[OpenLayers-Dev] Keep selected features drawn with the right style [Was] Re: editing controls, preserve selection
Pierre GIRAUD bluecarto at gmail.com
Thu Aug 23 04:20:53 EDT 2007
This is due to the fact that the drawFeature method in the
Layer.Vector class doesn't pay attention if the feature is one of the
selectedFeatures.
I'll open a new ticket for that.
Regards
> > On 8/22/07, Tim Schaub <tschaub at openplans.org> wrote:
> > > Hey-
> > > Pierre GIRAUD wrote:
> > > > The problem is that when a control is deactivated, the select control
> > > > it relies on is also deactivate and the selectFeature.unselect()
> > > > method is called.
> > > The unselect method should not be called when the SelectFeature control
> > > is deactivated.
> > > I can confirm that things work like they should by going to
> > > http://openlayers.org/dev/examples/select-feature.html
> > > After drawing a polygon, I click the "select polygon on click" input to
> > > activate the SelectFeature control.
> > > I click a polygon, it gets selected, and turns blue.
> > > I click the "draw polygon" input deactivating the SelectFeature control
> > > and activating the DrawFeature control, and the polygon stays blue.
> > > Are you seeing something different?
> > Hi,
> > You're right Tim, unselect() doesn't get called when deactivating the
> > SelectFeature Control.
> > However, I've noticed an issue, which might be what Pierre is running
> > into. Draw a polygon, choose "select polygon on click", click on the
> > polygon, then click on + or - on the zoom control, and your selection
> > will go away. The problem doesn't appear when clicking on the
> > LayerSwitcher or on the Pan Control.
> One additionnal note: after clicking to + or - on the zoom control, if
> you go back and click again on the feature, the selection won't work.
> You'll need to click a second time to actually select the feature.
> Eric
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
