2011-05-09 07:36:57 UTC (rev 11958)
+++ trunk/openlayers/tests/Format/CSWGetRecords/v2_0_2.html 2011-05-09 07:52:39 UTC (rev 11959)
@@ -41,10 +41,10 @@
function test_read(t) {
- t.plan(14);
+ t.plan(16);
var obj = format.read(csw_response);
var searchStatus = obj.SearchStatus;
var searchResults = obj.SearchResults;
var records = obj.records;
@@ -72,6 +72,10 @@
t.eq(bbox.crs, "::Lambert Azimuthal Projection", "check value for BoundingBox.crs");
t.eq(bbox.value, [156, -3, 37, 83], "check value for record.BoundingBox");
+ // test gninfo
+ testRecord = records[1];
+ t.ok(testRecord.gninfo, "object contains gninfo properties");
+ t.eq(testRecord.gninfo.schema, "iso19139", "check value for schema property in record.gninfo");
</script>
Modified: trunk/openlayers/tests/Format/CSWGetRecords/v2_0_2.js
--- trunk/openlayers/tests/Format/CSWGetRecords/v2_0_2.js 2011-05-09 07:36:57 UTC (rev 11958)
+++ trunk/openlayers/tests/Format/CSWGetRecords/v2_0_2.js 2011-05-09 07:52:39 UTC (rev 11959)
@@ -37,6 +37,10 @@
'<ows:LowerCorner>51.1 -34.6</ows:LowerCorner>' +
'<ows:UpperCorner>-17.3 38.2</ows:UpperCorner>' +
'</ows:BoundingBox>' +
+ '<geonet:info xmlns:gmd="http://www.isotc211.org/2005/gmd" xmlns:gco="http://www.isotc211.org/2005/gco" xmlns:gts="http://www.isotc211.org/2005/gts" xmlns:gml="http://www.opengis.net/gml">' +
+ '<id>859</id>' +
+ '<schema>iso19139</schema>' +
+ '</geonet:info>' +
'</csw:BriefRecord>' +
'</csw:SearchResults>' +
'</csw:GetRecordsResponse>'
More information about the Commits
