[OpenLayers-Dev] editing controls, preserve selection
Tim Schaub
tschaub at openplans.org
Wed Aug 22 17:56:21 EDT 2007
Hey-
Pierre GIRAUD wrote:
> The problem is that when a control is deactivated, the select control
> it relies on is also deactivate and the selectFeature.unselect()
> method is called.
The unselect method should not be called when the SelectFeature control
is deactivated.
I can confirm that things work like they should by going to
http://openlayers.org/dev/examples/select-feature.html
After drawing a polygon, I click the "select polygon on click" input to
activate the SelectFeature control.
I click a polygon, it gets selected, and turns blue.
I click the "draw polygon" input deactivating the SelectFeature control
and activating the DrawFeature control, and the polygon stays blue.
Are you seeing something different?
Tim
> Does someone has an idea of a workaround to let a control preserve
> selection so that another control can use it ?
> Regards
> Pierre
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
> !DSPAM:4033,46cc2faf22141849620573!
More information about the Dev
