[OpenLayers-Commits] r12368 - trunk/openlayers/tests/manual
commits-20090109 at openlayers.org
Wed Sep 14 15:39:22 EDT 2011
Author: ahocevar
Date: 2011-09-14 12:39:21 -0700 (Wed, 14 Sep 2011)
New Revision: 12368
Added:
trunk/openlayers/tests/manual/google-tilt.html
new manual test to see the unexpected tilt on google layers
Added: trunk/openlayers/tests/manual/google-tilt.html
--- trunk/openlayers/tests/manual/google-tilt.html (rev 0)
+++ trunk/openlayers/tests/manual/google-tilt.html 2011-09-14 19:39:21 UTC (rev 12368)
@@ -0,0 +1,39 @@
+<!DOCTYPE html>
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
+ <meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=0">
+ <meta name="apple-mobile-web-app-capable" content="yes">
+ <title>OpenLayers Google (v3) Layer Example</title>
+ <link rel="stylesheet" href="../../theme/default/style.css" type="text/css">
+ <link rel="stylesheet" href="../../theme/default/google.css" type="text/css">
+ <link rel="stylesheet" href="../../examples/style.css" type="text/css">
+ <script src="http://maps.google.com/maps/api/js?v=3.5&sensor=false"></script>
+ <script src="../../lib/OpenLayers.js"></script>
+ </head>
+ <body onload="init()">
+ <h1 id="title">Google (v3) Unexpected Tilt Test</h1>
+ <div id="map" class="smallmap"></div>
+ <div id="docs">
+ <p>
+ OpenLayers uses the disableDefaultUI option of the GMaps API.
+ Despite that, the tilt feature is active. To see it, zoom in
+ once and see the buildings from a 45° angle instead of from the
+ top as you would expect from aerial imagery.
+ </p>
+ </div>
+ <script>
+ var map = new OpenLayers.Map('map');
+ map.addControl(new OpenLayers.Control.LayerSwitcher());
+ var ghyb = new OpenLayers.Layer.Google(
+ "Google Hybrid",
+ {type: google.maps.MapTypeId.HYBRID, numZoomLevels: 20}
+ map.addLayers([ghyb]);
+ map.setCenter(new OpenLayers.LonLat(-13635213, 4544641), 17);
+ </script>
+ </body>
+</html>
More information about the Commits
