[OpenLayers-Commits] r12416 - in sandbox/mpriour/temporal_map/openlayers: build examples lib lib/OpenLayers lib/OpenLayers/Control lib/OpenLayers/Filter lib/OpenLayers/Format lib/OpenLayers/Geometry lib/OpenLayers/Handler lib/OpenLayers/Layer lib/OpenLayers/Layer/Vector lib/OpenLayers/Marker lib/OpenLayers/Popup lib/OpenLayers/Protocol lib/OpenLayers/Strategy tests tests/Control tests/Format tests/Layer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue Sep 27 10:35:31 EDT 2011
Author: mpriour
Date: 2011-09-27 07:35:25 -0700 (Tue, 27 Sep 2011)
New Revision: 12416
   sandbox/mpriour/temporal_map/openlayers/build/build.py
   sandbox/mpriour/temporal_map/openlayers/examples/mobile-drawing.js
   sandbox/mpriour/temporal_map/openlayers/examples/multitouch.html
   sandbox/mpriour/temporal_map/openlayers/examples/select-feature-multilayer.html
   sandbox/mpriour/temporal_map/openlayers/examples/vector-formats.html
   sandbox/mpriour/temporal_map/openlayers/examples/xyz-esri.html
   sandbox/mpriour/temporal_map/openlayers/examples/xyz-offset.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/DrawFeature.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/Geolocate.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/GetFeature.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/Measure.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/SLDSelect.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/SelectFeature.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/Snapping.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/Split.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/TimeManager.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/TransformFeature.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/WMSGetFeatureInfo.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/WMTSGetFeatureInfo.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Events.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Filter/Function.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Filter/Spatial.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Format/GPX.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Format/QueryStringFilter.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/Curve.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/LineString.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/LinearRing.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/MultiLineString.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/MultiPoint.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/MultiPolygon.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/Polygon.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/Surface.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Click.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Hover.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Path.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Pinch.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Polygon.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/ArcGIS93Rest.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/ArcIMS.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/Grid.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/TMS.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/Vector.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/Vector/RootContainer.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/WMS.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/XYZ.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Map.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Marker.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Marker/Box.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Popup/FramedCloud.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Protocol/HTTP.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Request.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Strategy/Save.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Tile.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Util.js
   sandbox/mpriour/temporal_map/openlayers/tests/Control/DrawFeature.html
   sandbox/mpriour/temporal_map/openlayers/tests/Events.html
   sandbox/mpriour/temporal_map/openlayers/tests/Format/GPX.html
   sandbox/mpriour/temporal_map/openlayers/tests/Layer/Grid.html
   sandbox/mpriour/temporal_map/openlayers/tests/Layer/Text.html
   sandbox/mpriour/temporal_map/openlayers/tests/Request.html
   sandbox/mpriour/temporal_map/openlayers/tests/run-tests.html
merge with trunk r12415
Modified: sandbox/mpriour/temporal_map/openlayers/build/build.py
--- sandbox/mpriour/temporal_map/openlayers/build/build.py	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/build/build.py	2011-09-27 14:35:25 UTC (rev 12416)
@@ -55,7 +55,20 @@
     elif use_compressor == "minimize":
         minimized = minimize.minimize(merged)
     elif use_compressor == "closure_ws":
-        minimized = closure_ws.minimize(merged)
+        if len(merged) > 1000000: # The maximum file size for this web service is 1000 KB.
+            print "\nPre-compressing using jsmin"
+            merged = jsmin.jsmin(merged)
+        print "\nIs being compressed using Closure Compiler Service."
+        try:
+            minimized = closure_ws.minimize(merged)
+        except Exception, E:
+            print "\nAbnormal termination."
+            sys.exit("ERROR: Closure Compilation using Web service failed!\n%s" % E)
+        if len(minimized) <= 2:
+            print "\nAbnormal termination due to compilation errors."
+            sys.exit("ERROR: Closure Compilation using Web service failed!")
+        else:
+            print '\nClosure Compilation using Web service has completed successfully.'
     elif use_compressor == "closure":
         minimized = closure.minimize(merged)
     else: # fallback
Modified: sandbox/mpriour/temporal_map/openlayers/examples/mobile-drawing.js
--- sandbox/mpriour/temporal_map/openlayers/examples/mobile-drawing.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/examples/mobile-drawing.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -48,7 +48,11 @@
             -20037508.34, -20037508.34, 20037508.34, 20037508.34
         controls: [
-            new OpenLayers.Control.TouchNavigation(),
+            new OpenLayers.Control.TouchNavigation({
+                dragPanOptions: {
+                    enableKinetic: true
             new OpenLayers.Control.ZoomPanel(),
             toolbar
Modified: sandbox/mpriour/temporal_map/openlayers/examples/multitouch.html
--- sandbox/mpriour/temporal_map/openlayers/examples/multitouch.html	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/examples/multitouch.html	2011-09-27 14:35:25 UTC (rev 12416)
@@ -5,7 +5,7 @@
    <title>Multitouch Test</title>
   </head>
   <body>
-   <div style="width:80%; height: 80%; border: 1px solid black; font-size: 5em;" id="box">
+   <div style="width:80%; height: 200px; border: 1px solid black; font-size: 5em;" id="box">
    </div>
    Touch inside the box. On a touch enabled browser, you will get the number
    of detected touch events. If the box is red, your browser does not support
Modified: sandbox/mpriour/temporal_map/openlayers/examples/select-feature-multilayer.html
--- sandbox/mpriour/temporal_map/openlayers/examples/select-feature-multilayer.html	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/examples/select-feature-multilayer.html	2011-09-27 14:35:25 UTC (rev 12416)
@@ -24,7 +24,12 @@
                 {layers: 'basic'}
+            // allow testing of specific renderers via "?renderer=Canvas", etc
+            var renderer = OpenLayers.Util.getParameters(window.location.href).renderer;
+            renderer = (renderer) ? [renderer] : OpenLayers.Layer.Vector.prototype.renderers;
             var vectors1 = new OpenLayers.Layer.Vector("Vector Layer 1", {
+                renderers: renderer,
                 styleMap: new OpenLayers.StyleMap({
                     "default": new OpenLayers.Style(OpenLayers.Util.applyDefaults({
                         externalGraphic: "../img/marker-green.png",
@@ -38,6 +43,7 @@
             var vectors2 = new OpenLayers.Layer.Vector("Vector Layer 2", {
                         fillColor: "red",
Modified: sandbox/mpriour/temporal_map/openlayers/examples/vector-formats.html
--- sandbox/mpriour/temporal_map/openlayers/examples/vector-formats.html	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/examples/vector-formats.html	2011-09-27 14:35:25 UTC (rev 12416)
@@ -86,7 +86,8 @@
                 gml2: new OpenLayers.Format.GML.v2(gmlOptionsIn),
                 gml3: new OpenLayers.Format.GML.v3(gmlOptionsIn),
                 kml: new OpenLayers.Format.KML(kmlOptionsIn),
-                atom: new OpenLayers.Format.Atom(in_options)
+                atom: new OpenLayers.Format.Atom(in_options),
+                gpx: new OpenLayers.Format.GPX(in_options)
               'out': {
                 wkt: new OpenLayers.Format.WKT(out_options),
@@ -95,7 +96,8 @@
                 gml2: new OpenLayers.Format.GML.v2(gmlOptionsOut),
                 gml3: new OpenLayers.Format.GML.v3(gmlOptionsOut),
                 kml: new OpenLayers.Format.KML(out_options),
-                atom: new OpenLayers.Format.Atom(out_options)
+                atom: new OpenLayers.Format.Atom(out_options),
+                gpx: new OpenLayers.Format.GPX(out_options)
@@ -199,6 +201,7 @@
                 <option value="gml2">GML (v2)</option>
                 <option value="gml3">GML (v3)</option>
                 <option value="wkt">Well-Known Text (WKT)</option>
+                <option value="gpx">GPX</option>
             </select>
             &nbsp;
             <label for="prettyPrint">Pretty print</label>
Modified: sandbox/mpriour/temporal_map/openlayers/examples/xyz-esri.html
--- sandbox/mpriour/temporal_map/openlayers/examples/xyz-esri.html	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/examples/xyz-esri.html	2011-09-27 14:35:25 UTC (rev 12416)
@@ -7,11 +7,15 @@
     <title>OpenLayers Basic ESRI Map Cache Example</title>
     <link rel="stylesheet" href="../theme/default/style.css" type="text/css">
     <link rel="stylesheet" href="style.css" type="text/css">
+    <style>
+      .olImageLoadError {
+          display: none;
+    </style>
     <script src="../lib/OpenLayers.js"></script>
     <script type="text/javascript">
         var map, layer;
         function init(){
-            OpenLayers.Util.onImageLoadError = function() { this.style.display="none";}
             var layerExtent = new OpenLayers.Bounds( -13758743.4295939,  5591455.28887228, -13531302.3472101 , 5757360.4178881)
             map = new OpenLayers.Map( 'map', {'restrictedExtent': layerExtent} );
             layer = new OpenLayers.Layer.XYZ( "ESRI",
Modified: sandbox/mpriour/temporal_map/openlayers/examples/xyz-offset.js
--- sandbox/mpriour/temporal_map/openlayers/examples/xyz-offset.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/examples/xyz-offset.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -1,10 +1,5 @@
 var map, layer;
-// if tiles are not available, hide images
-//OpenLayers.Util.onImageLoadError = function() {
-//    this.style.display = "none";
 // called on body load
 function init() {
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/DrawFeature.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/DrawFeature.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/DrawFeature.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -32,12 +32,9 @@
     callbacks: null,
-     * Constant: EVENT_TYPES
      * Supported event types:
      * featureadded - Triggered when a feature is added
-    EVENT_TYPES: ["featureadded"],
      * APIProperty: multi
@@ -67,13 +64,6 @@
      * options - {Object}
     initialize: function(layer, handler, options) {
-        // concatenate events specific to vector with those from the base
-        this.EVENT_TYPES =
-            OpenLayers.Control.DrawFeature.prototype.EVENT_TYPES.concat(
-            OpenLayers.Control.prototype.EVENT_TYPES
         OpenLayers.Control.prototype.initialize.apply(this, [options]);
         this.callbacks = OpenLayers.Util.extend(
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/Geolocate.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/Geolocate.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/Geolocate.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -23,14 +23,12 @@
 OpenLayers.Control.Geolocate = OpenLayers.Class(OpenLayers.Control, {
      *  - *locationupdated* Triggered when browser return a new position
      *  - *locationfailed* Triggered when geolocation has failed
      *  - *locationuncapable* Triggered when control is activated on a browser
      *  which doesn't support geolocation
-    EVENT_TYPES: ["locationupdated", "locationfailed", "locationuncapable"],
      * Property: geolocation
@@ -63,15 +61,6 @@
      * Create a new control to deal with browser geolocation API
-    initialize: function(options) {
-        // concatenate events specific to this control with those from the base
-            OpenLayers.Control.Geolocate.prototype.EVENT_TYPES.concat(
-        this.geolocationOptions = {};
-        OpenLayers.Control.prototype.initialize.apply(this, [options]);
      * Method: destroy
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/GetFeature.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/GetFeature.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/GetFeature.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -170,8 +170,6 @@
     filterType: OpenLayers.Filter.Spatial.BBOX,
      * beforefeatureselected - Triggered when <click> is true before a
      *      feature is selected. The event object has a feature property with
@@ -197,9 +195,6 @@
      * outfeature - Triggered when <hover> is true and the mouse moves
      *      moved away from a hover-selected feature
-    EVENT_TYPES: ["featureselected", "featuresselected", "featureunselected",
-        "clickout", "beforefeatureselected", "beforefeaturesselected",
-        "hoverfeature", "outfeature"],
      * Constructor: OpenLayers.Control.GetFeature
@@ -211,12 +206,6 @@
      *     made)
-            OpenLayers.Control.GetFeature.prototype.EVENT_TYPES.concat(
         options.handlerOptions = options.handlerOptions || {};
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/Measure.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/Measure.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/Measure.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -18,9 +18,7 @@
 OpenLayers.Control.Measure = OpenLayers.Class(OpenLayers.Control, {
-     * {Array(String)} Supported application event types.  Register a listener
-     *     for a particular event with the following syntax:
+     * Register a listener for a particular event with the following syntax:
      * (code)
      * control.events.register(type, obj, listener);
      * (end)
@@ -37,7 +35,6 @@
      *      measurement sketch is modified.  Listeners receive an event with measure,
      *      units, order, and geometry.
-    EVENT_TYPES: ['measure', 'measurepartial'],
      * APIProperty: handlerOptions
@@ -120,11 +117,6 @@
     initialize: function(handler, options) {
-        // concatenate events specific to measure with those from the base
-            OpenLayers.Control.Measure.prototype.EVENT_TYPES.concat(
         var callbacks = {done: this.measureComplete,
             point: this.measurePartial};
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/SLDSelect.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/SLDSelect.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/SLDSelect.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -24,9 +24,7 @@
 OpenLayers.Control.SLDSelect = OpenLayers.Class(OpenLayers.Control, {
      * (code)
      * (end)
@@ -41,7 +39,6 @@
      *     array of OpenLayers.Filter objects created in order to perform
      *     the particular selection.
-    EVENT_TYPES: ["selected"],
      * APIProperty: clearOnDeactivate
@@ -148,11 +145,6 @@
      *     selection on.
-            OpenLayers.Control.SLDSelect.prototype.EVENT_TYPES.concat(
         this.callbacks = OpenLayers.Util.extend({done: this.select,
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/SelectFeature.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/SelectFeature.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/SelectFeature.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -22,14 +22,11 @@
 OpenLayers.Control.SelectFeature = OpenLayers.Class(OpenLayers.Control, {
      *  - *beforefeaturehighlighted* Triggered before a feature is highlighted
      *  - *featurehighlighted* Triggered when a feature is highlighted
      *  - *featureunhighlighted* Triggered when a feature is unhighlighted
-    EVENT_TYPES: ["beforefeaturehighlighted", "featurehighlighted", "featureunhighlighted"],
      * Property: multipleKey
@@ -173,11 +170,6 @@
     initialize: function(layers, options) {
-            OpenLayers.Control.SelectFeature.prototype.EVENT_TYPES.concat(
         if(this.scope === null) {
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/Snapping.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/Snapping.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/Snapping.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -18,9 +18,7 @@
 OpenLayers.Control.Snapping = OpenLayers.Class(OpenLayers.Control, {
      * (code)
      * (end)
@@ -45,7 +43,6 @@
      * unsnap - Triggered when a vertex is unsnapped.  Listeners receive an
      *     event with a *point* property.
-    EVENT_TYPES: ["beforesnap", "snap", "unsnap"],
      * CONSTANT: DEFAULTS
@@ -175,10 +172,6 @@
      *     no maximum resolution limit.
-        Array.prototype.push.apply(
-            this.EVENT_TYPES, OpenLayers.Control.prototype.EVENT_TYPES
         this.options = options || {}; // TODO: this could be done by the super
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/Split.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/Split.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/Split.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -19,9 +19,7 @@
 OpenLayers.Control.Split = OpenLayers.Class(OpenLayers.Control, {
      * (code)
      * (end)
@@ -47,7 +45,6 @@
      *     sketch or modified feature used as a splitter.  The features
      *     property is a list of all resulting features.
-    EVENT_TYPES: ["beforesplit", "split", "aftersplit"],
      * APIProperty: layer
@@ -169,10 +166,6 @@
      *     splitting.
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/TimeManager.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/TimeManager.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/TimeManager.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -110,7 +110,7 @@
 	 * APIProperty: maxFrameDelay
 	 * {Number} The number of frame counts to delay the firing of the tick event
-	 *     while the control waits for its time handlers to be ready to advance.
+	 *     while the control waits for its time agents to be ready to advance.
 	 *     Default: 1
     maxFrameDelay:1,
@@ -121,11 +121,11 @@
 	currentTime:null,
-	 * Property: timeHandlers
-	 * {Array(<OpenLayers.TimeHandler>)} An array of the handlers that
+	 * Property: timeAgents
+	 * {Array(<OpenLayers.TimeAgent>)} An array of the agents that
 	 *     this control "manages". Read-Only
-	timeHandlers:null,
+	timeAgents:null,
      * Constructor: OpenLayers.Control.TimeManager
@@ -152,11 +152,11 @@
             this.fixedRange = true;
 		if (this.range && this.range.length) {
-            this.currentTime = new Date(this.range[0].getTime());
+            this.currentTime = this.currentTime || new Date(this.range[0].getTime());
 		if (options.layers) {
-            this.timeHandlers = this.buildTimeHandlers(options.layers);
-            if(this.timeHandlers.length){this.fixedLayers=true;}
+            this.timeAgents = this.buildTimeAgents(options.layers);
+            if(this.timeAgents.length){this.fixedLayers=true;}
@@ -164,8 +164,8 @@
 	 * Destroys the control
 	destroy:function(){
-		for(var i=this.timeHandlers.length-1;i>-1;i--){
-			this.timeHandlers[i].destroy();
+		for(var i=this.timeAgents.length-1;i>-1;i--){
+			this.timeAgents[i].destroy();
 		this.layers=null;
 		OpenLayers.Control.prototype.destroy.call(this);
@@ -180,8 +180,8 @@
     setMap:function(map){
         OpenLayers.Control.prototype.setMap.call(this,map);
         //if the control was not directly intialized with specific layers, then
-        //get layers from map and build appropiate time handlers
-        if (!this.timeHandlers) {
+        //get layers from map and build appropiate time agents
+        if (!this.timeAgents) {
             for (var i = 0, len = map.layers.length; i < len; i++) {
                 var lyr = map.layers[i];
                 if (lyr.metadata.timeInterval && lyr.metadata.timeInterval.length) {
@@ -189,19 +189,19 @@
                     this.layers.push(lyr);
-            this.timeHandlers = this.buildTimeHandlers(this.layers)
+            this.timeAgents = this.buildTimeAgents(this.layers)
-        //if no interval was specified & interval !== false, get from timeHandlers
+        //if no interval was specified & interval !== false, get from timeAgents
         if(!this.intevals && this.intervals !== false){
-            this.intervals = this.buildIntervals(this.timeHandlers);
+            this.intervals = this.buildIntervals(this.timeAgents);
-        //if no range was specified then get from timeHandlers
+        //if no range was specified then get from timeAgents
         if(!this.range){
-            this.range = this.buildRange(this.timeHandlers);
+            this.range = this.buildRange(this.timeAgents);
             if(this.range)this.currentTime = new Date(this.range[(this.step>0)?0:1].getTime())
-        //set map handlers for layer additions and removal
+        //set map agents for layer additions and removal
         this.map.events.on({
             'addlayer':this.onAddLayer,
             'removelayer':this.onRemoveLayer,
@@ -212,22 +212,22 @@
         var lyr = evt.layer;
         var added=false;
         if (lyr.metadata.timeInterval && !this.fixedLayers) {
-            this.timeHandlers || (this.timeHandlers = [])
-            var handlerClass = lyr.CLASS_NAME.match(/\.Layer\.(\w+)/)[1]
-            for (var i = 0, len = this.timeHandlers.length; i < len; i++) {
-                if (!lyr.timeHandler && this.timeHandlers[i] instanceof OpenLayers.TimeHandler[handlerClass]) {
-                    this.timeHandlers[i].addLayer(lyr);
+            this.timeAgents || (this.timeAgents = [])
+            var agentClass = lyr.CLASS_NAME.match(/\.Layer\.(\w+)/)[1]
+            for (var i = 0, len = this.timeAgents.length; i < len; i++) {
+                if (!lyr.timeAgent && this.timeAgents[i] instanceof OpenLayers.TimeAgent[agentClass]) {
+                    this.timeAgents[i].addLayer(lyr);
                     added = true;
                     break;
             if (!added) {
-                var handlers = this.buildTimeHandlers([lyr]);
-                this.timeHandlers.push(handlers[0]);
+                var agents = this.buildTimeAgents([lyr]);
+                this.timeAgents.push(agents[0]);
                 added = true;
-            //check if layer could be used in a time handler & if so modify the
-            //control range & interval as needed. time handler will convert timeInterval
+            //check if layer could be used in a time agent & if so modify the
+            //control range & interval as needed. time agent will convert timeInterval
             //values to real dates
             if(added){
                 var lyrIntervals = lyr.metadata.timeInterval;
@@ -257,28 +257,28 @@
         if(lyr.metadata.timeInterval){
-            //find the handler with the layer
-            for(var i=0, len = this.timeHandlers.length;i<len;i++){
-                var handler = this.timeHandlers[i];
-                if(OpenLayers.Util.indexOf(handler.layers,lyr)>-1){
-                    handler.removeLayer(lyr);
-                    //if the handler doesn't handle any layers, get rid of it
-                    if(!handler.layers.length){
-                        this.timeHandlers.splice(i,1);
-                        handler.destroy();
+            //find the agent with the layer
+            for(var i=0, len = this.timeAgents.length;i<len;i++){
+                var agent = this.timeAgents[i];
+                if(OpenLayers.Util.indexOf(agent.layers,lyr)>-1){
+                    agent.removeLayer(lyr);
+                    //if the agent doesn't handle any layers, get rid of it
+                    if(!agent.layers.length){
+                        this.timeAgents.splice(i,1);
+                        agent.destroy();
                     break;
             if(lyrIntervals.length>2 && !this.fixedIntervals){
                 if(this.intervals[0]<this.range[0]||this.intervals[1]>this.range[1]){
                     this.setRange([Math.min(this.intervals[0],this.range[0]),Math.max(this.intervals[1],this.range[1])])
             else if(!this.fixedRange){
                 if (lyrIntervals[0].getTime() == this.range[0].getTime() || lyrIntervals[1].getTime() == this.range[1].getTime()) {
-                    this.setRange(this.buildRange(this.timeHandlers));
+                    this.setRange(this.buildRange(this.timeAgents));
@@ -442,7 +442,7 @@
 		this.currentTime['setUTC'+stepUnit](this.currentTime['getUTC'+stepUnit]()+step);
-	 * Method: buildTimeHandlers
+	 * Method: buildTimeAgents
 	 * Creates the controls "managed" by this control.
 	 * Parameters:
@@ -451,73 +451,73 @@
 	 * Returns:
 	 * {Array(<OpenLayers.Control.TimeControl>)}
-	buildTimeHandlers:function(layers){
+	buildTimeAgents:function(layers){
 		layers = layers || this.layers || [];
-		var layerTypes = {}, handlers = [];
+		var layerTypes = {}, agents = [];
 		//categorize layers and separate into arrays for use in subclasses
 		for(var i=0,len=layers.length;i<len;i++){
 			var lyr = layers[i];
 			//allow user specified overrides and custom behavior
-            if (lyr.timeHandler) {
-                var handler;
-                if(lyr.timeHandler instanceof OpenLayers.TimeHandler){
-                    handler = lyr.timeHandler;
-                    handler.layers = (handler.layers && handler.layers instanceof Array)?(handler.layers.push(lyr)):handler.layers=[lyr];
-                    handler.timeManager=this;
-                }else if(lyr.timeHandler instanceof Function){
-                    handler = new OpenLayers.TimeHandler({
-                        onTick:lyr.timeHandler,
+            if (lyr.timeAgent) {
+                var agent;
+                if(lyr.timeAgent instanceof OpenLayers.TimeAgent){
+                    agent = lyr.timeAgent;
+                    agent.layers = (agent.layers && agent.layers instanceof Array)?(agent.layers.push(lyr)):agent.layers=[lyr];
+                    agent.timeManager=this;
+                }else if(lyr.timeAgent instanceof Function){
+                    agent = new OpenLayers.TimeAgent({
+                        onTick:lyr.timeAgent,
                         layers:[lyr],
                         timeManager:this
                 this.events.on({
-                    tick: handler.onTick,
+                    tick: agent.onTick,
                     scope: this
-                handlers.push(handler);
+                agents.push(agent);
             else {
                 var lyrClass = lyr.CLASS_NAME.match(/\.Layer\.(\w+)/)[1];
-                if (OpenLayers.TimeHandler[lyrClass]) {
+                if (OpenLayers.TimeAgent[lyrClass]) {
                     !layerTypes[lyrClass] && (layerTypes[lyrClass] = [])
                     layerTypes[lyrClass].push(lyr);
-		//create subclassed time handlers
+		//create subclassed time agents
 		for(var k in layerTypes){
-			var handlerOpts = {
+			var agentOpts = {
                 layers: layerTypes[k],
                 timeManager: this
-            if(this.handlerOptions&&this.handlerOptions[k]){OpenLayers.Util.applyDefaults(handlerOpts,this.handlerOptions[k])}
-            var handler = new OpenLayers.TimeHandler[k](handlerOpts);
+            if(this.agentOptions&&this.agentOptions[k]){OpenLayers.Util.applyDefaults(agentOpts,this.agentOptions[k])}
+            var agent = new OpenLayers.TimeAgent[k](agentOpts);
 			this.events.on({
-				'tick': handler.onTick,
-				scope: handler
+				'tick': agent.onTick,
+				scope: agent
-		return (handlers.length)?handlers:null;
+		return (agents.length)?agents:null;
 	 * Method: buildIntervals
-	 * Builds an array of distinct date/times that the time handlers are
+	 * Builds an array of distinct date/times that the time agents are
 	 * configured with
 	 * Parameters:
-	 *    handlers - {Array(<OpenLayers.TimeHandler>)}
-	 *       (Optional) An array of time handlers to calculate the intervals from.
-	 *       Defaults to the control's timeHandlers property.
+	 *    agents - {Array(<OpenLayers.TimeAgent>)}
+	 *       (Optional) An array of time agents to calculate the intervals from.
+	 *       Defaults to the control's timeAgents property.
 	 * Returns: {Array(Date)}
-    buildIntervals:function(handlers){
-        handlers = handlers || this.timeHandlers || [];
+    buildIntervals:function(agents){
+        agents = agents || this.timeAgents || [];
         var intervals = [];
-        for(var i=0,len=handlers.length;i<len;i++){
-            var handler = handlers[i];
-            if(handler.intervals){
-                intervals = intervals.concat(handler.intervals);
+        for(var i=0,len=agents.length;i<len;i++){
+            var agent = agents[i];
+            if(agent.intervals){
+                intervals = intervals.concat(agent.intervals);
         intervals =(intervals.length)?this.getUniqueDates(intervals):null;
@@ -526,18 +526,18 @@
 	 * Method: buildRange
 	 * Builds an 2 member array with the overall start & stop date/times that
-	 * the time handlers are configured with.
+	 * the time agents are configured with.
 	 * Parameters:
-    buildRange:function(handlers){
+    buildRange:function(agents){
         var range = [];
-            var subrange = handlers[i].range;
+            var subrange = agents[i].range;
             if(!range[0] || subrange[0]<range[0]){range[0]=new Date(subrange[0].getTime())}
             if(!range[1] || subrange[1]>range[1]){range[1]=new Date(subrange[1].getTime())}
@@ -559,8 +559,8 @@
     canTickCheck: function(){
         var canTick = false;
-            canTick = this.timeHandlers[i].canTick;
+            canTick = this.timeAgents[i].canTick;
             if (!canTick) break;
         return canTick;
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/TransformFeature.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/TransformFeature.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/TransformFeature.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -22,8 +22,6 @@
 OpenLayers.Control.TransformFeature = OpenLayers.Class(OpenLayers.Control, {
      *  - *beforesetfeature* Triggered before a feature is set for
      *      tranformation. The feature will not be set if a listener returns
@@ -51,8 +49,6 @@
      *  - *transformcomplete* Triggered after dragging. Listeners receive
      *      an event object with the transformed *feature*.
-    EVENT_TYPES: ["beforesetfeature", "setfeature", "beforetransform",
-        "transform", "transformcomplete"],
      * APIProperty: geometryTypes
@@ -181,11 +177,6 @@
      *     control.
     initialize: function(layer, options) {
-            OpenLayers.Control.TransformFeature.prototype.EVENT_TYPES.concat(
         this.layer = layer;
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/WMSGetFeatureInfo.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/WMSGetFeatureInfo.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/WMSGetFeatureInfo.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -155,8 +155,6 @@
     hoverRequest: null,
      * Supported event types (in addition to those from <OpenLayers.Control>):
      * beforegetfeatureinfo - Triggered before the request is sent.
      *      The event object has an *xy* property with the position of the
@@ -172,7 +170,6 @@
      *      layers, *text* and *request* will only contain the response body
      *      and request object of the last request.
-    EVENT_TYPES: ["beforegetfeatureinfo", "nogetfeatureinfo", "getfeatureinfo"],
      * Constructor: <OpenLayers.Control.WMSGetFeatureInfo>
@@ -181,12 +178,6 @@
-            OpenLayers.Control.WMSGetFeatureInfo.prototype.EVENT_TYPES.concat(
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/WMTSGetFeatureInfo.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/WMTSGetFeatureInfo.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/WMTSGetFeatureInfo.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -136,8 +136,6 @@
     hoverRequest: null,
      * beforegetfeatureinfo - Triggered before each request is sent.
@@ -157,7 +155,6 @@
      *      an event with *request*, *xy*, and *layer*  properties.  In the case
      *      of a parsing error, the event will also contain an *error* property.
-    EVENT_TYPES: ["beforegetfeatureinfo", "getfeatureinfo", "exception"],
      * Property: pending
@@ -172,12 +169,6 @@
-            OpenLayers.Control.WMTSGetFeatureInfo.prototype.EVENT_TYPES.concat(
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -145,9 +145,7 @@
     events: null,
      * (code)
      * (end)
@@ -165,7 +163,6 @@
      * activate - Triggered when activated.
      * deactivate - Triggered when deactivated.
-    EVENT_TYPES: ["activate", "deactivate"],
@@ -187,7 +184,7 @@
         OpenLayers.Util.extend(this, options);
-        this.events = new OpenLayers.Events(this, null, this.EVENT_TYPES);
+        this.events = new OpenLayers.Events(this);
         if(this.eventListeners instanceof Object) {
             this.events.on(this.eventListeners);
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Events.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Events.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Events.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -420,12 +420,6 @@
     element: null,
-     * Property: eventTypes
-     * {Array(String)}  list of support application events
-    eventTypes: null,
      * Property: eventHandler
      * {Function}  bound event handler attached to elements
@@ -480,7 +474,9 @@
      * Parameters:
      * object - {Object} The js object to which this Events object  is being added
      * element - {DOMElement} A dom element to respond to browser events
-     * eventTypes - {Array(String)} Array of custom application events
+     * eventTypes - {Array(String)} Deprecated.  Array of custom application
+     *     events.  A listener may be registered for any named event, regardless
+     *     of the values provided here.
      * fallThrough - {Boolean} Allow events to fall through after these have
      *                         been handled?
      * options - {Object} Options for the events object.
@@ -490,30 +486,20 @@
         this.object     = object;
         this.fallThrough = fallThrough;
         this.listeners  = {};
-        // keep a bound copy of handleBrowserEvent() so that we can
-        // pass the same function to both Event.observe() and .stopObserving()
-        this.eventHandler = OpenLayers.Function.bindAsEventListener(
-            this.handleBrowserEvent, this
-        // to be used with observe and stopObserving
-        this.clearMouseListener = OpenLayers.Function.bind(
-            this.clearMouseCache, this
-        // if eventTypes is specified, create a listeners list for each
-        // custom application event.
-        this.eventTypes = [];
-        if (eventTypes != null) {
-            for (var i=0, len=eventTypes.length; i<len; i++) {
-                this.addEventType(eventTypes[i]);
         // if a dom element is specified, add a listeners list
         // for browser events on the element and register them
         if (element != null) {
+            // keep a bound copy of handleBrowserEvent() so that we can
+            // pass the same function to both Event.observe() and .stopObserving()
+            this.eventHandler = OpenLayers.Function.bindAsEventListener(
+                this.handleBrowserEvent, this
+            // to be used with observe and stopObserving
+            this.clearMouseListener = OpenLayers.Function.bind(
+                this.clearMouseCache, this
             this.attachToElement(element);
@@ -534,24 +520,18 @@
         this.listeners = null;
         this.object = null;
-        this.eventTypes = null;
         this.fallThrough = null;
         this.eventHandler = null;
      * APIMethod: addEventType
-     * Add a new event type to this events object.
-     * If the event type has already been added, do nothing.
+     * Deprecated.  Any event can be triggered without adding it first.
      * Parameters:
      * eventName - {String}
     addEventType: function(eventName) {
-        if (!this.listeners[eventName]) {
-            this.eventTypes.push(eventName);
-            this.listeners[eventName] = [];
@@ -565,15 +545,11 @@
             OpenLayers.Event.stopObservingElement(this.element);
         this.element = element;
-        for (var i=0, len=this.BROWSER_EVENTS.length; i<len; i++) {
-            var eventType = this.BROWSER_EVENTS[i];
-            // every browser event has a corresponding application event
-            // (whether it's listened for or not).
-            this.addEventType(eventType);
-            // use Prototype to register the event cross-browser
-            OpenLayers.Event.observe(element, eventType, this.eventHandler);
+        for (var i = 0, len = this.BROWSER_EVENTS.length; i < len; i++) {
+            // register the event cross-browser
+            OpenLayers.Event.observe(
+                element, this.BROWSER_EVENTS[i], this.eventHandler
         // disable dragstart in IE so that mousedown/move/up works normally
         OpenLayers.Event.observe(element, "dragstart", OpenLayers.Event.stop);
@@ -610,7 +586,7 @@
     on: function(object) {
         for(var type in object) {
-            if(type != "scope") {
+            if(type != "scope" && object.hasOwnProperty(type)) {
                 this.register(type, object.scope, object[type]);
@@ -640,19 +616,24 @@
      *                     'object' property.
      * func - {Function} The callback function. If no callback is
      *                        specified, this function does nothing.
+     * priority - {Boolean} If true, adds the new listener to the *front* of
+     *                      the events queue instead of to the end.
-    register: function (type, obj, func) {
-        if ( (func != null) &&
-             (OpenLayers.Util.indexOf(this.eventTypes, type) != -1) ) {
+    register: function (type, obj, func, priority) {
+        if (func != null) {
             if (obj == null)  {
                 obj = this.object;
             var listeners = this.listeners[type];
-            listeners.push( {obj: obj, func: func} );
+            if (!listeners) {
+                listeners = [];
+                this.listeners[type] = listeners;
+            if (priority) {
+                listeners.unshift({obj: obj, func: func});
+            } else {
+                listeners.push({obj: obj, func: func});
@@ -674,16 +655,7 @@
     registerPriority: function (type, obj, func) {
-        if (func != null) {
-            if (obj == null)  {
-                obj = this.object;
-            var listeners = this.listeners[type];
-            if (listeners != null) {
-                listeners.unshift( {obj: obj, func: func} );
+        this.register(type, obj, func, true);
@@ -714,7 +686,7 @@
     un: function(object) {
                 this.unregister(type, object.scope, object[type]);
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Filter/Function.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Filter/Function.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Filter/Function.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -43,9 +43,6 @@
      * Returns:
      * {<OpenLayers.Filter.Function>}
-        OpenLayers.Filter.prototype.initialize.apply(this, [options]);
     CLASS_NAME: "OpenLayers.Filter.Function"
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Filter/Spatial.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Filter/Spatial.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Filter/Spatial.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -69,9 +69,6 @@
      * Returns:
      * {<OpenLayers.Filter.Spatial>}
     * Method: evaluate
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Format/GPX.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Format/GPX.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Format/GPX.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -20,6 +20,16 @@
  *  - <OpenLayers.Format.XML>
 OpenLayers.Format.GPX = OpenLayers.Class(OpenLayers.Format.XML, {
+     * APIProperty: defaultDesc
+     * {String} Default description for the waypoints/tracks in the case
+     *     where the feature has no "description" attribute.
+     *     Default is "No description available".
+    defaultDesc: "No description available",
     * APIProperty: extractWaypoints
     * {Boolean} Extract waypoints from GPX. (default: true)
@@ -45,6 +55,13 @@
      *     be extracted.
     extractAttributes: true,
+     * APIProperty: gpxns
+     * {String} GPX namespace to use. Defaults to
+     *   "http://www.topografix.com/GPX/1/1"
+    gpxns: "http://www.topografix.com/GPX/1/1",
      * Constructor: OpenLayers.Format.GPX
@@ -179,6 +196,170 @@
         return attributes;
+     * APIMethod: write
+     * Accepts Feature Collection, and returns a string.
+     * Parameters:
+     * features - {Array(<OpenLayers.Feature.Vector>)} List of features to serialize into a string.
+     * metadata - {Object} A key/value pairs object to build a metadata node to
+     *      add to the gpx. Supported keys are 'name', 'desc', 'author'.
+    write: function(features, metadata) {
+        var gpx;
+        features = OpenLayers.Util.isArray(features) ?
+            features : [features];
+        gpx = this.createElementNS(this.gpxns, "gpx");
+        for(var i=0, len=features.length; i<len; i++) {
+            gpx.appendChild(this.buildFeatureNode(features[i]));
+        if (metadata && typeof metadata == 'object') {
+            gpx.appendChild(this.buildMetadataNode(metadata));
+        return OpenLayers.Format.XML.prototype.write.apply(this, [gpx]);
+     * Method: buildMetadataNode
+     * Creates a "metadata" node.
+     * Returns:
+     * {DOMElement}
+    buildMetadataNode: function(metadata) {
+        var types = ['name', 'desc', 'author'],
+            node = this.createElementNS(this.gpxns, 'metadata');
+        for (var i=0; i < types.length; i++) {
+            var type = types[i];
+            if (metadata[type]) {
+                var n = this.createElementNS(this.gpxns, type);
+                n.appendChild(this.createTextNode(metadata[type]));
+                node.appendChild(n);
+        return node;
+     * Method: buildFeatureNode
+     * Accepts an <OpenLayers.Feature.Vector>, and builds a node for it.
+     * Parameters:
+     * feature - {<OpenLayers.Feature.Vector>}
+     * Returns:
+     * {DOMElement} - The created node, either a 'wpt' or a 'trk'.
+    buildFeatureNode: function(feature) {
+        var geometry = feature.geometry;
+            geometry = geometry.clone();
+        if (this.internalProjection && this.externalProjection) {
+            geometry.transform(this.internalProjection,
+                               this.externalProjection);
+        if (geometry.CLASS_NAME == "OpenLayers.Geometry.Point") {
+            var wpt = this.buildWptNode(feature);
+            return wpt;
+        } else {
+            var trkNode = this.createElementNS(this.gpxns, "trk");
+            this.appendAttributesNode(trkNode, feature);
+            var trkSegNodes = this.buildTrkSegNode(geometry);
+            trkSegNodes = OpenLayers.Util.isArray(trkSegNodes) ?
+                trkSegNodes : [trkSegNodes];
+            for (var i = 0, len = trkSegNodes.length; i < len; i++) {
+                trkNode.appendChild(trkSegNodes[i]);
+            return trkNode;
+     * Method: buildTrkSegNode
+     * Builds trkseg node(s) given a geometry
+     * Parameters:
+     * trknode
+     * geometry - {OpenLayers.Geometry}
+    buildTrkSegNode: function(geometry) {
+        var node,
+            i,
+            len,
+            point,
+            nodes;
+        if (geometry.CLASS_NAME == "OpenLayers.Geometry.LineString" ||
+            geometry.CLASS_NAME == "OpenLayers.Geometry.LinearRing") {
+            node = this.createElementNS(this.gpxns, "trkseg");
+            for (i = 0, len=geometry.components.length; i < len; i++) {
+                point = geometry.components[i];
+                node.appendChild(this.buildTrkPtNode(point));
+            return node;
+        } else {
+            nodes = [];
+            for (i = 0, len = geometry.components.length; i < len; i++) {
+                nodes.push(this.buildTrkSegNode(geometry.components[i]));
+            return nodes;
+     * Method: buildTrkPtNode
+     * Builds a trkpt node given a point
+     * Parameters:
+     * line - {OpenLayers.Geometry.Point}
+     * Returns:
+     * {DOMElement} A trkpt node
+    buildTrkPtNode: function(point) {
+        var node = this.createElementNS(this.gpxns, "trkpt");
+        node.setAttribute("lon", point.x);
+        node.setAttribute("lat", point.y);
+        return node;
+     * Method: buildWptNode
+     * Builds a wpt node given a point
+     * Parameters:
+     * feature - {OpenLayers.Feature.Vector}
+     * Returns:
+     * {DOMElement} A wpt node
+    buildWptNode: function(feature) {
+        var node = this.createElementNS(this.gpxns, "wpt");
+        node.setAttribute("lon", feature.geometry.x);
+        node.setAttribute("lat", feature.geometry.y);
+        this.appendAttributesNode(node, feature);
+        return node;
+     * Method: appendAttributesNode
+     * Adds some attributes node.
+     * Parameters:
+     * node - {DOMElement} the node to append the attribute nodes to.
+    appendAttributesNode: function(node, feature) {
+        var name = this.createElementNS(this.gpxns, 'name');
+        name.appendChild(this.createTextNode(
+            feature.attributes.name || feature.id));
+        node.appendChild(name);
+        var desc = this.createElementNS(this.gpxns, 'desc');
+        desc.appendChild(this.createTextNode(
+            feature.attributes.description || this.defaultDesc));
+        node.appendChild(desc);
+        // TBD - deal with remaining (non name/description) attributes.
     CLASS_NAME: "OpenLayers.Format.GPX"
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Format/QueryStringFilter.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Format/QueryStringFilter.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Format/QueryStringFilter.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -4,8 +4,11 @@
  * full text of the license. */
+ * @requires OpenLayers/Console.js
  * @requires OpenLayers/Format.js
+ * @requires OpenLayers/Filter/Spatial.js
  * @requires OpenLayers/Filter/Comparison.js
+ * @requires OpenLayers/Filter/Logical.js
@@ -177,4 +180,4 @@
\ No newline at end of file
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/Curve.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/Curve.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/Curve.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -32,10 +32,6 @@
      * Parameters:
      * point - {Array(<OpenLayers.Geometry.Point>)}
-    initialize: function(points) {
-        OpenLayers.Geometry.MultiPoint.prototype.initialize.apply(this,
-        arguments);
      * APIMethod: getLength
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/LineString.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/LineString.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/LineString.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -26,9 +26,6 @@
      *          generate the linestring
-        OpenLayers.Geometry.Curve.prototype.initialize.apply(this, arguments);
      * APIMethod: removeComponent
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/LinearRing.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/LinearRing.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/LinearRing.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -42,10 +42,6 @@
      * Parameters:
      * points - {Array(<OpenLayers.Geometry.Point>)} points
-        OpenLayers.Geometry.LineString.prototype.initialize.apply(this,
-        arguments);
      * APIMethod: addComponent
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/MultiLineString.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/MultiLineString.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/MultiLineString.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -36,10 +36,6 @@
      * components - {Array(<OpenLayers.Geometry.LineString>)}
-    initialize: function(components) {
-        OpenLayers.Geometry.Collection.prototype.initialize.apply(this,
-        arguments);
      * Method: split
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/MultiPoint.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/MultiPoint.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/MultiPoint.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -38,10 +38,6 @@
      * Returns:
      * {<OpenLayers.Geometry.MultiPoint>}
-        arguments);
      * APIMethod: addPoint
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/MultiPolygon.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/MultiPolygon.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/MultiPolygon.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -37,10 +37,6 @@
      *              used to generate the MultiPolygon
-        arguments);
     CLASS_NAME: "OpenLayers.Geometry.MultiPolygon"
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/Polygon.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/Polygon.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/Polygon.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -37,11 +37,7 @@
      * Parameters:
      * components - {Array(<OpenLayers.Geometry.LinearRing>)}
-        arguments);
      * APIMethod: getArea
      * Calculated by subtracting the areas of the internal holes from the
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/Surface.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/Surface.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Geometry/Surface.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -9,9 +9,5 @@
 OpenLayers.Geometry.Surface = OpenLayers.Class(OpenLayers.Geometry, {
-    initialize: function() {
-        OpenLayers.Geometry.prototype.initialize.apply(this, arguments);
     CLASS_NAME: "OpenLayers.Geometry.Surface"
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Click.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Click.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Click.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -146,9 +146,6 @@
      * options - {Object} Optional object whose properties will be set on the
      *     handler.
-    initialize: function(control, callbacks, options) {
-        OpenLayers.Handler.prototype.initialize.apply(this, arguments);
      * Method: touchstart
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Hover.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Hover.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Hover.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -69,9 +69,6 @@
      * options - {Object} An optional object whose properties will be set on
      *     the handler.
      * Method: mousemove
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Path.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Path.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Path.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -95,10 +95,7 @@
      * cancel - Called when the handler is deactivated while drawing.  The
      *     cancel callback will receive a geometry.
-        OpenLayers.Handler.Point.prototype.initialize.apply(this, arguments);
      * Method: createFeature
      * Add temporary geometries
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Pinch.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Pinch.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Pinch.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -74,9 +74,6 @@
      *     information about scale, distance, and position of touch points.
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Polygon.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Polygon.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Polygon.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -62,9 +62,6 @@
-        OpenLayers.Handler.Path.prototype.initialize.apply(this, arguments);
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/ArcGIS93Rest.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/ArcGIS93Rest.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/ArcGIS93Rest.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -91,17 +91,7 @@
-     * Method: destroy
-     * Destroy this layer
-    destroy: function() {
-        // for now, nothing special to do here.
-        OpenLayers.Layer.Grid.prototype.destroy.apply(this, arguments);
          * Method: clone
          * Create a clone of this layer
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/ArcIMS.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/ArcIMS.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/ArcIMS.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -149,18 +149,7 @@
-     * Method: destroy
      * Method: getURL
      * Return an image url this layer.
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/Grid.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/Grid.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/Grid.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -7,6 +7,7 @@
  * @requires OpenLayers/Layer/HTTPRequest.js
+ * @requires OpenLayers/Tile/Image.js
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/TMS.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/TMS.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/TMS.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -123,15 +123,6 @@
-     * APIMethod:destroy
      * APIMethod: clone
      * Create a complete copy of this layer.
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/Vector/RootContainer.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/Vector/RootContainer.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/Vector/RootContainer.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -50,9 +50,6 @@
      * {<OpenLayers.Layer.Vector.RootContainer>} A new vector layer root
      *     container
-    initialize: function(name, options) {
-        OpenLayers.Layer.Vector.prototype.initialize.apply(this, arguments);
      * Method: display
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/Vector.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/Vector.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/Vector.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -24,9 +24,7 @@
 OpenLayers.Layer.Vector = OpenLayers.Class(OpenLayers.Layer, {
      * (code)
      * layer.events.register(type, obj, listener);
      * (end)
@@ -111,13 +109,6 @@
      * refresh - Triggered when something wants a strategy to ask the protocol
      *      for a new set of features.
-    EVENT_TYPES: ["beforefeatureadded", "beforefeaturesadded",
-                  "featureadded", "featuresadded", "beforefeatureremoved",
-                  "beforefeaturesremoved", "featureremoved", "featuresremoved",
-                  "beforefeatureselected", "featureselected", "featureunselected",
-                  "beforefeaturemodified", "featuremodified", "afterfeaturemodified",
-                  "vertexmodified", "vertexremoved", "sketchstarted",
-                  "sketchmodified", "sketchcomplete", "refresh"],
      * APIProperty: isBaseLayer
@@ -240,13 +231,6 @@
      * {<OpenLayers.Layer.Vector>} A new vector layer
-            OpenLayers.Layer.Vector.prototype.EVENT_TYPES.concat(
-            OpenLayers.Layer.prototype.EVENT_TYPES
         OpenLayers.Layer.prototype.initialize.apply(this, arguments);
         // allow user-set renderer, otherwise assign one
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/WMS.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/WMS.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/WMS.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -182,16 +182,6 @@
-     * Method: destroy
      * Method: clone
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/XYZ.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/XYZ.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer/XYZ.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -144,8 +144,9 @@
             (res * this.tileSize.w));
         var y = Math.round((this.maxExtent.top - bounds.top) /
             (res * this.tileSize.h));
-        var z = this.serverResolutions != null ?
-            OpenLayers.Util.indexOf(this.serverResolutions, res) :
+        var resolutions = this.serverResolutions || this.resolutions;
+        var z = this.zoomOffset == 0 ?
+            OpenLayers.Util.indexOf(resolutions, res) :
             this.map.getZoom() + this.zoomOffset;
         var limit = Math.pow(2, z);
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Layer.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -58,9 +58,7 @@
     alwaysInRange: null,
      * (code)
      * (end)
@@ -89,8 +87,6 @@
      *     will receive an object with a *map* property referencing the map and
      *     a *layer* property referencing the layer.
-    EVENT_TYPES: ["loadstart", "loadend", "loadcancel", "visibilitychanged",
-                  "move", "moveend", "added", "removed"],
      * Constant: RESOLUTION_PROPERTIES
@@ -351,8 +347,7 @@
             this.div.style.height = "100%";
             this.div.dir = "ltr";
-            this.events = new OpenLayers.Events(this, this.div,
-                                                this.EVENT_TYPES);
+            this.events = new OpenLayers.Events(this, this.div);
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Map.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Map.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Map.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -36,9 +36,7 @@
      * (code)
      * map.events.register(type, obj, listener);
      * (end)
@@ -85,13 +83,6 @@
      *  - *mousemove* triggered after mousemove the map
      *  - *changebaselayer* triggered after the base layer changes
-    EVENT_TYPES: [
-        "preaddlayer", "addlayer","preremovelayer", "removelayer",
-        "changelayer", "movestart",
-        "move", "moveend", "zoomend", "popupopen", "popupclose",
-        "addmarker", "removemarker", "clearmarkers", "mouseover",
-        "mouseout", "mousemove", "dragstart", "drag", "dragend",
-        "changebaselayer"],
      * Property: id
@@ -538,7 +529,7 @@
         this.viewPortDiv.appendChild(eventsDiv);
         this.eventsDiv = eventsDiv;
-            this, this.eventsDiv, this.EVENT_TYPES, this.fallThrough,
+            this, this.eventsDiv, null, this.fallThrough,
             {includeXY: true}
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Marker/Box.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Marker/Box.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Marker/Box.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -40,7 +40,7 @@
         this.bounds = bounds;
         this.div    = OpenLayers.Util.createDiv();
         this.div.style.overflow = 'hidden';
-        this.events = new OpenLayers.Events(this, this.div, null);
         this.setBorder(borderColor, borderWidth);
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Marker.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Marker.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Marker.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -80,7 +80,7 @@
             this.icon.offset = newIcon.offset;
             this.icon.calculateOffset = newIcon.calculateOffset;
-        this.events = new OpenLayers.Events(this, this.icon.imageDiv, null);
+        this.events = new OpenLayers.Events(this, this.icon.imageDiv);
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Popup/FramedCloud.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Popup/FramedCloud.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Popup/FramedCloud.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -223,12 +223,5 @@
         this.contentDiv.className = this.contentDisplayClass;
-     * APIMethod: destroy
-        OpenLayers.Popup.Framed.prototype.destroy.apply(this, arguments);
     CLASS_NAME: "OpenLayers.Popup.FramedCloud"
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Protocol/HTTP.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Protocol/HTTP.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Protocol/HTTP.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -4,12 +4,7 @@
- * @requires OpenLayers/Console.js
  * @requires OpenLayers/Protocol.js
- * @requires OpenLayers/Feature/Vector.js
- * @requires OpenLayers/Filter/Spatial.js
- * @requires OpenLayers/Filter/Comparison.js
- * @requires OpenLayers/Filter/Logical.js
  * @requires OpenLayers/Request/XMLHttpRequest.js
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Request.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Request.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Request.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -57,7 +57,7 @@
      * success - Triggered when the HTTP response has a success code (200-299).
      * failure - Triggered when the HTTP response does not have a success code.
-    events: new OpenLayers.Events(this, null, ["complete", "success", "failure"]),
+    events: new OpenLayers.Events(this),
      * APIMethod: issue
@@ -122,6 +122,26 @@
             {proxy: OpenLayers.ProxyHost}
         config = OpenLayers.Util.applyDefaults(config, defaultConfig);
+        // Always set the "X-Requested-With" header to signal that this request
+        // was issued through the XHR-object. Since header keys are case
+        // insensitive and we want to allow overriding of the "X-Requested-With"
+        // header through the user we cannot use applyDefaults, but have to
+        // check manually whether we were called with a "X-Requested-With"
+        // header.
+        var customRequestedWithHeader = false,
+            headerKey;
+        for(headerKey in config.headers) {
+            if (config.headers.hasOwnProperty( headerKey )) {
+                if (headerKey.toLowerCase() === 'x-requested-with') {
+                    customRequestedWithHeader = true;
+        if (customRequestedWithHeader === false) {
+            // we did not have a custom "X-Requested-With" header
+            config.headers['X-Requested-With'] = 'XMLHttpRequest';
         // create request, open, and set headers
         var request = new OpenLayers.Request.XMLHttpRequest();
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Strategy/Save.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Strategy/Save.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Strategy/Save.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -20,19 +20,17 @@
 OpenLayers.Strategy.Save = OpenLayers.Class(OpenLayers.Strategy, {
      * (code)
      * strategy.events.register(type, obj, listener);
      * (end)
+     * Supported event types:
      *  - *start* Triggered before saving
      *  - *success* Triggered after a successful transaction
      *  - *fail* Triggered after a failed transaction
-    EVENT_TYPES: ["start", "success", "fail"],
      * Property: events
@@ -66,7 +64,7 @@
         OpenLayers.Strategy.prototype.initialize.apply(this, [options]);
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Tile.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Tile.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Tile.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -26,10 +26,12 @@
 OpenLayers.Tile = OpenLayers.Class({
+     *  - *loadstart* Triggered when tile loading starts.
+     *  - *loadend* Triggered when tile loading ends.
+     *  - *reload* Triggered when an already loading tile is reloaded.
+     *  - *unload* Triggered before a tile is unloaded.
-    EVENT_TYPES: [ "loadstart", "loadend", "reload", "unload"],
      * APIProperty: events
@@ -110,7 +112,7 @@
         //give the tile a unique id based on its BBOX.
         this.id = OpenLayers.Util.createUniqueID("Tile_");
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Util.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Util.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Util.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -1505,7 +1505,11 @@
     urlObject.args = OpenLayers.Util.getParameters(queryString);
-    //pathname (uniform browser behavior with leading "/")
+    // pathname
+    // This is a workaround for Internet Explorer where
+    // window.location.pathname has a leading "/", but
+    // a.pathname has no leading "/".
     urlObject.pathname = (a.pathname.charAt(0) == "/") ? a.pathname : "/" + a.pathname;
     return urlObject;
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers.js	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers.js	2011-09-27 14:35:25 UTC (rev 12416)
@@ -213,8 +213,8 @@
                 "OpenLayers/Control/TransformFeature.js",
                 "OpenLayers/Control/SLDSelect.js",
 				"OpenLayers/Control/TimeManager.js",
-				"OpenLayers/TimeHandler.js",
-                "OpenLayers/TimeHandler/WMS.js",
+				"OpenLayers/TimeAgent.js",
+                "OpenLayers/TimeAgent/WMS.js",
                 "OpenLayers/Geometry.js",
                 "OpenLayers/Geometry/Rectangle.js",
                 "OpenLayers/Geometry/Collection.js",
Modified: sandbox/mpriour/temporal_map/openlayers/tests/Control/DrawFeature.html
--- sandbox/mpriour/temporal_map/openlayers/tests/Control/DrawFeature.html	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/tests/Control/DrawFeature.html	2011-09-27 14:35:25 UTC (rev 12416)
@@ -4,12 +4,10 @@
     function test_initialize(t) {
-        t.plan(2);
+        t.plan(1);
         var control = new OpenLayers.Control.DrawFeature("foo", function() {});
         t.ok(control instanceof OpenLayers.Control.DrawFeature,
              "constructor returns an instance");
-        t.ok(OpenLayers.Util.indexOf(control.EVENT_TYPES, "featureadded") > -1,
-             "featureadded event in EVENT_TYPES");
     function test_multi(t) {
Modified: sandbox/mpriour/temporal_map/openlayers/tests/Events.html
--- sandbox/mpriour/temporal_map/openlayers/tests/Events.html	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/tests/Events.html	2011-09-27 14:35:25 UTC (rev 12416)
@@ -7,38 +7,22 @@
     var a;
     function test_Events_constructor (t) {
+        t.plan(4);
         var mapDiv = OpenLayers.Util.getElement('map');
         var obj = {result: 0};
-        var eventTypes = ["doThingA", "doThingB", "doThingC"];
-        var browserTypes = OpenLayers.Events.prototype.BROWSER_EVENTS;
-        var totalTests = 4 + 2*eventTypes.length + 2*browserTypes.length;
-        t.plan( totalTests );
-        events = new OpenLayers.Events(obj, mapDiv, eventTypes);
+        events = new OpenLayers.Events(obj, mapDiv);
         t.ok( events instanceof OpenLayers.Events, "new OpenLayers.Control returns object" );
         t.ok(events.object ==obj, " 'object' property correctly set");
         t.ok(events.element == mapDiv, " 'element' property correctly set");
+        events.destroy();
-        for (var i = 0; i < browserTypes.length; i++) {
-            var type = browserTypes[i];
-            t.ok( events.listeners[type] instanceof Array, "browser event: " + type + " correctly registered" );
-            t.ok( OpenLayers.Util.indexOf(events.eventTypes, type) != -1, "browser type " + type + "' correctly added to eventTypes array");
-        for (var i = 0; i < eventTypes.length; i++) {
-            var type = eventTypes[i];
-            t.ok( events.listeners[type] instanceof Array, "custom event: " + type + " correctly registered");
-            t.ok( OpenLayers.Util.indexOf(events.eventTypes, type) != -1, "eventType " + type + "' correctly added to eventTypes array");
         // default/nulls
         events = new OpenLayers.Events(null, null, null);
         t.ok( events.listeners != null,
               "init of Events with null object/element/eventTypes still creates listeners array" );
+        events.destroy();
     function test_Events_register(t){
@@ -59,8 +43,7 @@
                                 gFuncB = options.func;
-            'eventTypes': ['listenerA', 'listenerB']
         var type = null;
@@ -99,13 +82,12 @@
     function test_Events_register_unregister(t) {
-        t.plan( 18 );
+        t.plan(19);
         var func = function () { this.result++ }
         events.register( "doThingA", obj, func );
@@ -136,9 +118,12 @@
         var listenerList = events.listeners["doThingA"];
         t.eq( listenerList.length, 3, "register correctly does not append null callback to event.listeners[doThingA] even when obj passed in is null" );
-        events.register( "chicken", obj, func);
-        t.ok( events.listeners["chicken"] == null, "register() does nothing on attempt to register un-enabled event");
+        events.register("chicken", obj, func);
+        t.eq(events.listeners["chicken"].length, 1, "register() allows listeners for any named event");
+        events.unregister("chicken", obj, func);
+        t.eq(events.listeners["chicken"].length, 0, "unregistering an event that is not in eventTypes list works")
         events.unregister("doThingA", obj, null);
         t.eq( listenerList.length, 3, "trying to unregister a null callback does nothing -- but doesnt crash :-)" );
@@ -174,10 +159,13 @@
         t.ok( (listenerList.length == 1), "unregister does not bomb if you try to remove a null callback" );
-        events.unregister("chicken", null, func3);
-        t.ok( events.listeners["chicken"] == null, "unregistering an event that is not enabled does not wierdly enable it -- or cause a script error")
+        try {
+            events.unregister("asdf", obj, func);
+            t.ok("unregistering for an event with no registered listeners works");
+        } catch (err) {
+            t.fail("unregistering for an event with no registered listeners causes trouble: " + err);
     function test_Events_remove(t) {
@@ -186,9 +174,8 @@
         var func2 = function () { this.result-- }
@@ -213,9 +200,8 @@
@@ -248,7 +234,7 @@
         //no specific t.ok for this one, but if it breaks, you will know it.
         events.triggerEvent("chicken");
-        events = new OpenLayers.Events(null, mapDiv, eventTypes);
+        events = new OpenLayers.Events(null, mapDiv);
         // a is global variable (context-irrelevant)
         a = 0;
@@ -259,8 +245,7 @@
         t.eq(a, 5, "if Events has no object set and an event is registered also with no object, triggerEvent() calls it without trying to set the context to null");
         // trigger events with additional arguments
-        eventTypes = ["something"];
-        events = new OpenLayers.Events(null, null, eventTypes);
+        events = new OpenLayers.Events();
         var instance = {id: Math.random()};
         var listener = function(obj) {
             t.eq(this.id, instance.id,
@@ -309,7 +294,7 @@
     function test_Events_handleBrowserEvent(t) {
         t.plan(2);
-        var events = new OpenLayers.Events({}, null, ['sometouchevent']);
+        var events = new OpenLayers.Events({}, null);
         events.on({'sometouchevent': function() {}});
         // this test verifies that when handling a touch event we correctly
@@ -424,36 +409,6 @@
-    function test_Events_addEventType(t) {
-        t.plan( 8 );
-        var mapDiv = OpenLayers.Util.getElement('map');
-        var obj = {result: 0};
-        var eventTypes = ["doThingA", "doThingB"];
-        t.eq( events.listeners["doThingA"].length, 0, "event type passed as passed as param to OpenLayers.Events constructor correctly set up" );
-        t.eq( events.listeners["doThingB"].length, 0, "event type passed as passed as param to OpenLayers.Events constructor correctly set up" );
-        var newEventType = "onFoo";
-        t.ok( events.listeners[newEventType] == null, "event type not yet registered has null entry in listeners array");
-        t.ok( OpenLayers.Util.indexOf(events.eventTypes, newEventType) == -1, "event type not yet registered not in eventTypes array");
-        events.addEventType(newEventType);
-        t.eq( events.listeners[newEventType].length, 0, "event type passed to addEventType correctly set up" );
-        t.ok( OpenLayers.Util.indexOf(events.eventTypes, newEventType) != -1, "event type passed to addEventType in eventTypes array");
-        var func = function () {};
-        events.register( "doThingA", obj, func );
-        t.eq( events.listeners["doThingA"].length, 1, "listener correctly registered" );
-        events.addEventType("doThingsA");
-        t.eq( events.listeners["doThingA"].length, 1, "event type passed to addEventType correctly does nothing if clashes with already defined event type" );
     /** HACK HACK HACK Deprecated This test should be removed in 3.0 **/
     function test_Events_globalEventObject(t) {
         t.plan(1);
Modified: sandbox/mpriour/temporal_map/openlayers/tests/Format/GPX.html
--- sandbox/mpriour/temporal_map/openlayers/tests/Format/GPX.html	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/tests/Format/GPX.html	2011-09-27 14:35:25 UTC (rev 12416)
@@ -34,6 +34,85 @@
         t.eq(features[2].attributes['name'], "Mark", "Text attribute node read correctly.");
         t.eq(features[2].attributes['sym'], "Flag", "CDATA attribute node read correctly.");
+    function test_Format_GPX_serialize_points(t) {
+        t.plan(1);
+        var parser = new OpenLayers.Format.GPX();
+        var point = new OpenLayers.Geometry.Point(-111.04, 45.68);
+        var point2 = new OpenLayers.Geometry.Point(-112.04, 45.68);
+        var features = [
+            new OpenLayers.Feature.Vector(point, {name: 'foo', description: 'bar'}),
+            new OpenLayers.Feature.Vector(point2, {name: 'foo', description: 'bar'})
+        var data = parser.write(features);
+        t.xml_eq(data, '<?xml version="1.0" encoding="ISO-8859-1"?><gpx xmlns="http://www.topografix.com/GPX/1/1"><wpt lon="-111.04" lat="45.68"><name>foo</name><desc>bar</desc></wpt><wpt lon="-112.04" lat="45.68"><name>foo</name><desc>bar</desc></wpt></gpx>', 'GPX serializes points correctly');
+    function test_Format_GPX_serialize_line(t) {
+        t.plan(1);
+        var line = new OpenLayers.Geometry.LineString([point, point2]);
+        var f = new OpenLayers.Feature.Vector(line, {name: 'foo', description: 'bar'});
+        var data = parser.write(f);
+        t.xml_eq(data, '<?xml version="1.0" encoding="ISO-8859-1"?><gpx xmlns="http://www.topografix.com/GPX/1/1"><trk><name>foo</name><desc>bar</desc><trkseg><trkpt lon="-111.04" lat="45.68"/><trkpt lon="-112.04" lat="45.68"/></trkseg></trk></gpx>', 'GPX serializes line correctly');
+    function test_Format_GPX_serialize_lines(t) {
+        t.plan(1);
+        var point3 = new OpenLayers.Geometry.Point(1, 2);
+        var point4 = new OpenLayers.Geometry.Point(3, 4);
+        var line2 = new OpenLayers.Geometry.LineString([point3, point4]);
+        var f2 = new OpenLayers.Feature.Vector(line2, {name: 'dude', description: 'truite'});
+        var data = parser.write([f, f2]);
+        t.xml_eq(data, '<?xml version="1.0" encoding="ISO-8859-1"?><gpx xmlns="http://www.topografix.com/GPX/1/1"><trk><name>foo</name><desc>bar</desc><trkseg><trkpt lon="-111.04" lat="45.68"/><trkpt lon="-112.04" lat="45.68"/></trkseg></trk><trk><name>dude</name><desc>truite</desc><trkseg><trkpt lon="1" lat="2"/><trkpt lon="3" lat="4"/></trkseg></trk></gpx>', 'GPX serializes lines correctly');
+    function test_Format_GPX_serialize_multiline(t) {
+        t.plan(1);
+        var multiline = new OpenLayers.Geometry.MultiLineString([line, line2]);
+        var f = new OpenLayers.Feature.Vector(multiline, {name: 'foo', description: 'bar'});
+        var data = parser.write([f]);
+        t.xml_eq(data, '<?xml version="1.0" encoding="ISO-8859-1"?><gpx xmlns="http://www.topografix.com/GPX/1/1"><trk><name>foo</name><desc>bar</desc><trkseg><trkpt lon="-111.04" lat="45.68"/><trkpt lon="-112.04" lat="45.68"/></trkseg><trkseg><trkpt lon="1" lat="2"/><trkpt lon="3" lat="4"/></trkseg></trk></gpx>', 'GPX serializes multiline correctly');
+    function test_Format_GPX_serialize_polygon(t) {
+        t.plan(1);
+        var linearRing = new OpenLayers.Geometry.LinearRing([point, point2, point.clone()]);
+        var polygon = new OpenLayers.Geometry.Polygon([linearRing]);
+        var f = new OpenLayers.Feature.Vector(polygon, {name: 'foo', description: 'bar'});
+        t.xml_eq(data, '<?xml version="1.0" encoding="ISO-8859-1"?><gpx xmlns="http://www.topografix.com/GPX/1/1"><trk><name>foo</name><desc>bar</desc><trkseg><trkpt lon="-111.04" lat="45.68"/><trkpt lon="-112.04" lat="45.68"/><trkpt lon="-111.04" lat="45.68"/></trkseg></trk></gpx>', 'GPX serializes polygon correctly');
+    function test_Format_GPX_serialize_metadata(t) {
+        t.plan(1);
+        var data = parser.write([], {name: 'foo', desc: 'bar'});
+        t.xml_eq(data, '<?xml version="1.0" encoding="ISO-8859-1"?><gpx xmlns="http://www.topografix.com/GPX/1/1"><metadata><name>foo</name><desc>bar</desc></metadata></gpx>', 'GPX serializes metadata correctly');
     </script>
 </head>
 <body>
Modified: sandbox/mpriour/temporal_map/openlayers/tests/Layer/Grid.html
--- sandbox/mpriour/temporal_map/openlayers/tests/Layer/Grid.html	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/tests/Layer/Grid.html	2011-09-27 14:35:25 UTC (rev 12416)
@@ -21,19 +21,14 @@
     function test_Layer_Grid_constructor (t) {
-        t.plan( 8 );
+        t.plan( 5 );
         layer = new OpenLayers.Layer.Grid(name, url, params, null);
         t.ok( layer instanceof OpenLayers.Layer.Grid, "returns OpenLayers.Layer.Grid object" );
         t.eq( layer.buffer, 0, "buffer default is 0");
         t.eq( layer.ratio, 1.5, "ratio default is 1.5");
         t.eq( layer.numLoadingTiles, 0, "numLoadingTiles starts at 0");
-        t.ok( layer.events.listeners["tileloaded"] != null, "'tileloaded' event added to layer's event types");
-        t.ok( OpenLayers.Util.indexOf(layer.events.eventTypes, 'tileloaded') != -1 ,"'tileloaded' event added to layer's event types");
-        //regression testing for #1502
-        t.ok( layer.events.listeners['tileloaded'].length == 0, "no listeners for tileloaded preregister");
         var obj = {};
         var func = function() {};
         layer.events.register('tileloaded', obj, func);
Modified: sandbox/mpriour/temporal_map/openlayers/tests/Layer/Text.html
--- sandbox/mpriour/temporal_map/openlayers/tests/Layer/Text.html	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/tests/Layer/Text.html	2011-09-27 14:35:25 UTC (rev 12416)
@@ -173,7 +173,7 @@
         var event = {};
         t.delay_call( 1, function() {
           t.ok(layer.markers[0].events, "First marker has an events object");
-          t.eq(layer.markers[0].events.listeners['click'].length, 0, "Marker events has one object");
+          t.eq(layer.markers[0].events.listeners['click'], undefined, "Marker events has no object");
           layer.markers[0].events.triggerEvent('click', event);
           t.eq(map.popups.length, 0, "no popup on first marker");
           layer.markers[1].events.triggerEvent('click', event);
Modified: sandbox/mpriour/temporal_map/openlayers/tests/Request.html
--- sandbox/mpriour/temporal_map/openlayers/tests/Request.html	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/tests/Request.html	2011-09-27 14:35:25 UTC (rev 12416)
@@ -20,7 +20,7 @@
     function test_issue(t) {
         setup();
-        t.plan(22);
+        t.plan(25);
         var request, config;
         var proto = OpenLayers.Request.XMLHttpRequest.prototype;
         var issue = OpenLayers.Function.bind(OpenLayers.Request.issue,
@@ -96,19 +96,35 @@
         // reset open method
         proto.open = _open;
-        // test that headers are correctly set - 4 tests
+        // test that headers are correctly set - 6 tests
         var _setRequestHeader = proto.setRequestHeader;
         config = {
             headers: {
                 foo: "bar",
-                chicken: "soup"
+                chicken: "soup",
+                // This checks whether the autoadded 'X-Requested-With'-header
+                // can be overridden, even though the given key here is spelled
+                // in lowercase.
+                'x-requested-with': 'humpty'
+        // we also track how often setRequestHeader is being called, it should
+        // be called once for every header, even with the above defined
+        // custom 'x-requested-with' header which we usually autoadd.
+        // If the numbers match, we make sure to not send duplicate headers like
+        //   x-requested-with: humpty         AND
+        //   X-Requested-With: XMLHttpRequest
+        var actualSetHeaderCnt = 0;
+        var expectedSetHeaderCnt = 3; // and not four!
         proto.setRequestHeader = function(key, value) {
+            actualSetHeaderCnt++;
             t.ok(key in config.headers, "setRequestHeader called with key: " + key);
             t.eq(value, config.headers[key], "setRequestHeader called with correct value: " + value);
         request = issue(config);
+        t.eq(actualSetHeaderCnt, expectedSetHeaderCnt, 'A custom "x-requested-with" header overrides the default "X-Requested-With" header.');
         proto.setRequestHeader = _setRequestHeader;
         // test that callback is called (no scope) - 1 test
@@ -444,6 +460,35 @@
         var req = OpenLayers.Request.GET();
         req.abort();
+    function test_XRequestedWithHeaderAutoadded(t) {
+        t.plan( 2 );
+        var headerSet = false;
+        var headerGot = '';
+        var headerExpected = 'XMLHttpRequest';
+        // save to be able to restore later
+        var _setRequestHeader = OpenLayers.Request.XMLHttpRequest.prototype.setRequestHeader;
+        OpenLayers.Request.XMLHttpRequest.prototype.setRequestHeader = function(field, value) {
+            if (field === 'X-Requested-With') {
+                headerSet = true;
+                headerGot = value;
+        var req = OpenLayers.Request.issue({
+            url: location.href,
+            async: false
+        t.ok( headerSet, 'We call the method "setRequestHeader" to set a "X-Requested-With"-header' );
+        t.eq( headerGot, headerExpected,  'The "X-Requested-With"-header is set to "' + headerExpected + '" as expected.' );
+        // restore old setRequestHeader
+        OpenLayers.Request.XMLHttpRequest.prototype.setRequestHeader = _setRequestHeader;
     </script>
 </head>
 <body>
Modified: sandbox/mpriour/temporal_map/openlayers/tests/run-tests.html
--- sandbox/mpriour/temporal_map/openlayers/tests/run-tests.html	2011-09-27 11:44:03 UTC (rev 12415)
+++ sandbox/mpriour/temporal_map/openlayers/tests/run-tests.html	2011-09-27 14:35:25 UTC (rev 12416)
@@ -1,2419 +1,153 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
-<html><head><title> Run the testsuite</title>
-<noscript>Javascript is disabled in your browser. This page cannot be displayed correctly without Javascript. Sorry. <br/> If you want to view this page, please change your browser settings so that Javascript is enabled.</noscript>
-Test.AnotherWay version 0.5
-Copyright (c) 2005 Artem Khodush, http://straytree.org
-Permission is hereby granted, free of charge, to any person obtaining
-a copy of this software and associated documentation files (the
-"Software"), to deal in the Software without restriction, including
-without limitation the rights to use, copy, modify, merge, publish,
-distribute, sublicense, and/or sell copies of the Software, and to
-permit persons to whom the Software is furnished to do so, subject to
-the following conditions:
-The above copyright notice and this permission notice shall be
-included in all copies or substantial portions of the Software.
-THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
-EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
-MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
-NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE
-LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION
-OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION
-WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
-<style type="text/css">
-* { padding: 0; margin: 0; }
-html { height: 99%; }
-body { height: 98%; font: normal normal 10pt sans-serif }
-#col1 {  float: left; width: 27em; margin: 0 0 0 1em; overflow: visible; }
-#col2 {  position: relative; height: 98%; margin: 0 0.5em 0 28em; }
-#col1_header { margin-top: 0.5em; }
-#scroller { height: 400px; overflow: auto;}
-#testtable { margin: 0 0 2em 0; width: 97%; }
-#run_buttons { margin-bottom: 4em; }
-#right_header { padding-top: 0.8em; }
-#results_count { float: left; }
-.active_tab 			{ float: right; padding: 0 1em 0.2em 1em; background: #0af; border: 1px solid #048; border-bottom: none; cursor: pointer; cursor: hand;
-					 position: relative; top: -0.2em; }
-.inactive_tab 			{ float: right; padding: 0 1em 0 1em; background: #9bb; color: #444; border: 1px solid #9bb; border-bottom: none; cursor: pointer; cursor: hand; }
-.inactive_mouseover_tab 	{ float: right; padding: 0 1em 0 1em; background: #9bb; color: #062; border: 1px solid #062; border-bottom: none; cursor: pointer; cursor: hand; }
-#right_frame { overflow: auto; position: relative; top: -0.2em; clear: right; height: 95%; border: 1px solid #048; }
-#debug { display: none; }
-#debug p { margin: 2px 0 0 5em; text-indent: -4.8em; }
-#error { display: none; color: #c22; }
-#results p { margin: 0 0 2px 0; }
-/* cursor indicating that detailed results may be expanded/contracted */
-#results p.badtest { cursor: text; }
-#results p.ok, #results p.fail { cursor: pointer; cursor: hand; }
-/* colored squares in the results window at the left of test page names */
-#results p.ok .bullet { background: #6d6; }
-#results p.fail .bullet { background:  #d46; }
-#results p.badtest .bullet { background: #ea3; }
-#results p.loading .bullet { background: #48f; }
-#results p.running .bullet { background: #26e; }
-#results p.waiting .bullet { background: #04d; }
-/* highlight in the results line */
-#results p .warning { background: #ffc; }
-/* layout of the detailed results */
-.result_detail { padding-left: 3em; }
-.result_exception_detail { padding-left: 4em; }
-.result_exception_stack_detail { padding-left: 5em;  }
-.result_micro_detail { padding-left: 6em; }
-/* colouring in the detailed results */
-.result_detail .fail, .result_exception_detail .fail,  .result_micro_detail .fail { background: #ffd8d8; }
-/* "start recording" controls*/
-#record_div { margin-top: 3em; }
-#record_div p { margin-bottom: 0.5em; }
-#record_select { width: 88%; }
-#record_input { width: 53%; }
-</style>
-<script type="text/javascript">
-if( typeof( Test )=="undefined" ) {
-	Test={};
-Test.AnotherWay={};
-Test.AnotherWay._g_test_iframe=null; // frame where to load test pages
-Test.AnotherWay._g_test_frame_no_clear=false; // true - leave last page displayed after tests end
-Test.AnotherWay._g_test_page_urls=[]; // array of: { url: url, convention: "anotherway" or "jsan" }
-Test.AnotherWay._g_test_object_for_jsan=null; // test object for filling by tests that adhere to jsan Test.Simple calling convention
-Test.AnotherWay._g_pages_to_run=null; // list of pages to run automatically after loading
-Test.AnotherWay._g_run_on_main_load=false; // special handling for run_pages_to_run when it might be called before onload or before list of test pages is known.
-Test.AnotherWay._g_run_on_list_load=false;
-Test.AnotherWay._g_main_loaded=false;
-Test.AnotherWay._run_pages_to_run=function( called_from_outside )
-	if( !Test.AnotherWay._g_main_loaded ) {
-		Test.AnotherWay._g_run_on_main_load=true;
-	}else {
-		var a_pages=Test.AnotherWay._g_pages_to_run;
-		if( a_pages=="all" ) {
-			for( var i=0; i<Test.AnotherWay._g_test_page_urls.length; ++i ) {
-				Test.AnotherWay._run_test_page( "test"+i );
-		}else if( a_pages!=null ) {
-			for( var run_i=0; run_i<a_pages.length; ++run_i ) {
-				var run_page=a_pages[run_i];
-				var found=false;
-				for( var all_i=0; all_i<Test.AnotherWay._g_test_page_urls.length; ++all_i ) {
-					if( run_page==Test.AnotherWay._g_test_page_urls[all_i].url ) {
-						Test.AnotherWay._run_test_page( "test"+all_i, called_from_outside );
-						found=true;
-						break;
-				if( !found ) {
-					Test.AnotherWay._show_error( "page specified to run is not found in the page list: "+run_page );
-					break;
-Test.AnotherWay._add_test_page_url=function( test_url, convention )
-	var table=document.getElementById( "testtable" );
-	var record_select=document.getElementById( "record_select" );
-	var index=Test.AnotherWay._g_test_page_urls.length;
-	// trim spaces.
-	if( test_url.match( "^(\\s*)(.*\\S)(\\s*)$" ) ) {
-		test_url=RegExp.$2;
-	Test.AnotherWay._g_test_page_urls[index]={ url: test_url, convention: convention };
-	var row=table.insertRow( -1 );
-	var cell;
-	var cell_child;
-	cell=row.insertCell( -1 );
-	cell_child=document.createElement( "input" );
-	cell_child.type="checkbox";
-	cell_child.id="checkbox"+index;
-    cell_child.checked='checked';
-    cell_child.defaultChecked='checked';
-	cell.appendChild( cell_child );
-	cell.setAttribute( "width", "75%" );
-	cell.appendChild( document.createTextNode( test_url ) );
-	cell_child.type="button";
-	cell_child.id="test"+index;
-	cell_child.value=" run ";
-	cell_child.onclick=Test.AnotherWay._run_one_onclick;
-	cell.setAttribute( "width", "8em" );
-	cell_child=document.createElement( "span" );
-	var option=document.createElement( "option" );
-	option.appendChild( document.createTextNode( test_url ) );
-	record_select.appendChild( option );
-Test.AnotherWay._show_error=function( msg )
-	var error_div=document.getElementById( "error" );
-	error_div.innerHTML="";
-	error_div.appendChild( document.createTextNode( msg ) );
-	error_div.style.display="block";
-// read urls from the list in the html file inside the list_iframe
-// fill on-screen list with urls and "run" buttons, and fill the g_test_page_urls object.
-Test.AnotherWay._list_iframe_onload=function()
-	if( window.frames.list_iframe!=null && window.frames.list_iframe.location!="" && window.frames.list_iframe.location!="about:blank" ) {
-		var list_doc=window.frames.list_iframe.document;
-		var list=list_doc.getElementById( "testlist" );
-		if( list!=null ) {
-			for( var i=0; i<list.childNodes.length; ++i ) {
-				var item=list.childNodes[i];
-				if( item.nodeName=="LI" || item.nodeName=="li" ) {
-					var convention="anotherway";
-					if( Test.AnotherWay._get_css_class( item )=="jsan" ) {
-						convention="jsan";
-					Test.AnotherWay._add_test_page_url( item.innerHTML, convention );
-			if( Test.AnotherWay._g_run_on_list_load ) {
-				Test.AnotherWay._g_run_on_list_load=false;
-				Test.AnotherWay._run_pages_to_run();
-		}else {
-			Test.AnotherWay._show_error( "no list with id 'testlist' in a list file "+window.frames.list_iframe.location );
-Test.AnotherWay._map_checkboxes=function( f )
-	var checks=table.getElementsByTagName( "INPUT" );
-	for( var i=0; i<checks.length; ++i ) {
-		if( checks[i].type=="checkbox" && checks[i].id.match( /^checkbox(\d+)$/ ) ) {
-			f( checks[i], RegExp.$1 );
-Test.AnotherWay._run_all_onclick=function()
-	Test.AnotherWay._map_checkboxes( function( c, id ) { Test.AnotherWay._run_test_page( "test"+id ); } );
-Test.AnotherWay._run_selected_onclick=function()
-	Test.AnotherWay._map_checkboxes( function( c, id ) { if( c.checked ) Test.AnotherWay._run_test_page( "test"+id ); } );
-Test.AnotherWay._unselect_all_onclick=function()
-	Test.AnotherWay._map_checkboxes( function( c, id ) { c.checked=false; } );
-Test.AnotherWay._run_one_onclick=function()
-	Test.AnotherWay._run_test_page( this.id );
-// construct an object that will gather results of running one test function
-Test.AnotherWay._test_object_t=function( fun_name )
-	this.name=fun_name; // name of the test function
-	this.n_plan=null; // planned number of assertions
-	this.n_ok=0; // # of ok assertions
-	this.n_fail=0; // # of failed assertions
-	this.exception=""; // if the function throwed an exception, it's its message
-	this.exception_stack=[]; // strings: function call stack from the exception
-	this.assertions=[]; // assertion results: array of { ok: 1 or 0, name: string }
-	this.wait_result_milliseconds=0; // how long to wait before collecting results from the test
-	this.second_wait_msg=null; // <p> status message (in addition to the page wait_msg)
-	this.delay_actions=[]; // array of actions to be perfomed after the test function returns
-				//	action : { acton_kind: "call" | "window" | "replay"
-				//				when "call": 		{ call_fn call_delay_milliseconds } call_fn takes nothing
-				//				when "window" : 	{ wnd_url wnd_wnd wnd_fn wnd_timeout_milliseconds wnd_dont_close } wnd_fn takes wnd
-				//				wnen "replay" : 	{ replay_wnd replay_events replay_event_i replay_checkpoints } checkpoint_fn takes this, wnd
-	this.delay_action_i=null; // index of delay action currently being performed
-	this.delay_prev_timer_time=0;	// for counting time while performing delay_actions
-	this.delay_current_milliseconds_left=0; // time left before the next action, runs down
-	this.delay_total_milliseconds_left=0; 	// for indication: total estimated time for all actions, runs up and down
-Test.AnotherWay._test_object_t.prototype.ok=function( cond, name )
-	if( cond ) {
-		++this.n_ok;
-		cond=1;
-	}else {
-		++this.n_fail;
-		cond=0;
-	this.assertions.push( { ok: cond, name: name } );
-Test.AnotherWay._test_object_t.prototype.fail=function( name )
-	this.ok( false, name );
-Test.AnotherWay._test_object_t.prototype.plan=function( n )
-	this.n_plan=n;
-Test.AnotherWay._test_object_t.prototype.wait_result=function( seconds )
-	this.wait_result_milliseconds=1000*seconds;
-Test.AnotherWay._eq_fail_msg=function( path, what, expected, got )
-	return "eq: "+path+" "+what+" differ: got "+got+", but expected "+expected;
-Test.AnotherWay._array_eq=function( expected, got, path, msg )
-	if( expected.length!=got.length ) {
-		msg.msg=Test.AnotherWay._eq_fail_msg( path, "array length", expected.length, got.length );
-		return false;
-	for( var i=0; i<expected.length; ++i ) {
-		if( !Test.AnotherWay._thing_eq( expected[i], got[i], path+"["+i+"]", msg ) ) {
-			return false;
-	return true;
-Test.AnotherWay._object_eq=function( expected, got, path, msg )
-	var v;
-	for( v in expected ) {
-		if( ! (v in got) ) {
-			msg.msg=Test.AnotherWay._eq_fail_msg( path+"."+v, "properties", expected[v], "undefined" );
-			return false;
-		if( !Test.AnotherWay._thing_eq( expected[v], got[v], path+"."+v, msg ) ) {
-			return false;
-	for( v in got ) {
-		if( ! (v in expected) ) {
-			msg.msg=Test.AnotherWay._eq_fail_msg( path+"."+v, "properties", "undefined", got[v] );
-			return false;
-	return true;
-Test.AnotherWay._constructor_name=function( x )
-	if( x==null ) {
-		return "";
-	var s="unknown";
-	try {
-		s=typeof( x.constructor );
-		if( s!="unknown" ) {
-			s=x.constructor.toString();
-	}catch( e ) {
-		s="unknown";
-	if( s=="unknown" ) {
-		// hackish attempt to guess a type
-		var is_array=true;
-		var index=0;
-		for( i in x ) {
-			if( i!=index ) {
-				is_array=false;
-			++index;
-		return is_array ? "Array" : "Object"; // for empty arrays/objects, this will be wrong half the time
-	}else if( s.match( /^\s*function\s+(\w+)\s*\(/ ) ) {
-		return RegExp.$1;
-	}else {
-	  var c = '';
-	  switch(typeof x) {
-	    case 'string':
-	      c = 'String';
-	      break;
-	    case 'object':
-	      c = 'Object';
-	      break;
-	    default:
-	      c = '';
-		return c;
-Test.AnotherWay._is_array=function( x )
-	return Test.AnotherWay._constructor_name( x )=="Array";
-Test.AnotherWay._is_value_type=function( x )
-	cn=Test.AnotherWay._constructor_name( x );
-	return cn=="Number" || cn=="String" || cn=="Boolean" || cn=="Date";
-Test.AnotherWay._thing_eq=function( expected, got, path, msg )
-	if( expected==null && got==null ) {
-		return true;
-	}else if( (expected==null && got!=null) || (expected!=null && got==null) ) {
-		msg.msg=Test.AnotherWay._eq_fail_msg( path, "values", expected, got );
-		return false;
-	}else {
-		var expected_cn=Test.AnotherWay._constructor_name( expected );
-		var got_cn=Test.AnotherWay._constructor_name( got );
-		if( expected_cn!=got_cn ) {
-			msg.msg=Test.AnotherWay._eq_fail_msg( path, "types", expected_cn, got_cn );
-			return false;
-		}else {
-			if( Test.AnotherWay._is_array( expected ) ) {
-				return Test.AnotherWay._array_eq( expected, got, path, msg );
-			}else if( Test.AnotherWay._is_value_type( expected ) ) {
-				if( expected!=got ) {
-					return false;
-				}else {
-					return true;
-			}else { // just a plain object
-				return Test.AnotherWay._object_eq( expected, got, path, msg );
-Test.AnotherWay._test_object_t.prototype.eq=function( got, expected, name )
-	var msg={};
-	if( Test.AnotherWay._thing_eq( expected, got, "", msg ) ) {
-		this.ok( 1, name );
-	}else {
-		this.fail( name+". "+msg.msg );
-Test.AnotherWay._test_object_t.prototype.like=function( got, expected, name )
-	if( got.match( expected )!=null ) {
-	}else {
-		this.fail( name+": got "+got+", but expected it to match: "+expected );
-Test.AnotherWay._g_html_eq_span=null;
-Test.AnotherWay._html_eq_string_to_node=function( string_or_node, what, msg )
-	if( string_or_node.nodeType!=null ) {
-		string_or_node=Test.AnotherWay._html_eq_node_to_string( string_or_node ); // double trip - to make properties assigned in scripts available as html node attributes
-	if( Test.AnotherWay._g_html_eq_span==null ) {
-		Test.AnotherWay._g_html_eq_span=document.createElement( "span" );
-	Test.AnotherWay._g_html_eq_span.innerHTML=string_or_node;
-	if( Test.AnotherWay._g_html_eq_span.childNodes.length!=1 ) {
-		msg.msg="bad "+what+" html string given (should contain exactly one outermost element): "+string_or_node;
-	return Test.AnotherWay._g_html_eq_span.childNodes[0].cloneNode( true );
-Test.AnotherWay._html_eq_node_to_string=function( node ) {
-	Test.AnotherWay._g_html_eq_span.innerHTML="";
-	if( node.outerHTML!=null ) {
-		Test.AnotherWay._g_html_eq_span.innerHTML=node.outerHTML;
-	}else {
-            var clone = node.cloneNode(true);
-            var node = Test.AnotherWay._g_html_eq_span;
-            if(node.ownerDocument && node.ownerDocument.importNode) {
-                if(node.ownerDocument != clone.ownerDocument) {
-                    clone = node.ownerDocument.importNode(clone, true);
+<!DOCTYPE html>
+<html>
+    <head>
+        <title>Run the testsuite</title>
+        <noscript>
+            Javascript is disabled in your browser. This page cannot be
+            displayed correctly without Javascript. Sorry.
+            <br/>
+            If you want to view this page, please change your browser settings
+            so that Javascript is enabled.
+        </noscript>
+        Test.AnotherWay version 0.5
+        Copyright (c) 2005 Artem Khodush, http://straytree.org
+        Permission is hereby granted, free of charge, to any person obtaining
+        a copy of this software and associated documentation files (the
+        "Software"), to deal in the Software without restriction, including
+        without limitation the rights to use, copy, modify, merge, publish,
+        distribute, sublicense, and/or sell copies of the Software, and to
+        permit persons to whom the Software is furnished to do so, subject to
+        the following conditions:
+        The above copyright notice and this permission notice shall be
+        included in all copies or substantial portions of the Software.
+        THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
+        EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
+        MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
+        NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE
+        LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION
+        OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION
+        WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
+        <link rel="stylesheet" href="Test.AnotherWay.css" />
+        <script type="text/javascript" src="Test.AnotherWay.js"></script>
+        <script type="text/javascript" src="Test.AnotherWay.baseadditions.js"></script>
+        <script type="text/javascript" src="Test.AnotherWay.xml_eq.js"></script>
+        <script type="text/javascript" src="Test.AnotherWay.geom_eq.js"></script>
+    </head>
+    <body>
+        <div id="col1">
+            <div id="col1_header">
+                Test pages:
+                <input id="quickfilter" placeholder="quick filter">
+            </div>
+            <div id="scroller">
+                <table id="testtable">
+                </table>
+            </div>
+            <div id="run_buttons">
+                <input type="button" value=" clear " id="clear_btn" /><input type="button" value=" run all " id="run_all" /><input type="button" value=" run selected " id="run_selected" /><input type="button" value=" unselect all " id="unselect_all" />
+            </div>
+            <div id="running-time">
+            </div>
+            <input type="checkbox" id="dont_close_test_windows" /> do not close windows opened by tests
+            <div id="error">
+            </div>
+            <div id="record_div">
+                <p id="record_not_supported" style="display:none">
+                </p>
+                <p>
+                    Record mouse input for the page:
+                </p>
+                <p>
+                    <input type="radio" name="record_choose" value="select" checked="checked" />
+                    <select id="record_select">
+                        <option selected="selected">-- select a page: --</option>
+                    </select>
+                </p>
+                <p>
+                    <input type="radio" name="record_choose" value="input" /> or enter page url: <input type="text" id="record_input" />
+                </p>
+                <p>
+                    <input type="button" value=" record " id="record_start" />
+                </p>
+            </div>
+        </div>
+        <div id="col2">
+            <div id="right_header">
+                <span id="results_count">Results: <span id="total"></span></span>
+                <span id="results_tab" class="active_tab" style="visibility:hidden">Results</span>
+                <span id="debug_tab" class="inactive_tab" style="visibility:hidden">Debug</span>
+            </div>
+            <div id="right_frame">
+                <div id="results">
+                </div>
+                <div id="debug">
+                </div>
+            </div>
+        </div>
+        <span style="display:none">
+            <iframe name="list_iframe" onload="Test.AnotherWay._list_iframe_onload();">
+            </iframe>
+            <iframe name="test_iframe" onload="Test.AnotherWay._test_page_onload();">
+            </iframe>
+            <!-- record_control div is to be imported into other documents, so all its styles are inline -->-
+            <div id="record_control" style="position:absolute;bottom:0;left:0;margin:0;padding:0.5em;width:22em;height:22em;border:1px solid;background:#ffd;font: normal normal 8pt sans-serif; color:#000; text-align: left">
+                <p style="margin:0 0 0 0; padding:0">
+                    &nbsp;<span style="display:none;font-weight:bold;color:#408" id="record_indicator">recording. <span style="font-weight:normal">time: <span id="record_time"></span></span><span id="record_pause_indicator">paused</span></span>
+                </p>
+                <div id="record_cursor_over" style="margin:0;padding:2px;width:14em;height:1.1em;overflow:hidden;float:right;border:1px solid #777;background:#fff;font: normal normal 8pt sans-serif;position:relative;top:3px;color:#000;text-align:left;">
+                    &nbsp;
+                </div>
+                <p style="margin:2px 0 0 0; padding:0">
+                    cursor is over
+                </p>
+                <p style="margin:8px 0 0 0; padding:0;">
+                    keyboard control: press<span id="record_ctrl_key" style="border:1px solid #226;background:#adf;padding:0 0.5em">ctrl</span>
+                    -<span id="record_shift_key" style="border:1px solid #226;background:#adf;padding:0 0.5em">shift</span>
+                </p>
+                <p style="margin:4px 0 0 0; padding:0">
+                    <span id="record_s" style="border:1px solid #226;background:#adf;width:1.2em;float:left;font-weight:bold;text-align:center;margin-right:0.5em">s</span>
+                    <span id="record_on">to <b>start</b> recording</span>
+                    <span id="record_off" style="display:none">to <b>stop</b> recording</span>
+                </p>
+                    <span id="record_h" style="border:1px solid #226;background:#adf;width:1.2em;float:left;font-weight:bold;text-align:center;margin-right:0.5em">h</span>
+                    <span>to <b>hide/show</b> this window</span>
+                </p>
+                    <span id="record_m" style="border:1px solid #226;background:#adf;width:1.2em;float:left;font-weight:bold;text-align:center;margin-right:0.5em">m</span>
+                    <span id="record_include_mousemove">to <b>record</b> mousemove</span>
+                    <span id="record_omit_mousemove" style="display:none">to <b>omit</b> mousemove</span>
+                </p>
+                    <span id="record_p" style="border:1px solid #226;background:#aaa;width:1.2em;float:left;font-weight:bold;text-align:center;margin-right:0.5em">p</span>
+                    <span id="record_pause_on">to <b>pause</b> recording</span>
+                    <span id="record_pause_off" style="display:none">to <b>continue</b> recording</span>
+                </p>
+                    <span id="record_c" style="border:1px solid #226;background:#aaa;width:1.2em;float:left;font-weight:bold;text-align:center;margin-right:0.5em">c</span>
+                    <span>to add checkpoint</span>
+                </p>
+                <p style="margin:6px 0 0 0; padding:0">
+                    checkpoints:
+                </p>
+                <div id="record_checkpoints" style="position:relative;width:100%;height:6em;overflow:auto;font: normal normal 8pt sans-serif; color:#000; text-align: left">
+                </div>
+            </div>
+        </span>
+        <script>
+            if (/noscroll/.test(location.href)) {
+                document.getElementById('scroller').style.height = 'auto';
+                document.getElementById('right_frame').style.height = 'auto';
-            node.appendChild(clone);
-	return Test.AnotherWay._g_html_eq_span.innerHTML;
-Test.AnotherWay._html_eq_path_msg=function( path )
-	var msg="";
-	for( var i=0; i<path.length; ++i ) {
-		msg+=" [node "+path[i].node;
-		if( path[i].id!=null && path[i].id!="" ) {
-			msg+=" id "+path[i].id;
-		}else if( path[i].index!=null ) {
-			msg+=" at index "+path[i].index;
-		msg+="] "
-	return msg;
-Test.AnotherWay._html_eq_fail_msg=function( path, what, expected, got )
-	return Test.AnotherWay._html_eq_path_msg( path )+": "+what+" differ: got "+got+", but expected "+expected;
-Test.AnotherWay._html_eq_remove_blank=function( text )
-	if( text==null ) {
-		return "";
-	}else if( text.match( "^(\\s*)(.*\\S)(\\s*)$" ) ) {
-		return RegExp.$2;
-	}else if( text.match( "\s*" ) ) {
-		return "";
-	return text;
-Test.AnotherWay._html_eq_remove_blank_nodes=function( node )
-	var to_remove=[];
-	for( var child=node.firstChild; child!=null; child=child.nextSibling ) {
-		if( child.nodeType==3 ) {
-			var value=Test.AnotherWay._html_eq_remove_blank( child.nodeValue );
-			if( value=="" ) {
-				to_remove.push( child );
-			}else {
-				child.nodeValue=value;
-	for( var i=0; i<to_remove.length; ++i ) {
-		node.removeChild( to_remove[i] );
-Test.AnotherWay._html_node_type_text=function( node_type )
-	if( node_type==1 ) {
-		return "1 (html element)";
-	}else if( node_type==3 ) {
-		return "3 (text)";
-	}else {
-		return node_type;
-Test.AnotherWay._html_eq_node=function( expected, got, path, msg, expected_loc_base, got_loc_base )
-	if( expected.nodeType!=got.nodeType ) {
-		msg.msg=Test.AnotherWay._html_eq_fail_msg( path, "node types", Test.AnotherWay._html_node_type_text( expected.nodeType ), Test.AnotherWay._html_node_type_text( got.nodeType ) );
-		return false;
-	}else if( expected.nodeType==3 ) {
-		if( expected.nodeValue!=got.nodeValue ) {
-			msg.msg=Test.AnotherWay._html_eq_fail_msg( path, "text", expected.nodeValue, got.nodeValue );
-			return false;
-	}else if( expected.nodeType==1 ) {
-		if( expected.nodeName!=got.nodeName ) {
-			msg.msg=Test.AnotherWay._html_eq_fail_msg( path, "node names", expected.nodeName, got.nodeName );
-			return false;
-		// compare attributes
-		var expected_attrs={};
-		var got_attrs={};
-		var i;
-		var a;
-		for( i=0; i<expected.attributes.length; ++i ) {
-			a=expected.attributes[i];
-			if( a.specified ) {
-				expected_attrs[a.name]=1;
-		for( i=0; i<got.attributes.length; ++i ) {
-			a=got.attributes[i];
-				got_attrs[a.name]=1;
-		for( a in expected_attrs ) {
-			if( ! (a in got_attrs) ) {
-				msg.msg=Test.AnotherWay._html_eq_path_msg( path )+": attribute sets differ: expected attribute "+a+" is missing";
-				return false;
-		for( a in got_attrs ) {
-			if( ! (a in expected_attrs) ) {
-				msg.msg=Test.AnotherWay._html_eq_path_msg( path )+": attribute sets differ: got extra attribute "+a;
-				return false;
-			var expected_value=expected.getAttribute( a );
-			var got_value=got.getAttribute( a );
-			if( typeof( expected_value )=="string" && typeof( got_value )=="string" ) {
-				expected_value=Test.AnotherWay._html_eq_remove_blank( expected_value );
-				got_value=Test.AnotherWay._html_eq_remove_blank( got_value );
-				var ok=expected_value==got_value;
-				if( !ok && (a=="href" || a=="HREF" )  ) { // try relative hrefs
-					var expected_relative_value=expected_value;
-					if( expected_loc_base!=null && expected_value.substring( 0, expected_loc_base.length )==expected_loc_base ) {
-						expected_relative_value=expected_value.substring( expected_loc_base.length );
-					var got_relative_value=got_value;
-					if( got_loc_base!=null && got_value.substring( 0, got_loc_base.length )==got_loc_base ) {
-						got_relative_value=got_value.substring( got_loc_base.length );
-					ok=expected_relative_value==got_relative_value;
-				if( !ok ) {
-					msg.msg=Test.AnotherWay._html_eq_fail_msg( path, "attribute "+a+" values", expected_value, got_value );
-					return false;
-			}else if( typeof( expected_value )=="function" && typeof( got_value )=="function" ) {
-				expected_value=expected_value.toString();
-				got_value=got_value.toString();
-				if( expected_value!=got_value ) {
-					return false;
-			}else {
-				var value_msg={};
-				if( !Test.AnotherWay._thing_eq( expected_value, got_value, "", value_msg ) ) {
-					msg.msg=Test.AnotherWay._html_eq_path_msg( path )+": attribute "+a+" values differ: "+value_msg.msg;
-					return false;
-		// compare child nodes
-		Test.AnotherWay._html_eq_remove_blank_nodes( expected );
-		Test.AnotherWay._html_eq_remove_blank_nodes( got );
-		var expected_length=expected.childNodes.length;
-		var got_length=got.childNodes.length;
-		if( expected_length<got_length ) {
-			msg.msg=Test.AnotherWay._html_eq_path_msg( path )+": got "+(got_length-expected_length)+" extra child nodes";
-			return false;
-		}else if( expected_length>got_length ) {
-			msg.msg=Test.AnotherWay._html_eq_path_msg( path )+": expected "+(expected_length-got_length)+" more child nodes";
-			return false;
-		}else {
-			for( i=0; i<expected_length; ++i ) {
-				var expected_node=expected.childNodes[i];
-				path.push( { node: expected_node.nodeName, id: expected_node.id, index: i } );
-				var eq=Test.AnotherWay._html_eq_node( expected_node, got.childNodes[i], path, msg, expected_loc_base, got_loc_base );
-				path.pop();
-				if( !eq ) {
-					return false;
-	return true;
-Test.AnotherWay._html_eq_get_loc_base=function( node )
-	var loc_base=document.location;
-	if( node.ownerDocument!=null ) {
-		loc_base=node.ownerDocument.location;
-	if( loc_base!=null ) {
-		loc_base=loc_base.href;
-		var slash_pos=loc_base.lastIndexOf( "/" );
-		if( slash_pos!=-1 ) {
-			loc_base=loc_base.substring( 0, slash_pos+1 );
-	return loc_base;
-Test.AnotherWay._test_object_t.prototype.html_eq=function( got, expected, name )
-	var msg={};
-	var expected_node=Test.AnotherWay._html_eq_string_to_node( expected, "expected", msg );
-	if( msg.msg!=null ) {
-		this.fail( name+" html_eq: "+msg.msg );
-	}else {
-		var got_node=Test.AnotherWay._html_eq_string_to_node( got, "got", msg );
-		}else {
-			var expected_loc_base=Test.AnotherWay._html_eq_get_loc_base( expected );
-			var got_loc_base=Test.AnotherWay._html_eq_get_loc_base( got );
-			if( Test.AnotherWay._html_eq_node( expected_node, got_node, [], msg, expected_loc_base, got_loc_base ) ) {
-			}else {
-				var msg=name+" html_eq "+msg.msg;
-				var expected_str=Test.AnotherWay._html_eq_node_to_string( expected_node );
-				var got_str=Test.AnotherWay._html_eq_node_to_string( got_node );
-				msg+=".\n got html: "+got_str;
-				msg+=".\n expected html: "+expected_str;
-				this.fail( msg );
-Test.AnotherWay._debug_pane_print=function( msg )
-	var d=new Date();
-	var p=document.createElement( "p" );
-	p.appendChild( document.createTextNode( d.toLocaleTimeString()+" "+msg ) );
-	var debug_pane=document.getElementById( "debug" );
-	debug_pane.appendChild( p );
-	var debug_tab=document.getElementById( "debug_tab" );
-	var results_tab=document.getElementById( "results_tab" );
-	debug_tab.style.visibility="visible";
-	results_tab.style.visibility="visible";
-Test.AnotherWay._test_object_t.prototype.debug_print=function( msg )
-	Test.AnotherWay._debug_pane_print( this.name+": "+msg );
-Test.AnotherWay._test_object_t.prototype.delay_call=function()
-	var timeout_ms=200;
-	for( var i=0; i<arguments.length; ++i ) {
-		if( typeof( arguments[i] )!="function" ) {
-			timeout_ms=1000*arguments[i];
-		}else {
-			var action={ action_kind: "call", call_delay_milliseconds: timeout_ms, call_fn: arguments[i] };
-			this.delay_total_milliseconds_left+=Test.AnotherWay._action_estimate_milliseconds( action );
-			this.delay_actions.push( action );
-Test.AnotherWay._test_object_t.prototype.open_window=function( url, fn, timeout_seconds )
-	if( timeout_seconds==null ) {
-		timeout_seconds=4;
-	var no_close=document.getElementById( "dont_close_test_windows" );
-	var action={ action_kind: "window", wnd_url: url.toString() + (window.location.search || ""), wnd_wnd: null, wnd_fn: fn, wnd_timeout_milliseconds: timeout_seconds*1000, wnd_no_close: no_close.checked };
-Test.AnotherWay._test_object_t.prototype.replay_events=function( wnd, events )
-	if( Test.AnotherWay._g_no_record_msg!=null ) {
-		this.fail( "replay_events: "+Test.AnotherWay._g_no_record_msg );
-	}else {
-		var action={ action_kind: "replay", replay_wnd: wnd, replay_events: events.events, replay_event_i: null, replay_checkpoints: events.checkpoints };
-Test.AnotherWay._action_estimate_milliseconds=function( action )
-	var ms=0;
-	if( action.action_kind=="call" ) {
-		ms=action.call_delay_milliseconds;
-	}else if( action.action_kind=="window" ) {
-		ms=0;
-	}else if( action.action_kind=="replay" ) {
-		ms=0;
-		for( var i=0; i<action.replay_events.length; ++i ) {
-			ms+=action.replay_events[i]["time"]-0;
-	return ms;
-Test.AnotherWay._g_timeout_granularity=200;
-Test.AnotherWay._g_tests_queue=[]; // vector of { url: string, test_objects : array of test_object_t, test_object_i: int, wait_msg: <p> object, loading_timeout_milliseconds: int, timeout_id: id }
-// load one html page, schedule further processing
-Test.AnotherWay._run_test_page=function( id, called_from_outside )
-	if( id.match( /^test(\d+)/ ) ) {
-		id=RegExp.$1;
-		Test.AnotherWay._g_tests_queue.push( {
-			url: Test.AnotherWay._g_test_page_urls[id].url,
-			convention: Test.AnotherWay._g_test_page_urls[id].convention,
-			test_objects: []
-		if( Test.AnotherWay._g_tests_queue.length==1 ) {
-			if( !called_from_outside ) {
-				// Crap. Be careful stepping around.
-				// For Mozilla and Opera, when this file is included into the frameset page that is in another directory (and _g_outside_path_correction!=null)
-				// but the test pages are started from within it (by "run" buttons), then:
-				// depending on whether the page is the first one loaded into the test frame or not,
-				// the base url for relative test pages differs.
-				// Crap, like I said.
-				Test.AnotherWay._g_tests_queue[0].suppress_outside_path_correction=true;
-			Test.AnotherWay._start_loading_page();
-Test.AnotherWay._load_next_page=function()
-	Test.AnotherWay._g_tests_queue.splice( 0, 1 );
-	if( Test.AnotherWay._g_tests_queue.length>0 ) {
-	}else {
-		if( !Test.AnotherWay._g_test_frame_no_clear ) {
-			Test.AnotherWay._g_test_iframe.location.replace( "about:blank" );
-Test.AnotherWay._g_opera_path_correction=null; // ugly wart to support opera
-Test.AnotherWay._g_outside_path_correction=null; // ugly wart to accomodate Opera and Mozilla, where relative url relates to the directory where the page that calls this function is located
-Test.AnotherWay._set_iframe_location=function( iframe, loc, outside_path_correction )
-	// allow to load only locations with the same origin
-	var proto_end=loc.indexOf( "://" );
-	if( proto_end!=-1 ) { // otherwise, it's safe to assume (for Opera, Mozilla and IE ) that loc will be treated as relative
-		var main_loc=window.location.href;
-		var host_end=loc.substring( proto_end+3 ).indexOf( "/" );
-		var ok=false;
-		if( host_end!=-1 ) {
-			var loc_origin=loc.substring( 0, proto_end+3+host_end+1 );
-			if( main_loc.length>=loc_origin.length && main_loc.substring( 0, loc_origin.length )==loc_origin ) {
-				ok=true;
-		if( !ok ) {
-			return { msg: "test pages may have only urls with the same origin as "+main_loc };
-	// opera cannot handle urls relative to file:// without assistance
-	if( window.opera!=null && window.location.protocol=="file:" && loc.indexOf( ":" )==-1 ) {
-		var base=window.location.href;
-		var q_pos=base.indexOf( "?" );
-		if( q_pos!=-1 ) {
-			base=base.substring( 0, q_pos );
-		var slash_pos=base.lastIndexOf( "/" );
-			base=base.substring( 0, slash_pos+1 );
-			Test.AnotherWay._g_opera_path_correction=base;
-			loc=base+loc;
-	// if this function is called from another page, and if that page is in another directory, correction is needed
-	if( outside_path_correction!=null ) {
-		var pos=loc.indexOf( outside_path_correction );
-		if( pos==0 ) {
-			loc=loc.substring( outside_path_correction.length+1 );
-	if( iframe.location!=null ) {
-		iframe.location.replace( loc );
-	}else {
-		iframe.src=loc;
-	return {};
-Test.AnotherWay._start_loading_page=function()
-	var test_page=Test.AnotherWay._g_tests_queue[0];
-	test_page.loading_timeout_milliseconds=12000;
-	test_page.timeout_id=setTimeout( Test.AnotherWay._loading_timeout, Test.AnotherWay._g_timeout_granularity );
-	test_page.wait_msg=Test.AnotherWay._print_counter_result( test_page.url, "loading...", test_page.loading_timeout_milliseconds, "loading" );
-	if( test_page.convention=="jsan" ) {
-		// the tests in that page will run when it's loading, so the test object must be ready
-		Test.AnotherWay._g_test_object_for_jsan=new Test.AnotherWay._test_object_t( test_page.url );
-	var outside_path_correction=null;
-	if( Test.AnotherWay._g_outside_path_correction!=null && !test_page.suppress_outside_path_correction ) {
-		outside_path_correction=Test.AnotherWay._g_outside_path_correction;
-	var result=Test.AnotherWay._set_iframe_location( Test.AnotherWay._g_test_iframe, test_page.url, outside_path_correction );
-	if( result.msg!=null ) {
-		Test.AnotherWay._unprint_result( test_page.wait_msg );
-		Test.AnotherWay._print_result( test_page.url, result.msg, "badtest", null );
-		Test.AnotherWay._load_next_page();
-Test.AnotherWay._loading_timeout=function()
-	test_page.loading_timeout_milliseconds-=Test.AnotherWay._g_timeout_granularity;
-	if( test_page.loading_timeout_milliseconds>0 ) {
-		Test.AnotherWay._update_msg_counter( test_page.wait_msg, (test_page.loading_timeout_milliseconds/1000).toFixed() );
-	}else {
-		Test.AnotherWay._print_result( test_page.url, "Unable to load test page. Timeout expired", "badtest", null );
-Test.AnotherWay._strip_query_and_hash=function( s )
-	var i=s.lastIndexOf( "#" );
-	if( i!=-1 ) {
-		s=s.substring( 0, i );
-	i=s.lastIndexOf( "?" );
-	if( i!=-1 ) {
-	return s;
-Test.AnotherWay._is_url_loaded=function( url, wnd )
-	var loaded=false;
-	if( wnd!=null && wnd.location!=null ) {
-		// after some popup blocker interference, location may behave strange..
-		var location_s="";
-		location_s+=wnd.location;
-		if( location_s!="" ) {
-			var pathname=wnd.location.pathname;
-			var expected_url=url;
-			var i=expected_url.lastIndexOf( "#" );
-			if( i!=-1 ) {
-				expected_url=expected_url.substring( 0, i );
-			i=expected_url.lastIndexOf( "?" );
-			if( i!=-1 ) {
-			i=expected_url.lastIndexOf( "/" );
-			if( i!=-1 && i!=expected_url.length-1 ) {
-				expected_url=expected_url.substring( i+1 );
-			i=pathname.indexOf( expected_url )
-			if( wnd.location.href==url || (i!=-1 && i==pathname.length-expected_url.length) ) {
-				if( /*window.opera==null*/wnd.document.readyState==null || wnd.document.readyState=="complete" ) { // for opera (and IE?), getElementById does not work until..
-					loaded=true;
-	return loaded;
-// find and run all test functions in the g_cur_page html page.
-Test.AnotherWay._test_page_onload=function()
-	if( Test.AnotherWay._g_tests_queue.length==0 ) {
-		return;
-	if( !Test.AnotherWay._is_url_loaded( test_page.url, Test.AnotherWay._g_test_iframe ) ) {
-		return;
-	clearTimeout( test_page.timeout_id );
-	if( test_page.convention=="anotherway" ) {
-		// get test function names (those beginning with "test")
-		if( typeof( Test.AnotherWay._g_test_iframe.document.scripts )!='undefined' ) { // IE
-			for( var i=0; i<Test.AnotherWay._g_test_iframe.document.scripts.length; ++i ) {
-				var script_text=Test.AnotherWay._g_test_iframe.document.scripts[i].text;
-				var fun_sig="function test";
-				var fun_start=script_text.indexOf( fun_sig );
-				while( fun_start!=-1 ) {
-					script_text=script_text.substring( fun_start, script_text.length );
-					var fun_end=script_text.indexOf( '(' );
-					var fun_name=script_text.substring( "function ".length,  fun_end );
-                                        var whitespace = fun_name.indexOf( ' ' );
-                                        if (whitespace >= 0)
-                                            fun_name = fun_name.substring( 0, whitespace );
-					test_page.test_objects.push( new Test.AnotherWay._test_object_t( fun_name ) );
-					script_text=script_text.substring( fun_end, script_text.length );
-					fun_start=script_text.indexOf( fun_sig  );
-		}else { // otherwise (not IE) it ought to work like this
-			for( var i in Test.AnotherWay._g_test_iframe) {
-				// Hack to prevent failure in FF3.0b1 (innerWidth/innerHeight) and FF>=3.5 (sessionStorage)
-                if (i == "innerWidth" || i == "innerHeight" || i == "sessionStorage") { continue; }
-                if( typeof( Test.AnotherWay._g_test_iframe[i] )=='function' ) {
-					if( i.substring( 0, 4 )=="test" ) {
-						test_page.test_objects.push( new Test.AnotherWay._test_object_t( i ) );
-	}else if( test_page.convention=="jsan" ) {
-		// the test object is already filled with results
-		test_page.test_objects.push( Test.AnotherWay._g_test_object_for_jsan );
-	if( test_page.test_objects.length==0 ) {
-		Test.AnotherWay._print_result( test_page.url,  "No test functions defined in the page", "badtest", null );
-		return;
-	test_page.wait_msg=Test.AnotherWay._print_result( test_page.url, "running tests..<span class=\"counter\">"+test_page.test_objects.length+"</span>", "running", null );
-	test_page.test_object_i=0;
-	Test.AnotherWay._run_more_tests();
-Test.AnotherWay._handle_exception=function( o, e, title )
-	var s=title+": "+typeof( e )+": ";
-	if( e.message!=null ) {
-		s+=e.message;
-	}else if( e.description!=null ) {
-		s+=e.description;
-	}else {
-		s+=e.toString();
-//	if( e.location!=null ) {  // XXX figure out how to display exception location if it's present (like in mozilla)
-//		s+=" location: "+e.location.toString();
-	o.exception=s;
-	s=[];
-	if( e.stack ) {
-		var lines=e.stack.split( "\n" );
-		for( var i=0; i<lines.length; ++i ) {
-			// format of the line: func_name(args)@file_name:line_no
-			if( lines[i].match( /(\w*)\(([^\)]*)\)@(.*):([^:]*)$/ ) ) {
-				var func_name=RegExp.$1;
-				if( func_name.length==0 ) {
-					func_name="<anonymous>";
-				s.push( "in "+func_name+"( "+RegExp.$2+") at "+RegExp.$3+" line "+RegExp.$4+"\n" );
-	o.exception_stack=s;
-Test.AnotherWay._run_more_tests=function()
-	while( test_page.test_object_i<test_page.test_objects.length ) {
-		Test.AnotherWay._update_msg_counter( test_page.wait_msg, (1+test_page.test_object_i)+"/"+test_page.test_objects.length );
-		var o=test_page.test_objects[test_page.test_object_i];
-			try {
-				Test.AnotherWay._g_test_iframe[o.name]( o );
-			}catch( e ) {
-				Test.AnotherWay._handle_exception( o, e, "" );
-		} // for "jsan" convention, test has run already
-		if( o.delay_actions.length>0 || o.wait_result_milliseconds>0 ) {
-			o.delay_total_milliseconds_left+=o.wait_result_milliseconds;
-			Test.AnotherWay._delay_actions_timeout();
-			return;
-		++test_page.test_object_i;
-	Test.AnotherWay._print_result( test_page.url, null, null, test_page.test_objects );
-Test.AnotherWay._delay_actions_timeout=function()
-	var test_object=test_page.test_objects[test_page.test_object_i];
-	var finished=true;
-	if( test_object.delay_action_i==null ) {
-		// set up to start first action
-		test_object.delay_action_i=-1;
-	}else {
-		// perform current action
-		var milliseconds_passed=(new Date()).getTime()-test_object.delay_prev_timer_time;
-		test_object.delay_current_milliseconds_left-=milliseconds_passed;
-		test_object.delay_total_milliseconds_left-=milliseconds_passed;
-		finished=Test.AnotherWay._delay_continue_action( test_object, milliseconds_passed );
-	while( finished && test_object.delay_action_i<test_object.delay_actions.length ) {
-		++test_object.delay_action_i; // start next action
-		finished=Test.AnotherWay._delay_start_action( test_object );
-	if( test_object.delay_action_i<=test_object.delay_actions.length ) { // any more actions left ?
-		test_object.delay_prev_timer_time=(new Date()).getTime();
-		var next_timeout=Test.AnotherWay._g_timeout_granularity;
-		if( test_object.delay_current_milliseconds_left<next_timeout ) {
-			next_timeout=test_object.delay_current_milliseconds_left;
-		if( test_object.second_wait_msg!=null ) {
-			Test.AnotherWay._update_msg_counter( test_object.second_wait_msg, (test_object.delay_total_milliseconds_left/1000).toFixed() );
-		setTimeout( Test.AnotherWay._delay_actions_timeout, next_timeout );
-	}else { // no more actions left. run the next test.
-			Test.AnotherWay._unprint_result( test_object.second_wait_msg );
-			test_object.second_wait_msg=null;
-Test.AnotherWay._delay_start_action=function( test_object )
-	var finished=false;
-	var wait_msg="";
-	if( test_object.delay_action_i==test_object.delay_actions.length ) {
-		if( test_object.wait_result_milliseconds>0 ) {
-			test_object.delay_current_milliseconds_left=test_object.wait_result_milliseconds; // wait for result
-			wait_msg="waiting for results..";
-		}else {
-			++test_object.delay_action_i; // dont wait for result
-	}else {
-		var action=test_object.delay_actions[test_object.delay_action_i];
-			test_object.delay_current_milliseconds_left=action.call_delay_milliseconds;
-			wait_msg="performing delayed calls..";
-			if( Test.AnotherWay._g_opera_path_correction!=null && action.wnd_url.indexOf( ":" )==-1 ) {
-				action.wnd_url=Test.AnotherWay._g_opera_path_correction+action.wnd_url;
-			action.wnd_wnd=window.open( action.wnd_url, "_blank" );
-			if( action.wnd_wnd==null ) {
-				finished=true;
-				test_object.fail( "unable to open window for "+action.wnd_url );
-			}else {
-				test_object.delay_current_milliseconds_left=action.wnd_timeout_milliseconds;
-				wait_msg="opening window..";
-			if( action.replay_events.length==0 ) {
-				finished=true;
-			}else {
-				action.replay_event_i=0;
-				test_object.delay_current_milliseconds_left=action.replay_events[0]["time"];
-				wait_msg="replaying events..";
-	if( wait_msg!="" ) {
-		test_object.second_wait_msg=Test.AnotherWay._print_counter_result( test_page.url, wait_msg, test_object.delay_total_milliseconds_left, "waiting" );
-	}else {
-	return finished;
-Test.AnotherWay._delay_continue_action=function( test_object, milliseconds_passed )
-	var finished=test_object.delay_current_milliseconds_left<=0;
-	if( test_object.delay_action_i==test_object.delay_actions.length ) { // action is "waiting for results"
-		if( test_object.n_plan!=null && test_object.n_plan==test_object.n_ok+test_object.n_fail ) {
-			finished=true; // if all assertions results are recorded, don't wait any more
-		if( finished ) {
-			++test_object.delay_action_i; // move on to the next test
-	}else {
-			if( finished ) {
-				try {
-					action.call_fn();
-			    }catch( e ) {
-					Test.AnotherWay._handle_exception( test_object, e, "in delay_call" );
-			test_object.delay_total_milliseconds_left+=milliseconds_passed; // for "window", the countdown is suspended since it's unknown how long it will take
-			if( Test.AnotherWay._is_url_loaded( action.wnd_url, action.wnd_wnd ) ) {
-				try {
-					action.wnd_fn( action.wnd_wnd );
-				}catch( e ) {
-					Test.AnotherWay._handle_exception( test_object, e, "in open_window function call" );
-				finished=true;
-			}else if( finished ) {
-				test_object.fail(  "unable to open window for url '"+action.wnd_url+"'. timeout expired" );
-			if( finished ) {
-//				try {
-					Test.AnotherWay._delay_replay_event( test_object, action.replay_wnd, action.replay_events[action.replay_event_i], action.replay_checkpoints );
-//				}catch( e ) { // disabled, until I know how to gel location info from an exception
-//					Test.AnotherWay._handle_exception( test_object, e, "while replaying event" );
-				++action.replay_event_i;
-				finished=action.replay_event_i==action.replay_events.length;
-				if( !finished ) {
-					test_object.delay_current_milliseconds_left=action.replay_events[action.replay_event_i]["time"];
-	return finished;
-Test.AnotherWay._delay_replay_event=function( test_object, wnd, event, checkpoints )
-	if( event.type=="_checkpoint" ) {
-		var checkpoint_n=event.which;
-		var prev_n_fail=test_object.n_fail;
-		checkpoints[checkpoint_n]( test_object, wnd );
-		var flash_color= prev_n_fail==test_object.n_fail ? "#2f2" : "#f22" ;
-		Test.AnotherWay._record_flash_border( flash_color );
-	}else if( event.type=="click" || event.type=="mouseover" || event.type=="mouseout" || event.type=="mousemove" || event.type=="mousedown" || event.type=="mouseup" ) {
-		var target=Test.AnotherWay._record_node_path_to_node( event["target"], wnd.document );
-		if( target!=null ) {
-			Test.AnotherWay._record_control_update_highlight( target, "ball", event );
-			var e=wnd.document.createEvent( "MouseEvents" );
-			var related_target=Test.AnotherWay._record_node_path_to_node( event["relatedTarget"], wnd.document );
-			e.initMouseEvent(
-				event["type"],
-				event["cancelable"],
-				event["bubbles"],
-				wnd.document.defaultView,
-				event["detail"],
-				event["screenX"],
-				event["screenY"],
-				event["clientX"],
-				event["clientY"],
-				event["ctrlKey"],
-				event["altKey"],
-				event["shiftKey"],
-				event["metaKey"],
-				event["button"],
-				Test.AnotherWay._record_node_path_to_node( event["relatedTarget"], wnd.document )
-			// Firefox 1.0.6 somehow loses relatedTarget somewhere on the way. Pass through our own, for those who choose to care.
-			e.passThroughRelatedTarget=related_target;
-			target.dispatchEvent( e );
-	}else if( event.type=="keyup" || event.type=="keydown" || event.type=="keypress" ) {
-		var e=wnd.document.createEvent( "KeyboardEvents" ); // forget it. Apparently it's not supported neither by mozilla nor by opera.
-		e.initKeyboardEvent(
-				event["type"],
-				event["bubbles"],
-				event["which"],
-				event["which"],
-				event["ctrlKey"],
-				event["altKey"],
-				event["metaKey"],
-				false
-		wnd.document.dispatchEvent( e );
-Test.AnotherWay._print_counter_result=function( url, msg, milliseconds, style )
-	return Test.AnotherWay._print_result( url, msg+"<span class=\"counter\">"+(milliseconds/1000).toFixed()+"</span>", style, null );
-Test.AnotherWay._g_result_count=0; // for assigning unique ids to result paragraphs
-// number of pages tested
-Test.AnotherWay._g_ok_pages=0;
-Test.AnotherWay._g_fail_pages=0;
-Test.AnotherWay._print_result=function( url, msg, style, test_objects )
-	var results=document.getElementById( "results" );
-	var r=results.appendChild( document.createElement( "p" ) );
-	r.id="result"+Test.AnotherWay._g_result_count;
-	++Test.AnotherWay._g_result_count;
-	r.onclick=Test.AnotherWay._toggle_detail;
-	var text="<span class=\"bullet\">&nbsp;&nbsp;&nbsp;</span>&nbsp;";
-	if( url!="" ) {
-		text+=url+":  ";
-	if( msg!=null ) {
-		text+=msg;
-	if( test_objects!=null ) {
-		// compose summary and detail texts
-		var total_ok=0;
-		var total_detail_ok=0;
-		var total_fail=0;
-		var total_detail_fail=0;
-		var no_plan=0;
-		var detail=results.appendChild( document.createElement( "div" ) );
-		if( r.id.match( /^result(\d+)$/ ) ) {
-			detail.id="result_detail"+RegExp.$1;
-		for( var i=0; i<test_objects.length; ++i ) {
-			var o=test_objects[i];
-			var p;
-			var p_text;
-			p=document.createElement( "P" );
-			Test.AnotherWay._set_css_class( p, "result_detail" );
-			p_text=o.name;
-			if( o.n_fail>0 || o.exception || (o.n_plan!=null && o.n_plan!=o.n_ok+o.n_fail) || (o.n_plan==null && o.n_ok==0 && o.n_fail==0)) {
-				++total_fail;
-				p_text+=" <span class=\"fail\">";
-				if( o.n_plan!=null && o.n_plan!=o.n_ok+o.n_fail) {
-					p_text+="planned "+o.n_plan+" assertions but got "+(o.n_ok+o.n_fail)+"; ";
-				if(o.n_plan==null && o.n_ok==0 && o.n_fail==0) {
-					p_text+="test did not output anything";
-				}else {
-					p_text+=" fail "+o.n_fail;
-				p_text+="</span>";
-			}else {
-				++total_ok;
-			p_text+=" ok "+o.n_ok;
-			if( o.n_plan==null ) {
-				no_plan=1;
-				p_text+=" <span class=\"warning\">no plan</span>";
-			p.innerHTML=p_text;
-			detail.appendChild( p );
-			if( o.exception ) {
-				Test.AnotherWay._set_css_class( p, "result_exception_detail" );
-				p.innerHTML="<span class=\"fail\">exception:</span> "+o.exception;
-				Test.AnotherWay._set_css_class( p, "result_exception_stack_detail" );
-				p.innerHTML=o.exception_stack.join( "<br/>" );
-			for( var ii=0; ii<o.assertions.length; ++ii ) {
-				var oo=o.assertions[ii];
-				var status=oo.ok ? "ok" : "<span class=\"fail\">fail</span>";
-				Test.AnotherWay._set_css_class( p, "result_micro_detail" );
-				p.innerHTML=status;
-				p.appendChild( document.createTextNode( " "+oo.name ) );
-			total_detail_ok+=o.n_ok;
-			total_detail_fail+=o.n_fail;
-		if( total_fail || total_detail_fail ) {
-			text+=" fail "+total_fail;
-		text+=" ok "+total_ok+" (detailed:";
-			text+=" fail "+total_detail_fail;
-		text+=" ok "+total_detail_ok+")";
-		if( no_plan ) {
-			text+=" <span class=\"warning\">no plan</span>";
-		style= total_fail==0 ? "ok" : "fail";
-		detail.style.display= style=="fail" ? "block" : "none";
-		detail.style.cursor="text";
-	if( style!=null ) {
-		Test.AnotherWay._set_css_class( r, style );
-		if( style=="ok" ) {
-			++Test.AnotherWay._g_ok_pages;
-		}else if( style=="fail" || style=="badtest" ) {
-			++Test.AnotherWay._g_fail_pages;
-		var pages_total="";
-		if( Test.AnotherWay._g_fail_pages>0 ) {
-			pages_total+=" fail "+Test.AnotherWay._g_fail_pages;
-		pages_total+=" ok "+Test.AnotherWay._g_ok_pages;
-		Test.AnotherWay._update_results_total( pages_total );
-	r.innerHTML=text;
-	if( results.scrollHeight!=null && results.scrollTop!=null && results.offsetHeight!=null ) {
-		results.scrollTop=results.scrollHeight-results.offsetHeight;
-	// when test_objects is not null, the results are final - good time to clean up
-			var actions=test_objects[i].delay_actions;
-			for( var action_i=0; action_i<actions.length; ++action_i ) {
-				var action=actions[action_i];
-				if( action.action_kind=="window" && action.wnd_wnd!=null && !action.wnd_no_close ) {
-					action.wnd_wnd.close();
-					action.wnd_wnd=null;
-	return r;
-Test.AnotherWay._unprint_result=function( child )
-	results.removeChild( child );
-Test.AnotherWay._toggle_detail=function()
-	if( this.id.match( /^result(\d+)$/ ) ) {
-		var detail=document.getElementById( "result_detail"+RegExp.$1 );
-		if( detail!=null ) {
-			if( detail.style.display=="none" ) {
-				detail.style.display="block";
-			}else if( detail.style.display=="block" ) {
-				detail.style.display="none";
-Test.AnotherWay._update_msg_counter=function( msg, text )
-	for( var i=0; i<msg.childNodes.length; ++i ) {
-		var item=msg.childNodes[i];
-		if( item.nodeName=="SPAN" && Test.AnotherWay._get_css_class( item )=="counter" ) {
-			item.innerHTML=text;
-Test.AnotherWay._update_results_total=function( msg )
-	var total=document.getElementById( "total" );
-	if( total ) {
-		total.innerHTML=msg;
-Test.AnotherWay._results_clear_onclick=function()
-	results.innerHTML="";
-	Test.AnotherWay._update_results_total( "" );
-	Test.AnotherWay._g_ok_pages=0;
-	Test.AnotherWay._g_fail_pages=0;
-	var debug=document.getElementById( "debug" );
-	debug.innerHTML="";
-Test.AnotherWay._get_css_class=function( o )
-	var c=o.getAttribute( "className" );
-	if( c==null || c=="" ) {
-		c=o.getAttribute( "class" );
-	return c;
-Test.AnotherWay._set_css_class=function( o, css_class )
-	o.setAttribute( "className", css_class );
-	o.setAttribute( "class", css_class );
-Test.AnotherWay._tab_onclick=function()
-	var tab=this;
-	var tabs=[ document.getElementById( "debug_tab" ), document.getElementById( "results_tab" ) ];
-	var panes=[ document.getElementById( "debug" ), document.getElementById( "results" ) ];
-	for( var i=0; i<tabs.length; ++i ) {
-		if( tab==tabs[i] ) {
-			Test.AnotherWay._set_css_class( tabs[i], "active_tab" );
-			panes[i].style.display="block";
-		}else {
-			Test.AnotherWay._set_css_class( tabs[i], "inactive_tab" );
-			panes[i].style.display="none";
-Test.AnotherWay._tab_mouseover=function()
-	if( Test.AnotherWay._get_css_class( this )=="inactive_tab" ) {
-		Test.AnotherWay._set_css_class( this, "inactive_mouseover_tab" );
-Test.AnotherWay._tab_mouseout=function()
-	if( Test.AnotherWay._get_css_class( this )=="inactive_mouseover_tab" ) {
-		Test.AnotherWay._set_css_class( this, "inactive_tab" );
-// recording mouse input
-Test.AnotherWay._record_check_onfocus=function()
-	var o=this;
-	var check_select=o.type!="text";
-	var div=document.getElementById( "record_div" );
-	var inputs=div.getElementsByTagName( "input" );
-	for( var i=0; i<inputs.length; ++i ) {
-		var input=inputs[i];
-		if( input.type=="radio" ) {
-			if( input.value=="select" ) {
-				input.checked=check_select;
-			}else if( input.value=="input" ) {
-				input.checked=!check_select;
-Test.AnotherWay._g_no_record_msg=null; // not null - recording is unavailable
-Test.AnotherWay._g_record_timeout_cnt=0; // opening window for a page for recording
-Test.AnotherWay._g_record_url=null;
-Test.AnotherWay._g_record_wnd=null;
-Test.AnotherWay._g_record_random_id=null; // added to element ids of record_control div so that they do not clash with ids already in the page for which input is recorded
-Test.AnotherWay._g_record_keydown=null; // recording control - which key is down
-Test.AnotherWay._g_record_ctrl_keydown=false;
-Test.AnotherWay._g_record_shift_keydown=false;
-Test.AnotherWay._g_record_control_visible=true; // recording control ui state
-Test.AnotherWay._g_record_started;
-Test.AnotherWay._g_record_paused;
-Test.AnotherWay._g_record_include_mousemove=false;
-Test.AnotherWay._g_record_start_time; // for time references
-Test.AnotherWay._g_record_pause_start_time;
-Test.AnotherWay._g_record_update_time_interval; // showing time in the control ui
-Test.AnotherWay._g_record_waiting_for_results=false; // waiting for results window to open
-Test.AnotherWay._g_record_events; // recorded events
-Test.AnotherWay._g_record_under_cursor; // track element under cursor
-Test.AnotherWay._g_record_checkpoint_count; // for checkpoint numbering
-Test.AnotherWay._g_record_mouse_over_record_control; // for avoiding record control highlight on mouseover
-Test.AnotherWay._g_record_highlighted_element={ element: null, x: null, y: null };
-Test.AnotherWay._record_control_get_element=function( id )
-	if( Test.AnotherWay._g_record_wnd!=null && Test.AnotherWay._g_record_wnd.document!=null ) {
-		return Test.AnotherWay._g_record_wnd.document.getElementById( id+Test.AnotherWay._g_record_random_id );
-	}else {
-		return null;
-Test.AnotherWay._record_start_onclick=function() // "record" button on the run_tests.html: open a window for a page for which input is recorded
-		alert( Test.AnotherWay._g_no_record_msg );
-		return;
-	if( Test.AnotherWay._g_record_timeout_cnt>0
-	    || (Test.AnotherWay._g_record_wnd!=null && (Test.AnotherWay._g_record_wnd.closed!=null && !Test.AnotherWay._g_record_wnd.closed)) ) { // in opera, closed is null.
-		alert( "there is already window opened for recording input for a page "+Test.AnotherWay._g_record_url );
-		return;
-	var url=null;
-			if( input.value=="select" && input.checked ) {
-				var index=document.getElementById( "record_select" ).selectedIndex;
-				if( index>0 ) {
-					url=Test.AnotherWay._g_test_page_urls[index-1].url;
-			}else if( input.value=="input" && input.checked ) {
-				url=document.getElementById( "record_input" ).value;
-	if( url!=null ) {
-		Test.AnotherWay._g_record_url=url;
-		Test.AnotherWay._g_record_wnd=window.open( url, "_blank" );
-		if( Test.AnotherWay._g_record_wnd==null ) {
-			alert( "unable to open new window for a page: "+url );
-		}else {
-			Test.AnotherWay._g_record_timeout_cnt=50;
-			setTimeout( Test.AnotherWay._record_window_timeout, 100 );
-Test.AnotherWay._record_window_timeout=function()
-	if( Test.AnotherWay._is_url_loaded( Test.AnotherWay._g_record_url, Test.AnotherWay._g_record_wnd ) ) {
-		Test.AnotherWay._record_window_setup( Test.AnotherWay._g_record_wnd );
-	}else {
-		if( --Test.AnotherWay._g_record_timeout_cnt>0 ) {
-		}else {
-			alert( "timeout expired while opening new window for a page: "+Test.AnotherWay._g_record_url );
-			Test.AnotherWay._g_record_wnd=null;
-			Test.AnotherWay._g_record_url=null;
-			Test.AnotherWay._g_record_timeout_cnt=0;
-Test.AnotherWay._record_control_randomize_id=function( e, r )
-	if( e.id!="" ) {
-		e.id=e.id+r;
-	for( var c=e.firstChild; c!=null; c=c.nextSibling ) {
-		Test.AnotherWay._record_control_randomize_id( c, r );
-Test.AnotherWay._record_window_setup=function( wnd ) // insert recording control into the page for which input is recorded
-	var this_div=document.getElementById( "record_control" );
-	var record_control=wnd.document.importNode( this_div, true );
-	Test.AnotherWay._g_record_random_id=(1000*Math.random()).toFixed();
-	Test.AnotherWay._record_control_randomize_id( record_control, Test.AnotherWay._g_record_random_id );
-	Test.AnotherWay._g_record_control_visible=true;
-	Test.AnotherWay._g_record_started=false;
-	Test.AnotherWay._g_record_paused=false;
-	Test.AnotherWay._g_record_checkpoint_count=0;
-	Test.AnotherWay._g_record_mouse_over_record_control=false;
-	var doc=wnd.document;
-	doc.body.appendChild( record_control );
-	// opera sans-serif font is different
-	if( window.opera ) {
-		cursor_over_indicator=Test.AnotherWay._record_control_get_element( "record_cursor_over" );
-		cursor_over_indicator.style.width="18em";
-		cursor_over_indicator.style.height="2em";
-		cursor_over_indicator.style.fontSize="7pt";
-	doc.addEventListener( "keydown", Test.AnotherWay._record_control_keydown, true );
-	doc.addEventListener( "keyup", Test.AnotherWay._record_control_keyup, true );
-//	doc.addEventListener( "keypress", Test.AnotherWay._record_event, true ); // replaying is not supported by any known browser
-	doc.body.addEventListener( "mousemove", Test.AnotherWay._record_on_mousemove, true );
-	doc.body.addEventListener( "click", Test.AnotherWay._record_event, true );
-	doc.body.addEventListener( "mouseover", Test.AnotherWay._record_event, true );
-	doc.body.addEventListener( "mouseout", Test.AnotherWay._record_event, true );
-	doc.body.addEventListener( "mousedown", Test.AnotherWay._record_event, true );
-	doc.body.addEventListener( "mouseup", Test.AnotherWay._record_event, true );
-Test.AnotherWay._record_control_key_disabled=function( k )
-	if( k=="c" ) {
-		return !Test.AnotherWay._g_record_started;
-	}else if( k=="p" ) {
-	}else if( k=="s" ) {
-		return Test.AnotherWay._g_record_waiting_for_results;
-	}else {
-		return false;
-Test.AnotherWay._record_control_update_ui=function()
-	var keydown_color="#fff";
-	var disabled_color="#aaa";
-	var button_color="#adf";
-	var active_color="#fdf";
-	var display={};
-	display[false]="none";
-	display[true]="inline";
-	var s_button=Test.AnotherWay._record_control_get_element( "record_s" );
-	var record_on=Test.AnotherWay._record_control_get_element( "record_on" );
-	var record_off=Test.AnotherWay._record_control_get_element( "record_off" );
-	s_button.style.backgroundColor= Test.AnotherWay._record_control_key_disabled( "s" ) ? disabled_color
-		: Test.AnotherWay._g_record_keydown=="s" ? keydown_color : Test.AnotherWay._g_record_started ? active_color : button_color;
-	record_on.style.display=display[!Test.AnotherWay._g_record_started];
-	record_off.style.display=display[Test.AnotherWay._g_record_started];
-	var h_button=Test.AnotherWay._record_control_get_element( "record_h" );
-	h_button.style.backgroundColor= Test.AnotherWay._g_record_keydown=="h" ? keydown_color : button_color;
-	var p_button=Test.AnotherWay._record_control_get_element( "record_p" );
-	var record_pause_on=Test.AnotherWay._record_control_get_element( "record_pause_on" );
-	var record_pause_off=Test.AnotherWay._record_control_get_element( "record_pause_off" );
-	p_button.style.backgroundColor= Test.AnotherWay._record_control_key_disabled( "p" ) ? disabled_color
-		: Test.AnotherWay._g_record_keydown=="p" ? keydown_color : Test.AnotherWay._g_record_paused ? active_color : button_color;
-	record_pause_on.style.display=display[!Test.AnotherWay._g_record_paused];
-	record_pause_off.style.display=display[Test.AnotherWay._g_record_paused];
-	var m_button=Test.AnotherWay._record_control_get_element( "record_m" );
-	var record_include_mousemove=Test.AnotherWay._record_control_get_element( "record_include_mousemove" );
-	var record_omit_mousemove=Test.AnotherWay._record_control_get_element( "record_omit_mousemove" );
-	m_button.style.backgroundColor= Test.AnotherWay._g_record_keydown=="m" ? keydown_color : Test.AnotherWay._g_record_include_mousemove ? active_color : button_color;
-	record_include_mousemove.style.display=display[!Test.AnotherWay._g_record_include_mousemove];
-	record_omit_mousemove.style.display=display[Test.AnotherWay._g_record_include_mousemove];
-	var c_button=Test.AnotherWay._record_control_get_element( "record_c" );
-	c_button.style.backgroundColor= Test.AnotherWay._record_control_key_disabled( "c" ) ? disabled_color
-		: Test.AnotherWay._g_record_keydown=="c" ? keydown_color : button_color;
-	var record_indicator=Test.AnotherWay._record_control_get_element( "record_indicator" );
-	record_indicator.style.display=display[Test.AnotherWay._g_record_started];
-	var pause_indicator=Test.AnotherWay._record_control_get_element( "record_pause_indicator" );
-	pause_indicator.style.display=display[Test.AnotherWay._g_record_paused];
-	var record_control=Test.AnotherWay._record_control_get_element( "record_control" );
-	record_control.style.display= Test.AnotherWay._g_record_control_visible ? "block" : "none";
-	var shift_button=Test.AnotherWay._record_control_get_element( "record_shift_key" );
-	shift_button.style.backgroundColor= Test.AnotherWay._g_record_shift_keydown ? keydown_color : button_color;
-	var ctrl_button=Test.AnotherWay._record_control_get_element( "record_ctrl_key" );
-	ctrl_button.style.backgroundColor= Test.AnotherWay._g_record_ctrl_keydown ? keydown_color : button_color;
-Test.AnotherWay._record_format_time=function( t )
-	t=new Date( t );
-	var m=t.getMinutes();
-	var s=t.getSeconds();
-	var str= m==0 ? "" : m+"m ";
-	str+=s+"s.";
-	return str;
-Test.AnotherWay._record_control_update_time=function()
-	var time_display=Test.AnotherWay._record_control_get_element( "record_time" );
-	if( time_display!=null ) {
-		time_display.innerHTML=Test.AnotherWay._record_format_time( (new Date()).getTime()-Test.AnotherWay._g_record_start_time );
-Test.AnotherWay._record_control_update_highlight=function( elem, style, event )
-	if( elem==null ) {
-		Test.AnotherWay._record_highlight_border( null );
-	}else {
-		var pos=Test.AnotherWay._get_page_coords( elem );
-		if( style=="ball" || elem!=Test.AnotherWay._g_record_highlighted_element.element || pos.x!=Test.AnotherWay._g_record_highlighted_element.x || pos.y!=Test.AnotherWay._g_record_highlighted_element.y ) {
-			Test.AnotherWay._g_record_highlighted_element={ element: elem, x: pos.x, y: pos.y };
-			Test.AnotherWay._record_highlight_border( elem, style, event );
-Test.AnotherWay._record_decode_key=function( event )
-	var k=null;
-	if( event==null ) {
-		k=Test.AnotherWay._g_record_wnd.event.keyCode;
-	}else {
-		k=event.which;
-	if( k==83 ) {
-		return "s";
-	}else if( k==72 ) {
-		return "h";
-	}else if( k==73 ) {
-		return "i";
-	}else if( k==80 ) {
-		return "p";
-	}else if( k==67 ) {
-		return "c";
-	}else if( k==77 ) {
-		return "m";
-	}else if( k==16 ) {
-		return "shift";
-	}else if( k==17 ) {
-		return "ctrl";
-	}else if( k==18 ) {
-		return "alt";
-	}else if( k==19 ) {
-		return "pause";
-	}else if( k==123 ) {
-		return "f12";
-	return "";
-Test.AnotherWay._record_control_keydown=function( event )
-	var handled=false;
-	var k=Test.AnotherWay._record_decode_key( event );
-	if( k=="shift" ) {
-		Test.AnotherWay._g_record_shift_keydown=true;
-	}else if( k=="ctrl" ) {
-		Test.AnotherWay._g_record_ctrl_keydown=true;
-	}else if( k!="" && (Test.AnotherWay._g_record_keydown==null || Test.AnotherWay._g_record_keydown==k) ) {
-		if( Test.AnotherWay._g_record_ctrl_keydown && Test.AnotherWay._g_record_shift_keydown && !Test.AnotherWay._record_control_key_disabled( k ) ) {
-			Test.AnotherWay._g_record_keydown=k;
-			handled=true;
-	}else {
-		Test.AnotherWay._g_record_keydown="";
-	Test.AnotherWay._record_control_update_ui();
-	if( !handled ) {
-//		Test.AnotherWay._record_event( event ); // replaying is not supported in any known browser
-	return;
-Test.AnotherWay._record_control_keyup=function( event )
-		Test.AnotherWay._g_record_shift_keydown=false;
-		Test.AnotherWay._g_record_ctrl_keydown=false;
-	}else if( k!="" && k==Test.AnotherWay._g_record_keydown && Test.AnotherWay._g_record_ctrl_keydown && Test.AnotherWay._g_record_shift_keydown  ) {
-		if( k=="s" ) {
-			Test.AnotherWay._g_record_started=!Test.AnotherWay._g_record_started;
-			if( Test.AnotherWay._g_record_started ) {
-				Test.AnotherWay._g_record_events=[];
-				Test.AnotherWay._g_record_start_time=(new Date()).getTime();
-				Test.AnotherWay._record_control_update_time();
-				Test.AnotherWay._g_record_update_time_interval=window.setInterval( Test.AnotherWay._record_control_update_time, 200 );
-			}else {
-				Test.AnotherWay._record_control_update_highlight( null );
-				if( !Test.AnotherWay._g_record_paused ) {
-					window.clearInterval( Test.AnotherWay._g_record_update_time_interval );
-				Test.AnotherWay._g_record_waiting_for_results=true;
-				// open a new window for self, pass a parameter to dump recorded events as javascript code there
-				// (the easiest way to obtain a document from the same origin, so it's writable, is to open this same page again)
-				var loc=window.location;
-				loc=loc.protocol+"//"+loc.host+loc.pathname+"?recording_results="+Test.AnotherWay._g_record_random_id;
-				if( window.open( loc, "_blank" )==null ) {
-					alert( "unable to open new window for results" );
-			handled=true;
-		}else if( k=="h" ) {
-			Test.AnotherWay._g_record_control_visible=!Test.AnotherWay._g_record_control_visible;
-			handled=true;
-			Test.AnotherWay._g_record_paused=!Test.AnotherWay._g_record_paused;
-			if( Test.AnotherWay._g_record_paused ) {
-				Test.AnotherWay._g_record_pause_start_time=(new Date()).getTime();
-			}else {
-				var pause_duration=(new Date()).getTime()-Test.AnotherWay._g_record_pause_start_time;
-				Test.AnotherWay._g_record_start_time+=pause_duration;
-			handled=true;
-		}else if( k=="m" ) {
-			Test.AnotherWay._g_record_include_mousemove=!Test.AnotherWay._g_record_include_mousemove;
-			handled=true;
-		}else if( k=="c" ) {
-			var o=Test.AnotherWay._record_checkpoint();
-			Test.AnotherWay._record_display_checkpoint( o );
-			Test.AnotherWay._record_flash_border( "#24d" );
-			handled=true;
-	Test.AnotherWay._g_record_keydown=null;
-	if( !handled ) {
-	return;
-Test.AnotherWay._record_html_node_path=function( node )
-	if( node==null ) {
-		return null;
-	var path=[];
-	while( true ) {
-		if( node.id!=null && node.id!="" ) {
-			path.unshift( "#"+node.id+" "+node.nodeName );
-			break;
-		}else {
-			var parent_node=node.parentNode;
-			if( parent_node==null ) {
-				return []; // no BODY up the path - this node is screwed (browsers differ in what's above the body), discard
-			}else {
-				var i=0;
-				var found=false;
-				for( var child=parent_node.firstChild; child!=null; child=child.nextSibling ) {
-					if( child==node ) {
-						found=true;
-						break;
-					if( child.nodeType==1 ) { // count only HTML element nodes
-						++i;
-				if( !found ) {
-					i=-1;
-				path.unshift( i+" "+node.nodeName );
-				if( parent_node.nodeName=="BODY" || parent_node.nodeName=="body" ) {
-					break;
-				node=parent_node;
-	return path;
-Test.AnotherWay._record_node_path_to_string=function( path )
-	var s="";
-	if( path!=null ) {
-			s+= i==0 ? "" : ", ";
-			var elem=path[i].split( " " );
-			if( elem[0].charAt( 0 )=="#" ) {
-				s+=elem[1]+" "+elem[0];
-			}else {
-				s+=elem[1]+" ["+elem[0]+"]";
-	return s;
-Test.AnotherWay._record_node_path_to_node=function( path_str, doc )
-	if( path_str==null ) {
-		return null;
-	var path=path_str.split( "," );
-	var node=doc.body;
-		var node_i=path[i].split( " " )[0];
-		if( node_i.charAt( 0 )=="#" ) {
-			node=doc.getElementById( node_i.substring( 1 ) );
-		}else {
-			if( node_i<0 || node_i>=node.childNodes.length ) {
-				node=null;
-			}else {
-				node=node.firstChild;
-				while( node!=null ) {
-					if( node.nodeType==1 ) {  // count only HTML element nodes
-						if( node_i==0 ) {
-							break;
-						--node_i;
-					node=node.nextSibling;
-			return null;
-	return node;
-Test.AnotherWay._record_control_contains_id=function( s )
-	return s.match( /^#record_[\w_]+/ ) && s.match( Test.AnotherWay._g_record_random_id );
-Test.AnotherWay._record_checkpoint=function()
-	var o={ type: "_checkpoint", time: (new Date()).getTime()-Test.AnotherWay._g_record_start_time, which: Test.AnotherWay._g_record_checkpoint_count++,
-			target: Test.AnotherWay._record_html_node_path( Test.AnotherWay._g_record_under_cursor ) };
-	Test.AnotherWay._g_record_events.push( o );
-	return o;
-Test.AnotherWay._record_event=function( event )
-	var unneeded=["rangeOffset","eventPhase","timeStamp","isTrusted","popupWindowFeatures","rangeOffset"];
-	if( Test.AnotherWay._g_record_started && !Test.AnotherWay._g_record_paused ) {
-		var o={};
-		for( var n in event ) {
-			var needed=!n.match( /^[A-Z0-9_]+$/ );
-			if( needed ) {
-				for( var ui=0; ui<unneeded.length; ++ui ) {
-					if( unneeded[ui]==n ) {
-						needed=false;
-						break;
-				if( needed ) {
-					var value=event[n];
-					if( typeof( value )!="object" && typeof( value )!="function" ) {
-						o[n]=value;
-					}else if( n=="target" || n=="relatedTarget" ) {
-						o[n]=Test.AnotherWay._record_html_node_path( value );
-		o["time"]=(new Date()).getTime()-Test.AnotherWay._g_record_start_time;
-		var over_record_control= o["target"]!=null && o["target"][0]!=null && Test.AnotherWay._record_control_contains_id( o["target"][0] );
-		if( !over_record_control ) {
-	return true;
-Test.AnotherWay._record_on_mousemove=function( event )
-	var path=Test.AnotherWay._record_html_node_path( event.target );
-	var new_mouse_over_record_control= path!=null && path[0]!=null && Test.AnotherWay._record_control_contains_id( path[0] );
-	if( new_mouse_over_record_control!=Test.AnotherWay._g_record_mouse_over_record_control ) {
-		Test.AnotherWay._g_record_mouse_over_record_control=new_mouse_over_record_control;
-	if( event.target!=null && event.target!=Test.AnotherWay._g_record_under_cursor ) {
-		Test.AnotherWay._g_record_under_cursor=event.target;
-		var s="";
-		if( path==null || path[0]==null || !Test.AnotherWay._record_control_contains_id( path[0] ) ) {
-			s=Test.AnotherWay._record_node_path_to_string( path );
-		if( s=="" ) {
-			s="&nbsp;";
-		var cursor_over_indicator=Test.AnotherWay._record_control_get_element( "record_cursor_over" );
-		cursor_over_indicator.innerHTML=s;
-	var highlight_element=null;
-	if( !Test.AnotherWay._g_record_mouse_over_record_control && Test.AnotherWay._g_record_started && !Test.AnotherWay._g_record_paused ) {
-		highlight_element=event.target;
-	// highlight border disabled on recording - it causes page to scroll, issuing spurious mouseover/mouseout event
-	//Test.AnotherWay._record_control_update_highlight( highlight_element, "border" );
-	if( Test.AnotherWay._g_record_include_mousemove ) {
-		Test.AnotherWay._record_event( event );
-	return true;
-Test.AnotherWay._record_display_checkpoint=function( o )
-	var checkpoints_div=Test.AnotherWay._record_control_get_element( "record_checkpoints" );
-	var p=checkpoints_div.appendChild( checkpoints_div.ownerDocument.createElement( "div" ) );
-	p.style.marginTop="3px";
-	p.style.font="normal normal 8pt sans-serif";
-	p.style.color="#000";
-	p.style.textAligh="left";
-	p.style.position="relative";
-	p.style.width="100%";
-	var checkpoint_text="";
-	checkpoint_text+="#"+(o.which+1);
-	checkpoint_text+="  "+Test.AnotherWay._record_format_time( o.time );
-	if( o.target!=null ) {
-		checkpoint_text+=Test.AnotherWay._record_node_path_to_string( o.target );
-	p.appendChild( p.ownerDocument.createTextNode( checkpoint_text ) );
-Test.AnotherWay._record_save_results=function( doc )
-	// strange, but DOM-style append does not work here in opera 8.
-	var append=function( s ) { doc.write( "<div>"+s+"</div>" ); };
-	append( "/* paste this data into your javascript and pass it as an argument to replay_events method */" );
-	append( "{ checkpoints: [" );
-	var first_checkpoint=true;
-	for( var i=0; i<Test.AnotherWay._g_record_events.length; ++i ) {
-		var o=Test.AnotherWay._g_record_events[i];
-		if( o.type=="_checkpoint" ) {
-			var str= first_checkpoint ? "" : "}, ";
-			str+="function( tst, wnd ) { // #"+o.which+" time "+Test.AnotherWay._record_format_time( o.time )+" cursor was over "+Test.AnotherWay._record_node_path_to_string( o.target );
-			append( str );
-			first_checkpoint=false;
-	if( !first_checkpoint ) {
-		append( "}" );
-	append( "], events: [ " );
-	var prev_time=0;
-		var s="";
-		s+= "{";
-		var n_first=true;
-		for( var n in o ) {
-			if( n=="time" ) { // convert to relative time
-				var cur_time=o[n]-0;
-				o[n]=cur_time-prev_time;
-				prev_time=cur_time;
-			s+=n_first ? n : ", "+n;
-			s+=":";
-			if( o[n]==null ) {
-				s+="null";
-			}else {
-				s+="\""+o[n]+"\"";
-			n_first=false;
-		s+= i==Test.AnotherWay._g_record_events.length-1 ? "}" : "},";
-		append( s );
-	append( "] }" );
-	append( ";" );
-Test.AnotherWay._g_record_border; // border highlighting element under cursor
-Test.AnotherWay._g_record_border_flashes=[]; // array of { color: color, timeout: milliseconds }
-Test.AnotherWay._g_record_border_flashing=false;
-Test.AnotherWay._g_record_border_normal_color="#d4b";
-Test.AnotherWay._record_flash_border_timeout=function()
-	var color=Test.AnotherWay._g_record_border_normal_color;
-	var timeout=null;
-	if( Test.AnotherWay._g_record_border_flashes.length!=0 ) {
-		color=Test.AnotherWay._g_record_border_flashes[0].color;
-		timeout=Test.AnotherWay._g_record_border_flashes[0].timeout;
-		Test.AnotherWay._g_record_border_flashes.splice( 0, 1 );
-	if( Test.AnotherWay._g_record_border!=null ) {
-		for( var i=0; i<Test.AnotherWay._g_record_border.length; ++i ) {
-			Test.AnotherWay._g_record_border[i].style.backgroundColor=color;
-	if( timeout!=null ) {
-		setTimeout( Test.AnotherWay._record_flash_border_timeout, timeout );
-	}else {
-		Test.AnotherWay._g_record_border_flashing=false;
-Test.AnotherWay._get_page_coords=function( elm )
-	var point = { x: 0, y: 0 };
-	while( elm )  {
-		point.x+=elm.offsetLeft;
-		point.y+=elm.offsetTop;
-		elm=elm.offsetParent;
-	return point;
-Test.AnotherWay._set_page_coords=function( elm, x, y )
-	var parent_coords={ x: 0, y: 0 };
-	if( elm.offsetParent )  {
-		parent_coords=Test.AnotherWay._get_page_coords( elm.offsetParent );
-	var new_x=x-parent_coords.x;
-	if( new_x<0 ) {
-		new_x=0;
-	elm.style.left=new_x+'px';
-	var new_y=y-parent_coords.y;
-	if( new_y<0 ) {
-		new_y=0;
-	elm.style.top=new_y+'px';
-Test.AnotherWay._record_setup_highlight_positions=function( element, style, coords, positions )
-	if( style=="border" ) {
-		var width=element.clientWidth;
-		var height=element.clientHeight;
-		var step=0;
-		var thickness=2;
-		var fudge_expand=4;
-		positions.push( { x: coords.x-step-thickness, y: coords.y-step-thickness, width: width+2*step+2*thickness+fudge_expand, height: thickness } );
-		positions.push( { x: coords.x+width+step+fudge_expand, y: coords.y-step-thickness, width: thickness, height: height+2*step+2*thickness+fudge_expand } );
-		positions.push( { x:positions[0].x, y:positions[0].y, width:positions[0].width, height:positions[0].height } );
-		positions.push( { x:positions[1].x, y:positions[1].y, width:positions[1].width, height:positions[1].height } );
-		positions[2].y+=height+thickness+2*step+fudge_expand;
-		positions[3].x-=width+thickness+2*step+fudge_expand;
-	}else if( style=="ball" ) {
-		positions.push( { x: coords.x+2, y: coords.y, width: 2, height: 6 } );
-		positions.push( { x: coords.x, y: coords.y+2, width: 6, height: 2 } );
-		positions.push( { x: coords.x+1, y: coords.y+1, width: 4, height: 4 } );
-Test.AnotherWay._record_highlight_border=function( element, style, event ) // null - hide border
-	if( element!=null ) {
-		if( Test.AnotherWay._g_record_border==null || Test.AnotherWay._g_record_border[0].ownerDocument!=element.ownerDocument ) {
-			Test.AnotherWay._g_record_border=[];
-			var n= style=="border" ? 4 : style=="ball" ? 3 : 0;
-			for( var i=0; i<4; ++i ) {
-				var b=element.ownerDocument.createElement( "div" );
-				b.style.position="absolute";
-				b.style.zIndex="1";
-				b.style.backgroundColor=Test.AnotherWay._g_record_border_normal_color;
-				element.ownerDocument.body.appendChild( b );
-				Test.AnotherWay._g_record_border.push( b );
-		var coords=null;
-			coords=Test.AnotherWay._get_page_coords( element );
-			if( event!=null ) {
-				if( event.pageX!=null && event.pageY!=null ) {
-					coords={ x: event.pageX-0, y: event.pageY-0 };
-				}else if( event.clientX!=null && event.clientY!=null ) {
-					var doc=element.ownerDocument;
-					if( doc!=null ) {
-						coords={ x: (event.clientX-0)+doc.body.scrollLeft, y: (event.clientY-0)+doc.body.scrollTop };
-		if( coords!=null && element.clientWidth!=null && element.clientHeight!=null ) {
-			var positions=[];
-			Test.AnotherWay._record_setup_highlight_positions( element, style, coords, positions );
-			for( var i=0; i<positions.length; ++i ) {
-				var b=Test.AnotherWay._g_record_border[i];
-				var p=positions[i];
-				Test.AnotherWay._set_page_coords( b, p.x, p.y );
-				b.style.width=p.width+"px";
-				b.style.height=p.height+"px";
-				b.style.display="block";
-	}else {
-				Test.AnotherWay._g_record_border[i].style.display="none";
-Test.AnotherWay._record_flash_border=function( color )
-	if( Test.AnotherWay._g_record_border_flashing ) { //already
-		Test.AnotherWay._g_record_border_flashes.push( { color: Test.AnotherWay._g_record_border_normal_color, timeout:300 } );
-		Test.AnotherWay._g_record_border_flashes.push( { color: color, timeout:600 } );
-	}else {
-		Test.AnotherWay._g_record_border_flashing=true;
-		Test.AnotherWay._record_flash_border_timeout();
-Test.AnotherWay._record_prepare_doc_for_results=function()
-	document.open();
-	document.write( "<!DOCTYPE HTML PUBLIC \"-//W3C//DTD HTML 4.01//EN\" \"http://www.w3.org/TR/html4/strict.dtd\">" );
-	document.write( "<html><head><title> Input recording results</title>" );
-	document.write( "<style type=\"text/css\">" );
-	document.write( "body { font: normal normal smaller sans-serif; }" );
-	document.write( "div { margin-top: 3px; }" );
-	document.write( "</style></head><body>" );
-	// opera and mozilla disagree over who the opener is.
-	if( typeof( window.opener.Test )!="undefined" && typeof( window.opener.Test.AnotherWay )!="undefined" ) {
-		window.opener.Test.AnotherWay._record_save_results( document );
-		window.opener.Test.AnotherWay._g_record_waiting_for_results=false;
-		window.opener.Test.AnotherWay._record_control_update_ui();
-	}else if( typeof( window.opener.opener.Test  )!="undefined" && typeof( window.opener.opener.Test.AnotherWay )!="undefined" ) {
-		window.opener.opener.Test.AnotherWay._record_save_results( document );
-		window.opener.opener.Test.AnotherWay._g_record_waiting_for_results=false;
-		window.opener.opener.Test.AnotherWay._record_control_update_ui();
-	document.write( "</body>" );
-	document.close();
-// global initialization
-onload=function()
-		var good_opera=typeof( window.opera.version )=="function";
-		good_opera=good_opera && window.opera.version().match( /^\s*(\d+)/ );
-		good_opera=good_opera && RegExp.$1>=8;
-	var span=document.createElement( "SPAN" );
-	span.innerHTML="<!--[if IE]><br /><![endif]-"+"->";
-	var is_ie=span.getElementsByTagName( "BR" ).length>0;
-	Test.AnotherWay._g_test_iframe=window.frames.test_iframe;
-	var query_str=window.location.search;
-	if( query_str.charAt( 0 )=="?" ) {
-		query_str=query_str.substring( 1 );
-	var testlist_page="list-tests.html";
-	var auto_run=false;
-	if( query_str!="" ) {
-		var params=[query_str];
-		if( query_str.indexOf( ";" )!=-1 ) {
-			params=query_str.split( ";" );
-		}else if( query_str.indexOf( "&" )!=-1 ) {
-			params=query_str.split( "&" );
-		for( var param_i=0; param_i<params.length; ++param_i ) {
-			var param=params[param_i].split( "=" );
-			if( param[0]=="recording_results" ) {
-				if( window.opener!=null ) {
-					// we were told to show recording results - replace everything in the document with the results
-					Test.AnotherWay._record_prepare_doc_for_results();
-					return;
-			}else if( param[0]=="testpage" ) {
-				Test.AnotherWay._add_test_page_url( decodeURIComponent( param[1] ), "anotherway" );
-			}else if( param[0]=="jsantestpage" ) {
-				Test.AnotherWay._add_test_page_url( decodeURIComponent( param[1] ), "jsan" );
-			}else if( param[0]=="testlist" ) {
-				testlist_page=decodeURIComponent( param[1] );
-			}else if( param[0]=="testframe" ) {
-				if( window.opera && !good_opera ) {
-					Test.AnotherWay._show_error( "testframe parameter does not work in versions of Opera prior to 8.0. Sorry (pathches are welcome)." );
-					// Opera 7 barfs on attempt to access frame.frameElement.
-					// if someone knows a way to assign onload handler to that iframe in Opera 7
-					// without disrupting code that works in other browsers, patches are welcome.
-				}else {
-					var frame_path=param[1].split( "." );
-					var frame=top;
-					for( var frame_path_i=0; frame_path_i<frame_path.length; ++frame_path_i ) {
-						frame=frame[frame_path[frame_path_i]];
-					if( frame==null ) {
-						Test.AnotherWay._show_error( "unable to find frame specified for loading test pages: "+param[1] );
-					}else {
-						if( frame.frameElement!=null ) { // for the following assignement to onload to work, frameElement is required
-							frame=frame.frameElement;
-						Test.AnotherWay._g_test_iframe=frame;
-			}else if( param[0]=="testframe_no_clear" ) {
-				Test.AnotherWay._g_test_frame_no_clear=true;
-			}else if( param[0]=="windows" ) {
-                if (param[1] == "none") {
-                    Test.AnotherWay._test_object_t.prototype.open_window=null;
-			}else if( param[0]=="run" ) {
-				auto_run=true;
-				if( param[1]=="all" ) {
-					Test.AnotherWay._g_pages_to_run="all";
-				}else {
-					if( Test.AnotherWay._g_pages_to_run==null || Test.AnotherWay._g_pages_to_run=="all" ) {
-						Test.AnotherWay._g_pages_to_run=[];
-					var pages=param[1].split( "," );
-					for( var i=0; i<pages.length; ++i ) {
-						Test.AnotherWay._g_pages_to_run.push( pages[i] );
-	if( Test.AnotherWay._g_test_page_urls.length==0 ) {  // if no individual pages were given on the command line, load the list
-		var result=Test.AnotherWay._set_iframe_location( window.frames["list_iframe"], testlist_page );
-			Test.AnotherWay._show_error( result.msg );
-		Test.AnotherWay._g_run_on_list_load=auto_run;
-	}else {
-		Test.AnotherWay._g_run_on_main_load=auto_run;
-	var f=Test.AnotherWay._g_test_iframe;
-	try {
-		if( f.attachEvent!=null ) {
-			f.attachEvent( "onload", Test.AnotherWay._test_page_onload );
-		}else {
-			f.onload=Test.AnotherWay._test_page_onload;
-		if( Test.AnotherWay._g_test_iframe.nodeType!=null && Test.AnotherWay._g_test_iframe.contentWindow!=null ) { // it's iframe element, not the iframe. we need iframe.
-			Test.AnotherWay._g_test_iframe=Test.AnotherWay._g_test_iframe.contentWindow;
-	}catch(e) {
-		// ignore stupid opera error if the frame has onload handler assigned in the inline html
-	var handlers={
-		"run_all": { "onclick": Test.AnotherWay._run_all_onclick },
-		"run_selected": { "onclick": Test.AnotherWay._run_selected_onclick },
-		"unselect_all": { "onclick": Test.AnotherWay._unselect_all_onclick },
-		"record_select": { "onfocus": Test.AnotherWay._record_check_onfocus },
-		"record_input": { "onfocus": Test.AnotherWay._record_check_onfocus },
-		"record_start": { "onclick": Test.AnotherWay._record_start_onclick },
-		"clear_btn": { "onclick": Test.AnotherWay._results_clear_onclick },
-		"results_tab": { "onclick": Test.AnotherWay._tab_onclick, "onmouseover": Test.AnotherWay._tab_mouseover, "onmouseout": Test.AnotherWay._tab_mouseout },
-		"debug_tab": { "onclick": Test.AnotherWay._tab_onclick, "onmouseover": Test.AnotherWay._tab_mouseover, "onmouseout": Test.AnotherWay._tab_mouseout }
-	for( var hs in handlers ) {
-		var o=document.getElementById( hs );
-		if( o!=null ) {
-			for( var h in handlers[hs] ) {
-				o[h]=handlers[hs][h];
-		}else {
-			Test.AnotherWay._show_error( "unable to set "+h+" handler: id "+hs+" not found" );
-		Test.AnotherWay._g_no_record_msg="Input events recording and replaying is not available in opera versions prior to 8.0.";
-	if( is_ie ) {
-		Test.AnotherWay._g_no_record_msg="Input events recording and replaying is not available in internet explorer.";
-		var no_record_p=document.getElementById( "record_not_supported" );
-		no_record_p.style.display="block";
-		no_record_p.appendChild( document.createTextNode( Test.AnotherWay._g_no_record_msg ) );
-	Test.AnotherWay._g_main_loaded=true;
-	if( Test.AnotherWay._g_run_on_main_load ) {
-		Test.AnotherWay._g_run_on_main_load=false;
-		Test.AnotherWay._run_pages_to_run();
-</script>
-<script type="text/javascript" src="xml_eq.js"></script>
-<script type="text/javascript" src="geom_eq.js"></script>
-</head><body>
-<div id="col1">
-<div id="col1_header">Test pages:</div>
-<div id="scroller">
-<table id="testtable">
-</table>
-</div>
-<div id="run_buttons">
-<input type="button" value=" clear " id="clear_btn" />
-<input type="button" value=" run all " id="run_all" />
-<input type="button" value=" run selected " id="run_selected" />
-<input type="button" value=" unselect all " id="unselect_all" />
-</div>
-<input type="checkbox" id="dont_close_test_windows" /> do not close windows opened by tests
-<div id="error"></div>
-<div id="record_div">
-<p id="record_not_supported" style="display:none"></p>
-<p>Record mouse input for the page:</p>
-<p><input type="radio" name="record_choose" value="select" checked="checked" /> <select id="record_select"><option selected="selected">-- select a page: --</option></select></p>
-<p><input type="radio" name="record_choose" value="input" /> or enter page url: <input type="text" id="record_input" /></p>
-<p><input type="button" value=" record " id="record_start" /></p>
-</div>
-</div>
-<div id="col2">
-<div id="right_header">
-<span id="results_count">Results: <span id="total"></span></span>
-<span id="results_tab" class="active_tab" style="visibility:hidden">Results</span>
-<span id="debug_tab" class="inactive_tab" style="visibility:hidden">Debug</span>
-</div>
-<div id="right_frame">
-<div id="results"></div>
-<div id="debug"></div>
-</div>
-</div>
-<span style="display:none">
-<iframe name="list_iframe" onload="Test.AnotherWay._list_iframe_onload();"></iframe>
-<iframe name="test_iframe" onload="Test.AnotherWay._test_page_onload();"></iframe>
-<!-- record_control div is to be imported into other documents, so all its styles are inline -->
--<div id="record_control" style="position:absolute;bottom:0;left:0;margin:0;padding:0.5em;width:22em;height:22em;border:1px solid;background:#ffd;font: normal normal 8pt sans-serif; color:#000; text-align: left">
-<p style="margin:0 0 0 0; padding:0">
-&nbsp;
-<span style="display:none;font-weight:bold;color:#408" id="record_indicator">
-recording. <span style="font-weight:normal">time: <span id="record_time"></span></span><span id="record_pause_indicator"> paused</span>
-</span>
-</p>
-<div id="record_cursor_over" style="margin:0;padding:2px;width:14em;height:1.1em;overflow:hidden;float:right;border:1px solid #777;background:#fff;font: normal normal 8pt sans-serif;position:relative;top:3px;color:#000;text-align:left;">&nbsp;</div>
-<p style="margin:2px 0 0 0; padding:0">
-cursor is over
-</p>
-<p style="margin:8px 0 0 0; padding:0;">
- keyboard control: press
- <span id="record_ctrl_key" style="border:1px solid #226;background:#adf;padding:0 0.5em">ctrl</span> -
- <span id="record_shift_key" style="border:1px solid #226;background:#adf;padding:0 0.5em">shift</span> -
-</p>
-<p style="margin:4px 0 0 0; padding:0">
-<span id="record_s" style="border:1px solid #226;background:#adf;width:1.2em;float:left;font-weight:bold;text-align:center;margin-right:0.5em">s</span>
-<span id="record_on">to <b>start</b> recording</span>
-<span id="record_off" style="display:none">to <b>stop</b> recording</span>
-</p>
-<span id="record_h" style="border:1px solid #226;background:#adf;width:1.2em;float:left;font-weight:bold;text-align:center;margin-right:0.5em">h</span>
-<span>to <b>hide/show</b> this window</span>
-</p>
-<span id="record_m" style="border:1px solid #226;background:#adf;width:1.2em;float:left;font-weight:bold;text-align:center;margin-right:0.5em">m</span>
-<span id="record_include_mousemove">to <b> record</b> mousemove</span>
-<span id="record_omit_mousemove" style="display:none">to <b>omit</b> mousemove</span>
-</p>
-<span id="record_p" style="border:1px solid #226;background:#aaa;width:1.2em;float:left;font-weight:bold;text-align:center;margin-right:0.5em">p</span>
-<span id="record_pause_on">to <b> pause</b> recording</span>
-<span id="record_pause_off" style="display:none">to <b>continue</b> recording</span>
-</p>
-<span id="record_c" style="border:1px solid #226;background:#aaa;width:1.2em;float:left;font-weight:bold;text-align:center;margin-right:0.5em">c</span>
-<span>to add checkpoint</span>
-</p>
-<p style="margin:6px 0 0 0; padding:0">
-checkpoints:
-</p>
-<div id="record_checkpoints" style="position:relative;width:100%;height:6em;overflow:auto;font: normal normal 8pt sans-serif; color:#000; text-align: left">
-</div>
-</div>
-</span>
-<script>
-    if (/noscroll/.test(location.href)) {
-        document.getElementById('scroller').style.height='auto';
-        document.getElementById('right_frame').style.height='auto';
-</script>
-</body></html>
+        </script>
+    </body>
+</html>
More information about the Commits mailing list
