[OpenLayers-Commits] r12358 - in trunk/openlayers: lib/OpenLayers
lib/OpenLayers/Layer lib/OpenLayers/Renderer tests/manual
commits-20090109 at openlayers.org
Mon Sep 12 00:31:17 EDT 2011
Author: ahocevar
Date: 2011-09-11 21:31:16 -0700 (Sun, 11 Sep 2011)
New Revision: 12358
trunk/openlayers/lib/OpenLayers/Layer.js
trunk/openlayers/lib/OpenLayers/Layer/Grid.js
trunk/openlayers/lib/OpenLayers/Renderer/SVG.js
trunk/openlayers/tests/manual/dateline-sketch.html
reverting accidently committed changes
Modified: trunk/openlayers/lib/OpenLayers/Layer/Grid.js
--- trunk/openlayers/lib/OpenLayers/Layer/Grid.js 2011-09-12 04:26:32 UTC (rev 12357)
+++ trunk/openlayers/lib/OpenLayers/Layer/Grid.js 2011-09-12 04:31:16 UTC (rev 12358)
@@ -247,11 +247,7 @@
// *partially* contained by our tiles (IE user has
// programmatically panned to the other side of the earth)
// then we want to reTile (thus, partial true).
- var maxExtent = this.map.getMaxExtent(),
- bl = new OpenLayers.LonLat(bounds.left, bounds.bottom).wrapDateLine(maxExtent),
- tr = new OpenLayers.LonLat(bounds.right, bounds.top).wrapDateLine(maxExtent);
- bounds = new OpenLayers.Bounds(bl.lon, bl.lat, tr.lon, tr.lat);
if (forceReTile || !tilesBounds.containsBounds(bounds, true)) {
this.initGriddedTiles(bounds);
} else {
Modified: trunk/openlayers/lib/OpenLayers/Layer.js
--- trunk/openlayers/lib/OpenLayers/Layer.js 2011-09-12 04:26:32 UTC (rev 12357)
+++ trunk/openlayers/lib/OpenLayers/Layer.js 2011-09-12 04:31:16 UTC (rev 12358)
@@ -297,10 +297,7 @@
* APIProperty: wrapDateLine
- * {Boolean} Wraps the world at the international dateline, so the map can
- * be panned infinitely in longitudinal direction. Only use this on the
- * base layer, and only if the layer's maxExtent equals the world bounds.
- * #487 for more info.
+ * {Boolean} #487 for more info.
wrapDateLine: false,
Modified: trunk/openlayers/lib/OpenLayers/Renderer/SVG.js
--- trunk/openlayers/lib/OpenLayers/Renderer/SVG.js 2011-09-12 04:26:32 UTC (rev 12357)
+++ trunk/openlayers/lib/OpenLayers/Renderer/SVG.js 2011-09-12 04:31:16 UTC (rev 12358)
@@ -133,14 +133,6 @@
this.translate(0, 0);
return true;
} else {
- width = maxExtent.getWidth() / resolution;
- if (extent.left < maxExtent.left) {
- extent.left += width;
- if (extent.right > maxExtent.right) {
- extent.left -= width;
var inRange = this.translate(left - this.left, top - this.top);
if (!inRange) {
// recenter the coordinate system
Modified: trunk/openlayers/tests/manual/dateline-sketch.html
--- trunk/openlayers/tests/manual/dateline-sketch.html 2011-09-12 04:26:32 UTC (rev 12357)
+++ trunk/openlayers/tests/manual/dateline-sketch.html 2011-09-12 04:31:16 UTC (rev 12358)
@@ -22,29 +22,18 @@
var map;
function init(){
- var maxExtent = new OpenLayers.Bounds(-20037508, -20037508, 20037508, 20037508),
- maxResolution = 156543.0339;
- var options = {
- projection: new OpenLayers.Projection("EPSG:900913"),
- displayProjection: new OpenLayers.Projection("EPSG:4326"),
- units: "m",
- numZoomLevels: 18,
- maxResolution: maxResolution,
- maxExtent: maxExtent
- map = new OpenLayers.Map('map', options);
+ map = new OpenLayers.Map('map');
- var dummy = new OpenLayers.Layer(
- "dummy",
- {isBaseLayer: true, wrapDateLine: true}
+ var gmap = new OpenLayers.Layer.Google(
+ "Google Streets",
+ {sphericalMercator: true}
var vector = new OpenLayers.Layer.Vector("Editable Vectors");
- map.addLayers([dummy, vector]);
+ map.addLayers([gmap, vector]);
map.addControl(new OpenLayers.Control.EditingToolbar(vector));
- var extent = new OpenLayers.Bounds(15849982.183008, -11368938.517442, -14206280.326992, -1350184.3474418);
+ var extent = new OpenLayers.Bounds(-24225034.496992, -11368938.517442, -14206280.326992, -1350184.3474418);
map.zoomToExtent(extent);
More information about the Commits
