[OpenLayers-Dev] OpenLayers+MapServer+PostGIS <POINT OBJECTS>
Stephen Woodbridge woodbri at swoodbridge.com
Tue Apr 3 14:14:59 EDT 2007
E.Stefanakis wrote:
> Hi !
> I have a point dataset in postgis. I present it using OpenLayers.WMS(
> ... mapserver....)...
> everything works fine.
> Now I wish to click on the dots and get the info stored in postgis for
> each point object.
> Any hint for doing this ?
> Thanks in advance
> Emmanuel.
If you are using the svn trunk you can play with a WFS layer.
You should look at the examples/openmnnd.html for how to set it up.
There are still some bugs in some of this code and Christopher et al
have been providing excellent support. It would be good to get someone
else testing and reporting issues, to help stablize this before the 2.4
release.
-Steve W
More information about the Dev mailing list
