[OpenLayers-Commits] r12345 - in
sandbox/mpriour/temporal_map/openlayers: examples
lib/OpenLayers lib/OpenLayers/Control lib/OpenLayers/TimeHandler
commits-20090109 at openlayers.org
Thu Sep 8 06:15:50 EDT 2011
Author: mpriour
Date: 2011-09-08 03:15:49 -0700 (Thu, 08 Sep 2011)
New Revision: 12345
sandbox/mpriour/temporal_map/openlayers/examples/time-control.html
sandbox/mpriour/temporal_map/openlayers/examples/wmst.html
sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/TimeManager.js
sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/TimeHandler.js
sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/TimeHandler/WMS.js
- Create more complex time-control.html example with multiple temporal layers.
- Modify TimeManager.js & the TimeHandlers classes to better deal with this level of complexity
- Modify TimeManager.js to handle when it's child time handlers are not ready to tick forward. Control checks for 2 full frameRate cycles (2 x seconds/tick) at 1/4 framerate cycle intervals (0.25 * seconds/tick). After 8 checks, it gives up and fires the tick event anyway due to time constraints. This yeilds reasonable smoothness with waiting forever.
Modified: sandbox/mpriour/temporal_map/openlayers/examples/time-control.html
--- sandbox/mpriour/temporal_map/openlayers/examples/time-control.html 2011-09-08 10:08:35 UTC (rev 12344)
+++ sandbox/mpriour/temporal_map/openlayers/examples/time-control.html 2011-09-08 10:15:49 UTC (rev 12345)
@@ -18,67 +18,116 @@
<script type="text/javascript">
var map, pts_wms, line_wms, radii_wms, osm;
function init(){
- map = new OpenLayers.Map('map',{allOverlays:false});
+ osm = new OpenLayers.Layer.OSM();
+ map = new OpenLayers.Map('map', {
+ allOverlays: false,
+ projection: 'EPSG:900913',
+ maxExtent: osm.maxExtent.clone(),
+ maxResolution: osm.maxResolution
+ startTime = OpenLayers.Date.parse('2011-08-17T12:00:00.000Z').toISOString();
- osm = new OpenLayers.Layer.OSM();
pts_wms = new OpenLayers.Layer.WMS("Irene Centroid",
"http://mapstory.demo.opengeo.org:8080/geoserver/wms", {
- layers: "irene_11_pts,irene_11_radii",
+ layers: "irene_11_pts",
transparent: true,
format: 'image/png',
- time:OpenLayers.Date.toISOString(OpenLayers.Date.parse('2011-08-17T12:00:00Z')),
- srs:'EPSG:900913'
+ srs:'EPSG:900913',
+ time:startTime
metadata: {
timeInterval:
- [OpenLayers.Date.parse('2011-08-17T12:00:00Z'), OpenLayers.Date.parse('2011-08-29T00:00:00Z')]
+ ['2011-08-17T12:00:00.000Z','2011-08-17T18:00:00.000Z','2011-08-18T00:00:00.000Z',
+ '2011-08-18T06:00:00.000Z','2011-08-18T12:00:00.000Z','2011-08-18T18:00:00.000Z',
+ '2011-08-19T00:00:00.000Z','2011-08-19T06:00:00.000Z','2011-08-19T12:00:00.000Z',
+ '2011-08-19T18:00:00.000Z','2011-08-20T00:00:00.000Z','2011-08-20T06:00:00.000Z',
+ '2011-08-20T12:00:00.000Z','2011-08-20T18:00:00.000Z','2011-08-21T00:00:00.000Z',
+ '2011-08-21T06:00:00.000Z','2011-08-21T12:00:00.000Z','2011-08-21T18:00:00.000Z',
+ '2011-08-22T00:00:00.000Z','2011-08-22T06:00:00.000Z','2011-08-22T12:00:00.000Z',
+ '2011-08-22T18:00:00.000Z','2011-08-23T00:00:00.000Z','2011-08-23T06:00:00.000Z',
+ '2011-08-23T12:00:00.000Z','2011-08-23T18:00:00.000Z','2011-08-24T00:00:00.000Z',
+ '2011-08-24T06:00:00.000Z','2011-08-24T12:00:00.000Z','2011-08-24T18:00:00.000Z',
+ '2011-08-25T00:00:00.000Z','2011-08-25T06:00:00.000Z','2011-08-25T12:00:00.000Z',
+ '2011-08-25T18:00:00.000Z','2011-08-26T00:00:00.000Z','2011-08-26T06:00:00.000Z',
+ '2011-08-26T12:00:00.000Z','2011-08-26T18:00:00.000Z','2011-08-27T00:00:00.000Z',
+ '2011-08-27T06:00:00.000Z','2011-08-27T12:00:00.000Z','2011-08-27T18:00:00.000Z',
+ '2011-08-28T00:00:00.000Z','2011-08-28T06:00:00.000Z','2011-08-28T12:00:00.000Z',
+ '2011-08-28T18:00:00.000Z','2011-08-29T00:00:00.000Z']
- singleTile:true,
- ratio:1,
- transitionEffect:'resize',
- visibility:true,
- projection:'EPSG:900913',
- maxExtent:osm.maxExtent.clone(),
- maxResolution:osm.maxResolution
+ singleTile:true,
+ ratio:1,
+ transitionEffect:'resize',
+ visibility:true
+ radii_wms = new OpenLayers.Layer.WMS("Irene Storm Winds", "http://mapstory.demo.opengeo.org:8080/geoserver/wms", {
+ layers: "irene_11_radii",
+ transparent: true,
+ format: 'image/png',
+ srs: 'EPSG:900913',
+ time:startTime
+ metadata: {
+ timeInterval: ['2011-08-17T12:00:00.000Z', '2011-08-29T00:00:00.000Z']
+ singleTile: true,
+ ratio: 1,
+ transitionEffect: 'resize',
+ visibility: true
+ ia_wms = new OpenLayers.Layer.WMS("Nexrad", "http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r-t.cgi?", {
+ layers: "nexrad-n0r-wmst",
+ time:startTime
+ metadata: {
+ singleTile: true,
+ ratio: 1,
+ visibility: true
+ line_wms = new OpenLayers.Layer.WMS("Irene Storm Track", "http://mapstory.demo.opengeo.org:8080/geoserver/wms", {
+ layers: "irene_11_lin",
+ singleTile: true,
+ ratio: 1,
+ visibility: true
- line_wms = new OpenLayers.Layer.WMS("Irene Storm Track",
- "http://mapstory.demo.opengeo.org:8080/geoserver/wms", {
- layers: "irene_11_lin",
- transparent: true,
- format: 'image/png',
- srs:'EPSG:900913'
- singleTile:true,
- ratio:1,
- visibility:true,
+ timeCtl = new OpenLayers.Control.TimeManager({
+ units:OpenLayers.TimeUnit.HOURS,
+ step:6,
+ frameRate:1.2,
+ handlerOptions:{
+ WMS:{intervalMode:'exact'}
- timeCtl = new OpenLayers.Control.TimeManager({
- units:OpenLayers.TimeUnit.HOURS,
- step:6,
- frameRate:1.3
- timeCtl.events.on({
- 'tick': update_date,
- 'reset': update_date,
- 'stop':timeCtl.reset,
- scope: timeCtl
+ timeCtl.events.on({
+ 'tick': update_date,
+ 'reset': update_date,
+ 'stop': function(evt){if (evt.rangeExceeded) timeCtl.reset()},
+ scope: timeCtl
- map.addControls([timeCtl,new OpenLayers.Control.LayerSwitcher()]);
- map.addLayers([osm,line_wms, pts_wms]);
- map.zoomToExtent(new OpenLayers.Bounds(-8627260.535278,1425478.519205,-3729202.941056,5496444.989113));
- update_date({
- object: timeCtl,
- currentTime: timeCtl.currentTime
+ map.addControls([timeCtl,new OpenLayers.Control.LayerSwitcher()]);
+ map.addLayers([osm,ia_wms,line_wms,pts_wms,radii_wms]);
+ map.zoomToExtent(new OpenLayers.Bounds(-8627260.535278,1425478.519205,-3729202.941056,5496444.989113));
+ update_date({
+ object: timeCtl,
+ currentTime: timeCtl.currentTime
function update_date(evt) {
var time = this.currentTime||evt.currentTime;
OpenLayers.Util.getElement('timestamp').innerHTML = time.toString();
Modified: sandbox/mpriour/temporal_map/openlayers/examples/wmst.html
--- sandbox/mpriour/temporal_map/openlayers/examples/wmst.html 2011-09-08 10:08:35 UTC (rev 12344)
+++ sandbox/mpriour/temporal_map/openlayers/examples/wmst.html 2011-09-08 10:15:49 UTC (rev 12345)
@@ -14,7 +14,8 @@
step: 5,
- units: OpenLayers.TimeUnit.MINUTES
+ units: OpenLayers.TimeUnit.MINUTES,
+ frameRate:1.5
map = new OpenLayers.Map('map');
map.addControl(timeCtl);
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/TimeManager.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/TimeManager.js 2011-09-08 10:08:35 UTC (rev 12344)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/TimeManager.js 2011-09-08 10:15:49 UTC (rev 12345)
@@ -136,7 +136,7 @@
var interval = this.intervals[i];
if(!(interval[i] instanceof Date))this.intervals[i]=OpenLayers.Date.parse(interval);
- this.intervals.sort(function(a,b){return b-a});
+ this.intervals.sort(function(a,b){return a-b});
this.range=[this.intervals[0],this.intervals[this.intervals.length-1]];
this.fixedIntervals=true;
}else if(this.range){
@@ -228,7 +228,10 @@
this.intervals || (this.intervals = []);
this.intervals = this.getUniqueDates(this.intervals.concat(lyrIntervals));
//adjust range as needed
- if(this.intervals[0]<this.range[0]||this.intervals[1]>this.range[1]){
+ if(!this.range){
+ this.setRange([this.intervals[0],this.intervals[this.intervals.length-1]])
+ else if(this.intervals[0]<this.range[0]||this.intervals[1]>this.range[1]){
this.setRange([Math.min(this.intervals[0],this.range[0]),Math.max(this.intervals[1],this.range[1])])
@@ -308,18 +311,19 @@
else {
- function canTickCheck(){
- var canTick = false;
- for (var i = 0, len = this.timeHandlers.length; i < len; i++) {
- canTick = this.timeHandlers[i].canTick;
- if (!canTick) break;
- return canTick;
- if (canTickCheck.call(this)) {
+ if (this.canTickCheck()) {
this.events.triggerEvent('tick', {currentTime: this.currentTime});
}else{
- //TODO: Handle not yet ready timeHandlers & don't tick until we're ready
+ var intervalId,checkCount = 0;
+ intervalId = setInterval(OpenLayers.Function.bind(function(){
+ var doTick = this.canTickCheck() || checkCount++ >= 8
+ if(checkCount>8){console.log('ADVANCED DUE TO TIME LIMIT')}
+ if (doTick) {
+ clearInterval(intervalId);
+ this.events.triggerEvent('tick', {currentTime: this.currentTime});
+ },this),1000/(this.frameRate*4))
@@ -476,10 +480,12 @@
//create subclassed time handlers
for(var k in layerTypes){
- var handler = new OpenLayers.TimeHandler[k]({
+ var handlerOpts = {
layers: layerTypes[k],
timeManager: this
+ if(this.handlerOptions&&this.handlerOptions[k]){OpenLayers.Util.applyDefaults(handlerOpts,this.handlerOptions[k])}
+ var handler = new OpenLayers.TimeHandler[k](handlerOpts);
this.events.on({
'tick': handler.onTick,
scope: handler
@@ -532,9 +538,7 @@
getUniqueDates:function(dates){
//sort the times
- dates.sort(function(a, b){
- return b - a;
+ dates.sort(function(a, b){return a - b;});
//filter for unique
dates = OpenLayers.Array.filter(dates, function(item, index, array){
for (var i = index + 1; i < array.length; i++) {
@@ -545,7 +549,15 @@
return true;
return dates
+ canTickCheck: function(){
+ var canTick = false;
+ for (var i = 0, len = this.timeHandlers.length; i < len; i++) {
+ canTick = this.timeHandlers[i].canTick;
+ if (!canTick) break;
+ return canTick;
CLASS_NAME:'OpenLayers.Control.TimeManager'
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/TimeHandler/WMS.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/TimeHandler/WMS.js 2011-09-08 10:08:35 UTC (rev 12344)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/TimeHandler/WMS.js 2011-09-08 10:15:49 UTC (rev 12345)
@@ -42,19 +42,62 @@
initialize:function(options){
OpenLayers.TimeHandler.prototype.initialize.call(this,options);
+ //add layer loadend listeners
+ if (this.layers) {
+ for (var i = 0, len = this.layers.length; i < len; i++) {
+ this.layers[i].events.on({
+ 'loadend': this.onLayerLoadEnd,
+ 'loadstart': this.onLayerLoadStart,
+ scope: this
+ addLayer:function(layer){
+ OpenLayers.TimeHandler.prototype.addLayer.call(this,layer);
+ layer.events.on({
+ scope: this
+ removeLayer:function(layer){
+ OpenLayers.TimeHandler.prototype.removeLayer.call(this,layer);
+ layer.events.un({
+ scope: this
+ destroy:function(){
+ this.layers[i].events.un({
+ scope: this
+ OpenLayers.TimeHandler.prototype.destroy.call(this);
onTick:function(evt){
this.currentTime = evt.currentTime || this.timeManager.currentTime;
- if(this.currentTime<=this.range[1] && this.currentTime>=this.range[0]){
- for(var i=0,len=this.layers.length;i<len;i++){
- this.applyTime(this.layers[i],this.currentTime);
- }else{
- layers[i].setVisibility(false);
+ console.log('CurrentTime:'+this.currentTime.toTimeString());
+ var inrange = this.currentTime <= this.range[1] && this.currentTime >= this.range[0];
+ if (inrange) {
+ this.loadQueue = OpenLayers.Array.filter(this.layers, function(lyr){return lyr.visibility}).length;
+ this.canTick = !this.loadQueue;
+ console.log('canTick:FALSE\nQueueCount:' + this.loadQueue)
+ if (inrange) {
+ this.applyTime(this.layers[i], this.currentTime);
+ else {
+ this.layers[i].setVisibility(false);
applyTime:function(layer,time){
@@ -67,5 +110,13 @@
+ onLayerLoadEnd: function(){
+ this.loadQueue--;
+ console.log('QueueCount:'+this.loadQueue)
+ if (this.loadQueue <= 0) {this.canTick = true; console.log('canTick:TRUE')}
+ onLayerLoadStart: function(){
+ //this.loadQueue=(!this.loadQueue && this.loadQueue!==0)?0:this.loadQueue++
CLASS_NAME:'OpenLayers.TimeHandler.WMS'
\ No newline at end of file
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/TimeHandler.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/TimeHandler.js 2011-09-08 10:08:35 UTC (rev 12344)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/TimeHandler.js 2011-09-08 10:15:49 UTC (rev 12345)
@@ -62,7 +62,11 @@
this.intervals = timeConfig.intervals;
+ this.events.destroy();
+ this.timeManager.events.unregister('tick',this.timeManager,this.onTick);
+ this.timeManager = this.layers = this.range = this.intervals = null;
onTick:function(){
//Implemented By Subclasses
@@ -121,8 +125,9 @@
if(intervals.length){
intervals = this.timeManager.getUniqueDates(intervals);
+ var last = intervals.length-1;
if (!range[0] || intervals[0] < range[0]) {range[0] = intervals[0];}
- if (!range[1] || intervals[1] > range[1]) {range[1] = intervals[1];}
+ if (!range[1] || intervals[last] > range[1]) {range[1] = intervals[last];}
}else{
intervals=null;
More information about the Commits
