[OpenLayers-Dev] [OpenLayers-Users] Work around for bug #541 ??
Stephen Woodbridge woodbri at swoodbridge.com
Mon Apr 2 16:31:30 EDT 2007
Christopher,
I updated to trunk today, did a build.py full and I'm using the
OpenLayers.js - Thank you getting svn fixed up.
I am still having serious performance problems.
Step 1:
http://imaptools.com/ld-test.html
Click on Algers, DZ link this displays just fine and is very fast notice
the Features: 50, I have maxfeatures=50 set.
Step 2:
Click Zoom + This runs reasonably fast, BUT the Features: 100. This is
clearly wrong. maxfeatures=50 and there are less displayed because of
the zoom in. So this looks like a bug in OL where on zoom in:
1) you should reuse the current feature set for the layer if maxfeatures
is NOT set
2) you should clear the current feature set if maxfeatures IS set and
re-query for new features.
3) ALWAYS clear the current features set and requery, because in a
multiuser environment the features on the server might have been updated
and you want to get a fresh copy.
4) Allow some combination of these behaviors to be set in the layer
definition similar to maxfeatures.
Step 3:
Click Zoom + again and it takes about 5 mins for the browser to process
the request. Features: 139
Step 4:
Reload the page to start over.
Click on Algers, DZ
Click Zoom -, This takes about 5 mins to return with NO poi displayed.
The mapfile has MAXSCALE 50000 set for the WFS LAYER
Step 5: after Step 4 returns, you can zoom out fast and zoom in until
you hit the WFS points and if you try to zoom out again you get the same
delay.
I hope this helps, let me know if you need more info.
Thanks,
-Steve
Christopher Schmidt wrote:
> On Fri, Mar 30, 2007 at 05:09:00PM -0500, Stephen Woodbridge wrote:
>> Hi,
>> Is there a work around to bug #541 like putting a square about the point
>> instead of a circle? How would I do that to give it a try?
> The workaround is to update to SVN HEAD. :) Schuyler and I were able to
> reproduce with the WFS example you had provided, and were able to track
> the bug down to bad behavior in Firefox when drawing circles of radius
> less than .0001.  Opera and Safari were fine.
> All should now be fixed. Let us know if it isn't. (We'll probably be
> pushing for an RC soon: I tested with the imaptools URL you gave, but if
> you have some other failing case, please let us know as soon as
> possible.)
> Regards,
More information about the Dev mailing list
