[OpenLayers-Dev] ButtonBase code review
Cameron Shorter cameron.shorter at gmail.com
Sun Feb 25 15:29:51 EST 2007
Olivier,
I have spent an hour or so reviewing your code in
http://trac.openlayers.org/log/sandbox/oterral/ButtonBar/vector/lib/OpenLayers/.
Overall, you have done a pretty good job. Ideally I'd like to spend
more, so they are sure to be things I've missed.
Chris, I hope you will add comments too, especially about names of
classes. Eg, What should we call the base Button/Tool class? I'm
inclined to call it Button.js.
Minor: You have a few tab chars. Change them to spaces.
You have created tools in the directories:
lib/OpenLayers/MouseListener/ and
lib/OpenLayers/MouseListener/EditingListener
I think the classes and directory structure should be renamed to
emphasize  the fact that you are creating Button Tools. Rename
MouseListener to Tool or Button, probably Button.
DragPan currently inherits from MouseListener, but MouseListener doesn't
contain empty parameters for id, imageOn, imageOff, etc.
We should have a base Button class that all the Buttons/Tools inherit
from. We have 2 options:
1. MouseListener has child Button which has children DragPan, ZoomIn, etc.
2. MouseListener is renamed to Button, Button has children DragPan,
ZoomIn, ...
I prefer option 2. There will be Tools which don't have an icon and are
always on (Eg, mouseTrack tool). I suggest we create a type "NoButton"
type which can only be turned on/off from the program, not via operator
interaction. They will default to on.
Button will need null parameters for id, imageOn, imageOff, etc.
Button should also contain a param for cursorIconType. Ie, when the tool
is selected, the cursor type can change from an arrow, to a box, to
something else. You should be able to find examples in the Mapbuilder
code. I think it is in the MouseHander.js code.
Buttonbar.js (version 2281):
Why is X and Y initialised above the "inherit" braces? To be consistent
they should be initialised with the rest of the variables.
Buttonbar.js:
Please add jsdoc comments to all functions. It makes it much easier to
review. :)
Don't worry if your English has a French flavour to it. Us mono-language
speakers are generally very forgiving. So long as your writing is
understandable, then that is good. Someone else will clean up the
comments later if there is a problem.
Buttonbar.addTools line 54:
Minor comment: When looping over an array with length>=0, I suggest
using "for" instead of "while". This should be cleaner than the
"if,while" statements you have starting at line 54.
for(var i=0;i<tools.length;i++){...}
Buttonbar.addTools line 78:
Minor: This block loops through all the current this.tools. I suggest
that it only loop through the recently added tools. Ie, loop through
tools. Why not move the code into the block above (ie from line 54).
Buttonbar._addButton:
The properties of btn should be moved into the base Button class,
currently called MouseListener.
This means that the majority of _addButton will disappear.
I expected to see logic to ensure that one of the radio buttons is
always selected.
By default, the first radioButton added should be selected.
Why register for mouseup event on the button? It is not used. You can
also remove buttonUp() function.
Buttonbar.setTool:
You only seem to be catering for radioButton and button types. What
about a twoState button?
I suggest code like:
switch(tool.type)
  case "radioButton":
    break;
  default:
    tool.doSelect();
Buttonbar._swapButtonImg:
The logic for rendering a button should be moved into the base button
object, at the moment this is MouseListener.js.
An object should be responsible for drawing itself.
Cameron Shorter
Systems Architect, http://lisasoft.com.au
Tel: +61 (0)2 8570 5011
Mob: +61 (0)419 142 254
More information about the Dev mailing list
