[OpenLayers-Dev] Wanted: a generic control wrapper
Erik Uzureau euzuro at gmail.com
Fri Nov 10 07:44:55 EST 2006
Dear Ludwig,
I like this idea for factoring out generic code into Control.js --
your demo looks cool. Would you be interested in contributing to the
OpenLayers codebase?
Check out:
http://trac.openlayers.org/wiki/HowToContribute
for information on how to get this code into the project.
Thanks for your interest and input and hope to hear from you
Erik
On 11/9/06, Ludwig Max Brinckmann <ludwigbrinckmann at gmail.com> wrote:
> One step at a time. For the moment I just wanted to factor out the code the
> operates the generics of a control. But once this is done then OpenLayers
> would have the base to build some sort of dashboard for controls.
>  Ludwig
> On 11/8/06, Cameron Shorter <cameron.shorter at gmail.com> wrote:
> > Sounds like you are asking for a ToolBar or ControlBar.
> > A ToolBar shows an array of Tool Icons. When you select a tool, you get
> > a Control popup, or you change the way a Control works.
> > The entire Toolbar should be able to be hidden or expanded.
> > There should be a distinction between the different types of buttons.
> > They can be:
> > * 2 State - on/off, multiple tools can be selected at once
> > * Radio buttons - on/off, pressing one button deselects other radio
> buttons
> > * One Shot
> > (I'm also interested in this sort of functionality)
> > Ludwig Max Brinckmann wrote:
> > > I find that there is a little too much combination of 'business-logic'
> > > and presentation in the way the LayerSwitcher is implemented. One aspect
> > > of it is the actual layer control, but the other is just having a
> > > control that can be opened and closed.
> > > I do not know if you have considered separating the two, so that there
> > > would be a generic control, which would set up the open/close
> > > functionality and have some ways of positioning it on the page plus a
> > > control over the size when opened.
> > > A second bit of functionality would be e.g. the layerswitcher, which
> > > would simply fill a div in the generic control and to which the generic
> > > control would delegate when redrawing the contents.
> > > This would make it easier to develop custom controls that one could fill
> > > with additional functionality, with a shared behaviour/appearance on the
> > > screen.
> > > I hacked out some simple stuff that I just need for a demo here, but you
> > > can see the base idea at
> > > http://iceds.ge.ucl.ac.uk/OL/control.html
> > > On the right hand side are three controls, the top a variation of the
> > > layerswitcher, the bottom two browsers that will allow adding a layer to
> > > OpenLayers by clicking on a WMS Layer. All three controls just use the
> > > same dummy control to handle the opening and there are ways to set the
> > > size and position....
> > > (The green sliders in the layerswitcher are supposed to enable a user to
> > > adjust the opacity of a layer, but somehow the sliders do not get the
> > > mouse focus, as the map dragging monopolises it. The layers are also
> > > supposed to be restackable using scriptaculous sortable, but in this
> > > version it does not work for the same reason).
> > > I have only tested this on firefox (it does not work at all on IE) and
> > > there a quite a few bugs in it, but I thought submitting the idea to get
> > > some more input on how this could be done in the most generic fashion.
> > > Ludwig
> > > _______________________________________________
> > > Dev mailing list
> > > Dev at openlayers.org
> > > http://openlayers.org/mailman/listinfo/dev
> > Cameron Shorter
> > http://cameron.shorter.net
> Dev mailing list
More information about the Dev mailing list
