[OpenLayers-Commits] r12008 -
sandbox/bartvde/wps/openlayers/tests/Format
commits-20090109 at openlayers.org
Wed May 25 12:01:00 EDT 2011
Author: bartvde
Date: 2011-05-25 09:00:59 -0700 (Wed, 25 May 2011)
New Revision: 12008
sandbox/bartvde/wps/openlayers/tests/Format/WPSExecute.html
added new testcase, implementation still needs to be done
Modified: sandbox/bartvde/wps/openlayers/tests/Format/WPSExecute.html
--- sandbox/bartvde/wps/openlayers/tests/Format/WPSExecute.html 2011-05-25 15:24:08 UTC (rev 12007)
+++ sandbox/bartvde/wps/openlayers/tests/Format/WPSExecute.html 2011-05-25 16:00:59 UTC (rev 12008)
@@ -306,6 +306,61 @@
t.xml_eq(result, expected, "WPS Execute written out correctly");
+ function test_request_embedded_complex_data_input(t) {
+ t.plan(1);
+ // taken from http://geoprocessing.info/schemas/wps/1.0/examples/53_wpsExecute_request_ComplexValue.xml
+ var expected = '<?xml version="1.0" encoding="UTF-8" standalone="yes"?>' +
+'<wps:Execute service="WPS" version="1.0.0" xmlns:wps="http://www.opengis.net/wps/1.0.0" xmlns:ows="http://www.opengis.net/ows/1.1" ' +
+'xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wps/1.0.0' +
+' http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd">' +
+' <ows:Identifier>Reclassification</ows:Identifier>' +
+' <wps:DataInputs>' +
+' <wps:Input>' +
+' <ows:Identifier>InputLayer</ows:Identifier>' +
+' <ows:Title>The layer which\'s values shall be reclassified</ows:Title>' +
+' <wps:Reference xlink:href="http://orchestra.pisa.intecs.it/geoserver/test/height.tif" method="GET"/>' +
+' </wps:Input>' +
+' <wps:Input>' +
+' <ows:Identifier>BufferDistance</ows:Identifier>' +
+' <ows:Title>Distance which people will walk to get to a playground.</ows:Title>' +
+' <wps:Data>' +
+' <wps:ComplexData>' +
+' <RangeToValueMappings xmlns="http://mas.orchestra.jrc.it" xmlns:ows="http://www.opengeospatial.net/ows" ' +
+'xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">' +
+' <Mapping>' +
+' <ows:Range ows:rangeClosure="closed-open">' +
+' <ows:MinimumValue>0</ows:MinimumValue>' +
+' <ows:MaximumValue>119</ows:MaximumValue>' +
+' </ows:Range>' +
+' <ows:Value>A</ows:Value>' +
+' </Mapping>' +
+' <Mapping>' +
+' <ows:MinimumValue>120</ows:MinimumValue>' +
+' <ows:MaximumValue/>' +
+' </ows:Range>' +
+' <ows:Value>B</ows:Value>' +
+' </Mapping>' +
+' </RangeToValueMappings>' +
+' </wps:ComplexData>' +
+' </wps:Data>' +
+' </wps:Input>' +
+' </wps:DataInputs>' +
+' <wps:ResponseForm>' +
+' <wps:ResponseDocument storeExecuteResponse="true" lineage="true" status="true">' +
+' <wps:Output asReference="true">' +
+' <ows:Identifier>Outlayer</ows:Identifier>' +
+' <ows:Title>Reclassified Layer.</ows:Title>' +
+' <ows:Abstract>Layer classified into two classes, where class A is less than or equal 120 and class B is more than 120.</ows:Abstract>' +
+' </wps:Output>' +
+' </wps:ResponseDocument>' +
+' </wps:ResponseForm>' +
+'</wps:Execute>';
+ t.ok(true, "TODO");
</script>
</head>
<body>
More information about the Commits
