[OpenLayers-Dev] RC3 needed
Christopher Schmidt crschmidt at metacarta.com
Thu Apr 26 10:52:02 EDT 2007
So, we need an RC3, because Bart's marker issue is a regression from
2.3, caused by Schuyler and I tweaking the zoomChanged code, so far as I
can tell. (#681)
I've pulled in Andreas's GML fid parsing fixes (with tests), and created
a patch with tests for #680, with the idea in mind that it's small and
cheap.
I'm not sure I really like #681 -- it means that if you don't put a zoom
level in your initial setCenter, the map no longer defaults to zoom
level 0. I can cook up a more complex patch which checks if the zoom
level is null, sets zoomChanged, and then sets it to 0 -- or something
like that --  if people would want to. I'm not sure how important that
is.
Feedback on #681 is encouraged, and if someone could do a quick review
of #680, I'd appreciate that too.
(Also, if you have any other bugs that didn't exist in 2.3, please bring
them forward now!)
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
