[OpenLayers-Dev] removeFeatures - LineString
Pierre GIRAUD bluecarto at gmail.com
Wed Feb 7 11:34:38 EST 2007
I'm not able to reproduce it. In the tests I made, all is working good.
What I've tried is :
 - open http://dev.openlayers.org/sandbox/vector/examples/EditingDemo.html
in a browser,
 - switch the selected vector layer to Vector Layer (in the layer
switcher) in order to be able to draw lines,
 - launch the following script into my firebug console :
vector.removeFeatures(vector.features[vector.features.length - 1]);
The line is removed from the layer features and cleared on the screen
(removed from the display).
Pierre
On 2/2/07, Ben Brehmer <bbrehmer at refractions.net> wrote:
> Hi all,
> I'm just working with the vector branch and noticed that removeFeatures
> deosn't seem to work that well for LineString.
> Reproduction steps: Draw a LineString with mouse clicks on a vector
> layer. Trigger removeFeatures with the just-drawn LineString as a
> parameter. You will notice the line between the last two vertices
> remains as well as all the vertices.
> Thanks,
> Ben
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
