[OpenLayers-Dev] Dynamic Script Inclusion out of date for
Windows IE7 and recent Safaris
Lance Dyas
lancelot at inetnebr.com
Thu Jan 4 21:59:03 EST 2007
openlayers\lib\OpenLayers.js
What I did is comment the offending code out a more rigourous fix might
be testing for version...
for (var i = 0; i < jsfiles.length; i++) {
/* if (/MSIE/.test(navigator.userAgent) ||
/Safari/.test(navigator.userAgent)) {
var currentScriptTag = "<script src='" + host + jsfiles[i] +
"'></script>";
allScriptTags += currentScriptTag;
} else {*/
var s = document.createElement("script");
s.src = host + jsfiles[i];
var h = document.getElementsByTagName("head").length ?
document.getElementsByTagName("head")[0] :
document.body;
h.appendChild(s);
Erik Uzureau wrote:
> Dear Lance,
> Thank you for your email -- we actually *are* concerned about this
> problem
> you have found. Can you tell us where in the code you are experiencing
> this?
> Erik
> On 1/4/07, Lance Dyas <lancelot at inetnebr.com> wrote:
>> There is a branch which tests for MSIE and Safari user agents ...
>> basically it is no longer needed
>> the append child works fine and the other actually doesnt work... on
>> either platform.
>> Guess I am the only one developing under these conditions.
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
