[OpenLayers-Dev] "A square in one projection is not a square in the other projection
Christopher Schmidt crschmidt at metacarta.com
Fri Nov 24 17:52:06 EST 2006
On Fri, Nov 24, 2006 at 05:18:39PM +0100, Ana Henneberke wrote:
> Hello everyone,
> I have tryid open layers against a server that used Mercator projection and
> I get tiles that don't match with each other and parts of the land that are
> repeated.
> So I think this is because OpenLayers uses EPSG:4326 and I haven't find a
> way to overcome this problem. Does someone know how to fix this?
> Ana
Ana --
Please refer to the FAQ entry on projections[1], which should help you
resolve this problem.
[1] http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#Projections
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
