[OpenLayers-Dev] [OpenLayers-Trac] [OpenLayers] #686: Treat
Google Layer as projected data
Christopher Schmidt
crschmidt at metacarta.com
Fri Aug 31 16:30:41 EDT 2007
On Fri, Aug 31, 2007 at 08:18:50PM -0000, OpenLayers wrote:
> #686: Treat Google Layer as projected data
> I don't know how much testing we want to do on this, but I'm tapped out on
> it: for now, marking review just to garner comments from anyone interested
> in the code. This is just a diff between
> http://dev.openlayers.org/sandbox/tschaub/google/ and trunk -- The code
> can be checked out from:
> http://svn.openlayers.org/sandbox/tschaub/google/
> and the way you use it is to set:
> sphericalMercator: true
> as an option on the layer.
> I think this is going to be the final API: the GoogleMercator layer is
> going to go away, and it's just going to be an option on the layer.
Essentially, this is probably now API complete:
* You create your map with a maxExtent in spherical-mercator projected
meters.
* You add a Commercial base layer to that map with the
'sphericalMercator': true option set.
* You add overlays to that map.
This means that your overlays must support EPSG:900913 (or you can
override it after creating your layer if they support it via some other
number) -- the proj4/WKT is in the SphericalMercator.js file (which will
also show in the docs once this is in trunk).
The canonical example is:
http://dev.openlayers.org/sandbox/tschaub/google/examples/spherical-mercator.html
Tim's put together a number of different layers here, demonstrating the
functionality of the layer with a TileCache-powered WMS overlay, to
demonstrate that yes, Virginia, there really is a Google layer you can
lay TileCache down on top of.
Now is the time for API complaints -- and also the time for tests, if
you want to write them. Things which could use testing:
* In the test_SphericalMercator.html file, add functions for
initialization of each:
* Google
* VirtualEarth
* Yahoo
and ensure that:
* If sphericalMercator is set, they have inverse/forward proj
functions
* RESOLUTIONS is set to appropriate values if sphericalMercator is
set
* If sphericalMercator is not set, those layers dont have the
inverse/forward projection functions
* if sphericalMercator is not set, units aren't touched
* Create a test in SphericalMercator.html for checking tha
initMercatorParameters sets the proper units, and resolutions based
on MIN_ZOOM_LEVEL and MAX_ZOOM_LEVEL.
If you've got a sandbox account, feel free to commit tests directly into
the sandbox.
Questions? Comments? Complaints?
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
