[OpenLayers-Dev] path measuring tool
Cameron Shorter
cameron.shorter at gmail.com
Wed Feb 21 14:30:01 EST 2007
John,
Almost all of this is already coded in the vector branch - for creating
a feature on a vector layer.
All that is required is for the rendering of the vector to include
distance calculations and markers.
How accurate does your distance calculation need to be? Accurate
distance calculation will require access to the projection and
projection conversion which is not supported by OpenLayers.
There were some implementations discussed on the mapbuilder list,
although I'm not sure if they made it back into the codebase.
http://www.arcknowledge.com/gmane.comp.gis.mapbuilder.devel/2006-10/msg00068.html
John R. Frank wrote:
> We're discussing adding a path measuring tool to OpenLayers. If you
> have parts of such a tool, please consider contributing them.
> A somewhat audacious set of desired features is listed here:
> http://trac.openlayers.org/ticket/173
> If such a tool interests you, please comment on that ticket.
> John
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Cameron Shorter
Systems Architect, http://lisasoft.com.au
Tel: +61 (0)2 8570 5011
Mob: +61 (0)419 142 254
More information about the Dev
