[OpenLayers-Dev] [Dev] Re: Vectors in OpenLayers?
Paul Spencer pspencer at dmsolutions.ca
Fri Oct 20 09:09:27 EDT 2006
I'm not keen on using GML as the only representation.  For me, I
rarely deal with GML and am more often dealing with WKT.
I am also hesitant to agree to having the digitizing tools generate
GML that is then processed into Geometry->Shape ... that seems quite
awkward to me.
I suggest that the architecture support serializing Geometries/Shapes
into something ... those of us that are interested in implementing
support for a particular format can implement it.
Then digitizing/editing tools can generically operate on Shapes and
be part of the generic graphics lib.  Remember that one of our design
goals was to build a graphics lib independent of the GIS part, that
could be used as a stand-alone component.
Cheers
Paul
On 20-Oct-06, at 7:15 AM, Cameron Shorter wrote:
> Bart van den Eijnden (OSGIS) wrote:
>> Also, if somebody starts drawing new geometries from scratch, you
>> will need a way to generate GML to insert them using a WFS. So not
>> in all use cases will the client already have the data in GML format.
> We already cover this use case in Mapbuilder, and I suggest we use
> the same design pattern in this design.
> When a User draws on a map, we process the mouseActions and create
> a GML Layer. The GML Layer is rendered the normal way GML->Geometry
> Classes->Vector Renderer.
> Then when the user presses the SAVE button, you build a WFS
> Transaction from the GML and send it to the server.
> So there is no need for serialising from Geometry->GML.
>> Cameron, are you suggesting to go for one format (WKT or GML), and
>> then use the server-side to transform if necessary?
> I think it will be a rare user requirement to convert from WKT->GML
> or visa-versa in a Web Client. So I don't think it is worth
> spending too much time addressing yet.
>> If so, would you go for WKT or GML? In my opinion GML is the most
>> logical option, it can always be transformed server-side to WKT if
>> you need to go to something like PostGIS directly (without a WFS),
>> since mostly we will talk to OGC web services and not to something
>> like PostGIS directly. Disadvantage is that its structures are
>> more elaborate than WKT.
> I agree that GML would probably be better.
> We have quite a bit of experience and code dealing with GML and WFS
> in Mapbuilder, and we should be able to reuse that.
>> Best regards,
>> Bart
>> Cameron Shorter schreef:
>>> I'm wondering whether we will need to create a Geometry->GML
>>> serialiser.
>>> In an application which uses GML, the rendering logic will go:
>>> GML -> Geometry Classes -> Vector Rendering HTML
>>> Ie, the client will already have the data in GML format.
>>> If the user edits features, then we can have the tools update the
>>> data source (GML in this case) which in turn will propagate the
>>> update though to the Geometry and Renderer.
>>> The other reason you might want to serialise is so that you can
>>> convert from one format to another, eg WKT->Geometry->GML or
>>> similar. However I suggest we keep vector transformation on the
>>> server, probably as a web service.
>>> Paul Spencer wrote:
>>>> For you maybe ;)  GML would be another good output choice I guess
>>>> Paul
>>>> On 19-Oct-06, at 3:44 AM, Bart van den Eijnden (OSGIS) wrote:
>>>>> Will there also be an option to serialize the objects as GML?
>>>>> Since interaction will mostly be against OGC Web Services.
>>>>> Best regards,
>>>>> Bart
>>>>> OSGIS, Open Source GIS
>>>>> http://www.osgis.nl
>>>>> --------- Oorspronkelijk bericht --------
>>>>> Van: Paul Spencer <pspencer at dmsolutions.ca>
>>>>> Naar: Pierre GIRAUD <bluecarto at gmail.com>
>>>>> Cc: dev at openlayers.org
>>>>> Onderwerp: Re: [OpenLayers-Dev] [Dev]  Re: Vectors in OpenLayers?
>>>>> Datum: 19/10/06 00:09
>>>>>> Hi Pierre,
>>>>>> I haven't looked at the code but I think that this will be
>>>>>> needed in
>>>>>> some sort of factory object that can create Geometry (and
>>>>>> associated
>>>>>> Shape) objects from WKT.  We are a bit early for implementation
>>>>>> details right now (despite the fact that I've already done a
>>>>>> bunch of
>>>>>> implementation), but when the design is finalized, we'll need
>>>>>> this
>>>>>> piece.
>>>>>> This reminds me that Geometry objects need to be able to
>>>>>> serialize
>>>>>> themselves as WKT.
>>>>>> Cheers
>>>>>> Paul
>>>>>> On 13-Oct-06, at 12:46 PM, Pierre GIRAUD wrote:
>>>>>> &gt; I wanna propose you some peace of code for this.
>>>>>> &gt; Hope you'll be able to have a quick look and check if I'm
>>>>>> the  good
>>>>>> &gt; way.
>>>>>> &gt;
>>>>>> &gt; I tried to follow the &quot;factory&quot; pattern, but
>>>>>> I'm  not sure I
>>>>>> &gt; implemented it right considering the rest of the
>>>>>> architecture.
>>>>>> &gt;
>>>>>> &gt; Regards and nice week-end
>>>>>> &gt;
>>>>>> &gt; Pierre
>>>>>> &gt;
>>>>>> &gt; ps : this code might be useable in the current vector
>>>>>> sandbox
>>>>>> &gt;
>>>>>> &gt; On 10/13/06, Pierre GIRAUD &lt;bluecarto at gmail.com&gt;
>>>>>> wrote:
>>>>>> &gt;&gt; I don't know if this is a needed functionnality, but
>>>>>> it can
>>>>> probably
>>>>>> &gt;&gt; help. I was trying to think about and implement a way
>>>>>> to  add a
>>>>>> &gt;&gt; feature
>>>>>> &gt;&gt; by its WKT string writing.
>>>>>> &gt;&gt;
>>>>>> &gt;&gt; Something like :
>>>>>> &gt;&gt;
>>>>>> &gt;&gt; OpenLayers.Vector.WKT
>>>>>> &gt;&gt;
>>>>>> &gt;&gt; p4 = new OpenLayers.Vector.WKT('POINT(-40 30)');
>>>>>> &gt;&gt;
>>>>>> &gt;&gt; Regards
>>>>>> &gt;&gt;
>>>>>> &gt;&gt; Pierre
>>>>>> &gt;&gt;
>>>>>> &gt;&gt; On 10/13/06, Paul Spencer
>>>>>> &lt;pspencer at dmsolutions.ca&gt;  wrote:
>>>>>> &gt;&gt; &gt; Thanks Chris :)
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt; Performance really sucks if you add a lot of
>>>>>> features.  I
>>>>> wrote a
>>>>>> &gt;&gt; &gt; quick loop to add a 1 degree box every 10
>>>>>> degrees and
>>>>> brought my
>>>>>> &gt;&gt; &gt; firefox to a halt.  Profiling reveals a number of
>>>>> problematic
>>>>>> &gt;&gt; areas,
>>>>>> &gt;&gt; &gt; the biggest of which is getPx (of course).
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt; I've done some optimization that improves
>>>>>> performance in
>>>>> this case:
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt; * remove the call to Pixel.add(x,y) and
>>>>>> directly  modify the
>>>>> pixel
>>>>>> &gt;&gt; &gt; position - this was a big savings ...
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt; * cached px location in the Point object based
>>>>>> on  the bounds
>>>>> of the
>>>>>> &gt;&gt; &gt; containing vectorLayer so getPx is only called
>>>>>> when the
>>>>> bounds have
>>>>>> &gt;&gt; &gt; actually changed.
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt; attached is a patch against the sandbox to
>>>>>> incorporate these
>>>>>> &gt;&gt; changes.
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt; Next steps for me are:
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt; * fix rendering in IE and Safari (that was the
>>>>>> whole  point
>>>>> of using
>>>>>> &gt;&gt; &gt; excanvas)
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt; * further optimizations, including:
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt;    o try caching the bounds of each vector and
>>>>>> test for
>>>>>> &gt;&gt; intersection
>>>>>> &gt;&gt; &gt; with layer bounds before rendering
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt;    o tighten inner loops and remove deep call
>>>>>> chains
>>>>> (possibly
>>>>>> &gt;&gt; &gt; putting some of the pixel conversion stuff right
>>>>>> into
>>>>> convertToPx)
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt;   o anything else you can think of
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt; * convenience functions for constructing
>>>>>> polygons  and lines
>>>>> from
>>>>>> &gt;&gt; &gt; points without having to construct intermediate
>>>>>> objects
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt; Other things that need to be done at some point,
>>>>>> but  not
>>>>>> &gt;&gt; necessarily
>>>>>> &gt;&gt; &gt; for 2.3:
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt; * refactor the code (what, already?) so that the
>>>>>> Vector
>>>>>> &gt;&gt; architecture
>>>>>> &gt;&gt; &gt; can support multiple rendering types (Canvas,
>>>>>> SVG, VML,
>>>>> possibly
>>>>>> &gt;&gt; &gt; others in the future) by introducing
>>>>>> Layer.Vector  subclasses
>>>>> and a
>>>>>> &gt;&gt; &gt; new Rendering class that knows how to render
>>>>>> into the
>>>>> sub-classed
>>>>>> &gt;&gt; &gt; layer types
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt; * refactor styling support to make it less
>>>>>> specific to
>>>>> Canvas
>>>>>> &gt;&gt; &gt; rendering stuff
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt; * add some Controls for digitizing and possibly
>>>>>> editing
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt; Cheers
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt; Paul
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt; On 12-Oct-06, at 7:55 PM, Christopher Schmidt
>>>>>> wrote:
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt; &gt; On Thu, Oct 12, 2006 at 05:02:00PM -0400,
>>>>>> Paul  Spencer
>>>>> wrote:
>>>>>> &gt;&gt; &gt; &gt;&gt; Schuyler, et al
>>>>>> &gt;&gt; &gt; &gt;&gt; attached is a first cut at the vector
>>>>>> stuff.  It
>>>>> extracts
>>>>>> &gt;&gt; over an
>>>>>> &gt;&gt; &gt; &gt;&gt; existing openlayers folder and
>>>>>> contains  only the
>>>>> new files
>>>>>> &gt;&gt; I've added
>>>>>> &gt;&gt; &gt; &gt;&gt; plus a change to OpenLayers.js to load
>>>>>> the  extra
>>>>> files by
>>>>>> &gt;&gt; default
>>>>>> &gt;&gt; &gt; &gt;&gt; (except for excanvas for some reason ;)).
>>>>>> &gt;&gt; &gt; &gt;&gt; There is a vector.html in the examples
>>>>>> folder.
>>>>>> &gt;&gt; &gt; &gt;
>>>>>> &gt;&gt; &gt; &gt; This code, with some improvements from
>>>>>> Schuyler  and I,
>>>>> is now
>>>>>> &gt;&gt; in place
>>>>>> &gt;&gt; &gt; &gt; in a sandbox in the OpenLayers SVN. You
>>>>>> can  check out
>>>>> with:
>>>>>> &gt;&gt; &gt; &gt;
>>>>>> &gt;&gt; &gt; &gt; svn co http://svn.openlayers.org/sandbox/
>>>>>> sderle/ vector/
>>>>>> &gt;&gt; &gt; &gt;
>>>>>> &gt;&gt; &gt; &gt; You can try it out at:
>>>>>> &gt;&gt; &gt; &gt;
>>>>>> &gt;&gt; &gt; &gt;
>>>>> http://openlayers.org/~crschmidt/vector/examples/vector.html
>>>>>> &gt;&gt; &gt; &gt;
>>>>>> &gt;&gt; &gt; &gt; Click once to start drawing a line --
>>>>>> click  again to
>>>>> end it.
>>>>>> &gt;&gt; &gt; &gt;
>>>>>> &gt;&gt; &gt; &gt; FF only at the moment.
>>>>>> &gt;&gt; &gt; &gt;
>>>>>> &gt;&gt; &gt; &gt; Cool stuff, Paul, thanks for getting the
>>>>>> ball  rolling
>>>>> on this.
>>>>>> &gt;&gt; &gt; &gt; --
>>>>>> &gt;&gt; &gt; &gt; Christopher Schmidt
>>>>>> &gt;&gt; &gt; &gt; Web Developer
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt; |Paul Spencer
>>>>> pspencer at dmsolutions.ca    |
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt; |Chief Technology Officer
>>>>>> &gt;&gt; &gt; |DM Solutions Group Inc
>>>>> http://www.dmsolutions.ca/ |
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt; _______________________________________________
>>>>>> &gt;&gt; &gt; Dev mailing list
>>>>>> &gt;&gt; &gt; Dev at openlayers.org
>>>>>> &gt;&gt; &gt; http://openlayers.org/mailman/listinfo/dev
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt; &gt;
>>>>>> &gt;&gt;
>>>>>> &gt;&gt; &lt;wkt.html&gt;
>>>>>> &gt;&gt; &lt;WKT.js&gt;
>>>>>> |Paul Spencer
>>>>>> |Chief Technology
>>>>>> Officer                                         |
>>>>>> |DM Solutions Group Inc                http://
>>>>>> Dev mailing list
>>>> |Paul Spencer                          pspencer at dmsolutions.ca    |
>>>> |Chief Technology Officer                                         |
>>>> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
>>>> Dev mailing list
> Cameron Shorter
> http://cameron.shorter.net
More information about the Dev mailing list
