[OpenLayers-Commits] r12408 - trunk/openlayers/build
commits-20090109 at openlayers.org
Tue Sep 20 23:16:41 EDT 2011
Author: openlayersgit
Date: 2011-09-20 20:16:39 -0700 (Tue, 20 Sep 2011)
New Revision: 12408
trunk/openlayers/build/build.py
Modify build script to support minimizing with jsmin before passing to closure
webservice for closure_ws. (Closes #3422)
Modified: trunk/openlayers/build/build.py
--- trunk/openlayers/build/build.py 2011-09-21 03:16:33 UTC (rev 12407)
+++ trunk/openlayers/build/build.py 2011-09-21 03:16:39 UTC (rev 12408)
@@ -55,7 +55,20 @@
elif use_compressor == "minimize":
minimized = minimize.minimize(merged)
elif use_compressor == "closure_ws":
- minimized = closure_ws.minimize(merged)
+ if len(merged) > 1000000: # The maximum file size for this web service is 1000 KB.
+ print "\nPre-compressing using jsmin"
+ merged = jsmin.jsmin(merged)
+ print "\nIs being compressed using Closure Compiler Service."
+ try:
+ minimized = closure_ws.minimize(merged)
+ except Exception, E:
+ print "\nAbnormal termination."
+ sys.exit("ERROR: Closure Compilation using Web service failed!\n%s" % E)
+ if len(minimized) <= 2:
+ print "\nAbnormal termination due to compilation errors."
+ sys.exit("ERROR: Closure Compilation using Web service failed!")
+ else:
+ print '\nClosure Compilation using Web service has completed successfully.'
elif use_compressor == "closure":
minimized = closure.minimize(merged)
else: # fallback
More information about the Commits
