[OpenLayers-Dev] TileCache w/Apache and mod_python
Brian Levy blevy at taic.net
Tue Nov 21 19:45:58 EST 2006
I was wondering if I could get some help on an error I'm receiving from
TileCache.
Currently I'm running on the following configuration:
Apache/2.2.3 mod_python/3.2.10 Python/2.4.3 on Windows
I can execute test python scripts just fine, however when running the
following test url:
http://localhost/test/tilecache.py?LAYERS=basic&SERVICE=WMS&VERSION=1.1.1&RE
QUEST=GetMap&SRS=EPSG:4326&BBOX=-180,-90,0,90&WIDTH=256&HEIGHT=256
The following error is returned in the Apache error.log file:
[Tue Nov 21 16:31:12 2006] [error] [client 127.0.0.1] PythonHandler
TileCache.Service: Traceback (most recent call last):
TileCache.Service:   File "C:\\Program
Files\\Python24\\Lib\\site-packages\\mod_python\\apache.py", line 299, in
HandlerDispatch\n    result = object(req)
TileCache.Service:   File "C:/Program Files/Apache Software
Foundation/Apache2.2/htdocs/test/TileCache\\Service.py", line 344, in
handler\n    return modPythonHandler(apacheReq, Service.load(*cfgs))
Foundation/Apache2.2/htdocs/test/TileCache\\Service.py", line 249, in
_load\n    cache = cls.loadFromSection(config, "cache", Cache)
Foundation/Apache2.2/htdocs/test/TileCache\\Service.py", line 237, in
_loadFromSection\n    return objclass(**objargs)
Foundation/Apache2.2/htdocs/test/TileCache\\Cache.py", line 45, in
__init__\n    os.makedirs(base, perms)
TileCache.Service:   File "C:\\Program Files\\Python24\\lib\\os.py", line
159, in makedirs\n    mkdir(name, mode)
TileCache.Service: OSError: [Errno 22] Invalid argument: 'c:\\\\cache\\n***
optional iff layername if what\\nyour data source calls the layer **'
I'm thinking it has something to do with creating the cache sub directories
on my file system.  Can anyone provide insight into the error?
My tilecache.cfg is detailed below:
[cache]
type=DiskCache
base=c:\cache
[basic]
type=WMSLayer
url=http://labs.metacarta.com/wms/vmap0
extension=png
Thanks!
Brian
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20061121/6af55549/attachment.html
More information about the Dev mailing list
