[OpenLayers-Commits] r12310 -
sandbox/camptocamp/clientzoom/tests/Layer
commits-20090109 at openlayers.org
Thu Sep 1 03:14:44 EDT 2011
Author: erilem
Date: 2011-09-01 00:14:43 -0700 (Thu, 01 Sep 2011)
New Revision: 12310
sandbox/camptocamp/clientzoom/tests/Layer/Grid.html
better tests for Grid.transformDiv
Modified: sandbox/camptocamp/clientzoom/tests/Layer/Grid.html
--- sandbox/camptocamp/clientzoom/tests/Layer/Grid.html 2011-08-31 20:17:35 UTC (rev 12309)
+++ sandbox/camptocamp/clientzoom/tests/Layer/Grid.html 2011-09-01 07:14:43 UTC (rev 12310)
@@ -704,25 +704,39 @@
function test_transformDiv(t) {
- t.plan(6);
+ t.plan(8);
- var map = new OpenLayers.Map('map');
+ var map = new OpenLayers.Map('map4');
var layer = new OpenLayers.Layer.WMS('', '', {}, {
isBaseLayer: true
map.addLayer(layer);
map.zoomToMaxExtent();
- var tile = layer.grid[1][1];
- t.eq(tile.frame.style.left, '122%', 'tile (1,1) expected left');
- t.eq(tile.frame.style.top, '83%', 'tile (1, 1) expected top');
+ // the layer container's dimensions are 100px width 100px height
+ // the position of the viewport center is 384, 256
- layer.transformDiv(1.5);
- t.eq(layer.div.style.width, '150%', 'layer div has correct width');
- t.eq(layer.div.style.height, '150%', 'layer div has correct height');
- t.eq(layer.div.style.left, '-124.75%', 'layer div has correct left');
- t.eq(layer.div.style.top, '-137.25%', 'layer div has correct top');
+ layer.transformDiv(2);
+ t.eq(layer.div.style.width, '200%', '[1] layer div has correct width');
+ t.eq(layer.div.style.height, '200%', '[1] layer div has correct height');
+ t.eq(layer.div.style.left, '-384%', '[1] layer div has correct left');
+ t.eq(layer.div.style.top, '-256%', '[1] layer div has correct top');
+ // now move the layer container and test again
+ map.layerContainerDiv.style.left = '-1024px';
+ map.layerContainerDiv.style.top = '768px';
+ t.eq(layer.div.style.width, '200%', '[2] layer div has correct width');
+ t.eq(layer.div.style.height, '200%', '[2] layer div has correct height');
+ t.eq(layer.div.style.left, '-1408%', '[2] layer div has correct left');
+ t.eq(layer.div.style.top, '512%', '[2] layer div has correct top');
map.destroy();
@@ -732,5 +746,6 @@
<div id="map" style="width:499px;height:549px;display:none"></div>
<div id="map2" style="width:500px;height:550px;display:none"></div>
<div id="map3" style="width:594px;height:464px;display:none"></div>
+<div id="map4" style="width:768px;height:512px;display:none"></div>
</body>
</html>
More information about the Commits
