[OpenLayers-Commits] r11988 - in sandbox/ahocevar/google-ng:
examples lib lib/OpenLayers/Layer lib/OpenLayers/Tile theme/default
commits-20090109 at openlayers.org
Sun May 22 16:14:30 EDT 2011
Author: ahocevar
Date: 2011-05-22 13:14:29 -0700 (Sun, 22 May 2011)
New Revision: 11988
Added:
sandbox/ahocevar/google-ng/examples/google-ng.html
sandbox/ahocevar/google-ng/examples/google-ng.js
sandbox/ahocevar/google-ng/lib/OpenLayers/Layer/GoogleNG.js
sandbox/ahocevar/google-ng/lib/OpenLayers/Tile/Google.js
sandbox/ahocevar/google-ng/lib/OpenLayers.js
sandbox/ahocevar/google-ng/theme/default/style.css
Layer.GoogleNG and Tile.Google using the GMaps v3 API's getTile method to load tiles into the OpenLayers tile grid
Added: sandbox/ahocevar/google-ng/examples/google-ng.html
--- sandbox/ahocevar/google-ng/examples/google-ng.html (rev 0)
+++ sandbox/ahocevar/google-ng/examples/google-ng.html 2011-05-22 20:14:29 UTC (rev 11988)
@@ -0,0 +1,42 @@
+<!DOCTYPE html>
+<html>
+ <head>
+ <meta name="viewport" content="width=device-width; initial-scale=1.0; maximum-scale=1.0; user-scalable=0;" />
+ <meta name="apple-mobile-web-app-capable" content="yes" />
+ <title>OpenLayers Google NG Layer Example</title>
+ <link rel="stylesheet" href="../theme/default/style.css" type="text/css">
+ <link rel="stylesheet" href="../theme/default/google.css" type="text/css">
+ <link rel="stylesheet" href="style.css" type="text/css">
+ <style type="text/css">
+ .olControlAttribution {
+ left: 5px;
+ right: inherit;
+ bottom: 5px;
+ </style>
+ <script src="http://maps.google.com/maps/api/js?v=3.5&sensor=false"></script>
+ <script src="../lib/OpenLayers.js"></script>
+ <script src="google-ng.js"></script>
+ </head>
+ <body onload="init()">
+ <h1 id="title">Google NG Layer Example</h1>
+ <div id="tags">
+ Google, api key, apikey
+ </div>
+ <p id="shortdesc">
+ Demonstrate use of tiles from the Google Maps v3 API.
+ </p>
+ <div id="map" class="smallmap"></div>
+ <div id="docs">
+ <p>
+ If you use OpenLayers.Layer.GoogleNG, the getTile method of the
+ GMaps v3 API's MapType is used to load tiles. This allows for
+ better integration than interacting with a whole map generated
+ by a google.maps.Map instance, as done with
+ OpenLayers.Layer.Google. See the
+ <a href="google-v3.js" target="_blank">google-ng.js source</a>
+ to see how this is done.
+ </p>
+ </div>
+ </body>
+</html>
Added: sandbox/ahocevar/google-ng/examples/google-ng.js
--- sandbox/ahocevar/google-ng/examples/google-ng.js (rev 0)
+++ sandbox/ahocevar/google-ng/examples/google-ng.js 2011-05-22 20:14:29 UTC (rev 11988)
@@ -0,0 +1,28 @@
+var map;
+function init() {
+ map = new OpenLayers.Map('map');
+ map.addControl(new OpenLayers.Control.LayerSwitcher());
+ var gphy = new OpenLayers.Layer.GoogleNG(
+ {type: google.maps.MapTypeId.TERRAIN}
+ var gmap = new OpenLayers.Layer.GoogleNG(
+ // ROADMAP, the default
+ var ghyb = new OpenLayers.Layer.GoogleNG(
+ {type: google.maps.MapTypeId.HYBRID}
+ var gsat = new OpenLayers.Layer.GoogleNG(
+ {type: google.maps.MapTypeId.SATELLITE}
+ map.addLayers([gphy, gmap, ghyb, gsat]);
+ // Google.v3 uses EPSG:900913 as projection, so we have to
+ // transform our coordinates
+ map.setCenter(new OpenLayers.LonLat(10.2, 48.9).transform(
+ new OpenLayers.Projection("EPSG:4326"),
+ map.getProjectionObject()
+ ), 5);
Added: sandbox/ahocevar/google-ng/lib/OpenLayers/Layer/GoogleNG.js
--- sandbox/ahocevar/google-ng/lib/OpenLayers/Layer/GoogleNG.js (rev 0)
+++ sandbox/ahocevar/google-ng/lib/OpenLayers/Layer/GoogleNG.js 2011-05-22 20:14:29 UTC (rev 11988)
@@ -0,0 +1,230 @@
+/* Copyright (c) 2006-2011 by OpenLayers Contributors (see authors.txt for
+ * full list of contributors). Published under the Clear BSD license.
+ * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * @requires OpenLayers/Layer/XYZ.js
+ * Class: OpenLayers.Layer.GoogleNG
+ * Google layer using <OpenLayers.Tile.Google> tiles.
+ * Inherits from:
+ * - <OpenLayers.Layer.XYZ>
+OpenLayers.Layer.GoogleNG = OpenLayers.Class(OpenLayers.Layer.XYZ, {
+ * Property: SUPPORTED_TRANSITIONS
+ * {Array} An immutable (that means don't change it!) list of supported
+ * transitionEffect values. This layer type supports none.
+ SUPPORTED_TRANSITIONS: [],
+ * Property: attributionTemplate
+ * {String}
+ attributionTemplate: '<span class="olGoogleAttribution ${mapType}">' +
+ '<div><a target="_blank" href="http://maps.google.com/maps?' +
+ 'll=${center}&z=${zoom}&t=${t}"><img width="62" height="24" ' +
+ 'src="http://maps.gstatic.com/mapfiles/google_white.png"/></a>' +
+ '</div><a style="white-space: nowrap" target="_blank" ' +
+ 'href="http://maps.google.com/maps/api/staticmap?sensor=true' +
+ '¢er=${center}&zoom=${zoom}&size=${size}&maptype=${mapType}">' +
+ 'Map data</a> - <a style="white-space: nowrap" target="_blank" ' +
+ 'href="http://www.google.com/help/terms_maps.html">' +
+ 'Terms of Use</a></span>',
+ * Property: mapTypes
+ * {Object} mapping of {google.maps.MapTypeId} to the t param of
+ * http://maps.google.com/maps? permalinks
+ mapTypes: {
+ "roadmap": "m",
+ "satellite": "k",
+ "hybrid": "h",
+ "terrain": "p"
+ * Property: mapObject
+ * {google.maps.Map} Shared GMaps instance - will be set on the prototype
+ * upon instantiation of the 1st GoogleNG layer
+ mapObject: null,
+ * APIProperty: type
+ * {google.maps.MapTypeId} See
+ * http://code.google.com/apis/maps/documentation/javascript/reference.html#MapTypeId
+ type: null,
+ * Constructor: OpenLayers.Layer.GoogleNG
+ * Create a new GoogleNG layer. Requires the GMaps v3 JavaScript API script
+ * included in the html document.
+ * Example:
+ * (code)
+ * var terrain = new OpenLayers.Layer.GoogleNG({
+ * name: "Google Terrain",
+ * type: google.maps.MapTypeId.TERRAIN
+ * (end)
+ * Parameters:
+ * config - {Object} Configuration properties for the layer.
+ * Required configuration properties:
+ * type - {String} The layer identifier. See
+ * for valid types.
+ * Any other documented layer properties can be provided in the config object.
+ initialize: function(options) {
+ if (!this.mapObject) {
+ OpenLayers.Layer.GoogleNG.prototype.mapObject =
+ new google.maps.Map(document.createElement("div"));
+ google.maps.event.addListenerOnce(
+ this.mapObject,
+ "idle",
+ OpenLayers.Function.bind(this.initLayer, this)
+ options = OpenLayers.Util.applyDefaults({
+ sphericalMercator: true
+ }, options);
+ if (!options.type) {
+ options.type = google.maps.MapTypeId.ROADMAP;
+ var newArgs = [options.name, null, options];
+ OpenLayers.Layer.XYZ.prototype.initialize.apply(this, newArgs);
+ * Method: initLayer
+ * Sets layer properties according to the metadata provided by the API
+ initLayer: function() {
+ var mapType = this.mapObject.mapTypes[this.type];
+ if (!this.name) {
+ this.setName("Google " + mapType.name);
+ var numZoomLevels = mapType.maxZoom + 1;
+ if (this.numZoomLevels) {
+ numZoomLevels = Math.min(numZoomLevels, this.numZoomLevels);
+ var restrictedMinZoom = mapType.minZoom;
+ if (this.restrictedMinZoom) {
+ restrictedMinZoom = Math.max(
+ restrictedMinZoom, options.restrictedMinZoom
+ this.addOptions({
+ restrictedMinZoom: mapType.minZoom,
+ numZoomLevels: numZoomLevels,
+ tileSize: new OpenLayers.Size(
+ mapType.tileSize.width, mapType.tileSize.height
+ // redraw to populate tiles with content
+ this.redraw();
+ * APIMethod: addTile
+ * Create a tile, initialize it, and add it to the layer div.
+ * Parameters
+ * bounds - {<OpenLayers.Bounds>}
+ * position - {<OpenLayers.Pixel>}
+ * Returns:
+ * {<OpenLayers.Tile.Goolge>} The added OpenLayers.Tile.Google
+ addTile:function(bounds, position) {
+ return new OpenLayers.Tile.Google(this, position, bounds, null,
+ this.tileSize, this.tileOptions);
+ * Method: updateAttribution
+ * Updates the attribution using the <attributionTemplate>
+ updateAttribution: function() {
+ var center = this.map.getCenter();
+ center && center.transform(
+ this.map.getProjectionObject(),
+ var size = this.map.getSize();
+ this.attribution = OpenLayers.String.format(this.attributionTemplate, {
+ center: center ? center.lat + "," + center.lon : "",
+ zoom: this.map.getZoom(),
+ size: size.w + "x" + size.h,
+ t: this.mapTypes[this.type],
+ mapType: this.type
+ this.map && this.map.events.triggerEvent("changelayer", {layer: this});
+ * Method: setMap
+ setMap: function() {
+ OpenLayers.Layer.XYZ.prototype.setMap.apply(this, arguments);
+ this.updateAttribution();
+ this.map.events.register("moveend", this, this.updateAttribution);
+ * Method: removeMap
+ removeMap: function() {
+ OpenLayers.Layer.XYZ.prototype.removeMap.apply(this, arguments);
+ this.map.events.unregister("moveend", this, this.updateAttribution);
+ * APIMethod: clone
+ * Parameters:
+ * obj - {Object}
+ * Returns:
+ * {<OpenLayers.Layer.GoogleNG>} An exact clone of this
+ * <OpenLayers.Layer.GoogleNG>
+ clone: function(obj) {
+ if (obj == null) {
+ obj = new OpenLayers.Layer.GoogleNG(this.options);
+ //get all additions from superclasses
+ obj = OpenLayers.Layer.XYZ.prototype.clone.apply(this, [obj]);
+ // copy/set any non-init, non-simple values here
+ return obj;
+ * Method: destroy
+ destroy: function() {
+ this.map &&
+ OpenLayers.Layer.XYZ.prototype.destroy.apply(this, arguments);
+ CLASS_NAME: "OpenLayers.Layer.GoogleNG"
\ No newline at end of file
Added: sandbox/ahocevar/google-ng/lib/OpenLayers/Tile/Google.js
--- sandbox/ahocevar/google-ng/lib/OpenLayers/Tile/Google.js (rev 0)
+++ sandbox/ahocevar/google-ng/lib/OpenLayers/Tile/Google.js 2011-05-22 20:14:29 UTC (rev 11988)
@@ -0,0 +1,141 @@
+ * @requires OpenLayers/BaseTypes/Class.js
+ * @requires OpenLayers/Util.js
+ * @requires OpenLayers/Console.js
+ * @requires OpenLayers/Lang.js
+ * Class: OpenLayers.Tile.Google
+ * Instances of OpenLayers.Tile.Google are used to manage the tiles created
+ * by google.maps.MapType (see
+ * http://code.google.com/apis/maps/documentation/javascript/reference.html#MapType).
+ * Inherits from:
+ * - <OpenLayers.Tile>
+OpenLayers.Tile.Google = OpenLayers.Class(OpenLayers.Tile, {
+ * Property: node
+ * {DOMElement} The tile node from the MapType's getTile method
+ node: false,
+ /** TBD 3.0 -- remove 'url' from the list of parameters to the constructor.
+ * there is no need for the base tile class to have a url.
+ * Constructor: OpenLayers.Tile.Google
+ * Constructor for a new <OpenLayers.Tile.Google> instance.
+ * Parameters:
+ * layer - {<OpenLayers.Layer>} layer that the tile will go in.
+ * url - {<String>}
+ * size - {<OpenLayers.Size>}
+ * options - {Object}
+ initialize: function(layer, position, bounds, url, size, options) {
+ OpenLayers.Tile.prototype.initialize.apply(this, arguments);
+ * APIMethod: destroy
+ * Nullify references to prevent circular references and memory leaks.
+ destroy:function() {
+ this.node && this.clear();
+ OpenLayers.Tile.prototype.destroy.apply(this, arguments);
+ * Method: clone
+ * Parameters:
+ * obj - {<OpenLayers.Tile>} The tile to be cloned
+ * Returns:
+ * {<OpenLayers.Tile>} An exact clone of this <OpenLayers.Tile.Google>
+ clone: function (obj) {
+ obj = new OpenLayers.Tile.Google(this.layer,
+ this.position,
+ this.bounds,
+ this.url,
+ this.size);
+ // catch any randomly tagged-on properties
+ OpenLayers.Util.applyDefaults(obj, this);
+ return obj;
+ * Method: draw
+ * Check that a tile should be drawn, and draw it.
+ * Returns:
+ * {Boolean} Always returns true.
+ draw: function() {
+ var layerType = this.layer.mapObject.mapTypes[this.layer.type];
+ if (layerType && OpenLayers.Tile.prototype.draw.apply(this, arguments)) {
+ var xyz = this.layer.getXYZ(this.bounds);
+ var point = new google.maps.Point(xyz.x, xyz.y);
+ // The hybrid tile consists of two images. For some reason, we have
+ // to make sure that the satellite image loads first, otherwise we
+ // occasionally get blank tiles for one of the two images. This is
+ // done by requesting the tile for just the satellite mapType
+ // first, before requesting the hybrid one.
+ //TODO revisit this - it may be a temporary issue with GMaps
+ if (this.layer.type === google.maps.MapTypeId.HYBRID) {
+ layerType.getTile(point, xyz.z, document);
+ this.node = layerType.getTile(point, xyz.z, document);
+ this.isLoading = true;
+ this.events.triggerEvent("loadstart");
+ this.layer.div.appendChild(this.node);
+ OpenLayers.Util.modifyDOMElement(
+ this.node, null, this.position, null, "absolute"
+ // The images inside the node returned from getTile seem to be
+ // prelaoded already, so registering onload events on these images
+ // won't work. Instead, we trigger the loadend event immediately
+ // in the next cycle.
+ window.setTimeout(OpenLayers.Function.bind(function() {
+ this.isLoading = false;
+ this.events.triggerEvent("loadend");
+ }, this), 0);
+ return true;
+ * Method: clear
+ * Clear the tile of any bounds/position-related data so that it can
+ * be reused in a new location. To be implemented by subclasses.
+ clear: function() {
+ if (this.node) {
+ this.node.parentNode &&
+ this.node.parentNode.removeChild(this.node);
+ this.layer.mapObject.mapTypes[this.layer.type].releaseTile(this.node);
+ CLASS_NAME: "OpenLayers.Tile.Google"
Modified: sandbox/ahocevar/google-ng/lib/OpenLayers.js
--- sandbox/ahocevar/google-ng/lib/OpenLayers.js 2011-05-22 20:12:12 UTC (rev 11987)
+++ sandbox/ahocevar/google-ng/lib/OpenLayers.js 2011-05-22 20:14:29 UTC (rev 11988)
@@ -120,6 +120,7 @@
"OpenLayers/Marker/Box.js",
"OpenLayers/Popup.js",
"OpenLayers/Tile.js",
+ "OpenLayers/Tile/Google.js",
"OpenLayers/Tile/Image.js",
"OpenLayers/Tile/Image/IFrame.js",
"OpenLayers/Tile/WFS.js",
@@ -152,6 +153,7 @@
"OpenLayers/Layer/Boxes.js",
"OpenLayers/Layer/XYZ.js",
"OpenLayers/Layer/Bing.js",
+ "OpenLayers/Layer/GoogleNG.js",
"OpenLayers/Layer/TMS.js",
"OpenLayers/Layer/TileCache.js",
"OpenLayers/Layer/Zoomify.js",
Modified: sandbox/ahocevar/google-ng/theme/default/style.css
--- sandbox/ahocevar/google-ng/theme/default/style.css 2011-05-22 20:12:12 UTC (rev 11987)
+++ sandbox/ahocevar/google-ng/theme/default/style.css 2011-05-22 20:14:29 UTC (rev 11988)
@@ -355,6 +355,19 @@
color: #333;
+.olGoogleAttribution.hybrid, .olGoogleAttribution.satellite {
+ color: #DDD;
+.olGoogleAttribution {
+ color: #333;
+span.olGoogleAttribution a {
+ color: #77C;
+span.olGoogleAttribution.hybrid a, span.olGoogleAttribution.satellite a {
+ color: white;
* Editing and navigation icons.
* (using the editing_tool_bar.png sprint image)
More information about the Commits
