[OpenLayers-Commits] r12028 - sandbox/ahocevar/google-ng/tests/Layer
commits-20090109 at openlayers.org
Sat May 28 06:32:42 EDT 2011
Author: ahocevar
Date: 2011-05-28 03:32:42 -0700 (Sat, 28 May 2011)
New Revision: 12028
sandbox/ahocevar/google-ng/tests/Layer/GoogleNG.html
adding tests
Modified: sandbox/ahocevar/google-ng/tests/Layer/GoogleNG.html
--- sandbox/ahocevar/google-ng/tests/Layer/GoogleNG.html 2011-05-28 09:59:09 UTC (rev 12027)
+++ sandbox/ahocevar/google-ng/tests/Layer/GoogleNG.html 2011-05-28 10:32:42 UTC (rev 12028)
@@ -34,11 +34,11 @@
numZoomLevels: 24,
initLayer: function() {
log[layer2.id] = true;
- var origMinZoom = layer2.mapObject.mapTypes[layer2.type].minZoom;
+ var origMinZoom = OpenLayers.Layer.GoogleNG.mapObject.mapTypes[layer2.type].minZoom;
// pretend the API reports a minZoom of 1
- layer2.mapObject.mapTypes[layer2.type].minZoom = 1;
+ OpenLayers.Layer.GoogleNG.mapObject.mapTypes[layer2.type].minZoom = 1;
OpenLayers.Layer.GoogleNG.prototype.initLayer.apply(this, arguments);
- layer2.mapObject.mapTypes[layer2.type].minZoom = origMinZoom;
+ OpenLayers.Layer.GoogleNG.mapObject.mapTypes[layer2.type].minZoom = origMinZoom;
map2.addLayer(layer2);
@@ -49,7 +49,7 @@
t.eq(log[layer2.id], true, "initLayer called for 2nd layer");
t.eq(layer.numZoomLevels, 10, "numZoomLevels from configuration takes precedence if lower");
- t.eq(layer2.numZoomLevels, layer2.mapObject.mapTypes[layer2.type].maxZoom+1, "numZoomLevels from API takes precedence if lower");
+ t.eq(layer2.numZoomLevels, OpenLayers.Layer.GoogleNG.mapObject.mapTypes[layer2.type].maxZoom+1, "numZoomLevels from API takes precedence if lower");
t.eq(layer.restrictedMinZoom, 2, "restrictedMinZoom from configuration takes precedence if higher");
t.eq(layer2.restrictedMinZoom, 1, "restrictedMinZoom from API takes precedence if higher");
@@ -60,18 +60,25 @@
function test_attribution(t) {
- t.plan(3);
+ t.plan(4);
var log = [];
map = new OpenLayers.Map("map");
- layer = new OpenLayers.Layer.GoogleNG({type: google.maps.MapTypeId.HYBRID});
+ layer = new OpenLayers.Layer.GoogleNG({
+ type: google.maps.MapTypeId.HYBRID,
+ updateAttribution: function(copyrights) {
+ log.push(copyrights);
+ OpenLayers.Layer.GoogleNG.prototype.updateAttribution.apply(this, arguments);
map.addLayer(layer);
- map.zoomToMaxExtent();
+ map.setCenter(new OpenLayers.LonLat(16, 48).transform(new OpenLayers.Projection("EPSG:4326"), map.getProjectionObject()), 5);
- t.delay_call(1, function() {
- t.ok(layer.attribution.indexOf('olGoogleAttribution hybrid') !== -1, "Attribution has the correct css class");
- t.ok(layer.attribution.indexOf('?ll=0,0&z=0&t=h"') != -1, "maps.google.com link has correct parameters");
- t.ok(layer.attribution.indexOf('¢er=0,0&zoom=0&size=500x550&maptype=hybrid') != -1 , "Attribution has correct map data link");
+ t.delay_call(3, function() {
+ t.eq(log.length, 1, "updateAttribution was called once");
+ t.ok(log[0]["m"].length && log[0]["k"].length, "'m' and 'k' copyrights populated for hybrid layer");
+ t.ok(layer.attribution.indexOf('olGoogleAttribution hybrid') != -1, "Attribution has the correct css class");
+ t.ok(layer.attribution.indexOf('?ll=48,16&z=5&t=h"') != -1, "maps.google.com link has correct parameters");
map.destroy();
More information about the Commits
