[OpenLayers-Dev] Control outside map (re #445)
Ludwig Max Brinckmann
ludwigbrinckmann at gmail.com
Wed Jan 17 05:24:25 EST 2007
Thanks, that seems much happier.
Ludwig
On 1/17/07, Bart van den Eijnden (OSGIS) <bartvde at osgis.nl> wrote:
> Have you tried this syntax:
> overview = new OpenLayers.Control.OverviewMap({div: $('controls')});
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: Ludwig Max Brinckmann <ludwigbrinckmann at gmail.com>
> Naar: dev at openlayers.org <dev at openlayers.org>
> Onderwerp: [OpenLayers-Dev] Control outside map (re #445)
> Datum: 17/01/07 08:05
> > Ticket #445 promises a way of easily putting controls outside the main
> map
> -- a great help if there is more than just very simple mouse interaction
> since that seems to confuse many browsers.The way I understand it, to
> utilise this one, I have to pass in the id of the div where the control is
> supposed to be located when creating the control, such as
> > overview = new
> OpenLayers.Control.OverviewMap({div :
> 'controls'});
> map.addControl(overview);However, when running this it gives me the
> following exception:
> > Error: this.div.appendChild is not a functionSource File:
> http://localhost/javascripts/openlayers/lib/OpenLayers/Control/OverviewMap.js
> > Line: 117Is there a working example (with current svn head) someone
> could
> point me to? I am actually not that keen on this particular control, I am
> looking for a working starting point for my own control, so any control
> would do.
> > LudwigThe full script:<html
> xmlns="http://www.w3.org/1999/xhtml">
> <head> <style
> type="text/css">
> #map
> width:
> 80%;
> height: 100%; top:
> 0; left:
> 0;
> position: absolute;
> } #controls
> { width:
> 20%;
> position: absolute;
> > top:
> 0;
> right:
> 0;
> height:
> 100%; }
> </style> <script
> src="/javascripts/openlayers/lib/OpenLayers.js"></script>
> <script type="text/javascript">
> <!-- function
> init(){
> var map = new OpenLayers.Map('map');
> boundary = new
> OpenLayers.Layer.WMS.Untiled('Boundary',
> > http://localhost/cgi-bin/yunnanserver?", {layers:
> "Watersheds",
> transparent: "false", format:"image/png" }
> boundary.setVisibility
> (true);
> map.addLayers
> > ([boundary]); overview = new
> 'controls'});
> map.addControl(overview); bounds =
> new
> OpenLayers.Bounds(-180,-90,180,90);
> map.zoomToExtent
> > (bounds); }
> </script> </head> <body
> onload="init()"> <div
> id="controls"></div> <div
> id="map"></div> </body>
> > </html>
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070117/2dd2182c/attachment.html
More information about the Dev
