[OpenLayers-Dev] setting tile size
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Wed Nov 8 04:43:34 EST 2006
Hi Duarte,
OpenLayers creates a buffer (default value of 2 rows/columns) of tiles
around the map image, you can influence this using:
When creating a layer, add a 'buffer' option, and set it to '1':
Layer('WMS', 'http://url', {'map':'foo'}, {'buffer':1});
You can set the size of mapping using css:
#map {
width: 768px;
height: 512px;
which corresponds in my case to:
<div id="map">
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Duarte Carreira <DCarreira at edia.pt>
Naar: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
Cc: dev at openlayers.org
Onderwerp: RE: [OpenLayers-Dev] setting tile size
Datum: 08/11/06 07:37
> Bart,
> Thanks.
> Also about setting the size of the map and number of tiles. Is this
possible? How does OpenLayers calculate the number of tiles?
> Duarte
> -----Mensagem original-----
> De: Bart van den Eijnden (OSGIS) [mailto:bartvde at osgis.nl]
> Enviada: terça-feira, 7 de Novembro de 2006 21:01
> Para: Duarte Carreira
> Assunto: Re: [OpenLayers-Dev] setting tile size
> Hi,
> When creating the map or layer, add a tileSize option:
> Map('map', {'tileSize': new OpenLayers.Size(512,512)});
> Best regards,
> Bart
> Duarte Carreira schreef:
> > How is it possible to set the tile size to a custom size?
> > Regardless of the map size the tile size is always 256x256.
> > Does the map div set the map size? For instance, setting width and
> > height of the map div to 400x300 sets the size of the map object?
> > When I try a 400x300 map I still download 29 tiles, each being
> > 256x256... which seems too much for such a small map.
> > Can anyone shed some light on this please?
> > Thanks,
> > Duarte
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
> bartvde at osgis.nl
> http://www.osgis.nl
More information about the Dev
