[OpenLayers-Dev] Mouse Control positioning
Christopher Schmidt crschmidt at metacarta.com
Wed Feb 28 23:16:42 EST 2007
On Thu, Mar 01, 2007 at 03:03:04PM +1100, bradleyspencer wrote:
> Can you help me here? I have implemented a getfeatureinfo listener which
> works just fine.
> And in order to not conflict with the zoom and mouse controls, I have been
> able to move the zoom control bar outside the map area which is also fine.
> I used a div and placed control in it this way.
> map.addControl(new
> OpenLayers.Control.PanZoomBar({div:$('zoomLevelContainer')}));
> But I cannot do the same for the mouse control so I was wondering if this is
> a bug and if someone could fix it?
> So I would like to know precisely how to  move the mouse control outside the
> map area without having to modify the code.
Assuming you mean the MouseToolbar: You can't. You'll need to change the
code to support putting itself in a seperate div. (Alternatively, after
adding the control to the map, take controlvar.div and detach it,
reattaching it elsewhere in the DOM. If you do that I recommend passing
a position argument to the initializer with an OpenLayers.Pixel(0,0) so
that the control paints itslef in the upper left corner of the div.
Good luck.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
