[OpenLayers-Commits] r12378 - trunk/openlayers/tests
commits-20090109 at openlayers.org
Sat Sep 17 13:36:15 EDT 2011
Author: marcjansen
Date: 2011-09-17 10:36:14 -0700 (Sat, 17 Sep 2011)
New Revision: 12378
Added:
trunk/openlayers/tests/Test.AnotherWay.baseadditions.js
trunk/openlayers/tests/Test.AnotherWay.css
trunk/openlayers/tests/Test.AnotherWay.geom_eq.js
trunk/openlayers/tests/Test.AnotherWay.js
trunk/openlayers/tests/Test.AnotherWay.xml_eq.js
Removed:
trunk/openlayers/tests/geom_eq.js
trunk/openlayers/tests/xml_eq.js
trunk/openlayers/tests/run-tests.html
Various enhancements to the testsuite:
- split resources of the suite (CSS, HTML, !JavaScript)
- dedicated files for our changes to the suite
- CSS enhancements (e.g. hover colors)
- a simple quicksearch/filter for the list of testfiles (Only for browsers that support querySelectorAll)
- links to the testfiles to easily bypass browser cache
- running time info panel
- detailed total number of testcases that failed/were ok
Non-functional change (closes #3507)
Added: trunk/openlayers/tests/Test.AnotherWay.baseadditions.js
--- trunk/openlayers/tests/Test.AnotherWay.baseadditions.js (rev 0)
+++ trunk/openlayers/tests/Test.AnotherWay.baseadditions.js 2011-09-17 17:36:14 UTC (rev 12378)
@@ -0,0 +1,177 @@
+// total counters
+Test.AnotherWay._openlayers_sum_total_detail_ok=0;
+Test.AnotherWay._openlayers_sum_total_detail_fail=0;
+Test.AnotherWay._startTime = null;
+// method overwrites
+// behaviour (timing)
+Test.AnotherWay._old_run_all_onclick = Test.AnotherWay._run_all_onclick;
+Test.AnotherWay._run_all_onclick = function(){
+ Test.AnotherWay._startTime = (new Date()).getTime();
+ Test.AnotherWay.reset_running_time();
+ Test.AnotherWay._old_run_all_onclick.apply(this, arguments);
+Test.AnotherWay._old_run_selected_onclick = Test.AnotherWay._run_selected_onclick;
+Test.AnotherWay._run_selected_onclick = function(){
+ Test.AnotherWay._old_run_selected_onclick.apply(this, arguments);
+Test.AnotherWay._old_run_one_onclick = Test.AnotherWay._run_one_onclick;
+Test.AnotherWay._run_one_onclick = function(){
+ Test.AnotherWay._old_run_one_onclick.apply(this, arguments);
+// test page loading
+Test.AnotherWay.old_load_next_page = Test.AnotherWay._load_next_page;
+Test.AnotherWay._load_next_page = function(){
+ Test.AnotherWay.update_running_time();
+ Test.AnotherWay.old_load_next_page.apply(this, arguments);
+Test.AnotherWay._add_test_page_url = function(test_url, convention){
+ var table = document.getElementById("testtable");
+ var record_select = document.getElementById("record_select");
+ var index = Test.AnotherWay._g_test_page_urls.length;
+ // trim spaces.
+ if (test_url.match("^(\\s*)(.*\\S)(\\s*)$")) {
+ test_url = RegExp.$2;
+ Test.AnotherWay._g_test_page_urls[index] = {
+ url: test_url,
+ convention: convention
+ var row = table.insertRow(-1);
+ var cell;
+ var cell_child;
+ var link;
+ cell = row.insertCell(-1);
+ cell_child = document.createElement("input");
+ cell_child.type = "checkbox";
+ cell_child.id = "checkbox" + index;
+ cell_child.checked = 'checked';
+ cell_child.defaultChecked = 'checked';
+ cell.appendChild(cell_child);
+ cell.setAttribute("width", "75%");
+ // make the URL a clickable link that opens in a new window
+ // start changes
+ link = document.createElement("a");
+ link.href=test_url;
+ link.target='_blank';
+ link.title='Opens testfile in a new window.';
+ link.appendChild(document.createTextNode(test_url));
+ cell.appendChild(link);
+ // end changes
+ cell_child.type = "button";
+ cell_child.id = "test" + index;
+ cell_child.value = " run ";
+ cell_child.onclick = Test.AnotherWay._run_one_onclick;
+ cell.setAttribute("width", "8em");
+ cell_child = document.createElement("span");
+ var option = document.createElement("option");
+ option.appendChild(document.createTextNode(test_url));
+ record_select.appendChild(option);
+// new methods
+Test.AnotherWay.update_running_time = function() {
+ var now = (new Date()).getTime();
+ var floor = Math.floor;
+ var elapsed = now - Test.AnotherWay._startTime;
+ var zeroPad = function(num, length){
+ var len = -1 * (length || 2);
+ return ('00000' + num).slice(len);
+ var ms = zeroPad(elapsed%1000, 3);
+ var seconds=zeroPad(floor((elapsed/1000)%60));
+ var minutes=zeroPad(floor((elapsed/60000)%60));
+ document.getElementById('running-time').innerHTML = 'Elapsed time ' + minutes + ':' + seconds + ':' + ms +' (m:s:ms).';
+Test.AnotherWay.reset_running_time = function(){
+ document.getElementById('running-time').innerHTML = '';
+// quickfilter
+Test.AnotherWay.bindQuicksearchListener = function(){
+ var input = document.getElementById('quickfilter');
+ if (input.addEventListener) {
+ input.addEventListener('keyup', Test.AnotherWay.quicksearch);
+ } else if (input.attachEvent) {
+ input.attachEvent('onkeyup', Test.AnotherWay.quicksearch);
+ } else {
+ // remove the input field
+ input.parentNode.removeChild(input);
+Test.AnotherWay.quicksearchThrottleTimeOut = null;
+Test.AnotherWay.quicksearch = function(){
+ if (Test.AnotherWay.quicksearchThrottleTimeOut) {
+ window.clearTimeout(Test.AnotherWay.quicksearchThrottleTimeOut);
+ Test.AnotherWay.quicksearchThrottleTimeOut = window.setTimeout(function(){
+ Test.AnotherWay.filterTestList(input.value);
+ }, 300);
+Test.AnotherWay.filterTestList = function(str){
+ Test.AnotherWay.unfilterTestList();
+ var re = new RegExp(str, 'i');
+ var candidates = document.querySelectorAll('#testtable tr td:nth-child(2) a');
+ for (var idx = 0, len = candidates.length; idx<len; idx++) {
+ var tr = candidates[idx].parentNode.parentNode;
+ var html = candidates[idx].innerHTML;
+ if (re.test(html)) {
+ tr.className = 'isShown';
+ } else {
+ tr.className = 'isHidden';
+Test.AnotherWay.unfilterTestList = function() {
+ if ( document.querySelectorAll ) {
+ var hidden = document.querySelectorAll('.isHidden');
+ for (var idx = 0, len = hidden.length; idx < len; idx++) {
+ hidden[idx].className = 'isShown';
+// bind our quicksearch init method to body onload.
+(function(win){
+ if (win.addEventListener) {
+ win.addEventListener('load', Test.AnotherWay.bindQuicksearchListener);
+ win.attachEvent('onload', Test.AnotherWay.bindQuicksearchListener);
+ } else {
+ win.onload = function(){
+ Test.AnotherWay.bindQuicksearchListener();
+})(window);
Added: trunk/openlayers/tests/Test.AnotherWay.css
--- trunk/openlayers/tests/Test.AnotherWay.css (rev 0)
+++ trunk/openlayers/tests/Test.AnotherWay.css 2011-09-17 17:36:14 UTC (rev 12378)
@@ -0,0 +1,243 @@
+ * Test.AnotherWay version 0.5
+ * Copyright (c) 2005 Artem Khodush, http://straytree.org
+ * Permission is hereby granted, free of charge, to any person obtaining
+ * a copy of this software and associated documentation files (the
+ * "Software"), to deal in the Software without restriction, including
+ * without limitation the rights to use, copy, modify, merge, publish,
+ * distribute, sublicense, and/or sell copies of the Software, and to
+ * permit persons to whom the Software is furnished to do so, subject to
+ * the following conditions:
+ * The above copyright notice and this permission notice shall be
+ * included in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
+ * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
+ * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
+ * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE
+ * LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION
+ * OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION
+ * WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
+ padding: 0;
+ margin: 0;
+html {
+ height: 99%;
+body {
+ height: 98%;
+ font: normal normal 10pt sans-serif
+#col1 {
+ float: left;
+ width: 27em;
+ margin: 0 0 0 1em;
+ overflow: visible;
+#col2 {
+ position: relative;
+ height: 98%;
+ margin: 0 0.5em 0 28em;
+#col1_header {
+ margin-top: 0.5em;
+#scroller {
+ height: 400px;
+ overflow: auto;
+#testtable {
+ margin: 0 0 2em 0;
+ width: 97%;
+ font-size: 1em;
+ border-collapse: collapse;
+#testtable input {
+ cursor: pointer;
+#testtable td {
+ line-height: 2em;
+ padding: 0;
+ margin: 0;
+ border-top: 1px solid #ccc;
+ border-bottom: 1px solid #ccc;
+#testtable tr:hover td {
+ background-color: #ededed;
+#testtable tr.isHidden {
+ display: none;
+#testtable tr.isShown {
+ display: table-row;
+#run_buttons, #running-time {
+ margin-bottom: 1em;
+#right_header {
+ padding-top: 0.8em;
+#results_count {
+ float: left;
+#results > p:hover {
+.active_tab {
+ float: right;
+ padding: 0 1em 0.2em 1em;
+ background: #0af;
+ border: 1px solid #048;
+ border-bottom: none;
+ cursor: pointer;
+ cursor: hand;
+ top: -0.2em;
+.inactive_tab {
+ float: right;
+ padding: 0 1em 0 1em;
+ background: #9bb;
+ color: #444;
+ border: 1px solid #9bb;
+ cursor: pointer;
+ cursor: hand;
+.inactive_mouseover_tab {
+ float: right;
+ background: #9bb;
+ color: #062;
+ border: 1px solid #062;
+ cursor: pointer;
+ cursor: hand;
+#right_frame {
+ overflow: auto;
+ top: -0.2em;
+ clear: right;
+ height: 95%;
+#debug {
+ display: none;
+#debug p {
+ margin: 2px 0 0 5em;
+ text-indent: -4.8em;
+#error {
+ display: none;
+ color: #c22;
+#results p {
+ margin: 0 0 2px 0;
+/* cursor indicating that detailed results may be expanded/contracted */
+#results p.badtest {
+ cursor: text;
+#results p.ok, #results p.fail {
+ cursor: pointer;
+ cursor: hand;
+/* colored squares in the results window at the left of test page names */
+#results p.ok .bullet {
+ background: #6d6;
+#results p.fail .bullet {
+ background: #d46;
+#results p.badtest .bullet {
+ background: #ea3;
+#results p.loading .bullet {
+ background: #48f;
+#results p.running .bullet {
+ background: #26e;
+#results p.waiting .bullet {
+ background: #04d;
+/* highlight in the results line */
+#results p .warning {
+ background: #ffc;
+/* layout of the detailed results */
+.result_detail {
+ padding-left: 3em;
+.result_exception_detail {
+ padding-left: 4em;
+.result_exception_stack_detail {
+ padding-left: 5em;
+.result_micro_detail {
+ padding-left: 6em;
+/* colouring in the detailed results */
+.result_detail .fail, .result_exception_detail .fail, .result_micro_detail .fail {
+ background: #ffd8d8;
+/* "start recording" controls*/
+#record_div {
+ margin-top: 3em;
+#record_div p {
+ margin-bottom: 0.5em;
+#record_select {
+ width: 88%;
+#record_input {
+ width: 53%;
\ No newline at end of file
Added: trunk/openlayers/tests/Test.AnotherWay.geom_eq.js
--- trunk/openlayers/tests/Test.AnotherWay.geom_eq.js (rev 0)
+++ trunk/openlayers/tests/Test.AnotherWay.geom_eq.js 2011-09-17 17:36:14 UTC (rev 12378)
@@ -0,0 +1,110 @@
+ * File: Test.AnotherWay.geom_eq.js
+ * Adds a geom_eq method to AnotherWay test objects.
+(function() {
+ * Function assertEqual
+ * Test two objects for equivalence (based on ==). Throw an exception
+ * if not equivalent.
+ * Parameters:
+ * got - {Object}
+ * expected - {Object}
+ * msg - {String} The message to be thrown. This message will be appended
+ * with ": got {got} but expected {expected}" where got and expected are
+ * replaced with string representations of the above arguments.
+ function assertEqual(got, expected, msg) {
+ if(got === undefined) {
+ got = "undefined";
+ } else if (got === null) {
+ got = "null";
+ if(expected === undefined) {
+ expected = "undefined";
+ } else if (expected === null) {
+ expected = "null";
+ if(got != expected) {
+ throw msg + ": got '" + got + "' but expected '" + expected + "'";
+ * Function assertGeometryEqual
+ * Test two geometries for equivalence. Geometries are considered
+ * equivalent if they are of the same class, and given component
+ * geometries, if all components are equivalent. Throws a message as
+ * exception if not equivalent.
+ * Parameters:
+ * got - {OpenLayers.Geometry}
+ * expected - {OpenLayers.Geometry}
+ * options - {Object} Optional object for configuring test options.
+ function assertGeometryEqual(got, expected, options) {
+ var OpenLayers = Test.AnotherWay._g_test_iframe.OpenLayers;
+ // compare types
+ assertEqual(typeof got, typeof expected, "Object types mismatch");
+ // compare classes
+ assertEqual(got.CLASS_NAME, expected.CLASS_NAME, "Object class mismatch");
+ if(got instanceof OpenLayers.Geometry.Point) {
+ // compare points
+ assertEqual(got.x, expected.x, "x mismatch");
+ assertEqual(got.y, expected.y, "y mismatch");
+ assertEqual(got.z, expected.z, "z mismatch");
+ } else {
+ // compare components
+ assertEqual(
+ got.components.length, expected.components.length,
+ "Component length mismatch for " + got.CLASS_NAME
+ for(var i=0; i<got.components.length; ++i) {
+ try {
+ assertGeometryEqual(
+ got.components[i], expected.components[i], options
+ } catch(err) {
+ throw "Bad component " + i + " for " + got.CLASS_NAME + ": " + err;
+ return true;
+ * Function: Test.AnotherWay._test_object_t.geom_eq
+ * Test if two geometry objects are equivalent. Tests for same geometry
+ * class, same number of components (if any), equivalent component
+ * geometries, and same coordinates.
+ * (code)
+ * t.geom_eq(got, expected, message);
+ * (end)
+ * Parameters:
+ * got - {OpenLayers.Geometry} Any geometry instance.
+ * expected - {OpenLayers.Geometry} The expected geometry.
+ * msg - {String} A message to print with test output.
+ var proto = Test.AnotherWay._test_object_t.prototype;
+ proto.geom_eq = function(got, expected, msg, options) {
+ // test geometries for equivalence
+ try {
+ assertGeometryEqual(got, expected, options);
+ this.ok(true, msg);
+ } catch(err) {
+ this.fail(msg + ": " + err);
Added: trunk/openlayers/tests/Test.AnotherWay.js
--- trunk/openlayers/tests/Test.AnotherWay.js (rev 0)
+++ trunk/openlayers/tests/Test.AnotherWay.js 2011-09-17 17:36:14 UTC (rev 12378)
@@ -0,0 +1,2498 @@
+if (typeof(Test) == "undefined") {
+ Test = {};
+Test.AnotherWay = {};
+Test.AnotherWay._g_test_iframe = null; // frame where to load test pages
+Test.AnotherWay._g_test_frame_no_clear = false; // true - leave last page displayed after tests end
+Test.AnotherWay._g_test_page_urls = []; // array of: { url: url, convention: "anotherway" or "jsan" }
+Test.AnotherWay._g_test_object_for_jsan = null; // test object for filling by tests that adhere to jsan Test.Simple calling convention
+Test.AnotherWay._g_pages_to_run = null; // list of pages to run automatically after loading
+Test.AnotherWay._g_run_on_main_load = false; // special handling for run_pages_to_run when it might be called before onload or before list of test pages is known.
+Test.AnotherWay._g_run_on_list_load = false;
+Test.AnotherWay._g_main_loaded = false;
+Test.AnotherWay._run_pages_to_run = function(called_from_outside){
+ if (!Test.AnotherWay._g_main_loaded) {
+ Test.AnotherWay._g_run_on_main_load = true;
+ else {
+ var a_pages = Test.AnotherWay._g_pages_to_run;
+ if (a_pages == "all") {
+ for (var i = 0; i < Test.AnotherWay._g_test_page_urls.length; ++i) {
+ Test.AnotherWay._run_test_page("test" + i);
+ else
+ if (a_pages != null) {
+ for (var run_i = 0; run_i < a_pages.length; ++run_i) {
+ var run_page = a_pages[run_i];
+ var found = false;
+ for (var all_i = 0; all_i < Test.AnotherWay._g_test_page_urls.length; ++all_i) {
+ if (run_page == Test.AnotherWay._g_test_page_urls[all_i].url) {
+ Test.AnotherWay._run_test_page("test" + all_i, called_from_outside);
+ found = true;
+ break;
+ if (!found) {
+ Test.AnotherWay._show_error("page specified to run is not found in the page list: " + run_page);
+ break;
+ // trim spaces.
+ url: test_url,
+ var cell;
+ var cell_child;
+ var link;
+ cell.appendChild(document.createTextNode(test_url));
+Test.AnotherWay._show_error = function(msg){
+ var error_div = document.getElementById("error");
+ error_div.innerHTML = "";
+ error_div.appendChild(document.createTextNode(msg));
+ error_div.style.display = "block";
+// read urls from the list in the html file inside the list_iframe
+// fill on-screen list with urls and "run" buttons, and fill the g_test_page_urls object.
+Test.AnotherWay._list_iframe_onload = function(){
+ if (window.frames.list_iframe != null && window.frames.list_iframe.location != "" && window.frames.list_iframe.location != "about:blank") {
+ var list_doc = window.frames.list_iframe.document;
+ var list = list_doc.getElementById("testlist");
+ if (list != null) {
+ for (var i = 0; i < list.childNodes.length; ++i) {
+ var item = list.childNodes[i];
+ if (item.nodeName == "LI" || item.nodeName == "li") {
+ var convention = "anotherway";
+ if (Test.AnotherWay._get_css_class(item) == "jsan") {
+ convention = "jsan";
+ Test.AnotherWay._add_test_page_url(item.innerHTML, convention);
+ if (Test.AnotherWay._g_run_on_list_load) {
+ Test.AnotherWay._g_run_on_list_load = false;
+ Test.AnotherWay._run_pages_to_run();
+ else {
+ Test.AnotherWay._show_error("no list with id 'testlist' in a list file " + window.frames.list_iframe.location);
+Test.AnotherWay._map_checkboxes = function(f){
+ var checks = table.getElementsByTagName("INPUT");
+ for (var i = 0; i < checks.length; ++i) {
+ if (checks[i].type == "checkbox" && checks[i].id.match(/^checkbox(\d+)$/)) {
+ f(checks[i], RegExp.$1);
+ Test.AnotherWay._map_checkboxes(function(c, id){
+ Test.AnotherWay._run_test_page("test" + id);
+ if (c.checked) {
+Test.AnotherWay._unselect_all_onclick = function(){
+ c.checked = false;
+ Test.AnotherWay._run_test_page(this.id);
+// construct an object that will gather results of running one test function
+Test.AnotherWay._test_object_t = function(fun_name){
+ this.name = fun_name; // name of the test function
+ this.n_plan = null; // planned number of assertions
+ this.n_ok = 0; // # of ok assertions
+ this.n_fail = 0; // # of failed assertions
+ this.exception = ""; // if the function throwed an exception, it's its message
+ this.exception_stack = []; // strings: function call stack from the exception
+ this.assertions = []; // assertion results: array of { ok: 1 or 0, name: string }
+ this.wait_result_milliseconds = 0; // how long to wait before collecting results from the test
+ this.second_wait_msg = null; // <p> status message (in addition to the page wait_msg)
+ this.delay_actions = []; // array of actions to be perfomed after the test function returns
+ // action : { acton_kind: "call" | "window" | "replay"
+ // when "call": { call_fn call_delay_milliseconds } call_fn takes nothing
+ // when "window" : { wnd_url wnd_wnd wnd_fn wnd_timeout_milliseconds wnd_dont_close } wnd_fn takes wnd
+ // wnen "replay" : { replay_wnd replay_events replay_event_i replay_checkpoints } checkpoint_fn takes this, wnd
+ this.delay_action_i = null; // index of delay action currently being performed
+ this.delay_prev_timer_time = 0; // for counting time while performing delay_actions
+ this.delay_current_milliseconds_left = 0; // time left before the next action, runs down
+ this.delay_total_milliseconds_left = 0; // for indication: total estimated time for all actions, runs up and down
+Test.AnotherWay._test_object_t.prototype.ok = function(cond, name){
+ if (cond) {
+ ++this.n_ok;
+ cond = 1;
+ else {
+ ++this.n_fail;
+ cond = 0;
+ this.assertions.push({
+ ok: cond,
+ name: name
+Test.AnotherWay._test_object_t.prototype.fail = function(name){
+ this.ok(false, name);
+Test.AnotherWay._test_object_t.prototype.plan = function(n){
+ this.n_plan = n;
+Test.AnotherWay._test_object_t.prototype.wait_result = function(seconds){
+ this.wait_result_milliseconds = 1000 * seconds;
+Test.AnotherWay._eq_fail_msg = function(path, what, expected, got){
+ return "eq: " + path + " " + what + " differ: got " + got + ", but expected " + expected;
+Test.AnotherWay._array_eq = function(expected, got, path, msg){
+ if (expected.length != got.length) {
+ msg.msg = Test.AnotherWay._eq_fail_msg(path, "array length", expected.length, got.length);
+ return false;
+ for (var i = 0; i < expected.length; ++i) {
+ if (!Test.AnotherWay._thing_eq(expected[i], got[i], path + "[" + i + "]", msg)) {
+ return false;
+ return true;
+Test.AnotherWay._object_eq = function(expected, got, path, msg){
+ var v;
+ for (v in expected) {
+ if (!(v in got)) {
+ msg.msg = Test.AnotherWay._eq_fail_msg(path + "." + v, "properties", expected[v], "undefined");
+ return false;
+ if (!Test.AnotherWay._thing_eq(expected[v], got[v], path + "." + v, msg)) {
+ return false;
+ for (v in got) {
+ if (!(v in expected)) {
+ msg.msg = Test.AnotherWay._eq_fail_msg(path + "." + v, "properties", "undefined", got[v]);
+ return false;
+ return true;
+Test.AnotherWay._constructor_name = function(x){
+ if (x == null) {
+ return "";
+ var s = "unknown";
+ try {
+ s = typeof(x.constructor);
+ if (s != "unknown") {
+ s = x.constructor.toString();
+ catch (e) {
+ s = "unknown";
+ if (s == "unknown") {
+ // hackish attempt to guess a type
+ var is_array = true;
+ var index = 0;
+ for (i in x) {
+ if (i != index) {
+ is_array = false;
+ ++index;
+ return is_array ? "Array" : "Object"; // for empty arrays/objects, this will be wrong half the time
+ else
+ if (s.match(/^\s*function\s+(\w+)\s*\(/)) {
+ return RegExp.$1;
+ else {
+ var c = '';
+ switch (typeof x) {
+ case 'string':
+ c = 'String';
+ break;
+ case 'object':
+ c = 'Object';
+ break;
+ default:
+ c = '';
+ return c;
+Test.AnotherWay._is_array = function(x){
+ return Test.AnotherWay._constructor_name(x) == "Array";
+Test.AnotherWay._is_value_type = function(x){
+ cn = Test.AnotherWay._constructor_name(x);
+ return cn == "Number" || cn == "String" || cn == "Boolean" || cn == "Date";
+Test.AnotherWay._thing_eq = function(expected, got, path, msg){
+ if (expected == null && got == null) {
+ return true;
+ else
+ if ((expected == null && got != null) || (expected != null && got == null)) {
+ msg.msg = Test.AnotherWay._eq_fail_msg(path, "values", expected, got);
+ return false;
+ else {
+ var expected_cn = Test.AnotherWay._constructor_name(expected);
+ var got_cn = Test.AnotherWay._constructor_name(got);
+ if (expected_cn != got_cn) {
+ msg.msg = Test.AnotherWay._eq_fail_msg(path, "types", expected_cn, got_cn);
+ return false;
+ else {
+ if (Test.AnotherWay._is_array(expected)) {
+ return Test.AnotherWay._array_eq(expected, got, path, msg);
+ else
+ if (Test.AnotherWay._is_value_type(expected)) {
+ if (expected != got) {
+ return false;
+ else {
+ return true;
+ else { // just a plain object
+ return Test.AnotherWay._object_eq(expected, got, path, msg);
+Test.AnotherWay._test_object_t.prototype.eq = function(got, expected, name){
+ var msg = {};
+ if (Test.AnotherWay._thing_eq(expected, got, "", msg)) {
+ this.ok(1, name);
+ else {
+ this.fail(name + ". " + msg.msg);
+Test.AnotherWay._test_object_t.prototype.like = function(got, expected, name){
+ if (got.match(expected) != null) {
+ this.ok(1, name);
+ else {
+ this.fail(name + ": got " + got + ", but expected it to match: " + expected);
+Test.AnotherWay._g_html_eq_span = null;
+Test.AnotherWay._html_eq_string_to_node = function(string_or_node, what, msg){
+ if (string_or_node.nodeType != null) {
+ string_or_node = Test.AnotherWay._html_eq_node_to_string(string_or_node); // double trip - to make properties assigned in scripts available as html node attributes
+ if (Test.AnotherWay._g_html_eq_span == null) {
+ Test.AnotherWay._g_html_eq_span = document.createElement("span");
+ Test.AnotherWay._g_html_eq_span.innerHTML = string_or_node;
+ if (Test.AnotherWay._g_html_eq_span.childNodes.length != 1) {
+ msg.msg = "bad " + what + " html string given (should contain exactly one outermost element): " + string_or_node;
+ return Test.AnotherWay._g_html_eq_span.childNodes[0].cloneNode(true);
+Test.AnotherWay._html_eq_node_to_string = function(node){
+ Test.AnotherWay._g_html_eq_span.innerHTML = "";
+ if (node.outerHTML != null) {
+ Test.AnotherWay._g_html_eq_span.innerHTML = node.outerHTML;
+ else {
+ var clone = node.cloneNode(true);
+ var node = Test.AnotherWay._g_html_eq_span;
+ if (node.ownerDocument && node.ownerDocument.importNode) {
+ if (node.ownerDocument != clone.ownerDocument) {
+ clone = node.ownerDocument.importNode(clone, true);
+ node.appendChild(clone);
+ return Test.AnotherWay._g_html_eq_span.innerHTML;
+Test.AnotherWay._html_eq_path_msg = function(path){
+ var msg = "";
+ for (var i = 0; i < path.length; ++i) {
+ msg += " [node " + path[i].node;
+ if (path[i].id != null && path[i].id != "") {
+ msg += " id " + path[i].id;
+ else
+ if (path[i].index != null) {
+ msg += " at index " + path[i].index;
+ msg += "] ";
+ return msg;
+Test.AnotherWay._html_eq_fail_msg = function(path, what, expected, got){
+ return Test.AnotherWay._html_eq_path_msg(path) + ": " + what + " differ: got " + got + ", but expected " + expected;
+Test.AnotherWay._html_eq_remove_blank = function(text){
+ if (text == null) {
+ return "";
+ else
+ if (text.match("^(\\s*)(.*\\S)(\\s*)$")) {
+ return RegExp.$2;
+ else
+ if (text.match("\s*")) {
+ return "";
+ return text;
+Test.AnotherWay._html_eq_remove_blank_nodes = function(node){
+ var to_remove = [];
+ for (var child = node.firstChild; child != null; child = child.nextSibling) {
+ if (child.nodeType == 3) {
+ var value = Test.AnotherWay._html_eq_remove_blank(child.nodeValue);
+ if (value == "") {
+ to_remove.push(child);
+ else {
+ child.nodeValue = value;
+ for (var i = 0; i < to_remove.length; ++i) {
+ node.removeChild(to_remove[i]);
+Test.AnotherWay._html_node_type_text = function(node_type){
+ if (node_type == 1) {
+ return "1 (html element)";
+ else
+ if (node_type == 3) {
+ return "3 (text)";
+ else {
+ return node_type;
+Test.AnotherWay._html_eq_node = function(expected, got, path, msg, expected_loc_base, got_loc_base){
+ if (expected.nodeType != got.nodeType) {
+ msg.msg = Test.AnotherWay._html_eq_fail_msg(path, "node types", Test.AnotherWay._html_node_type_text(expected.nodeType), Test.AnotherWay._html_node_type_text(got.nodeType));
+ return false;
+ else
+ if (expected.nodeType == 3) {
+ if (expected.nodeValue != got.nodeValue) {
+ msg.msg = Test.AnotherWay._html_eq_fail_msg(path, "text", expected.nodeValue, got.nodeValue);
+ return false;
+ else
+ if (expected.nodeType == 1) {
+ if (expected.nodeName != got.nodeName) {
+ msg.msg = Test.AnotherWay._html_eq_fail_msg(path, "node names", expected.nodeName, got.nodeName);
+ return false;
+ // compare attributes
+ var expected_attrs = {};
+ var got_attrs = {};
+ var i;
+ var a;
+ for (i = 0; i < expected.attributes.length; ++i) {
+ a = expected.attributes[i];
+ if (a.specified) {
+ expected_attrs[a.name] = 1;
+ for (i = 0; i < got.attributes.length; ++i) {
+ a = got.attributes[i];
+ got_attrs[a.name] = 1;
+ for (a in expected_attrs) {
+ if (!(a in got_attrs)) {
+ msg.msg = Test.AnotherWay._html_eq_path_msg(path) + ": attribute sets differ: expected attribute " + a + " is missing";
+ return false;
+ for (a in got_attrs) {
+ if (!(a in expected_attrs)) {
+ msg.msg = Test.AnotherWay._html_eq_path_msg(path) + ": attribute sets differ: got extra attribute " + a;
+ return false;
+ var expected_value = expected.getAttribute(a);
+ var got_value = got.getAttribute(a);
+ if (typeof(expected_value) == "string" && typeof(got_value) == "string") {
+ expected_value = Test.AnotherWay._html_eq_remove_blank(expected_value);
+ got_value = Test.AnotherWay._html_eq_remove_blank(got_value);
+ var ok = expected_value == got_value;
+ if (!ok && (a == "href" || a == "HREF")) { // try relative hrefs
+ var expected_relative_value = expected_value;
+ if (expected_loc_base != null && expected_value.substring(0, expected_loc_base.length) == expected_loc_base) {
+ expected_relative_value = expected_value.substring(expected_loc_base.length);
+ var got_relative_value = got_value;
+ if (got_loc_base != null && got_value.substring(0, got_loc_base.length) == got_loc_base) {
+ got_relative_value = got_value.substring(got_loc_base.length);
+ ok = expected_relative_value == got_relative_value;
+ if (!ok) {
+ msg.msg = Test.AnotherWay._html_eq_fail_msg(path, "attribute " + a + " values", expected_value, got_value);
+ return false;
+ else
+ if (typeof(expected_value) == "function" && typeof(got_value) == "function") {
+ expected_value = expected_value.toString();
+ got_value = got_value.toString();
+ if (expected_value != got_value) {
+ return false;
+ else {
+ var value_msg = {};
+ if (!Test.AnotherWay._thing_eq(expected_value, got_value, "", value_msg)) {
+ msg.msg = Test.AnotherWay._html_eq_path_msg(path) + ": attribute " + a + " values differ: " + value_msg.msg;
+ return false;
+ // compare child nodes
+ Test.AnotherWay._html_eq_remove_blank_nodes(expected);
+ Test.AnotherWay._html_eq_remove_blank_nodes(got);
+ var expected_length = expected.childNodes.length;
+ var got_length = got.childNodes.length;
+ if (expected_length < got_length) {
+ msg.msg = Test.AnotherWay._html_eq_path_msg(path) + ": got " + (got_length - expected_length) + " extra child nodes";
+ return false;
+ else
+ if (expected_length > got_length) {
+ msg.msg = Test.AnotherWay._html_eq_path_msg(path) + ": expected " + (expected_length - got_length) + " more child nodes";
+ return false;
+ else {
+ for (i = 0; i < expected_length; ++i) {
+ var expected_node = expected.childNodes[i];
+ path.push({
+ node: expected_node.nodeName,
+ id: expected_node.id,
+ index: i
+ var eq = Test.AnotherWay._html_eq_node(expected_node, got.childNodes[i], path, msg, expected_loc_base, got_loc_base);
+ path.pop();
+ if (!eq) {
+ return false;
+ return true;
+Test.AnotherWay._html_eq_get_loc_base = function(node){
+ var loc_base = document.location;
+ if (node.ownerDocument != null) {
+ loc_base = node.ownerDocument.location;
+ if (loc_base != null) {
+ loc_base = loc_base.href;
+ var slash_pos = loc_base.lastIndexOf("/");
+ if (slash_pos != -1) {
+ loc_base = loc_base.substring(0, slash_pos + 1);
+ return loc_base;
+Test.AnotherWay._test_object_t.prototype.html_eq = function(got, expected, name){
+ var msg = {};
+ var expected_node = Test.AnotherWay._html_eq_string_to_node(expected, "expected", msg);
+ if (msg.msg != null) {
+ this.fail(name + " html_eq: " + msg.msg);
+ else {
+ var got_node = Test.AnotherWay._html_eq_string_to_node(got, "got", msg);
+ else {
+ var expected_loc_base = Test.AnotherWay._html_eq_get_loc_base(expected);
+ var got_loc_base = Test.AnotherWay._html_eq_get_loc_base(got);
+ if (Test.AnotherWay._html_eq_node(expected_node, got_node, [], msg, expected_loc_base, got_loc_base)) {
+ this.ok(1, name);
+ else {
+ var msg = name + " html_eq " + msg.msg;
+ var expected_str = Test.AnotherWay._html_eq_node_to_string(expected_node);
+ var got_str = Test.AnotherWay._html_eq_node_to_string(got_node);
+ msg += ".\n got html: " + got_str;
+ msg += ".\n expected html: " + expected_str;
+ this.fail(msg);
+Test.AnotherWay._debug_pane_print = function(msg){
+ var d = new Date();
+ var p = document.createElement("p");
+ p.appendChild(document.createTextNode(d.toLocaleTimeString() + " " + msg));
+ var debug_pane = document.getElementById("debug");
+ debug_pane.appendChild(p);
+ var debug_tab = document.getElementById("debug_tab");
+ var results_tab = document.getElementById("results_tab");
+ debug_tab.style.visibility = "visible";
+ results_tab.style.visibility = "visible";
+Test.AnotherWay._test_object_t.prototype.debug_print = function(msg){
+ Test.AnotherWay._debug_pane_print(this.name + ": " + msg);
+Test.AnotherWay._test_object_t.prototype.delay_call = function(){
+ var timeout_ms = 200;
+ for (var i = 0; i < arguments.length; ++i) {
+ if (typeof(arguments[i]) != "function") {
+ timeout_ms = 1000 * arguments[i];
+ else {
+ var action = {
+ action_kind: "call",
+ call_delay_milliseconds: timeout_ms,
+ call_fn: arguments[i]
+ this.delay_total_milliseconds_left += Test.AnotherWay._action_estimate_milliseconds(action);
+ this.delay_actions.push(action);
+Test.AnotherWay._test_object_t.prototype.open_window = function(url, fn, timeout_seconds){
+ if (timeout_seconds == null) {
+ timeout_seconds = 4;
+ var no_close = document.getElementById("dont_close_test_windows");
+ var action = {
+ action_kind: "window",
+ wnd_url: url.toString() + (window.location.search || ""),
+ wnd_wnd: null,
+ wnd_fn: fn,
+ wnd_timeout_milliseconds: timeout_seconds * 1000,
+ wnd_no_close: no_close.checked
+Test.AnotherWay._test_object_t.prototype.replay_events = function(wnd, events){
+ if (Test.AnotherWay._g_no_record_msg != null) {
+ this.fail("replay_events: " + Test.AnotherWay._g_no_record_msg);
+ else {
+ var action = {
+ action_kind: "replay",
+ replay_wnd: wnd,
+ replay_events: events.events,
+ replay_event_i: null,
+ replay_checkpoints: events.checkpoints
+Test.AnotherWay._action_estimate_milliseconds = function(action){
+ var ms = 0;
+ if (action.action_kind == "call") {
+ ms = action.call_delay_milliseconds;
+ else
+ if (action.action_kind == "window") {
+ ms = 0;
+ else
+ if (action.action_kind == "replay") {
+ ms = 0;
+ for (var i = 0; i < action.replay_events.length; ++i) {
+ ms += action.replay_events[i]["time"] - 0;
+ return ms;
+Test.AnotherWay._g_timeout_granularity = 200;
+Test.AnotherWay._g_tests_queue = []; // vector of { url: string, test_objects : array of test_object_t, test_object_i: int, wait_msg: <p> object, loading_timeout_milliseconds: int, timeout_id: id }
+// load one html page, schedule further processing
+Test.AnotherWay._run_test_page = function(id, called_from_outside){
+ if (id.match(/^test(\d+)/)) {
+ id = RegExp.$1;
+ Test.AnotherWay._g_tests_queue.push({
+ url: Test.AnotherWay._g_test_page_urls[id].url,
+ convention: Test.AnotherWay._g_test_page_urls[id].convention,
+ test_objects: []
+ if (Test.AnotherWay._g_tests_queue.length == 1) {
+ if (!called_from_outside) {
+ // Crap. Be careful stepping around.
+ // For Mozilla and Opera, when this file is included into the frameset page that is in another directory (and _g_outside_path_correction!=null)
+ // but the test pages are started from within it (by "run" buttons), then:
+ // depending on whether the page is the first one loaded into the test frame or not,
+ // the base url for relative test pages differs.
+ // Crap, like I said.
+ Test.AnotherWay._g_tests_queue[0].suppress_outside_path_correction = true;
+ Test.AnotherWay._start_loading_page();
+ Test.AnotherWay._g_tests_queue.splice(0, 1);
+ if (Test.AnotherWay._g_tests_queue.length > 0) {
+ else {
+ if (!Test.AnotherWay._g_test_frame_no_clear) {
+ Test.AnotherWay._g_test_iframe.location.replace("about:blank");
+Test.AnotherWay._g_opera_path_correction = null; // ugly wart to support opera
+Test.AnotherWay._g_outside_path_correction = null; // ugly wart to accomodate Opera and Mozilla, where relative url relates to the directory where the page that calls this function is located
+Test.AnotherWay._set_iframe_location = function(iframe, loc, outside_path_correction){
+ // allow to load only locations with the same origin
+ var proto_end = loc.indexOf("://");
+ if (proto_end != -1) { // otherwise, it's safe to assume (for Opera, Mozilla and IE ) that loc will be treated as relative
+ var main_loc = window.location.href;
+ var host_end = loc.substring(proto_end + 3).indexOf("/");
+ var ok = false;
+ if (host_end != -1) {
+ var loc_origin = loc.substring(0, proto_end + 3 + host_end + 1);
+ if (main_loc.length >= loc_origin.length && main_loc.substring(0, loc_origin.length) == loc_origin) {
+ ok = true;
+ if (!ok) {
+ return {
+ msg: "test pages may have only urls with the same origin as " + main_loc
+ // opera cannot handle urls relative to file:// without assistance
+ if (window.opera != null && window.location.protocol == "file:" && loc.indexOf(":") == -1) {
+ var base = window.location.href;
+ var q_pos = base.indexOf("?");
+ if (q_pos != -1) {
+ base = base.substring(0, q_pos);
+ var slash_pos = base.lastIndexOf("/");
+ base = base.substring(0, slash_pos + 1);
+ Test.AnotherWay._g_opera_path_correction = base;
+ loc = base + loc;
+ // if this function is called from another page, and if that page is in another directory, correction is needed
+ if (outside_path_correction != null) {
+ var pos = loc.indexOf(outside_path_correction);
+ if (pos == 0) {
+ loc = loc.substring(outside_path_correction.length + 1);
+ if (iframe.location != null) {
+ iframe.location.replace(loc);
+ else {
+ iframe.src = loc;
+ return {};
+Test.AnotherWay._start_loading_page = function(){
+ var test_page = Test.AnotherWay._g_tests_queue[0];
+ test_page.loading_timeout_milliseconds = 12000;
+ test_page.timeout_id = setTimeout(Test.AnotherWay._loading_timeout, Test.AnotherWay._g_timeout_granularity);
+ test_page.wait_msg = Test.AnotherWay._print_counter_result(test_page.url, "loading...", test_page.loading_timeout_milliseconds, "loading");
+ if (test_page.convention == "jsan") {
+ // the tests in that page will run when it's loading, so the test object must be ready
+ Test.AnotherWay._g_test_object_for_jsan = new Test.AnotherWay._test_object_t(test_page.url);
+ var outside_path_correction = null;
+ if (Test.AnotherWay._g_outside_path_correction != null && !test_page.suppress_outside_path_correction) {
+ outside_path_correction = Test.AnotherWay._g_outside_path_correction;
+ var result = Test.AnotherWay._set_iframe_location(Test.AnotherWay._g_test_iframe, test_page.url, outside_path_correction);
+ if (result.msg != null) {
+ Test.AnotherWay._unprint_result(test_page.wait_msg);
+ Test.AnotherWay._print_result(test_page.url, result.msg, "badtest", null);
+ Test.AnotherWay._load_next_page();
+Test.AnotherWay._loading_timeout = function(){
+ test_page.loading_timeout_milliseconds -= Test.AnotherWay._g_timeout_granularity;
+ if (test_page.loading_timeout_milliseconds > 0) {
+ Test.AnotherWay._update_msg_counter(test_page.wait_msg, (test_page.loading_timeout_milliseconds / 1000).toFixed());
+ else {
+ Test.AnotherWay._print_result(test_page.url, "Unable to load test page. Timeout expired", "badtest", null);
+Test.AnotherWay._strip_query_and_hash = function(s){
+ var i = s.lastIndexOf("#");
+ if (i != -1) {
+ s = s.substring(0, i);
+ i = s.lastIndexOf("?");
+ if (i != -1) {
+ return s;
+Test.AnotherWay._is_url_loaded = function(url, wnd){
+ var loaded = false;
+ if (wnd != null && wnd.location != null) {
+ // after some popup blocker interference, location may behave strange..
+ var location_s = "";
+ location_s += wnd.location;
+ if (location_s != "") {
+ var pathname = wnd.location.pathname;
+ var expected_url = url;
+ var i = expected_url.lastIndexOf("#");
+ if (i != -1) {
+ expected_url = expected_url.substring(0, i);
+ i = expected_url.lastIndexOf("?");
+ if (i != -1) {
+ i = expected_url.lastIndexOf("/");
+ if (i != -1 && i != expected_url.length - 1) {
+ expected_url = expected_url.substring(i + 1);
+ i = pathname.indexOf(expected_url);
+ if (wnd.location.href == url || (i != -1 && i == pathname.length - expected_url.length)) {
+ if ( /*window.opera==null*/wnd.document.readyState == null || wnd.document.readyState == "complete") { // for opera (and IE?), getElementById does not work until..
+ loaded = true;
+ return loaded;
+// find and run all test functions in the g_cur_page html page.
+Test.AnotherWay._test_page_onload = function(){
+ if (Test.AnotherWay._g_tests_queue.length == 0) {
+ return;
+ if (!Test.AnotherWay._is_url_loaded(test_page.url, Test.AnotherWay._g_test_iframe)) {
+ return;
+ clearTimeout(test_page.timeout_id);
+ if (test_page.convention == "anotherway") {
+ // get test function names (those beginning with "test")
+ if (typeof(Test.AnotherWay._g_test_iframe.document.scripts) != 'undefined') { // IE
+ for (var i = 0; i < Test.AnotherWay._g_test_iframe.document.scripts.length; ++i) {
+ var script_text = Test.AnotherWay._g_test_iframe.document.scripts[i].text;
+ var fun_sig = "function test";
+ var fun_start = script_text.indexOf(fun_sig);
+ while (fun_start != -1) {
+ script_text = script_text.substring(fun_start, script_text.length);
+ var fun_end = script_text.indexOf('(');
+ var fun_name = script_text.substring("function ".length, fun_end);
+ var whitespace = fun_name.indexOf(' ');
+ if (whitespace >= 0) {
+ fun_name = fun_name.substring(0, whitespace);
+ test_page.test_objects.push(new Test.AnotherWay._test_object_t(fun_name));
+ script_text = script_text.substring(fun_end, script_text.length);
+ fun_start = script_text.indexOf(fun_sig);
+ else { // otherwise (not IE) it ought to work like this
+ for (var i in Test.AnotherWay._g_test_iframe) {
+ // Hack to prevent failure in FF3.0b1 (innerWidth/innerHeight) and FF>=3.5 (sessionStorage)
+ if (i == "innerWidth" || i == "innerHeight" || i == "sessionStorage") {
+ continue;
+ if (typeof(Test.AnotherWay._g_test_iframe[i]) == 'function') {
+ if (i.substring(0, 4) == "test") {
+ test_page.test_objects.push(new Test.AnotherWay._test_object_t(i));
+ else
+ // the test object is already filled with results
+ test_page.test_objects.push(Test.AnotherWay._g_test_object_for_jsan);
+ if (test_page.test_objects.length == 0) {
+ Test.AnotherWay._print_result(test_page.url, "No test functions defined in the page", "badtest", null);
+ return;
+ test_page.wait_msg = Test.AnotherWay._print_result(test_page.url, "running tests..<span class=\"counter\">" + test_page.test_objects.length + "</span>", "running", null);
+ test_page.test_object_i = 0;
+ Test.AnotherWay._run_more_tests();
+Test.AnotherWay._handle_exception = function(o, e, title){
+ var s = title + ": " + typeof(e) + ": ";
+ if (e.message != null) {
+ s += e.message;
+ else
+ if (e.description != null) {
+ s += e.description;
+ else {
+ s += e.toString();
+ // if( e.location!=null ) { // XXX figure out how to display exception location if it's present (like in mozilla)
+ // s+=" location: "+e.location.toString();
+ o.exception = s;
+ s = [];
+ if (e.stack) {
+ var lines = e.stack.split("\n");
+ for (var i = 0; i < lines.length; ++i) {
+ // format of the line: func_name(args)@file_name:line_no
+ if (lines[i].match(/(\w*)\(([^\)]*)\)@(.*):([^:]*)$/)) {
+ var func_name = RegExp.$1;
+ if (func_name.length == 0) {
+ func_name = "<anonymous>";
+ s.push("in " + func_name + "( " + RegExp.$2 + ") at " + RegExp.$3 + " line " + RegExp.$4 + "\n");
+ o.exception_stack = s;
+Test.AnotherWay._run_more_tests = function(){
+ while (test_page.test_object_i < test_page.test_objects.length) {
+ Test.AnotherWay._update_msg_counter(test_page.wait_msg, (1 + test_page.test_object_i) + "/" + test_page.test_objects.length);
+ var o = test_page.test_objects[test_page.test_object_i];
+ try {
+ Test.AnotherWay._g_test_iframe[o.name](o);
+ catch (e) {
+ Test.AnotherWay._handle_exception(o, e, "");
+ } // for "jsan" convention, test has run already
+ if (o.delay_actions.length > 0 || o.wait_result_milliseconds > 0) {
+ o.delay_total_milliseconds_left += o.wait_result_milliseconds;
+ Test.AnotherWay._delay_actions_timeout();
+ return;
+ ++test_page.test_object_i;
+ Test.AnotherWay._print_result(test_page.url, null, null, test_page.test_objects);
+Test.AnotherWay._delay_actions_timeout = function(){
+ var test_object = test_page.test_objects[test_page.test_object_i];
+ var finished = true;
+ if (test_object.delay_action_i == null) {
+ // set up to start first action
+ test_object.delay_action_i = -1;
+ else {
+ // perform current action
+ var milliseconds_passed = (new Date()).getTime() - test_object.delay_prev_timer_time;
+ test_object.delay_current_milliseconds_left -= milliseconds_passed;
+ test_object.delay_total_milliseconds_left -= milliseconds_passed;
+ finished = Test.AnotherWay._delay_continue_action(test_object, milliseconds_passed);
+ while (finished && test_object.delay_action_i < test_object.delay_actions.length) {
+ ++test_object.delay_action_i; // start next action
+ finished = Test.AnotherWay._delay_start_action(test_object);
+ if (test_object.delay_action_i <= test_object.delay_actions.length) { // any more actions left ?
+ test_object.delay_prev_timer_time = (new Date()).getTime();
+ var next_timeout = Test.AnotherWay._g_timeout_granularity;
+ if (test_object.delay_current_milliseconds_left < next_timeout) {
+ next_timeout = test_object.delay_current_milliseconds_left;
+ if (test_object.second_wait_msg != null) {
+ Test.AnotherWay._update_msg_counter(test_object.second_wait_msg, (test_object.delay_total_milliseconds_left / 1000).toFixed());
+ setTimeout(Test.AnotherWay._delay_actions_timeout, next_timeout);
+ else { // no more actions left. run the next test.
+ Test.AnotherWay._unprint_result(test_object.second_wait_msg);
+ test_object.second_wait_msg = null;
+Test.AnotherWay._delay_start_action = function(test_object){
+ var finished = false;
+ var wait_msg = "";
+ if (test_object.delay_action_i == test_object.delay_actions.length) {
+ if (test_object.wait_result_milliseconds > 0) {
+ test_object.delay_current_milliseconds_left = test_object.wait_result_milliseconds; // wait for result
+ wait_msg = "waiting for results..";
+ else {
+ ++test_object.delay_action_i; // dont wait for result
+ else {
+ var action = test_object.delay_actions[test_object.delay_action_i];
+ test_object.delay_current_milliseconds_left = action.call_delay_milliseconds;
+ wait_msg = "performing delayed calls..";
+ else
+ if (Test.AnotherWay._g_opera_path_correction != null && action.wnd_url.indexOf(":") == -1) {
+ action.wnd_url = Test.AnotherWay._g_opera_path_correction + action.wnd_url;
+ action.wnd_wnd = window.open(action.wnd_url, "_blank");
+ if (action.wnd_wnd == null) {
+ finished = true;
+ test_object.fail("unable to open window for " + action.wnd_url);
+ else {
+ test_object.delay_current_milliseconds_left = action.wnd_timeout_milliseconds;
+ wait_msg = "opening window..";
+ else
+ if (action.replay_events.length == 0) {
+ finished = true;
+ else {
+ action.replay_event_i = 0;
+ test_object.delay_current_milliseconds_left = action.replay_events[0]["time"];
+ wait_msg = "replaying events..";
+ if (wait_msg != "") {
+ test_object.second_wait_msg = Test.AnotherWay._print_counter_result(test_page.url, wait_msg, test_object.delay_total_milliseconds_left, "waiting");
+ else {
+ return finished;
+Test.AnotherWay._delay_continue_action = function(test_object, milliseconds_passed){
+ var finished = test_object.delay_current_milliseconds_left <= 0;
+ if (test_object.delay_action_i == test_object.delay_actions.length) { // action is "waiting for results"
+ if (test_object.n_plan != null && test_object.n_plan == test_object.n_ok + test_object.n_fail) {
+ finished = true; // if all assertions results are recorded, don't wait any more
+ if (finished) {
+ ++test_object.delay_action_i; // move on to the next test
+ else {
+ if (finished) {
+ try {
+ action.call_fn();
+ catch (e) {
+ Test.AnotherWay._handle_exception(test_object, e, "in delay_call");
+ else
+ test_object.delay_total_milliseconds_left += milliseconds_passed; // for "window", the countdown is suspended since it's unknown how long it will take
+ if (Test.AnotherWay._is_url_loaded(action.wnd_url, action.wnd_wnd)) {
+ try {
+ action.wnd_fn(action.wnd_wnd);
+ catch (e) {
+ Test.AnotherWay._handle_exception(test_object, e, "in open_window function call");
+ finished = true;
+ else
+ if (finished) {
+ test_object.fail("unable to open window for url '" + action.wnd_url + "'. timeout expired");
+ else
+ if (finished) {
+ // try {
+ Test.AnotherWay._delay_replay_event(test_object, action.replay_wnd, action.replay_events[action.replay_event_i], action.replay_checkpoints);
+ // }catch( e ) { // disabled, until I know how to gel location info from an exception
+ // Test.AnotherWay._handle_exception( test_object, e, "while replaying event" );
+ ++action.replay_event_i;
+ finished = action.replay_event_i == action.replay_events.length;
+ if (!finished) {
+ test_object.delay_current_milliseconds_left = action.replay_events[action.replay_event_i]["time"];
+ return finished;
+Test.AnotherWay._delay_replay_event = function(test_object, wnd, event, checkpoints){
+ if (event.type == "_checkpoint") {
+ var checkpoint_n = event.which;
+ var prev_n_fail = test_object.n_fail;
+ checkpoints[checkpoint_n](test_object, wnd);
+ var flash_color = prev_n_fail == test_object.n_fail ? "#2f2" : "#f22";
+ Test.AnotherWay._record_flash_border(flash_color);
+ else
+ if (event.type == "click" || event.type == "mouseover" || event.type == "mouseout" || event.type == "mousemove" || event.type == "mousedown" || event.type == "mouseup") {
+ var target = Test.AnotherWay._record_node_path_to_node(event["target"], wnd.document);
+ if (target != null) {
+ Test.AnotherWay._record_control_update_highlight(target, "ball", event);
+ var e = wnd.document.createEvent("MouseEvents");
+ var related_target = Test.AnotherWay._record_node_path_to_node(event["relatedTarget"], wnd.document);
+ e.initMouseEvent(event["type"], event["cancelable"], event["bubbles"], wnd.document.defaultView, event["detail"], event["screenX"], event["screenY"], event["clientX"], event["clientY"], event["ctrlKey"], event["altKey"], event["shiftKey"], event["metaKey"], event["button"], Test.AnotherWay._record_node_path_to_node(event["relatedTarget"], wnd.document));
+ // Firefox 1.0.6 somehow loses relatedTarget somewhere on the way. Pass through our own, for those who choose to care.
+ e.passThroughRelatedTarget = related_target;
+ target.dispatchEvent(e);
+ else
+ if (event.type == "keyup" || event.type == "keydown" || event.type == "keypress") {
+ var e = wnd.document.createEvent("KeyboardEvents"); // forget it. Apparently it's not supported neither by mozilla nor by opera.
+ e.initKeyboardEvent(event["type"], event["cancelable"], event["bubbles"], wnd.document.defaultView, event["which"], event["which"], event["ctrlKey"], event["altKey"], event["shiftKey"], event["metaKey"], false);
+ wnd.document.dispatchEvent(e);
+Test.AnotherWay._print_counter_result = function(url, msg, milliseconds, style){
+ return Test.AnotherWay._print_result(url, msg + "<span class=\"counter\">" + (milliseconds / 1000).toFixed() + "</span>", style, null);
+Test.AnotherWay._g_result_count = 0; // for assigning unique ids to result paragraphs
+// number of pages tested
+Test.AnotherWay._g_ok_pages = 0;
+Test.AnotherWay._g_fail_pages = 0;
+Test.AnotherWay._print_result = function(url, msg, style, test_objects){
+ var results = document.getElementById("results");
+ var r = results.appendChild(document.createElement("p"));
+ r.id = "result" + Test.AnotherWay._g_result_count;
+ ++Test.AnotherWay._g_result_count;
+ r.onclick = Test.AnotherWay._toggle_detail;
+ var text = "<span class=\"bullet\"> </span> ";
+ if (url != "") {
+ text += url + ": ";
+ if (msg != null) {
+ text += msg;
+ if (test_objects != null) {
+ // compose summary and detail texts
+ var total_ok = 0;
+ var total_detail_ok = 0;
+ var total_fail = 0;
+ var total_detail_fail = 0;
+ var no_plan = 0;
+ var detail = results.appendChild(document.createElement("div"));
+ if (r.id.match(/^result(\d+)$/)) {
+ detail.id = "result_detail" + RegExp.$1;
+ for (var i = 0; i < test_objects.length; ++i) {
+ var o = test_objects[i];
+ var p;
+ var p_text;
+ p = document.createElement("P");
+ Test.AnotherWay._set_css_class(p, "result_detail");
+ p_text = o.name;
+ if (o.n_fail > 0 || o.exception || (o.n_plan != null && o.n_plan != o.n_ok + o.n_fail) || (o.n_plan == null && o.n_ok == 0 && o.n_fail == 0)) {
+ ++total_fail;
+ p_text += " <span class=\"fail\">";
+ if (o.n_plan != null && o.n_plan != o.n_ok + o.n_fail) {
+ p_text += "planned " + o.n_plan + " assertions but got " + (o.n_ok + o.n_fail) + "; ";
+ if (o.n_plan == null && o.n_ok == 0 && o.n_fail == 0) {
+ p_text += "test did not output anything";
+ else {
+ p_text += " fail " + o.n_fail;
+ p_text += "</span>";
+ else {
+ ++total_ok;
+ p_text += " ok " + o.n_ok;
+ if (o.n_plan == null) {
+ no_plan = 1;
+ p_text += " <span class=\"warning\">no plan</span>";
+ p.innerHTML = p_text;
+ detail.appendChild(p);
+ if (o.exception) {
+ Test.AnotherWay._set_css_class(p, "result_exception_detail");
+ p.innerHTML = "<span class=\"fail\">exception:</span> " + o.exception;
+ Test.AnotherWay._set_css_class(p, "result_exception_stack_detail");
+ p.innerHTML = o.exception_stack.join("<br/>");
+ for (var ii = 0; ii < o.assertions.length; ++ii) {
+ var oo = o.assertions[ii];
+ var status = oo.ok ? "ok" : "<span class=\"fail\">fail</span>";
+ Test.AnotherWay._set_css_class(p, "result_micro_detail");
+ p.innerHTML = status;
+ p.appendChild(document.createTextNode(" " + oo.name));
+ total_detail_ok += o.n_ok;
+ total_detail_fail += o.n_fail;
+ if (total_fail || total_detail_fail) {
+ text += " fail " + total_fail;
+ text += " ok " + total_ok + " (detailed:";
+ text += " fail " + total_detail_fail;
+ text += " ok " + total_detail_ok + ")";
+ if (no_plan) {
+ text += " <span class=\"warning\">no plan</span>";
+ style = total_fail == 0 ? "ok" : "fail";
+ detail.style.display = style == "fail" ? "block" : "none";
+ detail.style.cursor = "text";
+ if (style != null) {
+ Test.AnotherWay._set_css_class(r, style);
+ if (style == "ok") {
+ ++Test.AnotherWay._g_ok_pages;
+ else
+ if (style == "fail" || style == "badtest") {
+ ++Test.AnotherWay._g_fail_pages;
+ var pages_total = "";
+ if (Test.AnotherWay._g_fail_pages > 0) {
+ pages_total += " fail " + Test.AnotherWay._g_fail_pages;
+ pages_total += " ok " + Test.AnotherWay._g_ok_pages;
+ // also count out the total number of tests in fail and ok
+ Test.AnotherWay._openlayers_sum_total_detail_ok = Test.AnotherWay._openlayers_sum_total_detail_ok || 0;
+ Test.AnotherWay._openlayers_sum_total_detail_ok += (total_detail_ok||0);
+ Test.AnotherWay._openlayers_sum_total_detail_fail = Test.AnotherWay._openlayers_sum_total_detail_fail || 0;
+ Test.AnotherWay._openlayers_sum_total_detail_fail += (total_detail_fail||0);
+ pages_total+=" (detailed: fail " + Test.AnotherWay._openlayers_sum_total_detail_fail + " | ok " + Test.AnotherWay._openlayers_sum_total_detail_ok + ")";
+ Test.AnotherWay._update_results_total(pages_total);
+ r.innerHTML = text;
+ if (results.scrollHeight != null && results.scrollTop != null && results.offsetHeight != null) {
+ results.scrollTop = results.scrollHeight - results.offsetHeight;
+ // when test_objects is not null, the results are final - good time to clean up
+ var actions = test_objects[i].delay_actions;
+ for (var action_i = 0; action_i < actions.length; ++action_i) {
+ var action = actions[action_i];
+ if (action.action_kind == "window" && action.wnd_wnd != null && !action.wnd_no_close) {
+ action.wnd_wnd.close();
+ action.wnd_wnd = null;
+ return r;
+Test.AnotherWay._unprint_result = function(child){
+ results.removeChild(child);
+Test.AnotherWay._toggle_detail = function(){
+ if (this.id.match(/^result(\d+)$/)) {
+ var detail = document.getElementById("result_detail" + RegExp.$1);
+ if (detail != null) {
+ if (detail.style.display == "none") {
+ detail.style.display = "block";
+ else
+ if (detail.style.display == "block") {
+ detail.style.display = "none";
+Test.AnotherWay._update_msg_counter = function(msg, text){
+ for (var i = 0; i < msg.childNodes.length; ++i) {
+ var item = msg.childNodes[i];
+ if (item.nodeName == "SPAN" && Test.AnotherWay._get_css_class(item) == "counter") {
+ item.innerHTML = text;
+Test.AnotherWay._update_results_total = function(msg){
+ var total = document.getElementById("total");
+ if (total) {
+ total.innerHTML = msg;
+Test.AnotherWay._results_clear_onclick = function(){
+ results.innerHTML = "";
+ Test.AnotherWay._update_results_total("");
+ Test.AnotherWay._g_ok_pages = 0;
+ Test.AnotherWay._g_fail_pages = 0;
+ Test.AnotherWay._openlayers_sum_total_detail_ok=0;
+ Test.AnotherWay._openlayers_sum_total_detail_fail=0;
+ var debug = document.getElementById("debug");
+ debug.innerHTML = "";
+Test.AnotherWay._get_css_class = function(o){
+ var c = o.getAttribute("className");
+ if (c == null || c == "") {
+ c = o.getAttribute("class");
+ return c;
+Test.AnotherWay._set_css_class = function(o, css_class){
+ o.setAttribute("className", css_class);
+ o.setAttribute("class", css_class);
+Test.AnotherWay._tab_onclick = function(){
+ var tab = this;
+ var tabs = [document.getElementById("debug_tab"), document.getElementById("results_tab")];
+ var panes = [document.getElementById("debug"), document.getElementById("results")];
+ for (var i = 0; i < tabs.length; ++i) {
+ if (tab == tabs[i]) {
+ Test.AnotherWay._set_css_class(tabs[i], "active_tab");
+ panes[i].style.display = "block";
+ else {
+ Test.AnotherWay._set_css_class(tabs[i], "inactive_tab");
+ panes[i].style.display = "none";
+Test.AnotherWay._tab_mouseover = function(){
+ if (Test.AnotherWay._get_css_class(this) == "inactive_tab") {
+ Test.AnotherWay._set_css_class(this, "inactive_mouseover_tab");
+Test.AnotherWay._tab_mouseout = function(){
+ if (Test.AnotherWay._get_css_class(this) == "inactive_mouseover_tab") {
+ Test.AnotherWay._set_css_class(this, "inactive_tab");
+// recording mouse input
+Test.AnotherWay._record_check_onfocus = function(){
+ var o = this;
+ var check_select = o.type != "text";
+ var div = document.getElementById("record_div");
+ var inputs = div.getElementsByTagName("input");
+ for (var i = 0; i < inputs.length; ++i) {
+ var input = inputs[i];
+ if (input.type == "radio") {
+ if (input.value == "select") {
+ input.checked = check_select;
+ else
+ if (input.value == "input") {
+ input.checked = !check_select;
+Test.AnotherWay._g_no_record_msg = null; // not null - recording is unavailable
+Test.AnotherWay._g_record_timeout_cnt = 0; // opening window for a page for recording
+Test.AnotherWay._g_record_url = null;
+Test.AnotherWay._g_record_wnd = null;
+Test.AnotherWay._g_record_random_id = null; // added to element ids of record_control div so that they do not clash with ids already in the page for which input is recorded
+Test.AnotherWay._g_record_keydown = null; // recording control - which key is down
+Test.AnotherWay._g_record_ctrl_keydown = false;
+Test.AnotherWay._g_record_shift_keydown = false;
+Test.AnotherWay._g_record_control_visible = true; // recording control ui state
+Test.AnotherWay._g_record_started;
+Test.AnotherWay._g_record_paused;
+Test.AnotherWay._g_record_include_mousemove = false;
+Test.AnotherWay._g_record_start_time; // for time references
+Test.AnotherWay._g_record_pause_start_time;
+Test.AnotherWay._g_record_update_time_interval; // showing time in the control ui
+Test.AnotherWay._g_record_waiting_for_results = false; // waiting for results window to open
+Test.AnotherWay._g_record_events; // recorded events
+Test.AnotherWay._g_record_under_cursor; // track element under cursor
+Test.AnotherWay._g_record_checkpoint_count; // for checkpoint numbering
+Test.AnotherWay._g_record_mouse_over_record_control; // for avoiding record control highlight on mouseover
+Test.AnotherWay._g_record_highlighted_element = {
+ element: null,
+ x: null,
+ y: null
+Test.AnotherWay._record_control_get_element = function(id){
+ if (Test.AnotherWay._g_record_wnd != null && Test.AnotherWay._g_record_wnd.document != null) {
+ return Test.AnotherWay._g_record_wnd.document.getElementById(id + Test.AnotherWay._g_record_random_id);
+ else {
+ return null;
+Test.AnotherWay._record_start_onclick = function() // "record" button on the run_tests.html: open a window for a page for which input is recorded
+ alert(Test.AnotherWay._g_no_record_msg);
+ return;
+ if (Test.AnotherWay._g_record_timeout_cnt > 0 ||
+ (Test.AnotherWay._g_record_wnd != null && (Test.AnotherWay._g_record_wnd.closed != null && !Test.AnotherWay._g_record_wnd.closed))) { // in opera, closed is null.
+ alert("there is already window opened for recording input for a page " + Test.AnotherWay._g_record_url);
+ return;
+ var url = null;
+ if (input.value == "select" && input.checked) {
+ var index = document.getElementById("record_select").selectedIndex;
+ if (index > 0) {
+ url = Test.AnotherWay._g_test_page_urls[index - 1].url;
+ else
+ if (input.value == "input" && input.checked) {
+ url = document.getElementById("record_input").value;
+ if (url != null) {
+ Test.AnotherWay._g_record_url = url;
+ Test.AnotherWay._g_record_wnd = window.open(url, "_blank");
+ if (Test.AnotherWay._g_record_wnd == null) {
+ alert("unable to open new window for a page: " + url);
+ else {
+ Test.AnotherWay._g_record_timeout_cnt = 50;
+ setTimeout(Test.AnotherWay._record_window_timeout, 100);
+Test.AnotherWay._record_window_timeout = function(){
+ if (Test.AnotherWay._is_url_loaded(Test.AnotherWay._g_record_url, Test.AnotherWay._g_record_wnd)) {
+ Test.AnotherWay._record_window_setup(Test.AnotherWay._g_record_wnd);
+ else {
+ if (--Test.AnotherWay._g_record_timeout_cnt > 0) {
+ else {
+ alert("timeout expired while opening new window for a page: " + Test.AnotherWay._g_record_url);
+ Test.AnotherWay._g_record_wnd = null;
+ Test.AnotherWay._g_record_url = null;
+ Test.AnotherWay._g_record_timeout_cnt = 0;
+Test.AnotherWay._record_control_randomize_id = function(e, r){
+ if (e.id != "") {
+ e.id = e.id + r;
+ for (var c = e.firstChild; c != null; c = c.nextSibling) {
+ Test.AnotherWay._record_control_randomize_id(c, r);
+Test.AnotherWay._record_window_setup = function(wnd) // insert recording control into the page for which input is recorded
+ var this_div = document.getElementById("record_control");
+ var record_control = wnd.document.importNode(this_div, true);
+ Test.AnotherWay._g_record_random_id = (1000 * Math.random()).toFixed();
+ Test.AnotherWay._record_control_randomize_id(record_control, Test.AnotherWay._g_record_random_id);
+ Test.AnotherWay._g_record_control_visible = true;
+ Test.AnotherWay._g_record_started = false;
+ Test.AnotherWay._g_record_paused = false;
+ Test.AnotherWay._g_record_checkpoint_count = 0;
+ Test.AnotherWay._g_record_mouse_over_record_control = false;
+ var doc = wnd.document;
+ doc.body.appendChild(record_control);
+ // opera sans-serif font is different
+ if (window.opera) {
+ cursor_over_indicator = Test.AnotherWay._record_control_get_element("record_cursor_over");
+ cursor_over_indicator.style.width = "18em";
+ cursor_over_indicator.style.height = "2em";
+ cursor_over_indicator.style.fontSize = "7pt";
+ doc.addEventListener("keydown", Test.AnotherWay._record_control_keydown, true);
+ doc.addEventListener("keyup", Test.AnotherWay._record_control_keyup, true);
+ // doc.addEventListener( "keypress", Test.AnotherWay._record_event, true ); // replaying is not supported by any known browser
+ doc.body.addEventListener("mousemove", Test.AnotherWay._record_on_mousemove, true);
+ doc.body.addEventListener("click", Test.AnotherWay._record_event, true);
+ doc.body.addEventListener("mouseover", Test.AnotherWay._record_event, true);
+ doc.body.addEventListener("mouseout", Test.AnotherWay._record_event, true);
+ doc.body.addEventListener("mousedown", Test.AnotherWay._record_event, true);
+ doc.body.addEventListener("mouseup", Test.AnotherWay._record_event, true);
+Test.AnotherWay._record_control_key_disabled = function(k){
+ if (k == "c") {
+ return !Test.AnotherWay._g_record_started;
+ else
+ if (k == "p") {
+ else
+ if (k == "s") {
+ return Test.AnotherWay._g_record_waiting_for_results;
+ else {
+ return false;
+Test.AnotherWay._record_control_update_ui = function(){
+ var keydown_color = "#fff";
+ var disabled_color = "#aaa";
+ var button_color = "#adf";
+ var active_color = "#fdf";
+ var display = {};
+ display[false] = "none";
+ display[true] = "inline";
+ var s_button = Test.AnotherWay._record_control_get_element("record_s");
+ var record_on = Test.AnotherWay._record_control_get_element("record_on");
+ var record_off = Test.AnotherWay._record_control_get_element("record_off");
+ s_button.style.backgroundColor = Test.AnotherWay._record_control_key_disabled("s") ? disabled_color : Test.AnotherWay._g_record_keydown == "s" ? keydown_color : Test.AnotherWay._g_record_started ? active_color : button_color;
+ record_on.style.display = display[!Test.AnotherWay._g_record_started];
+ record_off.style.display = display[Test.AnotherWay._g_record_started];
+ var h_button = Test.AnotherWay._record_control_get_element("record_h");
+ h_button.style.backgroundColor = Test.AnotherWay._g_record_keydown == "h" ? keydown_color : button_color;
+ var p_button = Test.AnotherWay._record_control_get_element("record_p");
+ var record_pause_on = Test.AnotherWay._record_control_get_element("record_pause_on");
+ var record_pause_off = Test.AnotherWay._record_control_get_element("record_pause_off");
+ p_button.style.backgroundColor = Test.AnotherWay._record_control_key_disabled("p") ? disabled_color : Test.AnotherWay._g_record_keydown == "p" ? keydown_color : Test.AnotherWay._g_record_paused ? active_color : button_color;
+ record_pause_on.style.display = display[!Test.AnotherWay._g_record_paused];
+ record_pause_off.style.display = display[Test.AnotherWay._g_record_paused];
+ var m_button = Test.AnotherWay._record_control_get_element("record_m");
+ var record_include_mousemove = Test.AnotherWay._record_control_get_element("record_include_mousemove");
+ var record_omit_mousemove = Test.AnotherWay._record_control_get_element("record_omit_mousemove");
+ m_button.style.backgroundColor = Test.AnotherWay._g_record_keydown == "m" ? keydown_color : Test.AnotherWay._g_record_include_mousemove ? active_color : button_color;
+ record_include_mousemove.style.display = display[!Test.AnotherWay._g_record_include_mousemove];
+ record_omit_mousemove.style.display = display[Test.AnotherWay._g_record_include_mousemove];
+ var c_button = Test.AnotherWay._record_control_get_element("record_c");
+ c_button.style.backgroundColor = Test.AnotherWay._record_control_key_disabled("c") ? disabled_color : Test.AnotherWay._g_record_keydown == "c" ? keydown_color : button_color;
+ var record_indicator = Test.AnotherWay._record_control_get_element("record_indicator");
+ record_indicator.style.display = display[Test.AnotherWay._g_record_started];
+ var pause_indicator = Test.AnotherWay._record_control_get_element("record_pause_indicator");
+ pause_indicator.style.display = display[Test.AnotherWay._g_record_paused];
+ var record_control = Test.AnotherWay._record_control_get_element("record_control");
+ record_control.style.display = Test.AnotherWay._g_record_control_visible ? "block" : "none";
+ var shift_button = Test.AnotherWay._record_control_get_element("record_shift_key");
+ shift_button.style.backgroundColor = Test.AnotherWay._g_record_shift_keydown ? keydown_color : button_color;
+ var ctrl_button = Test.AnotherWay._record_control_get_element("record_ctrl_key");
+ ctrl_button.style.backgroundColor = Test.AnotherWay._g_record_ctrl_keydown ? keydown_color : button_color;
+Test.AnotherWay._record_format_time = function(t){
+ t = new Date(t);
+ var m = t.getMinutes();
+ var s = t.getSeconds();
+ var str = m == 0 ? "" : m + "m ";
+ str += s + "s.";
+ return str;
+Test.AnotherWay._record_control_update_time = function(){
+ var time_display = Test.AnotherWay._record_control_get_element("record_time");
+ if (time_display != null) {
+ time_display.innerHTML = Test.AnotherWay._record_format_time((new Date()).getTime() - Test.AnotherWay._g_record_start_time);
+Test.AnotherWay._record_control_update_highlight = function(elem, style, event){
+ if (elem == null) {
+ Test.AnotherWay._record_highlight_border(null);
+ else {
+ var pos = Test.AnotherWay._get_page_coords(elem);
+ if (style == "ball" || elem != Test.AnotherWay._g_record_highlighted_element.element || pos.x != Test.AnotherWay._g_record_highlighted_element.x || pos.y != Test.AnotherWay._g_record_highlighted_element.y) {
+ Test.AnotherWay._g_record_highlighted_element = {
+ element: elem,
+ x: pos.x,
+ y: pos.y
+ Test.AnotherWay._record_highlight_border(elem, style, event);
+Test.AnotherWay._record_decode_key = function(event){
+ var k = null;
+ if (event == null) {
+ k = Test.AnotherWay._g_record_wnd.event.keyCode;
+ else {
+ k = event.which;
+ if (k == 83) {
+ return "s";
+ else
+ if (k == 72) {
+ return "h";
+ else
+ if (k == 73) {
+ return "i";
+ else
+ if (k == 80) {
+ return "p";
+ else
+ if (k == 67) {
+ return "c";
+ else
+ if (k == 77) {
+ return "m";
+ else
+ if (k == 16) {
+ return "shift";
+ else
+ if (k == 17) {
+ return "ctrl";
+ else
+ if (k == 18) {
+ return "alt";
+ else
+ if (k == 19) {
+ return "pause";
+ else
+ if (k == 123) {
+ return "f12";
+ return "";
+Test.AnotherWay._record_control_keydown = function(event){
+ var handled = false;
+ var k = Test.AnotherWay._record_decode_key(event);
+ if (k == "shift") {
+ Test.AnotherWay._g_record_shift_keydown = true;
+ else
+ if (k == "ctrl") {
+ Test.AnotherWay._g_record_ctrl_keydown = true;
+ else
+ if (k != "" && (Test.AnotherWay._g_record_keydown == null || Test.AnotherWay._g_record_keydown == k)) {
+ if (Test.AnotherWay._g_record_ctrl_keydown && Test.AnotherWay._g_record_shift_keydown && !Test.AnotherWay._record_control_key_disabled(k)) {
+ Test.AnotherWay._g_record_keydown = k;
+ handled = true;
+ else {
+ Test.AnotherWay._g_record_keydown = "";
+ Test.AnotherWay._record_control_update_ui();
+ if (!handled) {
+ // Test.AnotherWay._record_event( event ); // replaying is not supported in any known browser
+ return;
+Test.AnotherWay._record_control_keyup = function(event){
+ Test.AnotherWay._g_record_shift_keydown = false;
+ else
+ Test.AnotherWay._g_record_ctrl_keydown = false;
+ else
+ if (k != "" && k == Test.AnotherWay._g_record_keydown && Test.AnotherWay._g_record_ctrl_keydown && Test.AnotherWay._g_record_shift_keydown) {
+ if (k == "s") {
+ Test.AnotherWay._g_record_started = !Test.AnotherWay._g_record_started;
+ if (Test.AnotherWay._g_record_started) {
+ Test.AnotherWay._g_record_events = [];
+ Test.AnotherWay._g_record_start_time = (new Date()).getTime();
+ Test.AnotherWay._record_control_update_time();
+ Test.AnotherWay._g_record_update_time_interval = window.setInterval(Test.AnotherWay._record_control_update_time, 200);
+ else {
+ Test.AnotherWay._record_control_update_highlight(null);
+ if (!Test.AnotherWay._g_record_paused) {
+ window.clearInterval(Test.AnotherWay._g_record_update_time_interval);
+ Test.AnotherWay._g_record_waiting_for_results = true;
+ // open a new window for self, pass a parameter to dump recorded events as javascript code there
+ // (the easiest way to obtain a document from the same origin, so it's writable, is to open this same page again)
+ var loc = window.location;
+ loc = loc.protocol + "//" + loc.host + loc.pathname + "?recording_results=" + Test.AnotherWay._g_record_random_id;
+ if (window.open(loc, "_blank") == null) {
+ alert("unable to open new window for results");
+ handled = true;
+ else
+ if (k == "h") {
+ Test.AnotherWay._g_record_control_visible = !Test.AnotherWay._g_record_control_visible;
+ handled = true;
+ else
+ if (k == "p") {
+ Test.AnotherWay._g_record_paused = !Test.AnotherWay._g_record_paused;
+ if (Test.AnotherWay._g_record_paused) {
+ Test.AnotherWay._g_record_pause_start_time = (new Date()).getTime();
+ else {
+ var pause_duration = (new Date()).getTime() - Test.AnotherWay._g_record_pause_start_time;
+ Test.AnotherWay._g_record_start_time += pause_duration;
+ handled = true;
+ else
+ if (k == "m") {
+ Test.AnotherWay._g_record_include_mousemove = !Test.AnotherWay._g_record_include_mousemove;
+ handled = true;
+ else
+ if (k == "c") {
+ var o = Test.AnotherWay._record_checkpoint();
+ Test.AnotherWay._record_display_checkpoint(o);
+ Test.AnotherWay._record_flash_border("#24d");
+ handled = true;
+ Test.AnotherWay._g_record_keydown = null;
+ if (!handled) {
+ return;
+Test.AnotherWay._record_html_node_path = function(node){
+ if (node == null) {
+ return null;
+ var path = [];
+ while (true) {
+ if (node.id != null && node.id != "") {
+ path.unshift("#" + node.id + " " + node.nodeName);
+ break;
+ else {
+ var parent_node = node.parentNode;
+ if (parent_node == null) {
+ return []; // no BODY up the path - this node is screwed (browsers differ in what's above the body), discard
+ else {
+ var i = 0;
+ for (var child = parent_node.firstChild; child != null; child = child.nextSibling) {
+ if (child == node) {
+ found = true;
+ break;
+ if (child.nodeType == 1) { // count only HTML element nodes
+ ++i;
+ if (!found) {
+ i = -1;
+ path.unshift(i + " " + node.nodeName);
+ if (parent_node.nodeName == "BODY" || parent_node.nodeName == "body") {
+ break;
+ node = parent_node;
+ return path;
+Test.AnotherWay._record_node_path_to_string = function(path){
+ var s = "";
+ if (path != null) {
+ s += i == 0 ? "" : ", ";
+ var elem = path[i].split(" ");
+ if (elem[0].charAt(0) == "#") {
+ s += elem[1] + " " + elem[0];
+ else {
+ s += elem[1] + " [" + elem[0] + "]";
+ return s;
+Test.AnotherWay._record_node_path_to_node = function(path_str, doc){
+ if (path_str == null) {
+ return null;
+ var path = path_str.split(",");
+ var node = doc.body;
+ var node_i = path[i].split(" ")[0];
+ if (node_i.charAt(0) == "#") {
+ node = doc.getElementById(node_i.substring(1));
+ else {
+ if (node_i < 0 || node_i >= node.childNodes.length) {
+ node = null;
+ else {
+ node = node.firstChild;
+ while (node != null) {
+ if (node.nodeType == 1) { // count only HTML element nodes
+ if (node_i == 0) {
+ break;
+ --node_i;
+ node = node.nextSibling;
+ return null;
+ return node;
+Test.AnotherWay._record_control_contains_id = function(s){
+ return s.match(/^#record_[\w_]+/) && s.match(Test.AnotherWay._g_record_random_id);
+Test.AnotherWay._record_checkpoint = function(){
+ var o = {
+ type: "_checkpoint",
+ time: (new Date()).getTime() - Test.AnotherWay._g_record_start_time,
+ which: Test.AnotherWay._g_record_checkpoint_count++,
+ target: Test.AnotherWay._record_html_node_path(Test.AnotherWay._g_record_under_cursor)
+ Test.AnotherWay._g_record_events.push(o);
+ return o;
+Test.AnotherWay._record_event = function(event){
+ var unneeded = ["rangeOffset", "eventPhase", "timeStamp", "isTrusted", "popupWindowFeatures", "rangeOffset"];
+ if (Test.AnotherWay._g_record_started && !Test.AnotherWay._g_record_paused) {
+ var o = {};
+ for (var n in event) {
+ var needed = !n.match(/^[A-Z0-9_]+$/);
+ if (needed) {
+ for (var ui = 0; ui < unneeded.length; ++ui) {
+ if (unneeded[ui] == n) {
+ needed = false;
+ break;
+ if (needed) {
+ var value = event[n];
+ if (typeof(value) != "object" && typeof(value) != "function") {
+ o[n] = value;
+ else
+ if (n == "target" || n == "relatedTarget") {
+ o[n] = Test.AnotherWay._record_html_node_path(value);
+ o["time"] = (new Date()).getTime() - Test.AnotherWay._g_record_start_time;
+ var over_record_control = o["target"] != null && o["target"][0] != null && Test.AnotherWay._record_control_contains_id(o["target"][0]);
+ if (!over_record_control) {
+ return true;
+Test.AnotherWay._record_on_mousemove = function(event){
+ var path = Test.AnotherWay._record_html_node_path(event.target);
+ var new_mouse_over_record_control = path != null && path[0] != null && Test.AnotherWay._record_control_contains_id(path[0]);
+ if (new_mouse_over_record_control != Test.AnotherWay._g_record_mouse_over_record_control) {
+ Test.AnotherWay._g_record_mouse_over_record_control = new_mouse_over_record_control;
+ if (event.target != null && event.target != Test.AnotherWay._g_record_under_cursor) {
+ Test.AnotherWay._g_record_under_cursor = event.target;
+ var s = "";
+ if (path == null || path[0] == null || !Test.AnotherWay._record_control_contains_id(path[0])) {
+ s = Test.AnotherWay._record_node_path_to_string(path);
+ if (s == "") {
+ s = " ";
+ var cursor_over_indicator = Test.AnotherWay._record_control_get_element("record_cursor_over");
+ cursor_over_indicator.innerHTML = s;
+ var highlight_element = null;
+ if (!Test.AnotherWay._g_record_mouse_over_record_control && Test.AnotherWay._g_record_started && !Test.AnotherWay._g_record_paused) {
+ highlight_element = event.target;
+ // highlight border disabled on recording - it causes page to scroll, issuing spurious mouseover/mouseout event
+ //Test.AnotherWay._record_control_update_highlight( highlight_element, "border" );
+ if (Test.AnotherWay._g_record_include_mousemove) {
+ Test.AnotherWay._record_event(event);
+ return true;
+Test.AnotherWay._record_display_checkpoint = function(o){
+ var checkpoints_div = Test.AnotherWay._record_control_get_element("record_checkpoints");
+ var p = checkpoints_div.appendChild(checkpoints_div.ownerDocument.createElement("div"));
+ p.style.marginTop = "3px";
+ p.style.font = "normal normal 8pt sans-serif";
+ p.style.color = "#000";
+ p.style.textAligh = "left";
+ p.style.position = "relative";
+ p.style.width = "100%";
+ var checkpoint_text = "";
+ checkpoint_text += "#" + (o.which + 1);
+ checkpoint_text += " " + Test.AnotherWay._record_format_time(o.time);
+ if (o.target != null) {
+ checkpoint_text += Test.AnotherWay._record_node_path_to_string(o.target);
+ p.appendChild(p.ownerDocument.createTextNode(checkpoint_text));
+Test.AnotherWay._record_save_results = function(doc){
+ // strange, but DOM-style append does not work here in opera 8.
+ var append = function(s){
+ doc.write("<div>" + s + "</div>");
+ append("/* paste this data into your javascript and pass it as an argument to replay_events method */");
+ append("{ checkpoints: [");
+ var first_checkpoint = true;
+ for (var i = 0; i < Test.AnotherWay._g_record_events.length; ++i) {
+ var o = Test.AnotherWay._g_record_events[i];
+ if (o.type == "_checkpoint") {
+ var str = first_checkpoint ? "" : "}, ";
+ str += "function( tst, wnd ) { // #" + o.which + " time " + Test.AnotherWay._record_format_time(o.time) + " cursor was over " + Test.AnotherWay._record_node_path_to_string(o.target);
+ append(str);
+ first_checkpoint = false;
+ if (!first_checkpoint) {
+ append("}");
+ append("], events: [ ");
+ var prev_time = 0;
+ var s = "";
+ s += "{";
+ var n_first = true;
+ for (var n in o) {
+ if (n == "time") { // convert to relative time
+ var cur_time = o[n] - 0;
+ o[n] = cur_time - prev_time;
+ prev_time = cur_time;
+ s += n_first ? n : ", " + n;
+ s += ":";
+ if (o[n] == null) {
+ s += "null";
+ else {
+ s += "\"" + o[n] + "\"";
+ n_first = false;
+ s += i == Test.AnotherWay._g_record_events.length - 1 ? "}" : "},";
+ append(s);
+ append("] }");
+ append(";");
+Test.AnotherWay._g_record_border; // border highlighting element under cursor
+Test.AnotherWay._g_record_border_flashes = []; // array of { color: color, timeout: milliseconds }
+Test.AnotherWay._g_record_border_flashing = false;
+Test.AnotherWay._g_record_border_normal_color = "#d4b";
+Test.AnotherWay._record_flash_border_timeout = function(){
+ var color = Test.AnotherWay._g_record_border_normal_color;
+ var timeout = null;
+ if (Test.AnotherWay._g_record_border_flashes.length != 0) {
+ color = Test.AnotherWay._g_record_border_flashes[0].color;
+ timeout = Test.AnotherWay._g_record_border_flashes[0].timeout;
+ Test.AnotherWay._g_record_border_flashes.splice(0, 1);
+ if (Test.AnotherWay._g_record_border != null) {
+ for (var i = 0; i < Test.AnotherWay._g_record_border.length; ++i) {
+ Test.AnotherWay._g_record_border[i].style.backgroundColor = color;
+ if (timeout != null) {
+ setTimeout(Test.AnotherWay._record_flash_border_timeout, timeout);
+ else {
+ Test.AnotherWay._g_record_border_flashing = false;
+Test.AnotherWay._get_page_coords = function(elm){
+ var point = {
+ x: 0,
+ y: 0
+ while (elm) {
+ point.x += elm.offsetLeft;
+ point.y += elm.offsetTop;
+ elm = elm.offsetParent;
+ return point;
+Test.AnotherWay._set_page_coords = function(elm, x, y){
+ var parent_coords = {
+ x: 0,
+ y: 0
+ if (elm.offsetParent) {
+ parent_coords = Test.AnotherWay._get_page_coords(elm.offsetParent);
+ var new_x = x - parent_coords.x;
+ if (new_x < 0) {
+ new_x = 0;
+ elm.style.left = new_x + 'px';
+ var new_y = y - parent_coords.y;
+ if (new_y < 0) {
+ new_y = 0;
+ elm.style.top = new_y + 'px';
+Test.AnotherWay._record_setup_highlight_positions = function(element, style, coords, positions){
+ if (style == "border") {
+ var width = element.clientWidth;
+ var height = element.clientHeight;
+ var step = 0;
+ var thickness = 2;
+ var fudge_expand = 4;
+ positions.push({
+ x: coords.x - step - thickness,
+ y: coords.y - step - thickness,
+ width: width + 2 * step + 2 * thickness + fudge_expand,
+ height: thickness
+ positions.push({
+ x: coords.x + width + step + fudge_expand,
+ width: thickness,
+ height: height + 2 * step + 2 * thickness + fudge_expand
+ positions.push({
+ x: positions[0].x,
+ y: positions[0].y,
+ width: positions[0].width,
+ height: positions[0].height
+ positions.push({
+ x: positions[1].x,
+ y: positions[1].y,
+ width: positions[1].width,
+ height: positions[1].height
+ positions[2].y += height + thickness + 2 * step + fudge_expand;
+ positions[3].x -= width + thickness + 2 * step + fudge_expand;
+ else
+ if (style == "ball") {
+ positions.push({
+ x: coords.x + 2,
+ y: coords.y,
+ width: 2,
+ height: 6
+ positions.push({
+ x: coords.x,
+ y: coords.y + 2,
+ width: 6,
+ height: 2
+ positions.push({
+ x: coords.x + 1,
+ y: coords.y + 1,
+ width: 4,
+ height: 4
+Test.AnotherWay._record_highlight_border = function(element, style, event) // null - hide border
+ if (element != null) {
+ if (Test.AnotherWay._g_record_border == null || Test.AnotherWay._g_record_border[0].ownerDocument != element.ownerDocument) {
+ Test.AnotherWay._g_record_border = [];
+ var n = style == "border" ? 4 : style == "ball" ? 3 : 0;
+ for (var i = 0; i < 4; ++i) {
+ var b = element.ownerDocument.createElement("div");
+ b.style.position = "absolute";
+ b.style.zIndex = "1";
+ b.style.backgroundColor = Test.AnotherWay._g_record_border_normal_color;
+ element.ownerDocument.body.appendChild(b);
+ Test.AnotherWay._g_record_border.push(b);
+ var coords = null;
+ coords = Test.AnotherWay._get_page_coords(element);
+ else
+ if (event != null) {
+ if (event.pageX != null && event.pageY != null) {
+ coords = {
+ x: event.pageX - 0,
+ y: event.pageY - 0
+ else
+ if (event.clientX != null && event.clientY != null) {
+ var doc = element.ownerDocument;
+ if (doc != null) {
+ coords = {
+ x: (event.clientX - 0) + doc.body.scrollLeft,
+ y: (event.clientY - 0) + doc.body.scrollTop
+ if (coords != null && element.clientWidth != null && element.clientHeight != null) {
+ var positions = [];
+ Test.AnotherWay._record_setup_highlight_positions(element, style, coords, positions);
+ for (var i = 0; i < positions.length; ++i) {
+ var b = Test.AnotherWay._g_record_border[i];
+ var p = positions[i];
+ Test.AnotherWay._set_page_coords(b, p.x, p.y);
+ b.style.width = p.width + "px";
+ b.style.height = p.height + "px";
+ b.style.display = "block";
+ else {
+ Test.AnotherWay._g_record_border[i].style.display = "none";
+Test.AnotherWay._record_flash_border = function(color){
+ if (Test.AnotherWay._g_record_border_flashing) { //already
+ Test.AnotherWay._g_record_border_flashes.push({
+ color: Test.AnotherWay._g_record_border_normal_color,
+ timeout: 300
+ color: color,
+ timeout: 600
+ else {
+ Test.AnotherWay._g_record_border_flashing = true;
+ color: color,
+ timeout: 600
+ Test.AnotherWay._record_flash_border_timeout();
+Test.AnotherWay._record_prepare_doc_for_results = function(){
+ document.open();
+ document.write("<!DOCTYPE HTML PUBLIC \"-//W3C//DTD HTML 4.01//EN\" \"http://www.w3.org/TR/html4/strict.dtd\">");
+ document.write("<html><head><title> Input recording results</title>");
+ document.write("<style type=\"text/css\">");
+ document.write("body { font: normal normal smaller sans-serif; }");
+ document.write("div { margin-top: 3px; }");
+ document.write("</style></head><body>");
+ // opera and mozilla disagree over who the opener is.
+ if (typeof(window.opener.Test) != "undefined" && typeof(window.opener.Test.AnotherWay) != "undefined") {
+ window.opener.Test.AnotherWay._record_save_results(document);
+ window.opener.Test.AnotherWay._g_record_waiting_for_results = false;
+ window.opener.Test.AnotherWay._record_control_update_ui();
+ else
+ if (typeof(window.opener.opener.Test) != "undefined" && typeof(window.opener.opener.Test.AnotherWay) != "undefined") {
+ window.opener.opener.Test.AnotherWay._record_save_results(document);
+ window.opener.opener.Test.AnotherWay._g_record_waiting_for_results = false;
+ window.opener.opener.Test.AnotherWay._record_control_update_ui();
+ document.write("</body>");
+ document.close();
+// global initialization
+onload = function(){
+ var good_opera = typeof(window.opera.version) == "function";
+ good_opera = good_opera && window.opera.version().match(/^\s*(\d+)/);
+ good_opera = good_opera && RegExp.$1 >= 8;
+ var span = document.createElement("SPAN");
+ span.innerHTML = "<!--[if IE]><br /><![endif]-" + "->";
+ var is_ie = span.getElementsByTagName("BR").length > 0;
+ Test.AnotherWay._g_test_iframe = window.frames.test_iframe;
+ var query_str = window.location.search;
+ if (query_str.charAt(0) == "?") {
+ query_str = query_str.substring(1);
+ var testlist_page = "list-tests.html";
+ var auto_run = false;
+ if (query_str != "") {
+ var params = [query_str];
+ if (query_str.indexOf(";") != -1) {
+ params = query_str.split(";");
+ else
+ if (query_str.indexOf("&") != -1) {
+ params = query_str.split("&");
+ for (var param_i = 0; param_i < params.length; ++param_i) {
+ var param = params[param_i].split("=");
+ if (param[0] == "recording_results") {
+ if (window.opener != null) {
+ // we were told to show recording results - replace everything in the document with the results
+ Test.AnotherWay._record_prepare_doc_for_results();
+ return;
+ else
+ if (param[0] == "testpage") {
+ Test.AnotherWay._add_test_page_url(decodeURIComponent(param[1]), "anotherway");
+ else
+ if (param[0] == "jsantestpage") {
+ Test.AnotherWay._add_test_page_url(decodeURIComponent(param[1]), "jsan");
+ else
+ if (param[0] == "testlist") {
+ testlist_page = decodeURIComponent(param[1]);
+ else
+ if (param[0] == "testframe") {
+ if (window.opera && !good_opera) {
+ Test.AnotherWay._show_error("testframe parameter does not work in versions of Opera prior to 8.0. Sorry (pathches are welcome).");
+ // Opera 7 barfs on attempt to access frame.frameElement.
+ // if someone knows a way to assign onload handler to that iframe in Opera 7
+ // without disrupting code that works in other browsers, patches are welcome.
+ else {
+ var frame_path = param[1].split(".");
+ var frame = top;
+ for (var frame_path_i = 0; frame_path_i < frame_path.length; ++frame_path_i) {
+ frame = frame[frame_path[frame_path_i]];
+ if (frame == null) {
+ Test.AnotherWay._show_error("unable to find frame specified for loading test pages: " + param[1]);
+ else {
+ if (frame.frameElement != null) { // for the following assignement to onload to work, frameElement is required
+ frame = frame.frameElement;
+ Test.AnotherWay._g_test_iframe = frame;
+ else
+ if (param[0] == "testframe_no_clear") {
+ Test.AnotherWay._g_test_frame_no_clear = true;
+ else
+ if (param[0] == "windows") {
+ if (param[1] == "none") {
+ Test.AnotherWay._test_object_t.prototype.open_window = null;
+ else
+ if (param[0] == "run") {
+ auto_run = true;
+ if (param[1] == "all") {
+ Test.AnotherWay._g_pages_to_run = "all";
+ else {
+ if (Test.AnotherWay._g_pages_to_run == null || Test.AnotherWay._g_pages_to_run == "all") {
+ Test.AnotherWay._g_pages_to_run = [];
+ var pages = param[1].split(",");
+ for (var i = 0; i < pages.length; ++i) {
+ Test.AnotherWay._g_pages_to_run.push(pages[i]);
+ if (Test.AnotherWay._g_test_page_urls.length == 0) { // if no individual pages were given on the command line, load the list
+ var result = Test.AnotherWay._set_iframe_location(window.frames["list_iframe"], testlist_page);
+ Test.AnotherWay._show_error(result.msg);
+ Test.AnotherWay._g_run_on_list_load = auto_run;
+ else {
+ Test.AnotherWay._g_run_on_main_load = auto_run;
+ var f = Test.AnotherWay._g_test_iframe;
+ try {
+ if (f.attachEvent != null) {
+ f.attachEvent("onload", Test.AnotherWay._test_page_onload);
+ else {
+ f.onload = Test.AnotherWay._test_page_onload;
+ if (Test.AnotherWay._g_test_iframe.nodeType != null && Test.AnotherWay._g_test_iframe.contentWindow != null) { // it's iframe element, not the iframe. we need iframe.
+ Test.AnotherWay._g_test_iframe = Test.AnotherWay._g_test_iframe.contentWindow;
+ catch (e) {
+ // ignore stupid opera error if the frame has onload handler assigned in the inline html
+ var handlers = {
+ "run_all": {
+ "onclick": Test.AnotherWay._run_all_onclick
+ "run_selected": {
+ "onclick": Test.AnotherWay._run_selected_onclick
+ "unselect_all": {
+ "onclick": Test.AnotherWay._unselect_all_onclick
+ "record_select": {
+ "onfocus": Test.AnotherWay._record_check_onfocus
+ "record_input": {
+ "record_start": {
+ "onclick": Test.AnotherWay._record_start_onclick
+ "clear_btn": {
+ "onclick": Test.AnotherWay._results_clear_onclick
+ "results_tab": {
+ "onclick": Test.AnotherWay._tab_onclick,
+ "onmouseover": Test.AnotherWay._tab_mouseover,
+ "onmouseout": Test.AnotherWay._tab_mouseout
+ "debug_tab": {
+ for (var hs in handlers) {
+ var o = document.getElementById(hs);
+ if (o != null) {
+ for (var h in handlers[hs]) {
+ o[h] = handlers[hs][h];
+ else {
+ Test.AnotherWay._show_error("unable to set " + h + " handler: id " + hs + " not found");
+ Test.AnotherWay._g_no_record_msg = "Input events recording and replaying is not available in opera versions prior to 8.0.";
+ if (is_ie) {
+ Test.AnotherWay._g_no_record_msg = "Input events recording and replaying is not available in internet explorer.";
+ var no_record_p = document.getElementById("record_not_supported");
+ no_record_p.style.display = "block";
+ no_record_p.appendChild(document.createTextNode(Test.AnotherWay._g_no_record_msg));
+ Test.AnotherWay._g_main_loaded = true;
+ if (Test.AnotherWay._g_run_on_main_load) {
+ Test.AnotherWay._g_run_on_main_load = false;
+ Test.AnotherWay._run_pages_to_run();
Added: trunk/openlayers/tests/Test.AnotherWay.xml_eq.js
--- trunk/openlayers/tests/Test.AnotherWay.xml_eq.js (rev 0)
+++ trunk/openlayers/tests/Test.AnotherWay.xml_eq.js 2011-09-17 17:36:14 UTC (rev 12378)
@@ -0,0 +1,311 @@
+ * File: Test.AnotherWay.xml_eq.js
+ * Adds a xml_eq method to AnotherWay test objects.
+(function() {
+ * Function: createNode
+ * Given a string, try to create an XML DOM node. Throws string messages
+ * on failure.
+ * Parameters:
+ * text - {String} An XML string.
+ * Returns:
+ * {DOMElement} An element node.
+ function createNode(text) {
+ var index = text.indexOf('<');
+ if(index > 0) {
+ text = text.substring(index);
+ var doc;
+ if(window.ActiveXObject && !this.xmldom) {
+ doc = new ActiveXObject("Microsoft.XMLDOM");
+ try {
+ doc.loadXML(text);
+ } catch(err) {
+ throw "ActiveXObject loadXML failed: " + err;
+ } else if(window.DOMParser) {
+ try {
+ doc = new DOMParser().parseFromString(text, 'text/xml');
+ } catch(err) {
+ throw "DOMParser.parseFromString failed";
+ if(doc.documentElement && doc.documentElement.nodeName == "parsererror") {
+ throw "DOMParser.parseFromString returned parsererror";
+ } else {
+ var req = new XMLHttpRequest();
+ req.open("GET", "data:text/xml;charset=utf-8," +
+ encodeURIComponent(text), false);
+ if(req.overrideMimeType) {
+ req.overrideMimeType("text/xml");
+ req.send(null);
+ doc = req.responseXML;
+ var root = doc.documentElement;
+ if(!root) {
+ throw "no documentElement";
+ return root;
+ * Function assertEqual
+ * Test two objects for equivalence (based on ==). Throw an exception
+ * if not equivalent.
+ * Parameters:
+ * got - {Object}
+ * expected - {Object}
+ * msg - {String} The message to be thrown. This message will be appended
+ * with ": got {got} but expected {expected}" where got and expected are
+ * replaced with string representations of the above arguments.
+ function assertEqual(got, expected, msg) {
+ if(got === undefined) {
+ got = "undefined";
+ } else if (got === null) {
+ got = "null";
+ if(expected === undefined) {
+ expected = "undefined";
+ } else if (expected === null) {
+ expected = "null";
+ if(got != expected) {
+ throw msg + ": got '" + got + "' but expected '" + expected + "'";
+ * Function assertElementNodesEqual
+ * Test two element nodes for equivalence. Nodes are considered equivalent
+ * if they are of the same type, have the same name, have the same
+ * namespace prefix and uri, and if all child nodes are equivalent.
+ * Throws a message as exception if not equivalent.
+ * Parameters:
+ * got - {DOMElement}
+ * expected - {DOMElement}
+ * options - {Object} Optional object for configuring test options.
+ * Valid options:
+ * prefix - {Boolean} Compare element and attribute
+ * prefixes (namespace uri always tested). Default is false.
+ * includeWhiteSpace - {Boolean} Include whitespace only nodes when
+ * comparing child nodes. Default is false.
+ function assertElementNodesEqual(got, expected, options) {
+ var testPrefix = (options && options.prefix === true);
+ // compare types
+ assertEqual(got.nodeType, expected.nodeType, "Node type mismatch");
+ // compare names
+ var gotName = testPrefix ?
+ got.nodeName : got.nodeName.split(":").pop();
+ var expName = testPrefix ?
+ expected.nodeName : expected.nodeName.split(":").pop();
+ assertEqual(gotName, expName, "Node name mismatch");
+ // for text nodes compare value
+ if(got.nodeType == 3) {
+ assertEqual(
+ got.nodeValue, expected.nodeValue, "Node value mismatch"
+ // for element type nodes compare namespace, attributes, and children
+ else if(got.nodeType == 1) {
+ // test namespace alias and uri
+ if(got.prefix || expected.prefix) {
+ if(testPrefix) {
+ assertEqual(
+ got.prefix, expected.prefix,
+ "Bad prefix for " + got.nodeName
+ if(got.namespaceURI || expected.namespaceURI) {
+ assertEqual(
+ got.namespaceURI, expected.namespaceURI,
+ "Bad namespaceURI for " + got.nodeName
+ // compare attributes - disregard xmlns given namespace handling above
+ var gotAttrLen = 0;
+ var gotAttr = {};
+ var expAttrLen = 0;
+ var expAttr = {};
+ var ga, ea, gn, en;
+ for(var i=0; i<got.attributes.length; ++i) {
+ ga = got.attributes[i];
+ if(ga.specified === undefined || ga.specified === true) {
+ if(ga.name.split(":").shift() != "xmlns") {
+ gn = testPrefix ? ga.name : ga.name.split(":").pop();
+ gotAttr[gn] = ga;
+ ++gotAttrLen;
+ for(var i=0; i<expected.attributes.length; ++i) {
+ ea = expected.attributes[i];
+ if(ea.specified === undefined || ea.specified === true) {
+ if(ea.name.split(":").shift() != "xmlns") {
+ en = testPrefix ? ea.name : ea.name.split(":").pop();
+ expAttr[en] = ea;
+ ++expAttrLen;
+ assertEqual(
+ gotAttrLen, expAttrLen,
+ "Attributes length mismatch for " + got.nodeName
+ var gv, ev;
+ for(var name in gotAttr) {
+ if(expAttr[name] == undefined) {
+ throw "Attribute name " + gotAttr[name].name + " expected for element " + got.nodeName;
+ // test attribute namespace
+ assertEqual(
+ gotAttr[name].namespaceURI, expAttr[name].namespaceURI,
+ "Attribute namespace mismatch for element " +
+ got.nodeName + " attribute name " + gotAttr[name].name
+ // test attribute value
+ assertEqual(
+ gotAttr[name].value, expAttr[name].value,
+ "Attribute value mismatch for element " + got.nodeName +
+ // compare children
+ var gotChildNodes = getChildNodes(got, options);
+ var expChildNodes = getChildNodes(expected, options);
+ assertEqual(
+ gotChildNodes.length, expChildNodes.length,
+ "Children length mismatch for " + got.nodeName
+ for(var j=0; j<gotChildNodes.length; ++j) {
+ try {
+ assertElementNodesEqual(
+ gotChildNodes[j], expChildNodes[j], options
+ } catch(err) {
+ throw "Bad child " + j + " for element " + got.nodeName + ": " + err;
+ return true;
+ * Function getChildNodes
+ * Returns the child nodes of the specified nodes. By default this method
+ * will ignore child text nodes which are made up of whitespace content.
+ * The 'includeWhiteSpace' option is used to control this behaviour.
+ * Parameters:
+ * node - {DOMElement}
+ * options - {Object} Optional object for test configuration.
+ * Valid options:
+ * Returns:
+ * {Array} of {DOMElement}
+ function getChildNodes(node, options) {
+ //check whitespace
+ if (options && options.includeWhiteSpace) {
+ return node.childNodes;
+ else {
+ nodes = [];
+ for (var i = 0; i < node.childNodes.length; i++ ) {
+ var child = node.childNodes[i];
+ //element node, add it
+ nodes.push(child);
+ else if (child.nodeType == 3) {
+ //text node, add if non empty
+ if (child.nodeValue &&
+ child.nodeValue.replace(/^\s*(.*?)\s*$/, "$1") != "" ) {
+ return nodes;
+ * Function: Test.AnotherWay._test_object_t.xml_eq
+ * Test if two XML nodes are equivalent. Tests for same node types, same
+ * node names, same namespace URI, same attributes, and recursively
+ * tests child nodes for same criteria.
+ * (code)
+ * t.xml_eq(got, expected, message);
+ * (end)
+ * Parameters:
+ * got - {DOMElement | String} A DOM node or XML string to test.
+ * expected - {DOMElement | String} The expected DOM node or XML string.
+ * msg - {String} A message to print with test output.
+ * options - {Object} Optional object for configuring test.
+ * Valid options:
+ var proto = Test.AnotherWay._test_object_t.prototype;
+ proto.xml_eq = function(got, expected, msg, options) {
+ // convert arguments to nodes if string
+ if(typeof got == "string") {
+ try {
+ got = createNode(got);
+ } catch(err) {
+ this.fail(msg + ": got argument could not be converted to an XML node: " + err);
+ return;
+ if(typeof expected == "string") {
+ try {
+ expected = createNode(expected);
+ } catch(err) {
+ this.fail(msg + ": expected argument could not be converted to an XML node: " + err);
+ return;
+ // test nodes for equivalence
+ try {
+ assertElementNodesEqual(got, expected, options);
+ this.ok(true, msg);
+ } catch(err) {
+ this.fail(msg + ": " + err);
Deleted: trunk/openlayers/tests/geom_eq.js
--- trunk/openlayers/tests/geom_eq.js 2011-09-17 17:30:36 UTC (rev 12377)
+++ trunk/openlayers/tests/geom_eq.js 2011-09-17 17:36:14 UTC (rev 12378)
@@ -1,110 +0,0 @@
- * File: xml_eq.js
- * Adds a xml_eq method to AnotherWay test objects.
-(function() {
- * Function assertEqual
- * Test two objects for equivalence (based on ==). Throw an exception
- * if not equivalent.
- * Parameters:
- * got - {Object}
- * expected - {Object}
- * msg - {String} The message to be thrown. This message will be appended
- * with ": got {got} but expected {expected}" where got and expected are
- * replaced with string representations of the above arguments.
- function assertEqual(got, expected, msg) {
- if(got === undefined) {
- got = "undefined";
- } else if (got === null) {
- got = "null";
- if(expected === undefined) {
- expected = "undefined";
- } else if (expected === null) {
- expected = "null";
- if(got != expected) {
- throw msg + ": got '" + got + "' but expected '" + expected + "'";
- * Function assertGeometryEqual
- * Test two geometries for equivalence. Geometries are considered
- * equivalent if they are of the same class, and given component
- * geometries, if all components are equivalent. Throws a message as
- * exception if not equivalent.
- * Parameters:
- * got - {OpenLayers.Geometry}
- * expected - {OpenLayers.Geometry}
- * options - {Object} Optional object for configuring test options.
- function assertGeometryEqual(got, expected, options) {
- var OpenLayers = Test.AnotherWay._g_test_iframe.OpenLayers;
- // compare types
- assertEqual(typeof got, typeof expected, "Object types mismatch");
- // compare classes
- assertEqual(got.CLASS_NAME, expected.CLASS_NAME, "Object class mismatch");
- if(got instanceof OpenLayers.Geometry.Point) {
- // compare points
- assertEqual(got.x, expected.x, "x mismatch");
- assertEqual(got.y, expected.y, "y mismatch");
- assertEqual(got.z, expected.z, "z mismatch");
- } else {
- // compare components
- assertEqual(
- got.components.length, expected.components.length,
- "Component length mismatch for " + got.CLASS_NAME
- for(var i=0; i<got.components.length; ++i) {
- try {
- assertGeometryEqual(
- got.components[i], expected.components[i], options
- } catch(err) {
- throw "Bad component " + i + " for " + got.CLASS_NAME + ": " + err;
- return true;
- * Function: Test.AnotherWay._test_object_t.geom_eq
- * Test if two geometry objects are equivalent. Tests for same geometry
- * class, same number of components (if any), equivalent component
- * geometries, and same coordinates.
- * (code)
- * t.geom_eq(got, expected, message);
- * (end)
- * Parameters:
- * got - {OpenLayers.Geometry} Any geometry instance.
- * expected - {OpenLayers.Geometry} The expected geometry.
- * msg - {String} A message to print with test output.
- var proto = Test.AnotherWay._test_object_t.prototype;
- proto.geom_eq = function(got, expected, msg, options) {
- // test geometries for equivalence
- try {
- assertGeometryEqual(got, expected, options);
- this.ok(true, msg);
- } catch(err) {
- this.fail(msg + ": " + err);
\ No newline at end of file
Modified: trunk/openlayers/tests/run-tests.html
--- trunk/openlayers/tests/run-tests.html 2011-09-17 17:30:36 UTC (rev 12377)
+++ trunk/openlayers/tests/run-tests.html 2011-09-17 17:36:14 UTC (rev 12378)
@@ -1,2419 +1,153 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
-<html><head><title> Run the testsuite</title>
-<noscript>Javascript is disabled in your browser. This page cannot be displayed correctly without Javascript. Sorry. <br/> If you want to view this page, please change your browser settings so that Javascript is enabled.</noscript>
-Test.AnotherWay version 0.5
-Copyright (c) 2005 Artem Khodush, http://straytree.org
-Permission is hereby granted, free of charge, to any person obtaining
-a copy of this software and associated documentation files (the
-"Software"), to deal in the Software without restriction, including
-without limitation the rights to use, copy, modify, merge, publish,
-distribute, sublicense, and/or sell copies of the Software, and to
-permit persons to whom the Software is furnished to do so, subject to
-the following conditions:
-The above copyright notice and this permission notice shall be
-included in all copies or substantial portions of the Software.
-THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
-EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
-MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
-NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE
-LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION
-OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION
-WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
-<style type="text/css">
-* { padding: 0; margin: 0; }
-html { height: 99%; }
-body { height: 98%; font: normal normal 10pt sans-serif }
-#col1 { float: left; width: 27em; margin: 0 0 0 1em; overflow: visible; }
-#col2 { position: relative; height: 98%; margin: 0 0.5em 0 28em; }
-#col1_header { margin-top: 0.5em; }
-#scroller { height: 400px; overflow: auto;}
-#testtable { margin: 0 0 2em 0; width: 97%; }
-#run_buttons { margin-bottom: 4em; }
-#right_header { padding-top: 0.8em; }
-#results_count { float: left; }
-.active_tab { float: right; padding: 0 1em 0.2em 1em; background: #0af; border: 1px solid #048; border-bottom: none; cursor: pointer; cursor: hand;
- position: relative; top: -0.2em; }
-.inactive_tab { float: right; padding: 0 1em 0 1em; background: #9bb; color: #444; border: 1px solid #9bb; border-bottom: none; cursor: pointer; cursor: hand; }
-.inactive_mouseover_tab { float: right; padding: 0 1em 0 1em; background: #9bb; color: #062; border: 1px solid #062; border-bottom: none; cursor: pointer; cursor: hand; }
-#right_frame { overflow: auto; position: relative; top: -0.2em; clear: right; height: 95%; border: 1px solid #048; }
-#debug { display: none; }
-#debug p { margin: 2px 0 0 5em; text-indent: -4.8em; }
-#error { display: none; color: #c22; }
-#results p { margin: 0 0 2px 0; }
-/* cursor indicating that detailed results may be expanded/contracted */
-#results p.badtest { cursor: text; }
-#results p.ok, #results p.fail { cursor: pointer; cursor: hand; }
-/* colored squares in the results window at the left of test page names */
-#results p.ok .bullet { background: #6d6; }
-#results p.fail .bullet { background: #d46; }
-#results p.badtest .bullet { background: #ea3; }
-#results p.loading .bullet { background: #48f; }
-#results p.running .bullet { background: #26e; }
-#results p.waiting .bullet { background: #04d; }
-/* highlight in the results line */
-#results p .warning { background: #ffc; }
-/* layout of the detailed results */
-.result_detail { padding-left: 3em; }
-.result_exception_detail { padding-left: 4em; }
-.result_exception_stack_detail { padding-left: 5em; }
-.result_micro_detail { padding-left: 6em; }
-/* colouring in the detailed results */
-.result_detail .fail, .result_exception_detail .fail, .result_micro_detail .fail { background: #ffd8d8; }
-/* "start recording" controls*/
-#record_div { margin-top: 3em; }
-#record_div p { margin-bottom: 0.5em; }
-#record_select { width: 88%; }
-#record_input { width: 53%; }
-</style>
-<script type="text/javascript">
-if( typeof( Test )=="undefined" ) {
- Test={};
-Test.AnotherWay={};
-Test.AnotherWay._g_test_iframe=null; // frame where to load test pages
-Test.AnotherWay._g_test_frame_no_clear=false; // true - leave last page displayed after tests end
-Test.AnotherWay._g_test_page_urls=[]; // array of: { url: url, convention: "anotherway" or "jsan" }
-Test.AnotherWay._g_test_object_for_jsan=null; // test object for filling by tests that adhere to jsan Test.Simple calling convention
-Test.AnotherWay._g_pages_to_run=null; // list of pages to run automatically after loading
-Test.AnotherWay._g_run_on_main_load=false; // special handling for run_pages_to_run when it might be called before onload or before list of test pages is known.
-Test.AnotherWay._g_run_on_list_load=false;
-Test.AnotherWay._g_main_loaded=false;
-Test.AnotherWay._run_pages_to_run=function( called_from_outside )
- if( !Test.AnotherWay._g_main_loaded ) {
- Test.AnotherWay._g_run_on_main_load=true;
- }else {
- var a_pages=Test.AnotherWay._g_pages_to_run;
- if( a_pages=="all" ) {
- for( var i=0; i<Test.AnotherWay._g_test_page_urls.length; ++i ) {
- Test.AnotherWay._run_test_page( "test"+i );
- }else if( a_pages!=null ) {
- for( var run_i=0; run_i<a_pages.length; ++run_i ) {
- var run_page=a_pages[run_i];
- var found=false;
- for( var all_i=0; all_i<Test.AnotherWay._g_test_page_urls.length; ++all_i ) {
- if( run_page==Test.AnotherWay._g_test_page_urls[all_i].url ) {
- Test.AnotherWay._run_test_page( "test"+all_i, called_from_outside );
- found=true;
- break;
- if( !found ) {
- Test.AnotherWay._show_error( "page specified to run is not found in the page list: "+run_page );
- break;
-Test.AnotherWay._add_test_page_url=function( test_url, convention )
- var table=document.getElementById( "testtable" );
- var record_select=document.getElementById( "record_select" );
- var index=Test.AnotherWay._g_test_page_urls.length;
- // trim spaces.
- if( test_url.match( "^(\\s*)(.*\\S)(\\s*)$" ) ) {
- test_url=RegExp.$2;
- Test.AnotherWay._g_test_page_urls[index]={ url: test_url, convention: convention };
- var row=table.insertRow( -1 );
- var cell;
- var cell_child;
- cell=row.insertCell( -1 );
- cell_child=document.createElement( "input" );
- cell_child.type="checkbox";
- cell_child.id="checkbox"+index;
- cell_child.checked='checked';
- cell_child.defaultChecked='checked';
- cell.appendChild( cell_child );
- cell.setAttribute( "width", "75%" );
- cell.appendChild( document.createTextNode( test_url ) );
- cell_child.type="button";
- cell_child.id="test"+index;
- cell_child.value=" run ";
- cell_child.onclick=Test.AnotherWay._run_one_onclick;
- cell.setAttribute( "width", "8em" );
- cell_child=document.createElement( "span" );
- var option=document.createElement( "option" );
- option.appendChild( document.createTextNode( test_url ) );
- record_select.appendChild( option );
-Test.AnotherWay._show_error=function( msg )
- var error_div=document.getElementById( "error" );
- error_div.innerHTML="";
- error_div.appendChild( document.createTextNode( msg ) );
- error_div.style.display="block";
-// read urls from the list in the html file inside the list_iframe
-// fill on-screen list with urls and "run" buttons, and fill the g_test_page_urls object.
-Test.AnotherWay._list_iframe_onload=function()
- if( window.frames.list_iframe!=null && window.frames.list_iframe.location!="" && window.frames.list_iframe.location!="about:blank" ) {
- var list_doc=window.frames.list_iframe.document;
- var list=list_doc.getElementById( "testlist" );
- if( list!=null ) {
- for( var i=0; i<list.childNodes.length; ++i ) {
- var item=list.childNodes[i];
- if( item.nodeName=="LI" || item.nodeName=="li" ) {
- var convention="anotherway";
- if( Test.AnotherWay._get_css_class( item )=="jsan" ) {
- convention="jsan";
- Test.AnotherWay._add_test_page_url( item.innerHTML, convention );
- if( Test.AnotherWay._g_run_on_list_load ) {
- Test.AnotherWay._g_run_on_list_load=false;
- Test.AnotherWay._run_pages_to_run();
- }else {
- Test.AnotherWay._show_error( "no list with id 'testlist' in a list file "+window.frames.list_iframe.location );
-Test.AnotherWay._map_checkboxes=function( f )
- var checks=table.getElementsByTagName( "INPUT" );
- for( var i=0; i<checks.length; ++i ) {
- if( checks[i].type=="checkbox" && checks[i].id.match( /^checkbox(\d+)$/ ) ) {
- f( checks[i], RegExp.$1 );
-Test.AnotherWay._run_all_onclick=function()
- Test.AnotherWay._map_checkboxes( function( c, id ) { Test.AnotherWay._run_test_page( "test"+id ); } );
-Test.AnotherWay._run_selected_onclick=function()
- Test.AnotherWay._map_checkboxes( function( c, id ) { if( c.checked ) Test.AnotherWay._run_test_page( "test"+id ); } );
-Test.AnotherWay._unselect_all_onclick=function()
- Test.AnotherWay._map_checkboxes( function( c, id ) { c.checked=false; } );
-Test.AnotherWay._run_one_onclick=function()
- Test.AnotherWay._run_test_page( this.id );
-// construct an object that will gather results of running one test function
-Test.AnotherWay._test_object_t=function( fun_name )
- this.name=fun_name; // name of the test function
- this.n_plan=null; // planned number of assertions
- this.n_ok=0; // # of ok assertions
- this.n_fail=0; // # of failed assertions
- this.exception=""; // if the function throwed an exception, it's its message
- this.exception_stack=[]; // strings: function call stack from the exception
- this.assertions=[]; // assertion results: array of { ok: 1 or 0, name: string }
- this.wait_result_milliseconds=0; // how long to wait before collecting results from the test
- this.second_wait_msg=null; // <p> status message (in addition to the page wait_msg)
- this.delay_actions=[]; // array of actions to be perfomed after the test function returns
- // action : { acton_kind: "call" | "window" | "replay"
- // when "call": { call_fn call_delay_milliseconds } call_fn takes nothing
- // when "window" : { wnd_url wnd_wnd wnd_fn wnd_timeout_milliseconds wnd_dont_close } wnd_fn takes wnd
- // wnen "replay" : { replay_wnd replay_events replay_event_i replay_checkpoints } checkpoint_fn takes this, wnd
- this.delay_action_i=null; // index of delay action currently being performed
- this.delay_prev_timer_time=0; // for counting time while performing delay_actions
- this.delay_current_milliseconds_left=0; // time left before the next action, runs down
- this.delay_total_milliseconds_left=0; // for indication: total estimated time for all actions, runs up and down
-Test.AnotherWay._test_object_t.prototype.ok=function( cond, name )
- if( cond ) {
- ++this.n_ok;
- cond=1;
- }else {
- ++this.n_fail;
- cond=0;
- this.assertions.push( { ok: cond, name: name } );
-Test.AnotherWay._test_object_t.prototype.fail=function( name )
- this.ok( false, name );
-Test.AnotherWay._test_object_t.prototype.plan=function( n )
- this.n_plan=n;
-Test.AnotherWay._test_object_t.prototype.wait_result=function( seconds )
- this.wait_result_milliseconds=1000*seconds;
-Test.AnotherWay._eq_fail_msg=function( path, what, expected, got )
- return "eq: "+path+" "+what+" differ: got "+got+", but expected "+expected;
-Test.AnotherWay._array_eq=function( expected, got, path, msg )
- if( expected.length!=got.length ) {
- msg.msg=Test.AnotherWay._eq_fail_msg( path, "array length", expected.length, got.length );
- return false;
- for( var i=0; i<expected.length; ++i ) {
- if( !Test.AnotherWay._thing_eq( expected[i], got[i], path+"["+i+"]", msg ) ) {
- return false;
- return true;
-Test.AnotherWay._object_eq=function( expected, got, path, msg )
- var v;
- for( v in expected ) {
- if( ! (v in got) ) {
- msg.msg=Test.AnotherWay._eq_fail_msg( path+"."+v, "properties", expected[v], "undefined" );
- return false;
- if( !Test.AnotherWay._thing_eq( expected[v], got[v], path+"."+v, msg ) ) {
- return false;
- for( v in got ) {
- if( ! (v in expected) ) {
- msg.msg=Test.AnotherWay._eq_fail_msg( path+"."+v, "properties", "undefined", got[v] );
- return false;
- return true;
-Test.AnotherWay._constructor_name=function( x )
- if( x==null ) {
- return "";
- var s="unknown";
- try {
- s=typeof( x.constructor );
- if( s!="unknown" ) {
- s=x.constructor.toString();
- }catch( e ) {
- s="unknown";
- if( s=="unknown" ) {
- // hackish attempt to guess a type
- var is_array=true;
- var index=0;
- for( i in x ) {
- if( i!=index ) {
- is_array=false;
- ++index;
- return is_array ? "Array" : "Object"; // for empty arrays/objects, this will be wrong half the time
- }else if( s.match( /^\s*function\s+(\w+)\s*\(/ ) ) {
- return RegExp.$1;
- }else {
- var c = '';
- switch(typeof x) {
- case 'string':
- c = 'String';
- break;
- case 'object':
- c = 'Object';
- break;
- default:
- c = '';
- return c;
-Test.AnotherWay._is_array=function( x )
- return Test.AnotherWay._constructor_name( x )=="Array";
-Test.AnotherWay._is_value_type=function( x )
- cn=Test.AnotherWay._constructor_name( x );
- return cn=="Number" || cn=="String" || cn=="Boolean" || cn=="Date";
-Test.AnotherWay._thing_eq=function( expected, got, path, msg )
- if( expected==null && got==null ) {
- return true;
- }else if( (expected==null && got!=null) || (expected!=null && got==null) ) {
- msg.msg=Test.AnotherWay._eq_fail_msg( path, "values", expected, got );
- return false;
- }else {
- var expected_cn=Test.AnotherWay._constructor_name( expected );
- var got_cn=Test.AnotherWay._constructor_name( got );
- if( expected_cn!=got_cn ) {
- msg.msg=Test.AnotherWay._eq_fail_msg( path, "types", expected_cn, got_cn );
- return false;
- }else {
- if( Test.AnotherWay._is_array( expected ) ) {
- return Test.AnotherWay._array_eq( expected, got, path, msg );
- }else if( Test.AnotherWay._is_value_type( expected ) ) {
- if( expected!=got ) {
- return false;
- }else {
- return true;
- }else { // just a plain object
- return Test.AnotherWay._object_eq( expected, got, path, msg );
-Test.AnotherWay._test_object_t.prototype.eq=function( got, expected, name )
- var msg={};
- if( Test.AnotherWay._thing_eq( expected, got, "", msg ) ) {
- this.ok( 1, name );
- }else {
- this.fail( name+". "+msg.msg );
-Test.AnotherWay._test_object_t.prototype.like=function( got, expected, name )
- if( got.match( expected )!=null ) {
- }else {
- this.fail( name+": got "+got+", but expected it to match: "+expected );
-Test.AnotherWay._g_html_eq_span=null;
-Test.AnotherWay._html_eq_string_to_node=function( string_or_node, what, msg )
- if( string_or_node.nodeType!=null ) {
- string_or_node=Test.AnotherWay._html_eq_node_to_string( string_or_node ); // double trip - to make properties assigned in scripts available as html node attributes
- if( Test.AnotherWay._g_html_eq_span==null ) {
- Test.AnotherWay._g_html_eq_span=document.createElement( "span" );
- Test.AnotherWay._g_html_eq_span.innerHTML=string_or_node;
- if( Test.AnotherWay._g_html_eq_span.childNodes.length!=1 ) {
- msg.msg="bad "+what+" html string given (should contain exactly one outermost element): "+string_or_node;
- return Test.AnotherWay._g_html_eq_span.childNodes[0].cloneNode( true );
-Test.AnotherWay._html_eq_node_to_string=function( node ) {
- Test.AnotherWay._g_html_eq_span.innerHTML="";
- if( node.outerHTML!=null ) {
- Test.AnotherWay._g_html_eq_span.innerHTML=node.outerHTML;
- }else {
- var clone = node.cloneNode(true);
- var node = Test.AnotherWay._g_html_eq_span;
- if(node.ownerDocument && node.ownerDocument.importNode) {
- if(node.ownerDocument != clone.ownerDocument) {
- clone = node.ownerDocument.importNode(clone, true);
+<!DOCTYPE html>
+<html>
+ <head>
+ <title>Run the testsuite</title>
+ <noscript>
+ Javascript is disabled in your browser. This page cannot be
+ displayed correctly without Javascript. Sorry.
+ <br/>
+ If you want to view this page, please change your browser settings
+ so that Javascript is enabled.
+ </noscript>
+ Test.AnotherWay version 0.5
+ Copyright (c) 2005 Artem Khodush, http://straytree.org
+ Permission is hereby granted, free of charge, to any person obtaining
+ a copy of this software and associated documentation files (the
+ "Software"), to deal in the Software without restriction, including
+ without limitation the rights to use, copy, modify, merge, publish,
+ distribute, sublicense, and/or sell copies of the Software, and to
+ permit persons to whom the Software is furnished to do so, subject to
+ the following conditions:
+ The above copyright notice and this permission notice shall be
+ included in all copies or substantial portions of the Software.
+ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
+ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
+ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
+ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE
+ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION
+ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION
+ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
+ <link rel="stylesheet" href="Test.AnotherWay.css" />
+ <script type="text/javascript" src="Test.AnotherWay.js"></script>
+ <script type="text/javascript" src="Test.AnotherWay.baseadditions.js"></script>
+ <script type="text/javascript" src="Test.AnotherWay.xml_eq.js"></script>
+ <script type="text/javascript" src="Test.AnotherWay.geom_eq.js"></script>
+ </head>
+ <body>
+ <div id="col1">
+ <div id="col1_header">
+ Test pages:
+ <input id="quickfilter" placeholder="quick filter">
+ </div>
+ <div id="scroller">
+ <table id="testtable">
+ </table>
+ </div>
+ <div id="run_buttons">
+ <input type="button" value=" clear " id="clear_btn" /><input type="button" value=" run all " id="run_all" /><input type="button" value=" run selected " id="run_selected" /><input type="button" value=" unselect all " id="unselect_all" />
+ </div>
+ <div id="running-time">
+ </div>
+ <input type="checkbox" id="dont_close_test_windows" /> do not close windows opened by tests
+ <div id="error">
+ </div>
+ <div id="record_div">
+ <p id="record_not_supported" style="display:none">
+ </p>
+ <p>
+ Record mouse input for the page:
+ </p>
+ <p>
+ <input type="radio" name="record_choose" value="select" checked="checked" />
+ <select id="record_select">
+ <option selected="selected">-- select a page: --</option>
+ </select>
+ </p>
+ <p>
+ <input type="radio" name="record_choose" value="input" /> or enter page url: <input type="text" id="record_input" />
+ </p>
+ <p>
+ <input type="button" value=" record " id="record_start" />
+ </p>
+ </div>
+ </div>
+ <div id="col2">
+ <div id="right_header">
+ <span id="results_count">Results: <span id="total"></span></span>
+ <span id="results_tab" class="active_tab" style="visibility:hidden">Results</span>
+ <span id="debug_tab" class="inactive_tab" style="visibility:hidden">Debug</span>
+ </div>
+ <div id="right_frame">
+ <div id="results">
+ </div>
+ <div id="debug">
+ </div>
+ </div>
+ </div>
+ <span style="display:none">
+ <iframe name="list_iframe" onload="Test.AnotherWay._list_iframe_onload();">
+ </iframe>
+ <iframe name="test_iframe" onload="Test.AnotherWay._test_page_onload();">
+ </iframe>
+ <!-- record_control div is to be imported into other documents, so all its styles are inline -->-
+ <div id="record_control" style="position:absolute;bottom:0;left:0;margin:0;padding:0.5em;width:22em;height:22em;border:1px solid;background:#ffd;font: normal normal 8pt sans-serif; color:#000; text-align: left">
+ <p style="margin:0 0 0 0; padding:0">
+ <span style="display:none;font-weight:bold;color:#408" id="record_indicator">recording. <span style="font-weight:normal">time: <span id="record_time"></span></span><span id="record_pause_indicator">paused</span></span>
+ </p>
+ <div id="record_cursor_over" style="margin:0;padding:2px;width:14em;height:1.1em;overflow:hidden;float:right;border:1px solid #777;background:#fff;font: normal normal 8pt sans-serif;position:relative;top:3px;color:#000;text-align:left;">
+ </div>
+ <p style="margin:2px 0 0 0; padding:0">
+ cursor is over
+ </p>
+ <p style="margin:8px 0 0 0; padding:0;">
+ keyboard control: press<span id="record_ctrl_key" style="border:1px solid #226;background:#adf;padding:0 0.5em">ctrl</span>
+ -<span id="record_shift_key" style="border:1px solid #226;background:#adf;padding:0 0.5em">shift</span>
+ </p>
+ <p style="margin:4px 0 0 0; padding:0">
+ <span id="record_s" style="border:1px solid #226;background:#adf;width:1.2em;float:left;font-weight:bold;text-align:center;margin-right:0.5em">s</span>
+ <span id="record_on">to <b>start</b> recording</span>
+ <span id="record_off" style="display:none">to <b>stop</b> recording</span>
+ </p>
+ <span id="record_h" style="border:1px solid #226;background:#adf;width:1.2em;float:left;font-weight:bold;text-align:center;margin-right:0.5em">h</span>
+ <span>to <b>hide/show</b> this window</span>
+ </p>
+ <span id="record_m" style="border:1px solid #226;background:#adf;width:1.2em;float:left;font-weight:bold;text-align:center;margin-right:0.5em">m</span>
+ <span id="record_include_mousemove">to <b>record</b> mousemove</span>
+ <span id="record_omit_mousemove" style="display:none">to <b>omit</b> mousemove</span>
+ </p>
+ <span id="record_p" style="border:1px solid #226;background:#aaa;width:1.2em;float:left;font-weight:bold;text-align:center;margin-right:0.5em">p</span>
+ <span id="record_pause_on">to <b>pause</b> recording</span>
+ <span id="record_pause_off" style="display:none">to <b>continue</b> recording</span>
+ </p>
+ <span id="record_c" style="border:1px solid #226;background:#aaa;width:1.2em;float:left;font-weight:bold;text-align:center;margin-right:0.5em">c</span>
+ <span>to add checkpoint</span>
+ </p>
+ <p style="margin:6px 0 0 0; padding:0">
+ checkpoints:
+ </p>
+ <div id="record_checkpoints" style="position:relative;width:100%;height:6em;overflow:auto;font: normal normal 8pt sans-serif; color:#000; text-align: left">
+ </div>
+ </div>
+ </span>
+ <script>
+ if (/noscroll/.test(location.href)) {
+ document.getElementById('scroller').style.height = 'auto';
+ document.getElementById('right_frame').style.height = 'auto';
- node.appendChild(clone);
- return Test.AnotherWay._g_html_eq_span.innerHTML;
-Test.AnotherWay._html_eq_path_msg=function( path )
- var msg="";
- for( var i=0; i<path.length; ++i ) {
- msg+=" [node "+path[i].node;
- if( path[i].id!=null && path[i].id!="" ) {
- msg+=" id "+path[i].id;
- }else if( path[i].index!=null ) {
- msg+=" at index "+path[i].index;
- msg+="] "
- return msg;
-Test.AnotherWay._html_eq_fail_msg=function( path, what, expected, got )
- return Test.AnotherWay._html_eq_path_msg( path )+": "+what+" differ: got "+got+", but expected "+expected;
-Test.AnotherWay._html_eq_remove_blank=function( text )
- if( text==null ) {
- return "";
- }else if( text.match( "^(\\s*)(.*\\S)(\\s*)$" ) ) {
- return RegExp.$2;
- }else if( text.match( "\s*" ) ) {
- return "";
- return text;
-Test.AnotherWay._html_eq_remove_blank_nodes=function( node )
- var to_remove=[];
- for( var child=node.firstChild; child!=null; child=child.nextSibling ) {
- if( child.nodeType==3 ) {
- var value=Test.AnotherWay._html_eq_remove_blank( child.nodeValue );
- if( value=="" ) {
- to_remove.push( child );
- }else {
- child.nodeValue=value;
- for( var i=0; i<to_remove.length; ++i ) {
- node.removeChild( to_remove[i] );
-Test.AnotherWay._html_node_type_text=function( node_type )
- if( node_type==1 ) {
- return "1 (html element)";
- }else if( node_type==3 ) {
- return "3 (text)";
- }else {
- return node_type;
-Test.AnotherWay._html_eq_node=function( expected, got, path, msg, expected_loc_base, got_loc_base )
- if( expected.nodeType!=got.nodeType ) {
- msg.msg=Test.AnotherWay._html_eq_fail_msg( path, "node types", Test.AnotherWay._html_node_type_text( expected.nodeType ), Test.AnotherWay._html_node_type_text( got.nodeType ) );
- return false;
- }else if( expected.nodeType==3 ) {
- if( expected.nodeValue!=got.nodeValue ) {
- msg.msg=Test.AnotherWay._html_eq_fail_msg( path, "text", expected.nodeValue, got.nodeValue );
- return false;
- }else if( expected.nodeType==1 ) {
- if( expected.nodeName!=got.nodeName ) {
- msg.msg=Test.AnotherWay._html_eq_fail_msg( path, "node names", expected.nodeName, got.nodeName );
- return false;
- // compare attributes
- var expected_attrs={};
- var got_attrs={};
- var i;
- var a;
- for( i=0; i<expected.attributes.length; ++i ) {
- a=expected.attributes[i];
- if( a.specified ) {
- expected_attrs[a.name]=1;
- for( i=0; i<got.attributes.length; ++i ) {
- a=got.attributes[i];
- got_attrs[a.name]=1;
- for( a in expected_attrs ) {
- if( ! (a in got_attrs) ) {
- msg.msg=Test.AnotherWay._html_eq_path_msg( path )+": attribute sets differ: expected attribute "+a+" is missing";
- return false;
- for( a in got_attrs ) {
- if( ! (a in expected_attrs) ) {
- msg.msg=Test.AnotherWay._html_eq_path_msg( path )+": attribute sets differ: got extra attribute "+a;
- return false;
- var expected_value=expected.getAttribute( a );
- var got_value=got.getAttribute( a );
- if( typeof( expected_value )=="string" && typeof( got_value )=="string" ) {
- expected_value=Test.AnotherWay._html_eq_remove_blank( expected_value );
- got_value=Test.AnotherWay._html_eq_remove_blank( got_value );
- var ok=expected_value==got_value;
- if( !ok && (a=="href" || a=="HREF" ) ) { // try relative hrefs
- var expected_relative_value=expected_value;
- if( expected_loc_base!=null && expected_value.substring( 0, expected_loc_base.length )==expected_loc_base ) {
- expected_relative_value=expected_value.substring( expected_loc_base.length );
- var got_relative_value=got_value;
- if( got_loc_base!=null && got_value.substring( 0, got_loc_base.length )==got_loc_base ) {
- got_relative_value=got_value.substring( got_loc_base.length );
- ok=expected_relative_value==got_relative_value;
- if( !ok ) {
- msg.msg=Test.AnotherWay._html_eq_fail_msg( path, "attribute "+a+" values", expected_value, got_value );
- return false;
- }else if( typeof( expected_value )=="function" && typeof( got_value )=="function" ) {
- expected_value=expected_value.toString();
- got_value=got_value.toString();
- if( expected_value!=got_value ) {
- return false;
- }else {
- var value_msg={};
- if( !Test.AnotherWay._thing_eq( expected_value, got_value, "", value_msg ) ) {
- msg.msg=Test.AnotherWay._html_eq_path_msg( path )+": attribute "+a+" values differ: "+value_msg.msg;
- return false;
- // compare child nodes
- Test.AnotherWay._html_eq_remove_blank_nodes( expected );
- Test.AnotherWay._html_eq_remove_blank_nodes( got );
- var expected_length=expected.childNodes.length;
- var got_length=got.childNodes.length;
- if( expected_length<got_length ) {
- msg.msg=Test.AnotherWay._html_eq_path_msg( path )+": got "+(got_length-expected_length)+" extra child nodes";
- return false;
- }else if( expected_length>got_length ) {
- msg.msg=Test.AnotherWay._html_eq_path_msg( path )+": expected "+(expected_length-got_length)+" more child nodes";
- return false;
- }else {
- for( i=0; i<expected_length; ++i ) {
- var expected_node=expected.childNodes[i];
- path.push( { node: expected_node.nodeName, id: expected_node.id, index: i } );
- var eq=Test.AnotherWay._html_eq_node( expected_node, got.childNodes[i], path, msg, expected_loc_base, got_loc_base );
- path.pop();
- if( !eq ) {
- return false;
- return true;
-Test.AnotherWay._html_eq_get_loc_base=function( node )
- var loc_base=document.location;
- if( node.ownerDocument!=null ) {
- loc_base=node.ownerDocument.location;
- if( loc_base!=null ) {
- loc_base=loc_base.href;
- var slash_pos=loc_base.lastIndexOf( "/" );
- if( slash_pos!=-1 ) {
- loc_base=loc_base.substring( 0, slash_pos+1 );
- return loc_base;
-Test.AnotherWay._test_object_t.prototype.html_eq=function( got, expected, name )
- var msg={};
- var expected_node=Test.AnotherWay._html_eq_string_to_node( expected, "expected", msg );
- if( msg.msg!=null ) {
- this.fail( name+" html_eq: "+msg.msg );
- }else {
- var got_node=Test.AnotherWay._html_eq_string_to_node( got, "got", msg );
- }else {
- var expected_loc_base=Test.AnotherWay._html_eq_get_loc_base( expected );
- var got_loc_base=Test.AnotherWay._html_eq_get_loc_base( got );
- if( Test.AnotherWay._html_eq_node( expected_node, got_node, [], msg, expected_loc_base, got_loc_base ) ) {
- }else {
- var msg=name+" html_eq "+msg.msg;
- var expected_str=Test.AnotherWay._html_eq_node_to_string( expected_node );
- var got_str=Test.AnotherWay._html_eq_node_to_string( got_node );
- msg+=".\n got html: "+got_str;
- msg+=".\n expected html: "+expected_str;
- this.fail( msg );
-Test.AnotherWay._debug_pane_print=function( msg )
- var d=new Date();
- var p=document.createElement( "p" );
- p.appendChild( document.createTextNode( d.toLocaleTimeString()+" "+msg ) );
- var debug_pane=document.getElementById( "debug" );
- debug_pane.appendChild( p );
- var debug_tab=document.getElementById( "debug_tab" );
- var results_tab=document.getElementById( "results_tab" );
- debug_tab.style.visibility="visible";
- results_tab.style.visibility="visible";
-Test.AnotherWay._test_object_t.prototype.debug_print=function( msg )
- Test.AnotherWay._debug_pane_print( this.name+": "+msg );
-Test.AnotherWay._test_object_t.prototype.delay_call=function()
- var timeout_ms=200;
- for( var i=0; i<arguments.length; ++i ) {
- if( typeof( arguments[i] )!="function" ) {
- timeout_ms=1000*arguments[i];
- }else {
- var action={ action_kind: "call", call_delay_milliseconds: timeout_ms, call_fn: arguments[i] };
- this.delay_total_milliseconds_left+=Test.AnotherWay._action_estimate_milliseconds( action );
- this.delay_actions.push( action );
-Test.AnotherWay._test_object_t.prototype.open_window=function( url, fn, timeout_seconds )
- if( timeout_seconds==null ) {
- timeout_seconds=4;
- var no_close=document.getElementById( "dont_close_test_windows" );
- var action={ action_kind: "window", wnd_url: url.toString() + (window.location.search || ""), wnd_wnd: null, wnd_fn: fn, wnd_timeout_milliseconds: timeout_seconds*1000, wnd_no_close: no_close.checked };
-Test.AnotherWay._test_object_t.prototype.replay_events=function( wnd, events )
- if( Test.AnotherWay._g_no_record_msg!=null ) {
- this.fail( "replay_events: "+Test.AnotherWay._g_no_record_msg );
- }else {
- var action={ action_kind: "replay", replay_wnd: wnd, replay_events: events.events, replay_event_i: null, replay_checkpoints: events.checkpoints };
-Test.AnotherWay._action_estimate_milliseconds=function( action )
- var ms=0;
- if( action.action_kind=="call" ) {
- ms=action.call_delay_milliseconds;
- }else if( action.action_kind=="window" ) {
- ms=0;
- }else if( action.action_kind=="replay" ) {
- ms=0;
- for( var i=0; i<action.replay_events.length; ++i ) {
- ms+=action.replay_events[i]["time"]-0;
- return ms;
-Test.AnotherWay._g_timeout_granularity=200;
-Test.AnotherWay._g_tests_queue=[]; // vector of { url: string, test_objects : array of test_object_t, test_object_i: int, wait_msg: <p> object, loading_timeout_milliseconds: int, timeout_id: id }
-// load one html page, schedule further processing
-Test.AnotherWay._run_test_page=function( id, called_from_outside )
- if( id.match( /^test(\d+)/ ) ) {
- id=RegExp.$1;
- Test.AnotherWay._g_tests_queue.push( {
- url: Test.AnotherWay._g_test_page_urls[id].url,
- convention: Test.AnotherWay._g_test_page_urls[id].convention,
- test_objects: []
- if( Test.AnotherWay._g_tests_queue.length==1 ) {
- if( !called_from_outside ) {
- // Crap. Be careful stepping around.
- // For Mozilla and Opera, when this file is included into the frameset page that is in another directory (and _g_outside_path_correction!=null)
- // but the test pages are started from within it (by "run" buttons), then:
- // depending on whether the page is the first one loaded into the test frame or not,
- // the base url for relative test pages differs.
- // Crap, like I said.
- Test.AnotherWay._g_tests_queue[0].suppress_outside_path_correction=true;
- Test.AnotherWay._start_loading_page();
-Test.AnotherWay._load_next_page=function()
- Test.AnotherWay._g_tests_queue.splice( 0, 1 );
- if( Test.AnotherWay._g_tests_queue.length>0 ) {
- }else {
- if( !Test.AnotherWay._g_test_frame_no_clear ) {
- Test.AnotherWay._g_test_iframe.location.replace( "about:blank" );
-Test.AnotherWay._g_opera_path_correction=null; // ugly wart to support opera
-Test.AnotherWay._g_outside_path_correction=null; // ugly wart to accomodate Opera and Mozilla, where relative url relates to the directory where the page that calls this function is located
-Test.AnotherWay._set_iframe_location=function( iframe, loc, outside_path_correction )
- // allow to load only locations with the same origin
- var proto_end=loc.indexOf( "://" );
- if( proto_end!=-1 ) { // otherwise, it's safe to assume (for Opera, Mozilla and IE ) that loc will be treated as relative
- var main_loc=window.location.href;
- var host_end=loc.substring( proto_end+3 ).indexOf( "/" );
- var ok=false;
- if( host_end!=-1 ) {
- var loc_origin=loc.substring( 0, proto_end+3+host_end+1 );
- if( main_loc.length>=loc_origin.length && main_loc.substring( 0, loc_origin.length )==loc_origin ) {
- ok=true;
- if( !ok ) {
- return { msg: "test pages may have only urls with the same origin as "+main_loc };
- // opera cannot handle urls relative to file:// without assistance
- if( window.opera!=null && window.location.protocol=="file:" && loc.indexOf( ":" )==-1 ) {
- var base=window.location.href;
- var q_pos=base.indexOf( "?" );
- if( q_pos!=-1 ) {
- base=base.substring( 0, q_pos );
- var slash_pos=base.lastIndexOf( "/" );
- base=base.substring( 0, slash_pos+1 );
- Test.AnotherWay._g_opera_path_correction=base;
- loc=base+loc;
- // if this function is called from another page, and if that page is in another directory, correction is needed
- if( outside_path_correction!=null ) {
- var pos=loc.indexOf( outside_path_correction );
- if( pos==0 ) {
- loc=loc.substring( outside_path_correction.length+1 );
- if( iframe.location!=null ) {
- iframe.location.replace( loc );
- }else {
- iframe.src=loc;
- return {};
-Test.AnotherWay._start_loading_page=function()
- var test_page=Test.AnotherWay._g_tests_queue[0];
- test_page.loading_timeout_milliseconds=12000;
- test_page.timeout_id=setTimeout( Test.AnotherWay._loading_timeout, Test.AnotherWay._g_timeout_granularity );
- test_page.wait_msg=Test.AnotherWay._print_counter_result( test_page.url, "loading...", test_page.loading_timeout_milliseconds, "loading" );
- if( test_page.convention=="jsan" ) {
- // the tests in that page will run when it's loading, so the test object must be ready
- Test.AnotherWay._g_test_object_for_jsan=new Test.AnotherWay._test_object_t( test_page.url );
- var outside_path_correction=null;
- if( Test.AnotherWay._g_outside_path_correction!=null && !test_page.suppress_outside_path_correction ) {
- outside_path_correction=Test.AnotherWay._g_outside_path_correction;
- var result=Test.AnotherWay._set_iframe_location( Test.AnotherWay._g_test_iframe, test_page.url, outside_path_correction );
- if( result.msg!=null ) {
- Test.AnotherWay._unprint_result( test_page.wait_msg );
- Test.AnotherWay._print_result( test_page.url, result.msg, "badtest", null );
- Test.AnotherWay._load_next_page();
-Test.AnotherWay._loading_timeout=function()
- test_page.loading_timeout_milliseconds-=Test.AnotherWay._g_timeout_granularity;
- if( test_page.loading_timeout_milliseconds>0 ) {
- Test.AnotherWay._update_msg_counter( test_page.wait_msg, (test_page.loading_timeout_milliseconds/1000).toFixed() );
- }else {
- Test.AnotherWay._print_result( test_page.url, "Unable to load test page. Timeout expired", "badtest", null );
-Test.AnotherWay._strip_query_and_hash=function( s )
- var i=s.lastIndexOf( "#" );
- if( i!=-1 ) {
- s=s.substring( 0, i );
- i=s.lastIndexOf( "?" );
- if( i!=-1 ) {
- return s;
-Test.AnotherWay._is_url_loaded=function( url, wnd )
- var loaded=false;
- if( wnd!=null && wnd.location!=null ) {
- // after some popup blocker interference, location may behave strange..
- var location_s="";
- location_s+=wnd.location;
- if( location_s!="" ) {
- var pathname=wnd.location.pathname;
- var expected_url=url;
- var i=expected_url.lastIndexOf( "#" );
- if( i!=-1 ) {
- expected_url=expected_url.substring( 0, i );
- i=expected_url.lastIndexOf( "?" );
- if( i!=-1 ) {
- i=expected_url.lastIndexOf( "/" );
- if( i!=-1 && i!=expected_url.length-1 ) {
- expected_url=expected_url.substring( i+1 );
- i=pathname.indexOf( expected_url )
- if( wnd.location.href==url || (i!=-1 && i==pathname.length-expected_url.length) ) {
- if( /*window.opera==null*/wnd.document.readyState==null || wnd.document.readyState=="complete" ) { // for opera (and IE?), getElementById does not work until..
- loaded=true;
- return loaded;
-// find and run all test functions in the g_cur_page html page.
-Test.AnotherWay._test_page_onload=function()
- if( Test.AnotherWay._g_tests_queue.length==0 ) {
- return;
- if( !Test.AnotherWay._is_url_loaded( test_page.url, Test.AnotherWay._g_test_iframe ) ) {
- return;
- clearTimeout( test_page.timeout_id );
- if( test_page.convention=="anotherway" ) {
- // get test function names (those beginning with "test")
- if( typeof( Test.AnotherWay._g_test_iframe.document.scripts )!='undefined' ) { // IE
- for( var i=0; i<Test.AnotherWay._g_test_iframe.document.scripts.length; ++i ) {
- var script_text=Test.AnotherWay._g_test_iframe.document.scripts[i].text;
- var fun_sig="function test";
- var fun_start=script_text.indexOf( fun_sig );
- while( fun_start!=-1 ) {
- script_text=script_text.substring( fun_start, script_text.length );
- var fun_end=script_text.indexOf( '(' );
- var fun_name=script_text.substring( "function ".length, fun_end );
- var whitespace = fun_name.indexOf( ' ' );
- if (whitespace >= 0)
- fun_name = fun_name.substring( 0, whitespace );
- test_page.test_objects.push( new Test.AnotherWay._test_object_t( fun_name ) );
- script_text=script_text.substring( fun_end, script_text.length );
- fun_start=script_text.indexOf( fun_sig );
- }else { // otherwise (not IE) it ought to work like this
- for( var i in Test.AnotherWay._g_test_iframe) {
- // Hack to prevent failure in FF3.0b1 (innerWidth/innerHeight) and FF>=3.5 (sessionStorage)
- if (i == "innerWidth" || i == "innerHeight" || i == "sessionStorage") { continue; }
- if( typeof( Test.AnotherWay._g_test_iframe[i] )=='function' ) {
- if( i.substring( 0, 4 )=="test" ) {
- test_page.test_objects.push( new Test.AnotherWay._test_object_t( i ) );
- }else if( test_page.convention=="jsan" ) {
- // the test object is already filled with results
- test_page.test_objects.push( Test.AnotherWay._g_test_object_for_jsan );
- if( test_page.test_objects.length==0 ) {
- Test.AnotherWay._print_result( test_page.url, "No test functions defined in the page", "badtest", null );
- return;
- test_page.wait_msg=Test.AnotherWay._print_result( test_page.url, "running tests..<span class=\"counter\">"+test_page.test_objects.length+"</span>", "running", null );
- test_page.test_object_i=0;
- Test.AnotherWay._run_more_tests();
-Test.AnotherWay._handle_exception=function( o, e, title )
- var s=title+": "+typeof( e )+": ";
- if( e.message!=null ) {
- s+=e.message;
- }else if( e.description!=null ) {
- s+=e.description;
- }else {
- s+=e.toString();
-// if( e.location!=null ) { // XXX figure out how to display exception location if it's present (like in mozilla)
-// s+=" location: "+e.location.toString();
- o.exception=s;
- s=[];
- if( e.stack ) {
- var lines=e.stack.split( "\n" );
- for( var i=0; i<lines.length; ++i ) {
- // format of the line: func_name(args)@file_name:line_no
- if( lines[i].match( /(\w*)\(([^\)]*)\)@(.*):([^:]*)$/ ) ) {
- var func_name=RegExp.$1;
- if( func_name.length==0 ) {
- func_name="<anonymous>";
- s.push( "in "+func_name+"( "+RegExp.$2+") at "+RegExp.$3+" line "+RegExp.$4+"\n" );
- o.exception_stack=s;
-Test.AnotherWay._run_more_tests=function()
- while( test_page.test_object_i<test_page.test_objects.length ) {
- Test.AnotherWay._update_msg_counter( test_page.wait_msg, (1+test_page.test_object_i)+"/"+test_page.test_objects.length );
- var o=test_page.test_objects[test_page.test_object_i];
- try {
- Test.AnotherWay._g_test_iframe[o.name]( o );
- }catch( e ) {
- Test.AnotherWay._handle_exception( o, e, "" );
- } // for "jsan" convention, test has run already
- if( o.delay_actions.length>0 || o.wait_result_milliseconds>0 ) {
- o.delay_total_milliseconds_left+=o.wait_result_milliseconds;
- Test.AnotherWay._delay_actions_timeout();
- return;
- ++test_page.test_object_i;
- Test.AnotherWay._print_result( test_page.url, null, null, test_page.test_objects );
-Test.AnotherWay._delay_actions_timeout=function()
- var test_object=test_page.test_objects[test_page.test_object_i];
- var finished=true;
- if( test_object.delay_action_i==null ) {
- // set up to start first action
- test_object.delay_action_i=-1;
- }else {
- // perform current action
- var milliseconds_passed=(new Date()).getTime()-test_object.delay_prev_timer_time;
- test_object.delay_current_milliseconds_left-=milliseconds_passed;
- test_object.delay_total_milliseconds_left-=milliseconds_passed;
- finished=Test.AnotherWay._delay_continue_action( test_object, milliseconds_passed );
- while( finished && test_object.delay_action_i<test_object.delay_actions.length ) {
- ++test_object.delay_action_i; // start next action
- finished=Test.AnotherWay._delay_start_action( test_object );
- if( test_object.delay_action_i<=test_object.delay_actions.length ) { // any more actions left ?
- test_object.delay_prev_timer_time=(new Date()).getTime();
- var next_timeout=Test.AnotherWay._g_timeout_granularity;
- if( test_object.delay_current_milliseconds_left<next_timeout ) {
- next_timeout=test_object.delay_current_milliseconds_left;
- if( test_object.second_wait_msg!=null ) {
- Test.AnotherWay._update_msg_counter( test_object.second_wait_msg, (test_object.delay_total_milliseconds_left/1000).toFixed() );
- setTimeout( Test.AnotherWay._delay_actions_timeout, next_timeout );
- }else { // no more actions left. run the next test.
- Test.AnotherWay._unprint_result( test_object.second_wait_msg );
- test_object.second_wait_msg=null;
-Test.AnotherWay._delay_start_action=function( test_object )
- var finished=false;
- var wait_msg="";
- if( test_object.delay_action_i==test_object.delay_actions.length ) {
- if( test_object.wait_result_milliseconds>0 ) {
- test_object.delay_current_milliseconds_left=test_object.wait_result_milliseconds; // wait for result
- wait_msg="waiting for results..";
- }else {
- ++test_object.delay_action_i; // dont wait for result
- }else {
- var action=test_object.delay_actions[test_object.delay_action_i];
- test_object.delay_current_milliseconds_left=action.call_delay_milliseconds;
- wait_msg="performing delayed calls..";
- if( Test.AnotherWay._g_opera_path_correction!=null && action.wnd_url.indexOf( ":" )==-1 ) {
- action.wnd_url=Test.AnotherWay._g_opera_path_correction+action.wnd_url;
- action.wnd_wnd=window.open( action.wnd_url, "_blank" );
- if( action.wnd_wnd==null ) {
- finished=true;
- test_object.fail( "unable to open window for "+action.wnd_url );
- }else {
- test_object.delay_current_milliseconds_left=action.wnd_timeout_milliseconds;
- wait_msg="opening window..";
- if( action.replay_events.length==0 ) {
- finished=true;
- }else {
- action.replay_event_i=0;
- test_object.delay_current_milliseconds_left=action.replay_events[0]["time"];
- wait_msg="replaying events..";
- if( wait_msg!="" ) {
- test_object.second_wait_msg=Test.AnotherWay._print_counter_result( test_page.url, wait_msg, test_object.delay_total_milliseconds_left, "waiting" );
- }else {
- return finished;
-Test.AnotherWay._delay_continue_action=function( test_object, milliseconds_passed )
- var finished=test_object.delay_current_milliseconds_left<=0;
- if( test_object.delay_action_i==test_object.delay_actions.length ) { // action is "waiting for results"
- if( test_object.n_plan!=null && test_object.n_plan==test_object.n_ok+test_object.n_fail ) {
- finished=true; // if all assertions results are recorded, don't wait any more
- if( finished ) {
- ++test_object.delay_action_i; // move on to the next test
- }else {
- if( finished ) {
- try {
- action.call_fn();
- }catch( e ) {
- Test.AnotherWay._handle_exception( test_object, e, "in delay_call" );
- test_object.delay_total_milliseconds_left+=milliseconds_passed; // for "window", the countdown is suspended since it's unknown how long it will take
- if( Test.AnotherWay._is_url_loaded( action.wnd_url, action.wnd_wnd ) ) {
- try {
- action.wnd_fn( action.wnd_wnd );
- }catch( e ) {
- Test.AnotherWay._handle_exception( test_object, e, "in open_window function call" );
- finished=true;
- }else if( finished ) {
- test_object.fail( "unable to open window for url '"+action.wnd_url+"'. timeout expired" );
- if( finished ) {
-// try {
- Test.AnotherWay._delay_replay_event( test_object, action.replay_wnd, action.replay_events[action.replay_event_i], action.replay_checkpoints );
-// }catch( e ) { // disabled, until I know how to gel location info from an exception
-// Test.AnotherWay._handle_exception( test_object, e, "while replaying event" );
- ++action.replay_event_i;
- finished=action.replay_event_i==action.replay_events.length;
- if( !finished ) {
- test_object.delay_current_milliseconds_left=action.replay_events[action.replay_event_i]["time"];
- return finished;
-Test.AnotherWay._delay_replay_event=function( test_object, wnd, event, checkpoints )
- if( event.type=="_checkpoint" ) {
- var checkpoint_n=event.which;
- var prev_n_fail=test_object.n_fail;
- checkpoints[checkpoint_n]( test_object, wnd );
- var flash_color= prev_n_fail==test_object.n_fail ? "#2f2" : "#f22" ;
- Test.AnotherWay._record_flash_border( flash_color );
- }else if( event.type=="click" || event.type=="mouseover" || event.type=="mouseout" || event.type=="mousemove" || event.type=="mousedown" || event.type=="mouseup" ) {
- var target=Test.AnotherWay._record_node_path_to_node( event["target"], wnd.document );
- if( target!=null ) {
- Test.AnotherWay._record_control_update_highlight( target, "ball", event );
- var e=wnd.document.createEvent( "MouseEvents" );
- var related_target=Test.AnotherWay._record_node_path_to_node( event["relatedTarget"], wnd.document );
- e.initMouseEvent(
- event["type"],
- event["cancelable"],
- event["bubbles"],
- wnd.document.defaultView,
- event["detail"],
- event["screenX"],
- event["screenY"],
- event["clientX"],
- event["clientY"],
- event["ctrlKey"],
- event["altKey"],
- event["shiftKey"],
- event["metaKey"],
- event["button"],
- Test.AnotherWay._record_node_path_to_node( event["relatedTarget"], wnd.document )
- // Firefox 1.0.6 somehow loses relatedTarget somewhere on the way. Pass through our own, for those who choose to care.
- e.passThroughRelatedTarget=related_target;
- target.dispatchEvent( e );
- }else if( event.type=="keyup" || event.type=="keydown" || event.type=="keypress" ) {
- var e=wnd.document.createEvent( "KeyboardEvents" ); // forget it. Apparently it's not supported neither by mozilla nor by opera.
- e.initKeyboardEvent(
- event["type"],
- event["bubbles"],
- event["which"],
- event["which"],
- event["ctrlKey"],
- event["altKey"],
- event["metaKey"],
- false
- wnd.document.dispatchEvent( e );
-Test.AnotherWay._print_counter_result=function( url, msg, milliseconds, style )
- return Test.AnotherWay._print_result( url, msg+"<span class=\"counter\">"+(milliseconds/1000).toFixed()+"</span>", style, null );
-Test.AnotherWay._g_result_count=0; // for assigning unique ids to result paragraphs
-// number of pages tested
-Test.AnotherWay._g_ok_pages=0;
-Test.AnotherWay._g_fail_pages=0;
-Test.AnotherWay._print_result=function( url, msg, style, test_objects )
- var results=document.getElementById( "results" );
- var r=results.appendChild( document.createElement( "p" ) );
- r.id="result"+Test.AnotherWay._g_result_count;
- ++Test.AnotherWay._g_result_count;
- r.onclick=Test.AnotherWay._toggle_detail;
- var text="<span class=\"bullet\"> </span> ";
- if( url!="" ) {
- text+=url+": ";
- if( msg!=null ) {
- text+=msg;
- if( test_objects!=null ) {
- // compose summary and detail texts
- var total_ok=0;
- var total_detail_ok=0;
- var total_fail=0;
- var total_detail_fail=0;
- var no_plan=0;
- var detail=results.appendChild( document.createElement( "div" ) );
- if( r.id.match( /^result(\d+)$/ ) ) {
- detail.id="result_detail"+RegExp.$1;
- for( var i=0; i<test_objects.length; ++i ) {
- var o=test_objects[i];
- var p;
- var p_text;
- p=document.createElement( "P" );
- Test.AnotherWay._set_css_class( p, "result_detail" );
- p_text=o.name;
- if( o.n_fail>0 || o.exception || (o.n_plan!=null && o.n_plan!=o.n_ok+o.n_fail) || (o.n_plan==null && o.n_ok==0 && o.n_fail==0)) {
- ++total_fail;
- p_text+=" <span class=\"fail\">";
- if( o.n_plan!=null && o.n_plan!=o.n_ok+o.n_fail) {
- p_text+="planned "+o.n_plan+" assertions but got "+(o.n_ok+o.n_fail)+"; ";
- if(o.n_plan==null && o.n_ok==0 && o.n_fail==0) {
- p_text+="test did not output anything";
- }else {
- p_text+=" fail "+o.n_fail;
- p_text+="</span>";
- }else {
- ++total_ok;
- p_text+=" ok "+o.n_ok;
- if( o.n_plan==null ) {
- no_plan=1;
- p_text+=" <span class=\"warning\">no plan</span>";
- p.innerHTML=p_text;
- detail.appendChild( p );
- if( o.exception ) {
- Test.AnotherWay._set_css_class( p, "result_exception_detail" );
- p.innerHTML="<span class=\"fail\">exception:</span> "+o.exception;
- Test.AnotherWay._set_css_class( p, "result_exception_stack_detail" );
- p.innerHTML=o.exception_stack.join( "<br/>" );
- for( var ii=0; ii<o.assertions.length; ++ii ) {
- var oo=o.assertions[ii];
- var status=oo.ok ? "ok" : "<span class=\"fail\">fail</span>";
- Test.AnotherWay._set_css_class( p, "result_micro_detail" );
- p.innerHTML=status;
- p.appendChild( document.createTextNode( " "+oo.name ) );
- total_detail_ok+=o.n_ok;
- total_detail_fail+=o.n_fail;
- if( total_fail || total_detail_fail ) {
- text+=" fail "+total_fail;
- text+=" ok "+total_ok+" (detailed:";
- text+=" fail "+total_detail_fail;
- text+=" ok "+total_detail_ok+")";
- if( no_plan ) {
- text+=" <span class=\"warning\">no plan</span>";
- style= total_fail==0 ? "ok" : "fail";
- detail.style.display= style=="fail" ? "block" : "none";
- detail.style.cursor="text";
- if( style!=null ) {
- Test.AnotherWay._set_css_class( r, style );
- if( style=="ok" ) {
- ++Test.AnotherWay._g_ok_pages;
- }else if( style=="fail" || style=="badtest" ) {
- ++Test.AnotherWay._g_fail_pages;
- var pages_total="";
- if( Test.AnotherWay._g_fail_pages>0 ) {
- pages_total+=" fail "+Test.AnotherWay._g_fail_pages;
- pages_total+=" ok "+Test.AnotherWay._g_ok_pages;
- Test.AnotherWay._update_results_total( pages_total );
- r.innerHTML=text;
- if( results.scrollHeight!=null && results.scrollTop!=null && results.offsetHeight!=null ) {
- results.scrollTop=results.scrollHeight-results.offsetHeight;
- // when test_objects is not null, the results are final - good time to clean up
- var actions=test_objects[i].delay_actions;
- for( var action_i=0; action_i<actions.length; ++action_i ) {
- var action=actions[action_i];
- if( action.action_kind=="window" && action.wnd_wnd!=null && !action.wnd_no_close ) {
- action.wnd_wnd.close();
- action.wnd_wnd=null;
- return r;
-Test.AnotherWay._unprint_result=function( child )
- results.removeChild( child );
-Test.AnotherWay._toggle_detail=function()
- if( this.id.match( /^result(\d+)$/ ) ) {
- var detail=document.getElementById( "result_detail"+RegExp.$1 );
- if( detail!=null ) {
- if( detail.style.display=="none" ) {
- detail.style.display="block";
- }else if( detail.style.display=="block" ) {
- detail.style.display="none";
-Test.AnotherWay._update_msg_counter=function( msg, text )
- for( var i=0; i<msg.childNodes.length; ++i ) {
- var item=msg.childNodes[i];
- if( item.nodeName=="SPAN" && Test.AnotherWay._get_css_class( item )=="counter" ) {
- item.innerHTML=text;
-Test.AnotherWay._update_results_total=function( msg )
- var total=document.getElementById( "total" );
- if( total ) {
- total.innerHTML=msg;
-Test.AnotherWay._results_clear_onclick=function()
- results.innerHTML="";
- Test.AnotherWay._update_results_total( "" );
- Test.AnotherWay._g_ok_pages=0;
- Test.AnotherWay._g_fail_pages=0;
- var debug=document.getElementById( "debug" );
- debug.innerHTML="";
-Test.AnotherWay._get_css_class=function( o )
- var c=o.getAttribute( "className" );
- if( c==null || c=="" ) {
- c=o.getAttribute( "class" );
- return c;
-Test.AnotherWay._set_css_class=function( o, css_class )
- o.setAttribute( "className", css_class );
- o.setAttribute( "class", css_class );
-Test.AnotherWay._tab_onclick=function()
- var tab=this;
- var tabs=[ document.getElementById( "debug_tab" ), document.getElementById( "results_tab" ) ];
- var panes=[ document.getElementById( "debug" ), document.getElementById( "results" ) ];
- for( var i=0; i<tabs.length; ++i ) {
- if( tab==tabs[i] ) {
- Test.AnotherWay._set_css_class( tabs[i], "active_tab" );
- panes[i].style.display="block";
- }else {
- Test.AnotherWay._set_css_class( tabs[i], "inactive_tab" );
- panes[i].style.display="none";
-Test.AnotherWay._tab_mouseover=function()
- if( Test.AnotherWay._get_css_class( this )=="inactive_tab" ) {
- Test.AnotherWay._set_css_class( this, "inactive_mouseover_tab" );
-Test.AnotherWay._tab_mouseout=function()
- if( Test.AnotherWay._get_css_class( this )=="inactive_mouseover_tab" ) {
- Test.AnotherWay._set_css_class( this, "inactive_tab" );
-// recording mouse input
-Test.AnotherWay._record_check_onfocus=function()
- var o=this;
- var check_select=o.type!="text";
- var div=document.getElementById( "record_div" );
- var inputs=div.getElementsByTagName( "input" );
- for( var i=0; i<inputs.length; ++i ) {
- var input=inputs[i];
- if( input.type=="radio" ) {
- if( input.value=="select" ) {
- input.checked=check_select;
- }else if( input.value=="input" ) {
- input.checked=!check_select;
-Test.AnotherWay._g_no_record_msg=null; // not null - recording is unavailable
-Test.AnotherWay._g_record_timeout_cnt=0; // opening window for a page for recording
-Test.AnotherWay._g_record_url=null;
-Test.AnotherWay._g_record_wnd=null;
-Test.AnotherWay._g_record_random_id=null; // added to element ids of record_control div so that they do not clash with ids already in the page for which input is recorded
-Test.AnotherWay._g_record_keydown=null; // recording control - which key is down
-Test.AnotherWay._g_record_ctrl_keydown=false;
-Test.AnotherWay._g_record_shift_keydown=false;
-Test.AnotherWay._g_record_control_visible=true; // recording control ui state
-Test.AnotherWay._g_record_started;
-Test.AnotherWay._g_record_paused;
-Test.AnotherWay._g_record_include_mousemove=false;
-Test.AnotherWay._g_record_start_time; // for time references
-Test.AnotherWay._g_record_pause_start_time;
-Test.AnotherWay._g_record_update_time_interval; // showing time in the control ui
-Test.AnotherWay._g_record_waiting_for_results=false; // waiting for results window to open
-Test.AnotherWay._g_record_events; // recorded events
-Test.AnotherWay._g_record_under_cursor; // track element under cursor
-Test.AnotherWay._g_record_checkpoint_count; // for checkpoint numbering
-Test.AnotherWay._g_record_mouse_over_record_control; // for avoiding record control highlight on mouseover
-Test.AnotherWay._g_record_highlighted_element={ element: null, x: null, y: null };
-Test.AnotherWay._record_control_get_element=function( id )
- if( Test.AnotherWay._g_record_wnd!=null && Test.AnotherWay._g_record_wnd.document!=null ) {
- return Test.AnotherWay._g_record_wnd.document.getElementById( id+Test.AnotherWay._g_record_random_id );
- }else {
- return null;
-Test.AnotherWay._record_start_onclick=function() // "record" button on the run_tests.html: open a window for a page for which input is recorded
- alert( Test.AnotherWay._g_no_record_msg );
- return;
- if( Test.AnotherWay._g_record_timeout_cnt>0
- || (Test.AnotherWay._g_record_wnd!=null && (Test.AnotherWay._g_record_wnd.closed!=null && !Test.AnotherWay._g_record_wnd.closed)) ) { // in opera, closed is null.
- alert( "there is already window opened for recording input for a page "+Test.AnotherWay._g_record_url );
- return;
- var url=null;
- if( input.value=="select" && input.checked ) {
- var index=document.getElementById( "record_select" ).selectedIndex;
- if( index>0 ) {
- url=Test.AnotherWay._g_test_page_urls[index-1].url;
- }else if( input.value=="input" && input.checked ) {
- url=document.getElementById( "record_input" ).value;
- if( url!=null ) {
- Test.AnotherWay._g_record_url=url;
- Test.AnotherWay._g_record_wnd=window.open( url, "_blank" );
- if( Test.AnotherWay._g_record_wnd==null ) {
- alert( "unable to open new window for a page: "+url );
- }else {
- Test.AnotherWay._g_record_timeout_cnt=50;
- setTimeout( Test.AnotherWay._record_window_timeout, 100 );
-Test.AnotherWay._record_window_timeout=function()
- if( Test.AnotherWay._is_url_loaded( Test.AnotherWay._g_record_url, Test.AnotherWay._g_record_wnd ) ) {
- Test.AnotherWay._record_window_setup( Test.AnotherWay._g_record_wnd );
- }else {
- if( --Test.AnotherWay._g_record_timeout_cnt>0 ) {
- }else {
- alert( "timeout expired while opening new window for a page: "+Test.AnotherWay._g_record_url );
- Test.AnotherWay._g_record_wnd=null;
- Test.AnotherWay._g_record_url=null;
- Test.AnotherWay._g_record_timeout_cnt=0;
-Test.AnotherWay._record_control_randomize_id=function( e, r )
- if( e.id!="" ) {
- e.id=e.id+r;
- for( var c=e.firstChild; c!=null; c=c.nextSibling ) {
- Test.AnotherWay._record_control_randomize_id( c, r );
-Test.AnotherWay._record_window_setup=function( wnd ) // insert recording control into the page for which input is recorded
- var this_div=document.getElementById( "record_control" );
- var record_control=wnd.document.importNode( this_div, true );
- Test.AnotherWay._g_record_random_id=(1000*Math.random()).toFixed();
- Test.AnotherWay._record_control_randomize_id( record_control, Test.AnotherWay._g_record_random_id );
- Test.AnotherWay._g_record_control_visible=true;
- Test.AnotherWay._g_record_started=false;
- Test.AnotherWay._g_record_paused=false;
- Test.AnotherWay._g_record_checkpoint_count=0;
- Test.AnotherWay._g_record_mouse_over_record_control=false;
- var doc=wnd.document;
- doc.body.appendChild( record_control );
- // opera sans-serif font is different
- if( window.opera ) {
- cursor_over_indicator=Test.AnotherWay._record_control_get_element( "record_cursor_over" );
- cursor_over_indicator.style.width="18em";
- cursor_over_indicator.style.height="2em";
- cursor_over_indicator.style.fontSize="7pt";
- doc.addEventListener( "keydown", Test.AnotherWay._record_control_keydown, true );
- doc.addEventListener( "keyup", Test.AnotherWay._record_control_keyup, true );
-// doc.addEventListener( "keypress", Test.AnotherWay._record_event, true ); // replaying is not supported by any known browser
- doc.body.addEventListener( "mousemove", Test.AnotherWay._record_on_mousemove, true );
- doc.body.addEventListener( "click", Test.AnotherWay._record_event, true );
- doc.body.addEventListener( "mouseover", Test.AnotherWay._record_event, true );
- doc.body.addEventListener( "mouseout", Test.AnotherWay._record_event, true );
- doc.body.addEventListener( "mousedown", Test.AnotherWay._record_event, true );
- doc.body.addEventListener( "mouseup", Test.AnotherWay._record_event, true );
-Test.AnotherWay._record_control_key_disabled=function( k )
- if( k=="c" ) {
- return !Test.AnotherWay._g_record_started;
- }else if( k=="p" ) {
- }else if( k=="s" ) {
- return Test.AnotherWay._g_record_waiting_for_results;
- }else {
- return false;
-Test.AnotherWay._record_control_update_ui=function()
- var keydown_color="#fff";
- var disabled_color="#aaa";
- var button_color="#adf";
- var active_color="#fdf";
- var display={};
- display[false]="none";
- display[true]="inline";
- var s_button=Test.AnotherWay._record_control_get_element( "record_s" );
- var record_on=Test.AnotherWay._record_control_get_element( "record_on" );
- var record_off=Test.AnotherWay._record_control_get_element( "record_off" );
- s_button.style.backgroundColor= Test.AnotherWay._record_control_key_disabled( "s" ) ? disabled_color
- : Test.AnotherWay._g_record_keydown=="s" ? keydown_color : Test.AnotherWay._g_record_started ? active_color : button_color;
- record_on.style.display=display[!Test.AnotherWay._g_record_started];
- record_off.style.display=display[Test.AnotherWay._g_record_started];
- var h_button=Test.AnotherWay._record_control_get_element( "record_h" );
- h_button.style.backgroundColor= Test.AnotherWay._g_record_keydown=="h" ? keydown_color : button_color;
- var p_button=Test.AnotherWay._record_control_get_element( "record_p" );
- var record_pause_on=Test.AnotherWay._record_control_get_element( "record_pause_on" );
- var record_pause_off=Test.AnotherWay._record_control_get_element( "record_pause_off" );
- p_button.style.backgroundColor= Test.AnotherWay._record_control_key_disabled( "p" ) ? disabled_color
- : Test.AnotherWay._g_record_keydown=="p" ? keydown_color : Test.AnotherWay._g_record_paused ? active_color : button_color;
- record_pause_on.style.display=display[!Test.AnotherWay._g_record_paused];
- record_pause_off.style.display=display[Test.AnotherWay._g_record_paused];
- var m_button=Test.AnotherWay._record_control_get_element( "record_m" );
- var record_include_mousemove=Test.AnotherWay._record_control_get_element( "record_include_mousemove" );
- var record_omit_mousemove=Test.AnotherWay._record_control_get_element( "record_omit_mousemove" );
- m_button.style.backgroundColor= Test.AnotherWay._g_record_keydown=="m" ? keydown_color : Test.AnotherWay._g_record_include_mousemove ? active_color : button_color;
- record_include_mousemove.style.display=display[!Test.AnotherWay._g_record_include_mousemove];
- record_omit_mousemove.style.display=display[Test.AnotherWay._g_record_include_mousemove];
- var c_button=Test.AnotherWay._record_control_get_element( "record_c" );
- c_button.style.backgroundColor= Test.AnotherWay._record_control_key_disabled( "c" ) ? disabled_color
- : Test.AnotherWay._g_record_keydown=="c" ? keydown_color : button_color;
- var record_indicator=Test.AnotherWay._record_control_get_element( "record_indicator" );
- record_indicator.style.display=display[Test.AnotherWay._g_record_started];
- var pause_indicator=Test.AnotherWay._record_control_get_element( "record_pause_indicator" );
- pause_indicator.style.display=display[Test.AnotherWay._g_record_paused];
- var record_control=Test.AnotherWay._record_control_get_element( "record_control" );
- record_control.style.display= Test.AnotherWay._g_record_control_visible ? "block" : "none";
- var shift_button=Test.AnotherWay._record_control_get_element( "record_shift_key" );
- shift_button.style.backgroundColor= Test.AnotherWay._g_record_shift_keydown ? keydown_color : button_color;
- var ctrl_button=Test.AnotherWay._record_control_get_element( "record_ctrl_key" );
- ctrl_button.style.backgroundColor= Test.AnotherWay._g_record_ctrl_keydown ? keydown_color : button_color;
-Test.AnotherWay._record_format_time=function( t )
- t=new Date( t );
- var m=t.getMinutes();
- var s=t.getSeconds();
- var str= m==0 ? "" : m+"m ";
- str+=s+"s.";
- return str;
-Test.AnotherWay._record_control_update_time=function()
- var time_display=Test.AnotherWay._record_control_get_element( "record_time" );
- if( time_display!=null ) {
- time_display.innerHTML=Test.AnotherWay._record_format_time( (new Date()).getTime()-Test.AnotherWay._g_record_start_time );
-Test.AnotherWay._record_control_update_highlight=function( elem, style, event )
- if( elem==null ) {
- Test.AnotherWay._record_highlight_border( null );
- }else {
- var pos=Test.AnotherWay._get_page_coords( elem );
- if( style=="ball" || elem!=Test.AnotherWay._g_record_highlighted_element.element || pos.x!=Test.AnotherWay._g_record_highlighted_element.x || pos.y!=Test.AnotherWay._g_record_highlighted_element.y ) {
- Test.AnotherWay._g_record_highlighted_element={ element: elem, x: pos.x, y: pos.y };
- Test.AnotherWay._record_highlight_border( elem, style, event );
-Test.AnotherWay._record_decode_key=function( event )
- var k=null;
- if( event==null ) {
- k=Test.AnotherWay._g_record_wnd.event.keyCode;
- }else {
- k=event.which;
- if( k==83 ) {
- return "s";
- }else if( k==72 ) {
- return "h";
- }else if( k==73 ) {
- return "i";
- }else if( k==80 ) {
- return "p";
- }else if( k==67 ) {
- return "c";
- }else if( k==77 ) {
- return "m";
- }else if( k==16 ) {
- return "shift";
- }else if( k==17 ) {
- return "ctrl";
- }else if( k==18 ) {
- return "alt";
- }else if( k==19 ) {
- return "pause";
- }else if( k==123 ) {
- return "f12";
- return "";
-Test.AnotherWay._record_control_keydown=function( event )
- var handled=false;
- var k=Test.AnotherWay._record_decode_key( event );
- if( k=="shift" ) {
- Test.AnotherWay._g_record_shift_keydown=true;
- }else if( k=="ctrl" ) {
- Test.AnotherWay._g_record_ctrl_keydown=true;
- }else if( k!="" && (Test.AnotherWay._g_record_keydown==null || Test.AnotherWay._g_record_keydown==k) ) {
- if( Test.AnotherWay._g_record_ctrl_keydown && Test.AnotherWay._g_record_shift_keydown && !Test.AnotherWay._record_control_key_disabled( k ) ) {
- Test.AnotherWay._g_record_keydown=k;
- handled=true;
- }else {
- Test.AnotherWay._g_record_keydown="";
- Test.AnotherWay._record_control_update_ui();
- if( !handled ) {
-// Test.AnotherWay._record_event( event ); // replaying is not supported in any known browser
- return;
-Test.AnotherWay._record_control_keyup=function( event )
- Test.AnotherWay._g_record_shift_keydown=false;
- Test.AnotherWay._g_record_ctrl_keydown=false;
- }else if( k!="" && k==Test.AnotherWay._g_record_keydown && Test.AnotherWay._g_record_ctrl_keydown && Test.AnotherWay._g_record_shift_keydown ) {
- if( k=="s" ) {
- Test.AnotherWay._g_record_started=!Test.AnotherWay._g_record_started;
- if( Test.AnotherWay._g_record_started ) {
- Test.AnotherWay._g_record_events=[];
- Test.AnotherWay._g_record_start_time=(new Date()).getTime();
- Test.AnotherWay._record_control_update_time();
- Test.AnotherWay._g_record_update_time_interval=window.setInterval( Test.AnotherWay._record_control_update_time, 200 );
- }else {
- Test.AnotherWay._record_control_update_highlight( null );
- if( !Test.AnotherWay._g_record_paused ) {
- window.clearInterval( Test.AnotherWay._g_record_update_time_interval );
- Test.AnotherWay._g_record_waiting_for_results=true;
- // open a new window for self, pass a parameter to dump recorded events as javascript code there
- // (the easiest way to obtain a document from the same origin, so it's writable, is to open this same page again)
- var loc=window.location;
- loc=loc.protocol+"//"+loc.host+loc.pathname+"?recording_results="+Test.AnotherWay._g_record_random_id;
- if( window.open( loc, "_blank" )==null ) {
- alert( "unable to open new window for results" );
- handled=true;
- }else if( k=="h" ) {
- Test.AnotherWay._g_record_control_visible=!Test.AnotherWay._g_record_control_visible;
- handled=true;
- Test.AnotherWay._g_record_paused=!Test.AnotherWay._g_record_paused;
- if( Test.AnotherWay._g_record_paused ) {
- Test.AnotherWay._g_record_pause_start_time=(new Date()).getTime();
- }else {
- var pause_duration=(new Date()).getTime()-Test.AnotherWay._g_record_pause_start_time;
- Test.AnotherWay._g_record_start_time+=pause_duration;
- handled=true;
- }else if( k=="m" ) {
- Test.AnotherWay._g_record_include_mousemove=!Test.AnotherWay._g_record_include_mousemove;
- handled=true;
- }else if( k=="c" ) {
- var o=Test.AnotherWay._record_checkpoint();
- Test.AnotherWay._record_display_checkpoint( o );
- Test.AnotherWay._record_flash_border( "#24d" );
- handled=true;
- Test.AnotherWay._g_record_keydown=null;
- if( !handled ) {
- return;
-Test.AnotherWay._record_html_node_path=function( node )
- if( node==null ) {
- return null;
- var path=[];
- while( true ) {
- if( node.id!=null && node.id!="" ) {
- path.unshift( "#"+node.id+" "+node.nodeName );
- break;
- }else {
- var parent_node=node.parentNode;
- if( parent_node==null ) {
- return []; // no BODY up the path - this node is screwed (browsers differ in what's above the body), discard
- }else {
- var i=0;
- var found=false;
- for( var child=parent_node.firstChild; child!=null; child=child.nextSibling ) {
- if( child==node ) {
- found=true;
- break;
- if( child.nodeType==1 ) { // count only HTML element nodes
- ++i;
- if( !found ) {
- i=-1;
- path.unshift( i+" "+node.nodeName );
- if( parent_node.nodeName=="BODY" || parent_node.nodeName=="body" ) {
- break;
- node=parent_node;
- return path;
-Test.AnotherWay._record_node_path_to_string=function( path )
- var s="";
- if( path!=null ) {
- s+= i==0 ? "" : ", ";
- var elem=path[i].split( " " );
- if( elem[0].charAt( 0 )=="#" ) {
- s+=elem[1]+" "+elem[0];
- }else {
- s+=elem[1]+" ["+elem[0]+"]";
- return s;
-Test.AnotherWay._record_node_path_to_node=function( path_str, doc )
- if( path_str==null ) {
- return null;
- var path=path_str.split( "," );
- var node=doc.body;
- var node_i=path[i].split( " " )[0];
- if( node_i.charAt( 0 )=="#" ) {
- node=doc.getElementById( node_i.substring( 1 ) );
- }else {
- if( node_i<0 || node_i>=node.childNodes.length ) {
- node=null;
- }else {
- node=node.firstChild;
- while( node!=null ) {
- if( node.nodeType==1 ) { // count only HTML element nodes
- if( node_i==0 ) {
- break;
- --node_i;
- node=node.nextSibling;
- return null;
- return node;
-Test.AnotherWay._record_control_contains_id=function( s )
- return s.match( /^#record_[\w_]+/ ) && s.match( Test.AnotherWay._g_record_random_id );
-Test.AnotherWay._record_checkpoint=function()
- var o={ type: "_checkpoint", time: (new Date()).getTime()-Test.AnotherWay._g_record_start_time, which: Test.AnotherWay._g_record_checkpoint_count++,
- target: Test.AnotherWay._record_html_node_path( Test.AnotherWay._g_record_under_cursor ) };
- Test.AnotherWay._g_record_events.push( o );
- return o;
-Test.AnotherWay._record_event=function( event )
- var unneeded=["rangeOffset","eventPhase","timeStamp","isTrusted","popupWindowFeatures","rangeOffset"];
- if( Test.AnotherWay._g_record_started && !Test.AnotherWay._g_record_paused ) {
- var o={};
- for( var n in event ) {
- var needed=!n.match( /^[A-Z0-9_]+$/ );
- if( needed ) {
- for( var ui=0; ui<unneeded.length; ++ui ) {
- if( unneeded[ui]==n ) {
- needed=false;
- break;
- if( needed ) {
- var value=event[n];
- if( typeof( value )!="object" && typeof( value )!="function" ) {
- o[n]=value;
- }else if( n=="target" || n=="relatedTarget" ) {
- o[n]=Test.AnotherWay._record_html_node_path( value );
- o["time"]=(new Date()).getTime()-Test.AnotherWay._g_record_start_time;
- var over_record_control= o["target"]!=null && o["target"][0]!=null && Test.AnotherWay._record_control_contains_id( o["target"][0] );
- if( !over_record_control ) {
- return true;
-Test.AnotherWay._record_on_mousemove=function( event )
- var path=Test.AnotherWay._record_html_node_path( event.target );
- var new_mouse_over_record_control= path!=null && path[0]!=null && Test.AnotherWay._record_control_contains_id( path[0] );
- if( new_mouse_over_record_control!=Test.AnotherWay._g_record_mouse_over_record_control ) {
- Test.AnotherWay._g_record_mouse_over_record_control=new_mouse_over_record_control;
- if( event.target!=null && event.target!=Test.AnotherWay._g_record_under_cursor ) {
- Test.AnotherWay._g_record_under_cursor=event.target;
- var s="";
- if( path==null || path[0]==null || !Test.AnotherWay._record_control_contains_id( path[0] ) ) {
- s=Test.AnotherWay._record_node_path_to_string( path );
- if( s=="" ) {
- s=" ";
- var cursor_over_indicator=Test.AnotherWay._record_control_get_element( "record_cursor_over" );
- cursor_over_indicator.innerHTML=s;
- var highlight_element=null;
- if( !Test.AnotherWay._g_record_mouse_over_record_control && Test.AnotherWay._g_record_started && !Test.AnotherWay._g_record_paused ) {
- highlight_element=event.target;
- // highlight border disabled on recording - it causes page to scroll, issuing spurious mouseover/mouseout event
- //Test.AnotherWay._record_control_update_highlight( highlight_element, "border" );
- if( Test.AnotherWay._g_record_include_mousemove ) {
- Test.AnotherWay._record_event( event );
- return true;
-Test.AnotherWay._record_display_checkpoint=function( o )
- var checkpoints_div=Test.AnotherWay._record_control_get_element( "record_checkpoints" );
- var p=checkpoints_div.appendChild( checkpoints_div.ownerDocument.createElement( "div" ) );
- p.style.marginTop="3px";
- p.style.font="normal normal 8pt sans-serif";
- p.style.color="#000";
- p.style.textAligh="left";
- p.style.position="relative";
- p.style.width="100%";
- var checkpoint_text="";
- checkpoint_text+="#"+(o.which+1);
- checkpoint_text+=" "+Test.AnotherWay._record_format_time( o.time );
- if( o.target!=null ) {
- checkpoint_text+=Test.AnotherWay._record_node_path_to_string( o.target );
- p.appendChild( p.ownerDocument.createTextNode( checkpoint_text ) );
-Test.AnotherWay._record_save_results=function( doc )
- // strange, but DOM-style append does not work here in opera 8.
- var append=function( s ) { doc.write( "<div>"+s+"</div>" ); };
- append( "/* paste this data into your javascript and pass it as an argument to replay_events method */" );
- append( "{ checkpoints: [" );
- var first_checkpoint=true;
- for( var i=0; i<Test.AnotherWay._g_record_events.length; ++i ) {
- var o=Test.AnotherWay._g_record_events[i];
- if( o.type=="_checkpoint" ) {
- var str= first_checkpoint ? "" : "}, ";
- str+="function( tst, wnd ) { // #"+o.which+" time "+Test.AnotherWay._record_format_time( o.time )+" cursor was over "+Test.AnotherWay._record_node_path_to_string( o.target );
- append( str );
- first_checkpoint=false;
- if( !first_checkpoint ) {
- append( "}" );
- append( "], events: [ " );
- var prev_time=0;
- var s="";
- s+= "{";
- var n_first=true;
- for( var n in o ) {
- if( n=="time" ) { // convert to relative time
- var cur_time=o[n]-0;
- o[n]=cur_time-prev_time;
- prev_time=cur_time;
- s+=n_first ? n : ", "+n;
- s+=":";
- if( o[n]==null ) {
- s+="null";
- }else {
- s+="\""+o[n]+"\"";
- n_first=false;
- s+= i==Test.AnotherWay._g_record_events.length-1 ? "}" : "},";
- append( s );
- append( "] }" );
- append( ";" );
-Test.AnotherWay._g_record_border; // border highlighting element under cursor
-Test.AnotherWay._g_record_border_flashes=[]; // array of { color: color, timeout: milliseconds }
-Test.AnotherWay._g_record_border_flashing=false;
-Test.AnotherWay._g_record_border_normal_color="#d4b";
-Test.AnotherWay._record_flash_border_timeout=function()
- var color=Test.AnotherWay._g_record_border_normal_color;
- var timeout=null;
- if( Test.AnotherWay._g_record_border_flashes.length!=0 ) {
- color=Test.AnotherWay._g_record_border_flashes[0].color;
- timeout=Test.AnotherWay._g_record_border_flashes[0].timeout;
- Test.AnotherWay._g_record_border_flashes.splice( 0, 1 );
- if( Test.AnotherWay._g_record_border!=null ) {
- for( var i=0; i<Test.AnotherWay._g_record_border.length; ++i ) {
- Test.AnotherWay._g_record_border[i].style.backgroundColor=color;
- if( timeout!=null ) {
- setTimeout( Test.AnotherWay._record_flash_border_timeout, timeout );
- }else {
- Test.AnotherWay._g_record_border_flashing=false;
-Test.AnotherWay._get_page_coords=function( elm )
- var point = { x: 0, y: 0 };
- while( elm ) {
- point.x+=elm.offsetLeft;
- point.y+=elm.offsetTop;
- elm=elm.offsetParent;
- return point;
-Test.AnotherWay._set_page_coords=function( elm, x, y )
- var parent_coords={ x: 0, y: 0 };
- if( elm.offsetParent ) {
- parent_coords=Test.AnotherWay._get_page_coords( elm.offsetParent );
- var new_x=x-parent_coords.x;
- if( new_x<0 ) {
- new_x=0;
- elm.style.left=new_x+'px';
- var new_y=y-parent_coords.y;
- if( new_y<0 ) {
- new_y=0;
- elm.style.top=new_y+'px';
-Test.AnotherWay._record_setup_highlight_positions=function( element, style, coords, positions )
- if( style=="border" ) {
- var width=element.clientWidth;
- var height=element.clientHeight;
- var step=0;
- var thickness=2;
- var fudge_expand=4;
- positions.push( { x: coords.x-step-thickness, y: coords.y-step-thickness, width: width+2*step+2*thickness+fudge_expand, height: thickness } );
- positions.push( { x: coords.x+width+step+fudge_expand, y: coords.y-step-thickness, width: thickness, height: height+2*step+2*thickness+fudge_expand } );
- positions.push( { x:positions[0].x, y:positions[0].y, width:positions[0].width, height:positions[0].height } );
- positions.push( { x:positions[1].x, y:positions[1].y, width:positions[1].width, height:positions[1].height } );
- positions[2].y+=height+thickness+2*step+fudge_expand;
- positions[3].x-=width+thickness+2*step+fudge_expand;
- }else if( style=="ball" ) {
- positions.push( { x: coords.x+2, y: coords.y, width: 2, height: 6 } );
- positions.push( { x: coords.x, y: coords.y+2, width: 6, height: 2 } );
- positions.push( { x: coords.x+1, y: coords.y+1, width: 4, height: 4 } );
-Test.AnotherWay._record_highlight_border=function( element, style, event ) // null - hide border
- if( element!=null ) {
- if( Test.AnotherWay._g_record_border==null || Test.AnotherWay._g_record_border[0].ownerDocument!=element.ownerDocument ) {
- Test.AnotherWay._g_record_border=[];
- var n= style=="border" ? 4 : style=="ball" ? 3 : 0;
- for( var i=0; i<4; ++i ) {
- var b=element.ownerDocument.createElement( "div" );
- b.style.position="absolute";
- b.style.zIndex="1";
- b.style.backgroundColor=Test.AnotherWay._g_record_border_normal_color;
- element.ownerDocument.body.appendChild( b );
- Test.AnotherWay._g_record_border.push( b );
- var coords=null;
- coords=Test.AnotherWay._get_page_coords( element );
- if( event!=null ) {
- if( event.pageX!=null && event.pageY!=null ) {
- coords={ x: event.pageX-0, y: event.pageY-0 };
- }else if( event.clientX!=null && event.clientY!=null ) {
- var doc=element.ownerDocument;
- if( doc!=null ) {
- coords={ x: (event.clientX-0)+doc.body.scrollLeft, y: (event.clientY-0)+doc.body.scrollTop };
- if( coords!=null && element.clientWidth!=null && element.clientHeight!=null ) {
- var positions=[];
- Test.AnotherWay._record_setup_highlight_positions( element, style, coords, positions );
- for( var i=0; i<positions.length; ++i ) {
- var b=Test.AnotherWay._g_record_border[i];
- var p=positions[i];
- Test.AnotherWay._set_page_coords( b, p.x, p.y );
- b.style.width=p.width+"px";
- b.style.height=p.height+"px";
- b.style.display="block";
- }else {
- Test.AnotherWay._g_record_border[i].style.display="none";
-Test.AnotherWay._record_flash_border=function( color )
- if( Test.AnotherWay._g_record_border_flashing ) { //already
- Test.AnotherWay._g_record_border_flashes.push( { color: Test.AnotherWay._g_record_border_normal_color, timeout:300 } );
- Test.AnotherWay._g_record_border_flashes.push( { color: color, timeout:600 } );
- }else {
- Test.AnotherWay._g_record_border_flashing=true;
- Test.AnotherWay._record_flash_border_timeout();
-Test.AnotherWay._record_prepare_doc_for_results=function()
- document.open();
- document.write( "<!DOCTYPE HTML PUBLIC \"-//W3C//DTD HTML 4.01//EN\" \"http://www.w3.org/TR/html4/strict.dtd\">" );
- document.write( "<html><head><title> Input recording results</title>" );
- document.write( "<style type=\"text/css\">" );
- document.write( "body { font: normal normal smaller sans-serif; }" );
- document.write( "div { margin-top: 3px; }" );
- document.write( "</style></head><body>" );
- // opera and mozilla disagree over who the opener is.
- if( typeof( window.opener.Test )!="undefined" && typeof( window.opener.Test.AnotherWay )!="undefined" ) {
- window.opener.Test.AnotherWay._record_save_results( document );
- window.opener.Test.AnotherWay._g_record_waiting_for_results=false;
- window.opener.Test.AnotherWay._record_control_update_ui();
- }else if( typeof( window.opener.opener.Test )!="undefined" && typeof( window.opener.opener.Test.AnotherWay )!="undefined" ) {
- window.opener.opener.Test.AnotherWay._record_save_results( document );
- window.opener.opener.Test.AnotherWay._g_record_waiting_for_results=false;
- window.opener.opener.Test.AnotherWay._record_control_update_ui();
- document.write( "</body>" );
- document.close();
-// global initialization
-onload=function()
- var good_opera=typeof( window.opera.version )=="function";
- good_opera=good_opera && window.opera.version().match( /^\s*(\d+)/ );
- good_opera=good_opera && RegExp.$1>=8;
- var span=document.createElement( "SPAN" );
- span.innerHTML="<!--[if IE]><br /><![endif]-"+"->";
- var is_ie=span.getElementsByTagName( "BR" ).length>0;
- Test.AnotherWay._g_test_iframe=window.frames.test_iframe;
- var query_str=window.location.search;
- if( query_str.charAt( 0 )=="?" ) {
- query_str=query_str.substring( 1 );
- var testlist_page="list-tests.html";
- var auto_run=false;
- if( query_str!="" ) {
- var params=[query_str];
- if( query_str.indexOf( ";" )!=-1 ) {
- params=query_str.split( ";" );
- }else if( query_str.indexOf( "&" )!=-1 ) {
- params=query_str.split( "&" );
- for( var param_i=0; param_i<params.length; ++param_i ) {
- var param=params[param_i].split( "=" );
- if( param[0]=="recording_results" ) {
- if( window.opener!=null ) {
- // we were told to show recording results - replace everything in the document with the results
- Test.AnotherWay._record_prepare_doc_for_results();
- return;
- }else if( param[0]=="testpage" ) {
- Test.AnotherWay._add_test_page_url( decodeURIComponent( param[1] ), "anotherway" );
- }else if( param[0]=="jsantestpage" ) {
- Test.AnotherWay._add_test_page_url( decodeURIComponent( param[1] ), "jsan" );
- }else if( param[0]=="testlist" ) {
- testlist_page=decodeURIComponent( param[1] );
- }else if( param[0]=="testframe" ) {
- if( window.opera && !good_opera ) {
- Test.AnotherWay._show_error( "testframe parameter does not work in versions of Opera prior to 8.0. Sorry (pathches are welcome)." );
- // Opera 7 barfs on attempt to access frame.frameElement.
- // if someone knows a way to assign onload handler to that iframe in Opera 7
- // without disrupting code that works in other browsers, patches are welcome.
- }else {
- var frame_path=param[1].split( "." );
- var frame=top;
- for( var frame_path_i=0; frame_path_i<frame_path.length; ++frame_path_i ) {
- frame=frame[frame_path[frame_path_i]];
- if( frame==null ) {
- Test.AnotherWay._show_error( "unable to find frame specified for loading test pages: "+param[1] );
- }else {
- if( frame.frameElement!=null ) { // for the following assignement to onload to work, frameElement is required
- frame=frame.frameElement;
- Test.AnotherWay._g_test_iframe=frame;
- }else if( param[0]=="testframe_no_clear" ) {
- Test.AnotherWay._g_test_frame_no_clear=true;
- }else if( param[0]=="windows" ) {
- if (param[1] == "none") {
- Test.AnotherWay._test_object_t.prototype.open_window=null;
- }else if( param[0]=="run" ) {
- auto_run=true;
- if( param[1]=="all" ) {
- Test.AnotherWay._g_pages_to_run="all";
- }else {
- if( Test.AnotherWay._g_pages_to_run==null || Test.AnotherWay._g_pages_to_run=="all" ) {
- Test.AnotherWay._g_pages_to_run=[];
- var pages=param[1].split( "," );
- for( var i=0; i<pages.length; ++i ) {
- Test.AnotherWay._g_pages_to_run.push( pages[i] );
- if( Test.AnotherWay._g_test_page_urls.length==0 ) { // if no individual pages were given on the command line, load the list
- var result=Test.AnotherWay._set_iframe_location( window.frames["list_iframe"], testlist_page );
- Test.AnotherWay._show_error( result.msg );
- Test.AnotherWay._g_run_on_list_load=auto_run;
- }else {
- Test.AnotherWay._g_run_on_main_load=auto_run;
- var f=Test.AnotherWay._g_test_iframe;
- try {
- if( f.attachEvent!=null ) {
- f.attachEvent( "onload", Test.AnotherWay._test_page_onload );
- }else {
- f.onload=Test.AnotherWay._test_page_onload;
- if( Test.AnotherWay._g_test_iframe.nodeType!=null && Test.AnotherWay._g_test_iframe.contentWindow!=null ) { // it's iframe element, not the iframe. we need iframe.
- Test.AnotherWay._g_test_iframe=Test.AnotherWay._g_test_iframe.contentWindow;
- }catch(e) {
- // ignore stupid opera error if the frame has onload handler assigned in the inline html
- var handlers={
- "run_all": { "onclick": Test.AnotherWay._run_all_onclick },
- "run_selected": { "onclick": Test.AnotherWay._run_selected_onclick },
- "unselect_all": { "onclick": Test.AnotherWay._unselect_all_onclick },
- "record_select": { "onfocus": Test.AnotherWay._record_check_onfocus },
- "record_input": { "onfocus": Test.AnotherWay._record_check_onfocus },
- "record_start": { "onclick": Test.AnotherWay._record_start_onclick },
- "clear_btn": { "onclick": Test.AnotherWay._results_clear_onclick },
- "results_tab": { "onclick": Test.AnotherWay._tab_onclick, "onmouseover": Test.AnotherWay._tab_mouseover, "onmouseout": Test.AnotherWay._tab_mouseout },
- "debug_tab": { "onclick": Test.AnotherWay._tab_onclick, "onmouseover": Test.AnotherWay._tab_mouseover, "onmouseout": Test.AnotherWay._tab_mouseout }
- for( var hs in handlers ) {
- var o=document.getElementById( hs );
- if( o!=null ) {
- for( var h in handlers[hs] ) {
- o[h]=handlers[hs][h];
- }else {
- Test.AnotherWay._show_error( "unable to set "+h+" handler: id "+hs+" not found" );
- Test.AnotherWay._g_no_record_msg="Input events recording and replaying is not available in opera versions prior to 8.0.";
- if( is_ie ) {
- Test.AnotherWay._g_no_record_msg="Input events recording and replaying is not available in internet explorer.";
- var no_record_p=document.getElementById( "record_not_supported" );
- no_record_p.style.display="block";
- no_record_p.appendChild( document.createTextNode( Test.AnotherWay._g_no_record_msg ) );
- Test.AnotherWay._g_main_loaded=true;
- if( Test.AnotherWay._g_run_on_main_load ) {
- Test.AnotherWay._g_run_on_main_load=false;
- Test.AnotherWay._run_pages_to_run();
-</script>
-<script type="text/javascript" src="xml_eq.js"></script>
-<script type="text/javascript" src="geom_eq.js"></script>
-</head><body>
-<div id="col1">
-<div id="col1_header">Test pages:</div>
-<div id="scroller">
-<table id="testtable">
-</table>
-</div>
-<div id="run_buttons">
-<input type="button" value=" clear " id="clear_btn" />
-<input type="button" value=" run all " id="run_all" />
-<input type="button" value=" run selected " id="run_selected" />
-<input type="button" value=" unselect all " id="unselect_all" />
-</div>
-<input type="checkbox" id="dont_close_test_windows" /> do not close windows opened by tests
-<div id="error"></div>
-<div id="record_div">
-<p id="record_not_supported" style="display:none"></p>
-<p>Record mouse input for the page:</p>
-<p><input type="radio" name="record_choose" value="select" checked="checked" /> <select id="record_select"><option selected="selected">-- select a page: --</option></select></p>
-<p><input type="radio" name="record_choose" value="input" /> or enter page url: <input type="text" id="record_input" /></p>
-<p><input type="button" value=" record " id="record_start" /></p>
-</div>
-</div>
-<div id="col2">
-<div id="right_header">
-<span id="results_count">Results: <span id="total"></span></span>
-<span id="results_tab" class="active_tab" style="visibility:hidden">Results</span>
-<span id="debug_tab" class="inactive_tab" style="visibility:hidden">Debug</span>
-</div>
-<div id="right_frame">
-<div id="results"></div>
-<div id="debug"></div>
-</div>
-</div>
-<span style="display:none">
-<iframe name="list_iframe" onload="Test.AnotherWay._list_iframe_onload();"></iframe>
-<iframe name="test_iframe" onload="Test.AnotherWay._test_page_onload();"></iframe>
-<!-- record_control div is to be imported into other documents, so all its styles are inline -->
--<div id="record_control" style="position:absolute;bottom:0;left:0;margin:0;padding:0.5em;width:22em;height:22em;border:1px solid;background:#ffd;font: normal normal 8pt sans-serif; color:#000; text-align: left">
-<p style="margin:0 0 0 0; padding:0">
-<span style="display:none;font-weight:bold;color:#408" id="record_indicator">
-recording. <span style="font-weight:normal">time: <span id="record_time"></span></span><span id="record_pause_indicator"> paused</span>
-</span>
-</p>
-<div id="record_cursor_over" style="margin:0;padding:2px;width:14em;height:1.1em;overflow:hidden;float:right;border:1px solid #777;background:#fff;font: normal normal 8pt sans-serif;position:relative;top:3px;color:#000;text-align:left;"> </div>
-<p style="margin:2px 0 0 0; padding:0">
-cursor is over
-</p>
-<p style="margin:8px 0 0 0; padding:0;">
- keyboard control: press
- <span id="record_ctrl_key" style="border:1px solid #226;background:#adf;padding:0 0.5em">ctrl</span> -
- <span id="record_shift_key" style="border:1px solid #226;background:#adf;padding:0 0.5em">shift</span> -
-</p>
-<p style="margin:4px 0 0 0; padding:0">
-<span id="record_s" style="border:1px solid #226;background:#adf;width:1.2em;float:left;font-weight:bold;text-align:center;margin-right:0.5em">s</span>
-<span id="record_on">to <b>start</b> recording</span>
-<span id="record_off" style="display:none">to <b>stop</b> recording</span>
-</p>
-<span id="record_h" style="border:1px solid #226;background:#adf;width:1.2em;float:left;font-weight:bold;text-align:center;margin-right:0.5em">h</span>
-<span>to <b>hide/show</b> this window</span>
-</p>
-<span id="record_m" style="border:1px solid #226;background:#adf;width:1.2em;float:left;font-weight:bold;text-align:center;margin-right:0.5em">m</span>
-<span id="record_include_mousemove">to <b> record</b> mousemove</span>
-<span id="record_omit_mousemove" style="display:none">to <b>omit</b> mousemove</span>
-</p>
-<span id="record_p" style="border:1px solid #226;background:#aaa;width:1.2em;float:left;font-weight:bold;text-align:center;margin-right:0.5em">p</span>
-<span id="record_pause_on">to <b> pause</b> recording</span>
-<span id="record_pause_off" style="display:none">to <b>continue</b> recording</span>
-</p>
-<span id="record_c" style="border:1px solid #226;background:#aaa;width:1.2em;float:left;font-weight:bold;text-align:center;margin-right:0.5em">c</span>
-<span>to add checkpoint</span>
-</p>
-<p style="margin:6px 0 0 0; padding:0">
-checkpoints:
-</p>
-<div id="record_checkpoints" style="position:relative;width:100%;height:6em;overflow:auto;font: normal normal 8pt sans-serif; color:#000; text-align: left">
-</div>
-</div>
-</span>
-<script>
- if (/noscroll/.test(location.href)) {
- document.getElementById('scroller').style.height='auto';
- document.getElementById('right_frame').style.height='auto';
-</script>
-</body></html>
+ </script>
+ </body>
+</html>
Deleted: trunk/openlayers/tests/xml_eq.js
--- trunk/openlayers/tests/xml_eq.js 2011-09-17 17:30:36 UTC (rev 12377)
+++ trunk/openlayers/tests/xml_eq.js 2011-09-17 17:36:14 UTC (rev 12378)
@@ -1,311 +0,0 @@
- * File: xml_eq.js
- * Adds a xml_eq method to AnotherWay test objects.
-(function() {
- * Function: createNode
- * Given a string, try to create an XML DOM node. Throws string messages
- * on failure.
- * Parameters:
- * text - {String} An XML string.
- * Returns:
- * {DOMElement} An element node.
- function createNode(text) {
- var index = text.indexOf('<');
- if(index > 0) {
- text = text.substring(index);
- var doc;
- if(window.ActiveXObject && !this.xmldom) {
- doc = new ActiveXObject("Microsoft.XMLDOM");
- try {
- doc.loadXML(text);
- } catch(err) {
- throw "ActiveXObject loadXML failed: " + err;
- } else if(window.DOMParser) {
- try {
- doc = new DOMParser().parseFromString(text, 'text/xml');
- } catch(err) {
- throw "DOMParser.parseFromString failed";
- if(doc.documentElement && doc.documentElement.nodeName == "parsererror") {
- throw "DOMParser.parseFromString returned parsererror";
- } else {
- var req = new XMLHttpRequest();
- req.open("GET", "data:text/xml;charset=utf-8," +
- encodeURIComponent(text), false);
- if(req.overrideMimeType) {
- req.overrideMimeType("text/xml");
- req.send(null);
- doc = req.responseXML;
- var root = doc.documentElement;
- if(!root) {
- throw "no documentElement";
- return root;
- * Function assertEqual
- * Test two objects for equivalence (based on ==). Throw an exception
- * if not equivalent.
- * Parameters:
- * got - {Object}
- * expected - {Object}
- * msg - {String} The message to be thrown. This message will be appended
- * with ": got {got} but expected {expected}" where got and expected are
- * replaced with string representations of the above arguments.
- function assertEqual(got, expected, msg) {
- if(got === undefined) {
- got = "undefined";
- } else if (got === null) {
- got = "null";
- if(expected === undefined) {
- expected = "undefined";
- } else if (expected === null) {
- expected = "null";
- if(got != expected) {
- throw msg + ": got '" + got + "' but expected '" + expected + "'";
- * Function assertElementNodesEqual
- * Test two element nodes for equivalence. Nodes are considered equivalent
- * if they are of the same type, have the same name, have the same
- * namespace prefix and uri, and if all child nodes are equivalent.
- * Throws a message as exception if not equivalent.
- * Parameters:
- * got - {DOMElement}
- * expected - {DOMElement}
- * options - {Object} Optional object for configuring test options.
- * Valid options:
- * prefix - {Boolean} Compare element and attribute
- * prefixes (namespace uri always tested). Default is false.
- * includeWhiteSpace - {Boolean} Include whitespace only nodes when
- * comparing child nodes. Default is false.
- function assertElementNodesEqual(got, expected, options) {
- var testPrefix = (options && options.prefix === true);
- // compare types
- assertEqual(got.nodeType, expected.nodeType, "Node type mismatch");
- // compare names
- var gotName = testPrefix ?
- got.nodeName : got.nodeName.split(":").pop();
- var expName = testPrefix ?
- expected.nodeName : expected.nodeName.split(":").pop();
- assertEqual(gotName, expName, "Node name mismatch");
- // for text nodes compare value
- if(got.nodeType == 3) {
- assertEqual(
- got.nodeValue, expected.nodeValue, "Node value mismatch"
- // for element type nodes compare namespace, attributes, and children
- else if(got.nodeType == 1) {
- // test namespace alias and uri
- if(got.prefix || expected.prefix) {
- if(testPrefix) {
- assertEqual(
- got.prefix, expected.prefix,
- "Bad prefix for " + got.nodeName
- if(got.namespaceURI || expected.namespaceURI) {
- assertEqual(
- got.namespaceURI, expected.namespaceURI,
- "Bad namespaceURI for " + got.nodeName
- // compare attributes - disregard xmlns given namespace handling above
- var gotAttrLen = 0;
- var gotAttr = {};
- var expAttrLen = 0;
- var expAttr = {};
- var ga, ea, gn, en;
- for(var i=0; i<got.attributes.length; ++i) {
- ga = got.attributes[i];
- if(ga.specified === undefined || ga.specified === true) {
- if(ga.name.split(":").shift() != "xmlns") {
- gn = testPrefix ? ga.name : ga.name.split(":").pop();
- gotAttr[gn] = ga;
- ++gotAttrLen;
- for(var i=0; i<expected.attributes.length; ++i) {
- ea = expected.attributes[i];
- if(ea.specified === undefined || ea.specified === true) {
- if(ea.name.split(":").shift() != "xmlns") {
- en = testPrefix ? ea.name : ea.name.split(":").pop();
- expAttr[en] = ea;
- ++expAttrLen;
- assertEqual(
- gotAttrLen, expAttrLen,
- "Attributes length mismatch for " + got.nodeName
- var gv, ev;
- for(var name in gotAttr) {
- if(expAttr[name] == undefined) {
- throw "Attribute name " + gotAttr[name].name + " expected for element " + got.nodeName;
- // test attribute namespace
- assertEqual(
- gotAttr[name].namespaceURI, expAttr[name].namespaceURI,
- "Attribute namespace mismatch for element " +
- got.nodeName + " attribute name " + gotAttr[name].name
- // test attribute value
- assertEqual(
- gotAttr[name].value, expAttr[name].value,
- "Attribute value mismatch for element " + got.nodeName +
- " attribute name " + gotAttr[name].name
- // compare children
- var gotChildNodes = getChildNodes(got, options);
- var expChildNodes = getChildNodes(expected, options);
- assertEqual(
- gotChildNodes.length, expChildNodes.length,
- "Children length mismatch for " + got.nodeName
- for(var j=0; j<gotChildNodes.length; ++j) {
- try {
- assertElementNodesEqual(
- gotChildNodes[j], expChildNodes[j], options
- } catch(err) {
- throw "Bad child " + j + " for element " + got.nodeName + ": " + err;
- return true;
- * Function getChildNodes
- * Returns the child nodes of the specified nodes. By default this method
- * will ignore child text nodes which are made up of whitespace content.
- * The 'includeWhiteSpace' option is used to control this behaviour.
- * Parameters:
- * node - {DOMElement}
- * options - {Object} Optional object for test configuration.
- * Valid options:
- * Returns:
- * {Array} of {DOMElement}
- function getChildNodes(node, options) {
- //check whitespace
- if (options && options.includeWhiteSpace) {
- return node.childNodes;
- else {
- nodes = [];
- for (var i = 0; i < node.childNodes.length; i++ ) {
- var child = node.childNodes[i];
- if (child.nodeType == 1) {
- //element node, add it
- nodes.push(child);
- else if (child.nodeType == 3) {
- //text node, add if non empty
- if (child.nodeValue &&
- child.nodeValue.replace(/^\s*(.*?)\s*$/, "$1") != "" ) {
- return nodes;
- * Function: Test.AnotherWay._test_object_t.xml_eq
- * Test if two XML nodes are equivalent. Tests for same node types, same
- * node names, same namespace URI, same attributes, and recursively
- * tests child nodes for same criteria.
- * (code)
- * t.xml_eq(got, expected, message);
- * (end)
- * Parameters:
- * got - {DOMElement | String} A DOM node or XML string to test.
- * expected - {DOMElement | String} The expected DOM node or XML string.
- * msg - {String} A message to print with test output.
- * options - {Object} Optional object for configuring test.
- * Valid options:
- var proto = Test.AnotherWay._test_object_t.prototype;
- proto.xml_eq = function(got, expected, msg, options) {
- // convert arguments to nodes if string
- if(typeof got == "string") {
- try {
- got = createNode(got);
- } catch(err) {
- this.fail(msg + ": got argument could not be converted to an XML node: " + err);
- return;
- if(typeof expected == "string") {
- try {
- expected = createNode(expected);
- } catch(err) {
- this.fail(msg + ": expected argument could not be converted to an XML node: " + err);
- return;
- // test nodes for equivalence
- try {
- assertElementNodesEqual(got, expected, options);
- this.ok(true, msg);
- } catch(err) {
- this.fail(msg + ": " + err);
More information about the Commits
